1) Install Autodesk Moldflow Insight Ultimate , choose network licensing, use 666-66666666 as serial and 575F1 as product code& N* i! R2 g8 ^+ L7 U [
? ?Select Single License and use 127.0.0.1 as server name, ignore the warning message,click Yes to continue.: d) Q) I6 e$ w2 U2 e
安装AMIU,选择网络许可证(这个可以不要选,默认就好了),用序列号666-66666666,产品代码575F1,AMS的产品代码是579F1,AMCD的产品代码是577F1。用127.0.0.1用作服务器名称。点下一步,忽略警告信息,继续。* X$ c- M5 B# q6 X. w- C
2) Install network license manager from setup tools & utilities or from the DVD
+ K3 @* M& `! u7 ?" G0 Q? ?x86\Support\nlm\NLM.msi or x64\Support\nlm\NLM.msi+ y+ j& _& v( q- i0 V
安装网络许可证管理器,这个在开始安装界面的工具中也可找到。6 D3 I C. d* |" a
Copy cracked FlexLM vendor daemon "adskflex.exe" into C:\Program Files\Autodesk\Autodesk Network License Manager) b2 x7 s* [( i* m; ?" D% Z4 @ E! g
复制破解文件adskflex.exe到C:\Program Files\Autodesk\Autodesk Network License Manager1 _( r0 ?9 v) g) ~! `* _# B; |" ?
下面
8 N5 V* u' {0 w7 [! H4) Copy adlmint.dll in all installed apps "bin" folder
+ \$ W- P% U2 ^1 V( C$ s7 r' f
0 S a7 q5 S" n9 u }4 P? ?C:\Program Files\Autodesk\Simulation Moldflow Insight 2014\bin\- V4 b c; l/ b1 H, [4 l
? ?C:\Program Files\Autodesk\Simulation Moldflow Communicator 2014\bin
0 i+ j) F3 e3 h/ h? ?C:\Program Files\Autodesk\Simulation Moldflow Synergy 2014\bin、
/ D# C: ]& p' L: N- w& e5 {# U复制adlmint.dll到所有下面,记得要复制和替换。
; ~; T5 p" C; D: [0 j" z3 s- t? ?
! J$ ]& e! g" O/ B? ?9 V! w/ x2 m# U7 s
: N# y4 j% Q" G5) Edit lic.dat and change HOSTNAME and MAC to suit your configuration (if you are not sure start LMTOOLS Utility and go to
; n0 g9 E+ E$ z. f? ?System Settings, your HOSTNAME and MAC will be listed)
1 ? _7 E1 u; q# P) t$ h1 ]8 ]? ?You can change vendor port too and add your previous licenses of course " {+ c, `# J; r: L9 }
? ?Save the file where you want1 S! p% [, }- [( P3 R) E, g6 ?8 M
编辑lic.dat文件,把HOSTNAME改为你的计算机名,MAC地址就是你的网卡物理地址,由十二个字母和数字组成,地址之间不要用”-”号。Lic.dat文件中其它东西你最好不要去改动,改完保存后复制到C:\Program Files\Autodesk\Autodesk Network License Manager下# ~% W2 A- T5 R1 _% ?
8 o3 t! _8 k' j+ j6) Start LMTOOLS Utility (lmtools.exe GUI)4 J; A# J" ?# x; V
? ?- in 'config services', add a "Autodesk' service name/ j ]& F/ \0 _9 g+ @( |% v! s0 {3 a9 `
? ?? ?? ?? ?? ?? ?? ?? ?? ?choose C:\Program Files\Autodesk\Autodesk Network License Manager\lmgrd.exe for path to lmgrd9 R, A* G D' y% L
? ?? ?? ?? ?? ?? ?? ?? ?? ?choose X:\path\where\you\saved\lic.dat for path to license file" O. e- P! ?+ B* o! c
? ?? ?? ?? ?? ?? ?? ?? ?? ?choose a empty file to have debug logs (optional)
9 S# f( e' n6 M8 e) \+ j? ?? ?? ?? ?? ?? ?? ?? ?? ?tick 'start server at power up' and 'use services'
& a$ w/ g$ q1 X- A2 ]? ?? ?? ?? ?? ?? ?? ?? ?? ?Click Save& c9 B) b' b& M% [
? ?- in 'service/license file' choose configuration using services and tick 'ignore license file path env var" (dont click that if you
5 M; c3 D9 w/ C% b1 G3 G! Q? ?? ?? ?? ?? ?? ?? ?? ?? ?? ? you wanna use a ditributed licensing .. or you will have to edit or create a Licpath.lic file)? ?? ?? ?? ?? ???
& }$ b6 d+ K' a" _: E? ?- in 'start/stop/read' click 'start server'
, X. o4 O' P- m& y7 z7 p/ O? ?? ?? ?? ?? ?? ?? ?? ???click 'rereadlicense file'
/ n& U7 w/ k/ u. Q: u! I- |. v: A? ?- in 'server status' click 'perform status enquiry'? ?# ?% O1 M* w' q/ A9 v3 t2 ^& _
? ?? ?? ?? ?? ?? ?? ?? ?check that you have 'adskflex: UP v11.11'
; y) P4 K6 e1 e+ Y1 \# O? ?? ?? ?? ?? ?? ?? ?? ?check features are activated : (ex: Users of 86152MFAA_2014_0F: (Total of ....))
" G% w7 M$ ^9 c. e3 g* H/ o? ?- in 'server diags' check all featured can be checked out
- \; I- a" a; [4 B' q? ?- check logs also win 'config services' if you configured it
" R+ a2 R, C* h2 d- W7 f- m* p7 w* B3 a1 p* l- @- X) z
7) Start app
& f; n5 ?8 q% E, D0 K2 T' I8) Smoke it if you want ; f% y% P9 w4 X% s6 C
开始许可证服务管理器,点config services,添加一个服务,名字随便你自己定,llmgrd/license file/log ,这三项自己依次选择正确的文件,我就不多说了。然后点击开机服务自动运行和使用服务,单击save.$ T) q4 r8 f# o9 J! e: w' v3 O% J
在service\license file选项中点击刚保存的服务,勾选ignore license file path envar选项,点击start server,点击rereadlicense file' M( ^/ I+ |" p/ D0 b2 v5 M
在服务状态中,你可以单击perorm status enquiry ,检查许可证服务是否正常运行,有些人得电脑中如果有很多的许可证管理器版本,记得要在许可证管理工具中点Ulities中找到和你许可证关联的版本额,不然就容易出错,破解就会有问题的。9 \% a! E! _2 [0 |3 F% c
1 n$ ^$ S5 h' \( a$ T这以下部分,你就不要更改了,因为我们一般不设置分布式许可证系统,如果还是不行试着把licpath.lic中的server 127.0.0.1后面所有的0替换为你的MAC地址,我的就是这么设置的,两个都要改,licpath.lic地址如下' M, }, w# ^% z1 K# v; w
C:\Program Files\Autodesk\Simulation Moldflow Insight 20140 g4 V+ C9 }0 |& f9 o* i
C:\Program Files\Autodesk\Simulation Moldflow Synergy 2014\Moldflow Synergy$ p W/ x: a9 M2 d
You Could also set a distributed license system, having one machine serving them all+ Y+ Z* w/ g3 ?4 K' b, {' j: b
0 L7 |, l# P$ r" g9 c
For that matter. p3 o! h! @$ L1 o) ~6 E: U
you need to Set the ADSKFLEX_LICENSE_FILE environment variable on the client machine (the procedure varies depending on the operating system). / A. E. U' ^0 F1 `! U9 Y
7 G' \2 `' h% H- w- ]# d
To set the environment variable
1 n. M/ t( L K7 \# B/ O) m' ]# P7 Z7 b8 @5 t$ V
Use the procedure described for your operating system to set the environment variable:8 @7 i( @- t \0 ~6 I+ G/ s8 Z
4 ]4 V3 I: ^ ?! k* V6 E
For Windows 7/8: 2 Q3 B1 t% G0 I h t9 ?( o3 y
: Q$ `7 I B( M l* W5 `# d+ s
? ? Right-click Computer and click Properties, or, in the Control Panel select System and Maintenance > System. Q$ W! P u7 }# ~! b. ^+ t
? ? Click Advanced system settings and select the Advanced tab.
9 e% t- g; z4 L? ? Click Environment Variables. l' N! n" d+ q) p5 ?7 e; h0 u# a
? ? In the Environment Variables dialog box, under System Variables, click New.2 f# x) d6 R; }# s" n, S: _) D
? ? In the New System Variable dialog box, enter ADSKFLEX_LICENSE_FILE in the Variable Name field.$ u" u* V v7 |9 c9 b
? ? In the Variable Value field, enter an at sign (@) followed by the host name of each license server to which you want to point the client. Separate each server name with a semicolon (;). For example:
7 c A+ ~7 j3 ^. P6 c; V
s8 G9 x: z& B5 @, D& Z? ? @server1;@server2;@server3: B3 Y- A. `9 |
" M% y: X1 F2 XDont forget to open your firewall, you may also need to check the LICPATH.LIC file in root of the installed application in case you have issues
7 L4 S4 V% w4 Y' Q [& r4 S! Jand read the docs.4 V6 T! G- h* a! F; q
/ T( W: X% D. y" w5 G6 N
' P6 c; T! P3 A+ h# s7 o! I# z* A) U! C
###################################8 ]+ P$ C" Q! |' J, W3 G1 i( P
X-Force total domination again 2 W( N& ~% E0 w9 X7 ^, M' |, N7 t1 v
, S) e! W0 J& t5 p8 G B3 j+ c7 H* T2 I
希望大家安装成功。。。。
" a3 j H% U i' N# O
5 T' N5 ^+ T( T |
