楼主 |
发表于 2013-4-13 14:39
显示全部楼层
if { ![string compare $spindle_first "TRUE"] } {
) d0 K Z( n! W" X if { ![string compare $rapid_spindle_inhibit "FALSE"] } {+ O% E4 H3 j& c* Z& c" U& F- A- q
if { [string compare $spindle_block ""] } {
; I. n. K0 Z3 U7 S PB_FORCE Once $mod_spindle8 E, d% ^5 N$ H. ?- T) b6 r1 D1 s
MOM_do_template $spindle_block
$ m3 s. M7 m1 l' t: r; ` } else {) q' H! |' n( `; d
MOM_output_literal "$co Rapid Spindle Block is empty! $ci"9 b/ s& q; [- ^/ V
}' F& ?. x# W7 `8 @$ e( O& K
}7 C* ]& c2 M0 t% _3 {. C: b8 {
if { ![string compare $rapid_traverse_inhibit "FALSE"] } {# p) _: H3 {! | v
if { [string compare $traverse_block ""] } {* `: m1 z: |0 }9 H A
PB_FORCE Once $mod_traverse
+ m5 h& h w; A MOM_do_template $traverse_block1 _+ O8 R; A# b% v6 S
} else {# j! }4 ^. l- M: h/ G% q' [1 w
MOM_output_literal "$co Rapid Traverse Block is empty! $ci"
* V( a- z" k- j8 m+ _9 ? }" N1 a2 s% p% k* E G0 u
8 `6 U+ U( E# ^ } elseif { ![string compare $spindle_first "FALSE"] } {" F3 ]2 I0 w. C
( d* _+ J) \) k0 n- q" ^( V" e" } if { [string compare $traverse_block ""] } {2 H( o4 |7 o) {' t) L. W {2 D
PB_FORCE Once $mod_traverse% ?' L) [& }6 |) |% J5 x
! }# c; Y1 {4 \7 a3 C' G } else {
+ m0 n" G" @- S; ~. P MOM_output_literal "$co Rapid Traverse Block is empty! $ci"' x( O- F& I* U% J1 t, A
4 m$ c% ^6 }% ?( Y }
! p6 f3 v+ M4 i0 ^! z- \1 t0 I, i* x8 N$ ], z7 a+ F( N" k
% q+ }, N1 e1 i, J6 D# y9 X4 h3 H$ J6 J- \0 r& n. z1 p+ E
* E y4 F, Q5 W8 Y
u8 `. T" ?+ u4 }5 `% s4 N
! N& ^1 c7 c( e/ s+ `* f; Z% V/ P; j; @. [: j& ^* r& Q$ A
0 l, q$ d: ]' J) {( I O: b
1 q# T/ B0 @5 o/ N$ }2 ?* s if { ![string compare $rapid_spindle_inhibit "FALSE"] } {
- ?/ `* P# g; _0 |* _! Z if { [string compare $spindle_block ""] } {
) F3 G0 `- Z) u7 X% ?' D% o t5 T PB_FORCE Once $mod_spindle
: X/ Z6 q3 s, ~ p5 s2 U- v MOM_do_template $spindle_block4 G$ g, ` h3 u, t" `
} else {
4 \0 B; s6 ^3 J! o% l$ v& q& q' a MOM_output_literal "$co Rapid Spindle Block is empty! $ci"7 P3 ^7 L: }! W6 K. a. t2 }' Z5 }
}$ C6 w% F3 h$ G8 S9 A
) u0 l. Y1 l! T. b9 L } else {9 f7 O9 n6 n. y
- r: F/ P+ {) X0 n MOM_do_template rapid_traverse
5 @" p) ? x2 x% W ]5 ^! W }
0 E: T; W% a% d" ~1 e' [}
; o9 A2 T+ Z: n1 q% Q6 N; R这是什么意思呀 |
