查看: 3076|回复: 4
[疑难] 跪求高手改下一次显示所有刀具性息源代码格式
发表于 2013-5-6 15:05 | 显示全部楼层 |阅读模式
跪求高手改下源代码格式,感激不尽,或者觉得重写比较快,希望高手帮帮忙,谢谢!小弟万分感激
3 Q+ V! W- w5 ~3 d$ [3 a+ i* c% ~
- N( v' D3 u. f0 [. p#  This command will be executed automatically at the "Start of Program" to
* f% w7 m' ?3 n5 s#  prepare for the tool list generation.1 L& B0 ?8 o+ N# j! U+ i& }. q
#& J8 t" I: B  Z. }# P
#  This command will add the shop doc event handlers to the post.% i+ O/ {# S' A) y. ?% q5 n# ?0 M6 t
#  You may edit the proc MOM_TOOL_BODY to customize your tool list output.
4 V/ w# T+ I. Q#
* y! H2 r8 O- [" J#  Only the tools used in the program being post-processed will be listed.
. E& S- R1 @/ z/ ~4 w5 x#& }, Y1 p! N+ p( `: Z# P
#  In order to create the tool list, you MUST add the command
  O" F/ C$ w9 v#  PB_CMD_create_tool_list to either the "Start of Program"
2 B2 v3 I, I' _7 g9 @#  or the "End of Program" event marker depending on where
' x( R* r( |9 j. Y#  the tool list is to be output in your NC code.5 [% H& N2 j$ R, g& P0 s
& j7 u) T/ f& n- H0 M#  The Shop Doc template file "pb_post_tool_list.tpl" residing in the
4 X% @2 \3 E  _) q4 @#  "postbuild/pblib/misc" directory is required for this service to work.9 O' ?2 @! N2 v6 f4 N
#  You may need to copy it to the "mach/resource/postprocessor". W% e: e- q+ P& J, E6 l* O$ {+ }
#  or "mach/resource/shop_docs" directory, in case your ug runtime
! V$ m* X) B  m6 k; z5 Z& R# u#  environment does not have access to the Post Builder installation." m" |; f! r. N
( e: b" |" y- V2 w6 m
8 [9 P6 |% Y$ ~* Z) Y2 T   global mom_sys_tool_list_initialized% H* g" u" g, y4 N( u
6 D+ z2 V& u# e9 v2 Y  L
5 q  X& i* |+ r# o+ z$ o2 F! ?
uplevel #0 {* A/ O6 ]; X9 w
& b- R* g2 L* k) k
proc MOM_TOOL_BODY { } {3 @+ V; O5 G& s
   global mom_tool_name  @/ ]5 H: A$ Y% I
   global mom_tool_number, ^/ j- z( W) A5 z2 [  D
   global mom_tool_diameter* h+ @! Q' t+ O# W. N! z8 G  ]3 E
   global mom_tool_length6 T* |2 O1 j2 f+ ~9 w8 {7 k% t
   global mom_tool_type  }- ?1 l: d) ^$ u: d. s
   global mom_template_subtype
5 r! \" N$ j& u, d& i" o' B   global mom_tool_point_angle( C+ }9 O5 q- \6 g% \& L! f
   global mom_tool_flute_length+ a9 ]1 M" H) n" F# T& ^' w* p
   global mom_tool_length_adjust_register
5 `8 ~5 [% |, T7 e6 i/ f) N$ S   global mom_tool_nose_radius9 d) z! B+ X1 D3 H4 R
   global mom_tool_corner1_radius
: v  F: D( C  d$ j3 d  }- t   global mom_tool_flute_length! i7 S6 M% u& K) q6 P2 p; M
   global mom_tool_orientation% [5 h' A0 A. t
   global mom_sys_control_out mom_sys_control_in
* A$ Q# X3 I* V& E   global cycle_program_name current_program_name, ?$ f5 K& g+ [! b# y- X4 g
   global mom_sys_tool_stack5 e) B# n( ]3 U, r/ `) q, B! Z; i
! R7 V7 F& Z8 @3 g   global tool_data_buffer
1 t  ~6 C# S0 N  O# M* b- @# g- Z7 N! Y3 w7 U7 E6 y2 f$ j3 [
& \$ M# v7 L) ^  # Handle single operation case.4 K( V5 v. B- ~$ R* Y' V
  # current_program_name will be blank when no group has been selected.
- M6 V: w1 j1 B$ |# C6 A, P
9 G1 n% {3 e* `" }; W7 z   if { [string length $current_program_name] != 0 } {, T) V+ N9 I# @7 c  h
      set n1 [string toupper $cycle_program_name]: y8 f* F3 N4 F, X0 s: G
      set n2 [string toupper $current_program_name]% L; b1 D* J0 Z3 f( G
      if { [string compare $n1 $n2] && [string length $n1] != 0 } {5 v+ J5 h+ P& S# \. F
return& A1 g3 \1 h' I, K( X& o% x) p$ f
      }: v2 M8 j1 C/ b- c1 _( n3 }
   } else {
" R8 f6 {# Y% p6 ~6 T- A8 O" ^* V7 i2 y# f
     # mom_sys_change_mach_operation_name is set in MOM_machine_mode
* a- ?) Z9 L. C/ O     # Use this variable to generate tool info for a single operation.* O: D  Y. x* j3 }8 G
) k* F9 D' D* U7 O* G3 f* h
      global mom_sys_change_mach_operation_name mom_operation_name" P% I" V9 j) N" l3 P4 q  e) s
. U) ~# }# Z- K1 k- T; @% C
      if [info exists mom_sys_change_mach_operation_name] {+ F# ]  |, q8 r% I5 \
         if { ![string match "$mom_operation_name" $mom_sys_change_mach_operation_name] } {
( O1 c. L& W6 F# g. m$ H% Creturn2 C* Z/ d$ i  ^  w! D: f
% {/ i4 h$ E$ F8 [, ~9 L      } else {
* Y% U3 f- g' l( i) d& preturn: X- k4 N" D' k* O. [
      }  `5 k; o$ y# s  I9 p
: d, `7 Q8 W: d) B) x% O/ R. i: H+ T' Z( l6 E" l) l# m
) l% }# b8 j' k! R3 \6 a  #****************************
3 `2 L! l- O6 m. p+ M3 [, r  # Collect various tool lists, w1 h+ _" @: x# _0 Q
* h6 U" j. U: A5 ?   lappend mom_sys_tool_stack(IN_USE) $mom_tool_name4 e. L9 f0 Q8 M
" X6 x  y) _0 X- }+ r   set tool_type [MAP_TOOL_TYPE]
& y: g0 B& O) T9 }$ c) l; p- ]
: u: v; m( S7 N; _. X   if { [lsearch $mom_sys_tool_stack(ALL) $mom_tool_name] < 0 } {
* X. q/ x. r. Y; y+ u
/ S8 w$ e% W* g' @7 ]! w( T      lappend mom_sys_tool_stack(ALL)         $mom_tool_name
9 P' {0 x3 k6 V$ A7 L7 b$ C! |0 n      lappend mom_sys_tool_stack($tool_type)  $mom_tool_name
: W; ^* q2 ?4 s7 S% [   }1 F' G. F" E! w6 A* f
' }( s8 n5 {2 y! J" R, D  ^# U* e
. a" V0 e' y( l/ `+ d$ f' r  #*************************************************6 k4 d/ z7 I' h
  # Define data to be output for each tool per type& X, Z. f7 x* g8 I9 X1 J7 @
" O! f5 R/ O6 ?9 E) b   set output ""
4 H$ [# d# c) w1 x
, i$ ^- C- p- L0 z   set ci $mom_sys_control_in
6 C: \  H$ Q/ I' i$ U   set co $mom_sys_control_out$ O) W7 x' m9 v# ?
7 h% d* O* N# r+ P: ^" w! c. \. a1 g1 x
   if { [string length $mom_template_subtype] == 0 } { set mom_template_subtype $mom_tool_type }
) y! `2 C  Y/ @2 d# ~
/ V/ ]. F! V6 |   set tool_name [string range $mom_tool_name 0 19]2 K7 m% y6 V  W; y9 j; h
   set template_subtype [string range $mom_template_subtype 0 19]& ^5 J% a" z' O3 E; [2 w
, H9 b5 f) C+ J; b9 S! z
   switch $tool_type {
7 K. G7 l+ `9 x$ N. `  A, K. w
; {, Z0 [  |2 u* k      "MILL" {6 ^% L7 e5 e& u
( q$ A( T2 p; B2 y( k8 l
1 v1 a9 |! G9 S) s         set output [format "%-20s %-20s %-10.4f %-10.4f %-10.4f %-10d" \
" Y" Y) ?. W8 q                     $tool_name $template_subtype \6 M7 w0 h2 f+ u/ q+ {
                     $mom_tool_diameter $mom_tool_corner1_radius \3 S0 N8 h7 ]$ a8 k/ N
                     $mom_tool_flute_length $mom_tool_length_adjust_register]
% Z- t- _3 ]$ ]8 c      }* }! Q- ^4 L+ N- h
+ d3 b( q' l9 r4 o& Z      "DRILL" {- e7 }1 U" `2 x5 Z. n
6 y- b. v$ L, `# {6 h2 ^
         set mom_tool_point_angle [expr (180.0 / 3.14159) * $mom_tool_point_angle]
# k( [0 g0 q* r4 z6 C: J, Q; c8 U/ }         set output [format "%-20s %-20s %-10.4f %-10.4f %-10.4f %-10d" \
% o3 ?' |: N; Q! y6 t5 \# c                     $tool_name $template_subtype \
8 |+ Y6 A9 u% Q& P                     $mom_tool_diameter $mom_tool_point_angle \& t' G' d" p. f) m
6 w' a4 A( L: a0 M" X; [; m2 i) R( m      }
6 J0 N, W, g% }
) Q5 m: n% ~+ x! R, |; u: s, W# \) f      "LATHE" {  V/ Y" L& T1 k  n: L
; |' U4 V1 u" k- F         set pi [expr 2 * asin(1.0)]
: p5 u" I# ^3 {: S         set tool_orient [expr (180. / 3.14159) * $mom_tool_orientation]" n/ I. W2 I4 l% @. v& {5 B
         set output [format "%-20s %-20s %-10.4f %-15.4f %-10d" \* ^- n8 x3 o; Q: G
' ^! q6 t2 j5 ?' v: ?8 R  T                     $mom_tool_nose_radius $tool_orient \
5 K) Q8 z$ Y4 x% c                     $mom_tool_length_adjust_register]
5 J" D, F$ |$ r( N      }
, K9 e4 |3 ?  H# X, o   }
9 v4 m- |& P. y
% X$ `: q$ [, {) M+ I2 L1 ]
! K$ k9 L1 H* U9 i3 z  #*******************************************************************************/ }9 h4 h4 I& X. S3 w& I
  # Fetch tool time data from the post.+ h8 q9 L5 ?% V/ b4 p/ y+ B
  # This info is only available when tool list is created at the end of a program.
# _# a. j, p6 V% N) [  #*******************************************************************************: M$ O& {! N( @* c( l6 c
   global mom_sys_tool_list_output_type/ G1 C9 E# P% v; H
   global mom_sys_tool_time5 W6 A; X9 i6 K, [* O) Y
   global mom_operation_name- A3 b" V+ D  F7 v, n, v# n1 c* B
  q. n1 z0 P# q5 D7 v. S
   set tool_time "": r/ j+ y; ^. |4 A- v+ J1 P/ Z
1 H+ _2 L5 ?. U! v, g   if [info exists mom_sys_tool_time] {
7 y% q1 c( E; [8 a, L! k1 H0 i
% a& D& i+ P# E! t% D      switch $mom_sys_tool_list_output_type {
" w  R5 _( N  y( Z; f% j         "ORDER_IN_USE" {% f0 a* P- v: D2 D" K1 h1 s
           # Tool time per operations.* \' q" [1 d( w; V- r
            set tool_time $mom_sys_tool_time($mom_tool_name,$mom_operation_name)
4 T( b: d2 H# P         }
1 R. K+ o9 ]2 q! F3 Y9 ?" {( R; S1 s( H8 d
         default {9 b+ o3 t/ f/ b3 |) D2 W
           # Accumulate tool time from all operations using this tool.$ ?7 ?7 B4 f1 ?% g; n7 a' r- V- [* `
            set tool_time 0
& y: x* o  \$ |            if [info exists mom_sys_tool_time($mom_tool_name,oper_list)] {) \/ x3 |3 @) o, e# r( S0 x
               foreach oper $mom_sys_tool_time($mom_tool_name,oper_list) {
* [! H; P4 S% q  X% D                  set tool_time [expr $tool_time + $mom_sys_tool_time($mom_tool_name,$oper)]+ O( ]3 H' c6 g  c. L) F
               }, I9 B* }1 A  N
            }1 Y4 [) _0 E8 y' F
         }: z; L7 V6 K  c* l; J
      }2 ]; S' H5 |( x+ @
, x% D9 G+ s5 P
0 k/ ^0 l" }3 E3 O   if { [string length $tool_time]  &&  $tool_time != 0 } {
+ @+ _/ B. v0 e) _2 f! l      set tool_time [format "%-10.2f" $tool_time]  B; B7 u+ R4 \" O# ?" }/ V+ r; \
5 ^, i* @4 \) O' `1 }9 P  _
: I$ G; }; `* i  S
  u  J. d) v# T0 L+ R" J  #++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
) Q  M& K6 D0 v+ s% x  # Store data to be output or used in PB_CMD_create_tool_list.6 k. A0 B8 r) B  `7 w8 X* t
  #; W$ L3 o( Q* l
  # <Ex.>  A: z- Y; V7 P2 i3 e
  #  global mom_tool_number
0 h7 B+ N- b5 w  #   set tool_data_buffer($mom_tool_name,tool_number) $mom_tool_number
% ]# a6 l4 M4 I8 O4 H9 Z" }+ o  #- m, H: N. K* C( B7 U/ c
  # If a BLOCK_TEMPLATE is used to output the data, the global varaibles
- U# ~5 i( G$ d! v) x) W6 |# z! L1 [  # used in the expression of an Address need to be set accordingly# u! W" ^3 ?8 x6 |. P+ t
  # before "MOM_do_template" is called.
" x! f% Y$ B0 ]5 V' f  #++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
8 u6 C7 r3 O; @- H5 S6 T2 d- o   set tool_data_buffer($mom_tool_name,output) "$co$output$tool_time$ci"
9 R8 i' c9 D  ^' D1 f7 @9 V7 i   set tool_data_buffer($mom_tool_name,type)   "$tool_type"3 d/ ^7 A; A9 ?2 W. G9 M
}( @) Q) D# E- L- O% R
+ Z( h4 R5 B2 h; O6 u# k% v
  K8 Q( U/ a5 l
proc MOM_SETUP_HDR {} {
; Y4 z. i$ k' H0 \4 Z( s   global mom_sys_control_out mom_sys_control_in% t' D3 }# Q6 A# Y* L
: P) z  X( j* u: q& u0 h3 M* U( M: s& M) V  a8 e
  # Initialize various tool lists% Q# F3 g; m. y$ A7 x
8 H& I( c+ S1 c2 U3 d7 r' I: h, e) G5 ]$ Q1 D1 E: l( o
   set mom_sys_tool_stack(IN_USE)
    ; \( E! D- f' w
       set mom_sys_tool_stack(ALL)
      1 a8 u  x% Y' `. L* E6 E
         set mom_sys_tool_stack(MILL)
        4 b( @0 }0 f6 d; j
           set mom_sys_tool_stack(DRILL)
          , g' ]4 E, h0 `# P
             set mom_sys_tool_stack(LATHE)
            ) y3 d2 z+ }" D( B. J  E9 _6 g
            3 M& L2 v  c0 w: K: ^$ x1 k
            # v* E. r7 U% e0 Z9 X
            . B) W6 Y9 [1 n   set co $mom_sys_control_out9 J! j2 a  B; N/ Q2 m4 Q, B
            ' E2 M" s, w% m+ a5 Y
            ! a* W1 L1 d/ J: g
            * d  w* e2 A7 _- L( [1 _  # Define header to be output per tool type
            $ c( ^7 I" z" l! }7 G+ i) J  #++++++++++++++++++++++++++++++++++++++++++' E1 N, x* s" D% G8 [' t
               global tool_data_buffer9 K  ]4 m, }  R( q2 Q* _% q2 u
            ; }6 z6 X; T! R+ F
               set tool_desc   "DESCRIPTION"( l- q  M$ R7 z& `  j0 U2 g7 a
               set tool_dia    "DIAMETER"! d6 y, {  V0 j# z
               set corner_rad  "COR RAD"
            . L! f" Y; G/ Y6 p; `8 w+ B7 Y   set tip_ang     "TIP ANG"; D  B8 M5 P) ~; d# z" D
               set flute_len   "FLUTE LEN"- B# Y; [' z) n, w
               set adjust      "ADJ REG") V/ W. E8 D. y( ]2 N
               set nose_dia    "NOSE RAD"
            4 D2 m) |$ N# G7 o2 N   set tool_orient "TOOL ORIENT"
            , h; E- E# }/ s8 o; h5 J
            ' P5 k4 Z$ t% [& q0 B& G( m% L  # Label title for tool time only when it exists.
            / A1 g. l0 c( G  s   global mom_sys_tool_time
            , o2 t1 P6 g: ~5 r; r& c   if [info exists mom_sys_tool_time] {
            * k9 [8 n: G/ J% M7 ?      set mach_time   "MACH TIME"' K* j1 i$ X  f: V6 Z5 X
               } else {
            ! ?9 \8 w; ^) t! j$ U& o7 z      set mach_time   ""0 g" g; l: Z) M5 m! E4 |4 ^
            & t* q5 D& E  u8 Z8 E+ R+ e1 R, E. W2 e! b1 ?0 `! t
                 set tool_name   "DRILL"+ ?1 X& P8 q1 z7 Q1 I8 F7 M
                 set output [format "%-20s %-20s %-10s %-10s %-10s %-9s %-10s" \# r7 x+ O- U0 `( j/ D! A& ~7 e! ~) @$ n
                                     $tool_name $tool_desc \8 ?$ q( H& \( S+ t6 s! O3 `$ Y
                                     $tool_dia $tip_ang $flute_len $adjust $mach_time]
            " w6 B6 \& C$ H( c  K- p1 M5 [' d& e( M5 m( s' q% X8 w+ m
                 set header
              , S) C7 N, c3 S
                   lappend header "$co        $ci"
              6 M7 X. ?) Y5 G, E8 E' O) \     lappend header "$co-----------------------------------------------------------------------------------------------$ci"& g2 p, v% I: S  W) ^
                   lappend header "$co$output$ci"2 F0 J$ t4 U/ @$ z3 v
                   lappend header "$co-----------------------------------------------------------------------------------------------$ci"" V' U: m: g+ b! U
              8 r8 ^2 |( B) K   set tool_data_buffer(DRILL,header) [join $header \n]3 p( ^: y2 Z/ M6 s; J4 V
              & y& H3 ]4 H/ p# O% B5 [0 T' a: c
              5 K  m8 e1 w) K! d- @5 F) l: J9 @6 l     set tool_name   "MILL"# @; {; [( x* F! R
                   set output [format "%-20s %-20s %-10s %-10s %-10s %-9s %-10s" \! a1 K% J" M( n/ n6 R% }
              + g2 s0 O" Y' g3 ]+ F) O# I                         $tool_dia $corner_rad $flute_len $adjust $mach_time]
              0 Y3 F4 ?# ]3 E5 X- q1 j$ @/ a3 x2 R: T
                   set header
                6 j$ Y+ `! ^1 R5 `, Y) s
                  b, o1 u6 J% i1 b3 C* r+ o     lappend header "$co-----------------------------------------------------------------------------------------------$ci") w# q/ s: p! k7 v! \0 {
                     lappend header "$co$output$ci"4 t& Z* u& J+ N' Q; P
                / O3 u; \: q* p% a9 u) D& H7 {& H7 P" `  E
                   set tool_data_buffer(MILL,header) [join $header \n]
                & v! ^3 E- w9 o1 b! I: }# t9 Q0 I/ P  P1 d$ `1 B
                1 ]" U4 m& o1 \! ^! H     set tool_name   "LATHE"! {1 P& \+ f# I; }: T* c+ ^
                     set output [format "%-20s %-20s %-10s %-15s %-9s %-10s" \) {$ r5 L: N" H) u. r0 t: M
                                         $tool_name $tool_desc $nose_dia $tool_orient $adjust $mach_time]# [2 ~% G: l  r0 O: S9 ?
                ' l7 T" O- _# y& O$ d' s3 H* b& m
                     set header
                  + y/ N0 w  i: }; q  O, }% p     lappend header "$co        $ci"
                  # m! O! k, V' }1 b2 y7 Y4 _     lappend header "$co-----------------------------------------------------------------------------------------------$ci"
                  $ g$ V; E+ t2 ]: g! m     lappend header "$co$output$ci"; [- \1 l+ X4 r! R/ c
                       lappend header "$co-----------------------------------------------------------------------------------------------$ci"' H$ `9 F# l. \: c4 x3 K& a
                  : j5 w4 u/ E6 |9 a( I' ^
                     set tool_data_buffer(LATHE,header) [join $header \n], D+ e4 K2 j7 B' s1 I: O. M
                  }# J& r: B& K; ?- l8 H1 k' ]
                  0 N& o. v1 Y' u1 }6 G- ^( T& k+ y4 S' ]( s/ _+ T! Q9 D! a$ N5 I5 K9 O$ E, V
                  proc MOM_PROGRAMVIEW_HDR {} {}. S) \' ^0 N& d2 j# F
                  proc MOM_SETUP_FTR {} {}+ k- J4 @, j; p
                  ( M( ~4 n8 o! T9 `
                  4 a5 Z' ~, M) P$ |proc MOM_MEMBERS_HDR {} {
                  6 o5 \9 N. g; S  R& G. o% i1 ~3 I   global mom_sys_program_stack cycle_program_name
                  * [7 z+ c8 L' r) y* B2 W2 a   global current_program_name
                  . L8 B; ]2 U' F2 V# j( |/ t# E0 x' E0 e7 Q2 U' t0 s' |
                     lappend mom_sys_program_stack $cycle_program_name/ q' s. X2 z8 e: w
                    g) ]4 k  b. F, C   if { [lsearch $mom_sys_program_stack "$current_program_name"] >= 0 } {; x! W- @+ A, b6 _; n
                        set cycle_program_name $current_program_name+ S8 B: X7 C+ F6 y2 Z. w
                  4 F6 m  k- ]) e}! j+ {) M0 V- l% n
                  / N6 M! m7 h4 r: Q3 W/ V% r0 Z
                  & {+ n( F3 T! @. l" Y3 u: ^2 ?proc MOM_MEMBERS_FTR {} {
                  7 {( ~& _0 p4 w9 V4 o; a& ~   global mom_sys_program_stack cycle_program_name
                  * {# ^, X  D. h' p# m   global current_program_name5 \& z5 t% r9 L8 a1 H9 [% O( }
                  # P. P  p7 [8 I! @7 k) e! d2 d
                     set mom_sys_program_stack [lreplace $mom_sys_program_stack end end]
                  % Q5 e# |5 U! x4 g9 g, b   set cycle_program_name [lindex $mom_sys_program_stack end]- y+ t: J9 b. ~% r
                  , C0 X% c4 I7 O# S5 E. T! g1 o' C* s   if { [lsearch $mom_sys_program_stack "$current_program_name"] >= 0 } {  V* Q0 w! }6 o
                  - U% M7 e# t0 F   }' M3 T% t8 a: \
                  ' c- E/ N) l6 p, {0 N, A) J5 j  N2 O$ S
                  + r$ `% e2 L1 Y7 xproc MOM_PROGRAM_BODY {} {4 K# `4 J3 k8 S# D
                     global mom_object_name cycle_program_name
                  . y+ a8 f2 Y1 \0 v! ?. D" L' X
                  , r+ [( p7 G4 I   set cycle_program_name $mom_object_name/ o9 @( _; x; |/ E3 @
                  : i, h4 |4 t1 G6 ?* ]0 s) x; C1 h/ y/ ]. Q0 m8 H
                  + p  `! {) O0 [proc MOM_SETUP_BODY {} {}1 q4 c; e7 n/ L1 ?) [
                  proc MOM_OPER_BODY  {} {}9 b* D! P- u1 T! F
                  proc MOM_TOOL_HDR   {} {}- @. u  M9 j0 ], I& ?+ U; y
                  proc MOM_TOOL_FTR   {} {}
                  6 ^! p: T& _$ z, _" l% H, ~. Rproc MOM_PROGRAMVIEW_FTR {} {}4 Y9 u6 ^6 x  w0 B
                  2 l7 `3 b0 C& p& p* _! b, R
                  2 l: L# d; P* bproc MAP_TOOL_TYPE { } {0 A0 p9 a3 |+ n, o2 ]
                     global mom_tool_type# g, n; l  D: _! t! n" x  Q
                  ! q& U3 A; u2 s+ H
                     if {[string match "Milling*" $mom_tool_type]} {7 E+ x4 `8 h- r% A% ]
                        return "MILL"
                  ) z9 P9 f7 d7 {( y" @2 U   } elseif { [string match "Turning*" $mom_tool_type]} {
                  5 c* d4 c0 p/ D: [8 p      return "LATHE"
                  2 @. O1 J* d  Z# F/ E7 [+ _. ~, e   } elseif { [string match "Grooving*" $mom_tool_type]} {. U; H; A) p* W, M+ W7 S& L* g: ^
                        return "LATHE"5 `/ T9 F$ p( x+ x5 I0 f
                     } elseif { [string match "Threading*" $mom_tool_type]} {( |0 v! @- d) e$ v
                        return "LATHE"/ ]5 z7 F3 G4 Y* g/ ^( e) A
                     } elseif { [string match "Drilling*" $mom_tool_type]} {
                  ) p3 H/ z' ]* N% w0 X  ?3 u      return "DRILL"! O3 h/ d2 M' A8 b  c
                     } else {
                  . @/ B5 ]9 p% Q' N& {      return ""
                  - |, z$ Z; V9 k. B0 R   }  s# z! a* r- V' \& j
                  , ?7 G/ `  J. e9 G8 P3 _! D: l( e' y; V7 e. k1 s. @
                  ! @) J- x& O2 @1 g7 iproc shop_doc_output_literal { line } {1 W3 U5 M" v! V! G
                     global tool_list_commentary list_file6 s% b  T( O; c0 g2 n4 c
                  % W7 V: v; V) B; n+ X& x3 \: U   set line_list [split $line \n]2 m( z) \$ H8 n+ X/ j0 [# N
                  6 K' {! h5 _: d) o! E$ m' n3 L
                     foreach line $line_list {
                  & J) p- k; A+ p
                  " C" ?4 s3 s$ |2 o( @# U      if [info exists tool_list_commentary] {9 S: F  @  _3 i8 j9 j
                           puts $list_file $line
                    ]$ m  Z7 Z  m! |& Q9 x      } else {" m: h& F/ E" |$ m2 A4 M
                           MOM_output_literal $line
                  ( W6 U2 a" @6 }/ H" s4 g; \( j      }( h3 `8 H( i# f: o5 p0 \
                  % R/ A" N2 t& k# m( C1 }
                  6 Q7 Q% L9 P; q3 l8 }: ^9 f}
                  + Y! z* Y8 Q) K( n0 n$ p
                  9 W6 u  b/ f. Y& X' P
                  2 m4 D9 l. S& l9 b. C5 ]} ;# uplevel8 e$ i: |" h. o) L
                  0 H4 J5 b% ?; w$ e% H
                  , ]7 N' A, O6 {$ f' ~: Q9 u   set mom_sys_tool_list_initialized 1
                  / m5 Q3 N6 c2 {0 O) w; P2 |
                  3 r( l/ X2 b* s8 W+ H1 j' K
原来的
原来的
理想的格式
理想的格式
 楼主| 发表于 2013-5-6 15:07 | 显示全部楼层
本人QQ799813522    跪求高手出招,谢谢
回复 支持 1 反对 0
发表于 2013-5-6 17:48 | 显示全部楼层
本帖最后由 fyzfyz 于 2013-5-6 17:53 编辑 . r, e; B# B" A
" h0 Z; j- m1 U+ ~) B膜拜神贴,后面的请保持队形~
 楼主| 发表于 2013-5-7 13:38 | 显示全部楼层
高手们出招把,跪求你们了
 楼主| 发表于 2013-5-14 10:10 | 显示全部楼层
原来没有高手
GMT+8, 2025-9-17 03:18 , Processed in 0.055125 second(s), 23 queries .
