查看: 31587|回复: 28
Moldflow2014破解的问题
发表于 2013-4-19 17:14 | 显示全部楼层 |阅读模式
本帖最后由 897015209 于 2013-4-24 14:31 编辑 2 {4 V# H" Y& |3 S: Z) o
* D  b7 B+ U2 h, M2 X# c9 b
问题1:; u( U% R# p. w* P- c0 o
        相信大部分安装moldflow的同行都在Crack的时候看到安装说明上写着这么一句话:“Edit lic.dat and change HOSTNAME and MAC to suit your configuration”,就是对其中的“MAC”何解?没有弄明白。
3 ?+ x$ U  M' k: A        我的MF就是百度网盘大侠lianjin07传播版本的MF"pan.baidu.com/share/home?uk=3759321846(你懂的)"。Crack的时候我google了下“Moldflow2014 HOSTNAME and MAC ”,搜索结果真是令人兴奋。结果让我看到了一篇文章专门报道“LMTOOLS Procedure for Host Name and ID”。& N4 U7 S" a4 d6 R' E
原文如下(加上小编的注解,绿色字)
4 A, z. Z) w, C4 hLMTOOLS Procedure for Host Name and ID
- j7 t- ]6 R, Y# fTo obtain the host name and ID using the LMTOOLS utility
+ E4 ~" H( r$ K7 g3 JImportant Do not run LMTOOLS on a remote computer.
  R/ O2 M9 v4 E2 K) J4 FYou should be logged in with Administrator rights when working with the LMTOOLS utility.
3 T' t* o7 ~: P3 }3 d* ^; B
1.Click Start  All Programs  Autodesk  Network License Manager  LMTOOLS Utility.
) u# s4 E( c9 R& n4 |( S. C2.In the LMTOOLS utility, click the Systems Settings tab. 7 C: ~6 }; a/ Y3 J9 p$ T
3.Locate the Computer/Hostname box. Copy the host name and paste the information into a text editor.
  {. I: D6 u. U7 }4 R! y4.Locate the Ethernet Address box. The 12-character Ethernet address is the host ID.
9 q5 G% v% M: jNoteIf your server has more than one Ethernet adapter, select one that corresponds to a physical network adapter. If you are using a Mac OS X computer with more than one network card, you must use the address of the primary network card. 4 w& b$ ~4 A: m# j
5.Close LMTOOLS.
9 f2 _/ t+ E# o        首先安装network license manager即LMTOOLS,Install network license manager from setup tools & utilities or from the DVD,x86\Support\nlm\NLM.msi or x64\Support\nlm\NLM.msi ,以管理员的方式运行。那上面的“MAC”的正解就是这ID,在LMTOOLS Systems Settings 选项卡中的Ethernet Address一栏,复制填到你的.lic文件里去。
; C% O" U# Y8 P1 O: t  Z5 A
) t- r9 E* _( U3 n, b% E问题2:
: g  b( c6 ~$ P/ x% C  u
        在MF安装破解完成后,运行MF时弹出写着这么行字“A security failure has occured……”窗口。( Y7 G: ?/ P2 B! d9 B
        几经周折寻找问题的答案,原来这个问题很简单,由于安装第一个文件的时候一步一步地按照说明来做的,在安装第二个文件的时候我们常常忽略文件的替换这一步。自己想象都觉的惊讶!!
' }- `2 g$ h6 U% `  I( N0 o原安装文件写着:
* W! X3 O0 S1 D+ ~4) Copy adlmint.dll in all installed apps "bin" folder
+ J% X4 K' w0 b    C:\Program Files\Autodesk\Simulation Moldflow Insight 2014\bin\
8 n) ^6 w+ e0 ^! q; K3 X
  T+ m. d' l" s5 D: J  A3 d
问题3:
9 x, m/ X) h  N有的朋友在安装并且破解好了Moldflow后,发现无法分析,并且出现错误代码如** ERROR 99998 ** Required license for AMI_STANDARD is not available, or all licenses are currently in use or the product you have installed is not licensed to run this feature.
6 t2 ^8 a* w/ L1 R) q
此问题感谢网友Aaron热心提供。问题分析:Required license for AMI_STANDARD那么就是缺少了AMI_STANDARD版本的许可证了,但是不是已经安装好了吗,而且也破解成功了吗?注意,目前我了解的是AMI有三个版本,AMI_BASIC 、AMI_STANDARD、 AMI_PERFORMANCE。
5 c2 i4 d: M$ N7 N/ Z8 c5 `
按我的猜想是可能以前电脑上安装了其他版本的AMI了,想网友Aaron可能就是MF2013非STANDARD版本。那么卸载之前的MF版本,确定卸载干净,重新安装MF2014,确认每一步的密钥都输入正确.
/ k8 S" Y* a5 j) z+ Z; z& GAMI的对应序列号有三个版本(就像Win8安装的时候输入不同的密钥安装不同版本的win8‘企业版,专业版’一个道理
+ ^7 |6 H' b' P) W! R/ I. P573F1 - Autodesk Simulation Moldflow Insight Standard 2014(有功能限制)
' ?3 h! v: ]6 A574F1 - Autodesk Simulation Moldflow Insight Premium 2014(有功能限制)
" ?) S9 k2 n- {& O4 ^; q9 f575F1 - Autodesk Simulation Moldflow Insight Ultimate 2014(无功能限制)
0 u1 u6 R5 D# w* t6 m9 M% h安装那个程序就用那个程序文件夹下的Crack文件,避免搞混。
+ @2 r9 i- |# M8 M附上英文网站上原文解答:
5 E( ], F# v* MHi,this might be related to product key used when installing Autodesk Moldflow Insight 2012 solver.4 `4 O7 A9 V+ g" j
Seems has you have an Autodesk Moldflow Insight Advanced 2012.& Q8 s& z' ^" K  }# {/ e/ D
If solver is installed as Autodesk Moldflow Insight Basic 2012, it cannot run fiber flow analysis or find Basic license, as you have Advanced and you will get an security error.
+ b* X8 S; K" \: c3 jPlease, reinstall solver with serial number and product key of Autodesk Moldflow Insight Advanced 2012.
; W" g- s+ T- S! U1 p, hAutodesk Moldflow Insight Advanced 2012 : 575D14 b, |  Q3 U5 \- x" s2 G3 N
Hope this helps.
9 q8 N$ _0 t5 Q7 Q% S
亲,对你是不是有帮助呢,那么顶贴吧……
5 e+ _+ c$ O0 k: O$ E# G0 b0 D. X& B3 D: z/ G/ U: e7 j7 H( H
# ?4 t* ^& p! z+ N8 F
& x# ?7 }4 d# a% P' x
7 P$ f1 w, q$ j6 _+ i# d1 }: X9 J+ J6 S% u* A# f
) ?1 G) I' c7 G" p0 ~3 F
MLTOOLS
MLTOOLS
替换文件
替换文件
 楼主| 发表于 2013-4-19 17:24 | 显示全部楼层
1 K0 S$ i/ M9 _1 k+ n# H
7 Y1 n% Z, w' f( _" ?" q5 Y有疑问的朋友都可以向我询问,534134516(常用)或者897015209,你懂的。无耻地自占沙发……真舒服的沙发啊!
发表于 2013-4-21 22:43 | 显示全部楼层
替换文件还是出现错误  我也用的是Win8系统
发表于 2013-4-21 23:05 | 显示全部楼层
终于可以了  原来是我又两块网卡,一个有线一个无线,替换Mac时没有注意,一起弄进去了。
发表于 2013-4-22 05:53 | 显示全部楼层
xqy2008 发表于 2013-4-21 23:05 : U/ s  p" w6 Q( d
- p8 ~4 r* h$ ~楼上的能分享一下破解步骤和方法吗?我也是WIN8的系统,但是只有一个网卡地址,不知道是安装步骤有问题还是跟UG冲突!谢谢!
7 h8 q5 T. x. O9 k
 楼主| 发表于 2013-4-22 21:50 | 显示全部楼层
xqy2008 发表于 2013-4-21 23:05 2 m/ e/ }6 V, l& _
* l7 _6 ]% M* z: u% gYes, 这句话被我忽略了,我的是台式机,不好意思。
9 S6 ]& _* z- a2 H8 L& Z原文:
8 m  @4 B4 ~5 U% ?If you are using a Mac OS X computer with more than one network card, you must use the address of the primary network card.
8 C# }8 b  |. i0 G' O1 R注解:如果你有两块网卡,那么用你正在用的网卡吧(这个你不知道在用那个网卡?不要问我哦,百度去)!
 楼主| 发表于 2013-4-22 21:52 | 显示全部楼层
neopan110 发表于 2013-4-22 05:53   B4 `! |/ y; N% _2 A8 P- ^
楼上的能分享一下破解步骤和方法吗?我也是WIN8的系统,但是只有一个网卡地址,不知道是安装步骤有问题还 ...
& s3 V# n5 W9 }3 v. E/ t: |7 K3 K这个跟UG不冲突,一定是你那个环节漏了,不要急着卸载,认真想一想,无非就是替换文件或者是lic文件编辑和LMTOOLS加载……
发表于 2013-4-22 23:06 | 显示全部楼层
顶起来,解释的很清楚·
发表于 2013-4-24 22:00 | 显示全部楼层
谁有中文包啊?分享一下哈!谢谢!
发表于 2013-5-1 23:07 | 显示全部楼层
不错,又占了一个沙发!
GMT+8, 2025-6-11 06:01 , Processed in 0.056602 second(s), 24 queries .
