查看: 2524|回复: 10
装配问题求助
发表于 2008-4-2 15:52 | 显示全部楼层 |阅读模式
装配问题求助
* t" k+ V) t0 X" k) K! U0 y( g* Q请问各位装配中的发布怎么用?我直接在装配环境里画的两个part (画的时候已经互相几何约束了),但是在修改其中一个part后,在装配环境中并没有更新,我不想再在装配里 重新约束了 ,有什么方法可以解决的,呵呵
选项里把外部引用设成关联就行了。没有CATIA,要不就能给你个图了。QQ>>715749205
3 g4 m( C" A9 L8 I( D欢迎交流
你可以手动更新一下就好。
" r3 k: D3 v9 L& H  h; P, e) F7 E; B: l, f5 g8 {9 B6 I$ w! H
Update的小按钮点一下http://www.3dportal.cn/discuz/?fromuid=182415
发布是用来去参操作的,发布后就彻底打散了
奥 我试一下, 手动更新我是过的不行啊 我看了下http://www.3dportal.cn/discuz/viewthread.php?tid=379215&extra=page%3D1%26amp%3Bfilter%3Dtype%26amp%3Btypeid%3D60的topdown 的做法,在第七张图里为什么在旋转之后会有两个几何集的?这是怎么回事亚,谢谢各位了
外部应用在哪里调?
LZ~, let me show you how to do this
; J) a# h$ K% u; t( O1 P$ w. R9 a/ J" Q# x: I9 g
See the below picture, you can selecte the Option_1 to make it active. After doing this, the part in the assembly can be automaticly updated as you change the sketch in the another part.* E4 j3 V: i& R1 b6 d: w
6 j# B2 ]! @  `7 x! G" e
If you selecte Option_3, there will display a warning message which confirm whether you need to keep link with the selected object when you make a external references .3 E( t# l' y3 q1 U
( L, I3 w1 g# W/ ?' o
Check this Option_4 if you want to allow only published elements to be selected as external geometry. This restricts and therefore controls the selections that can be made when selecting elements belonging to a different part.
, `2 y2 X; k* P5 H# g7 ~! T4 r" I/ T+ i% I7 ?0 m3 @
As for Option_2, I have not known its use. so...Have you known how to do?LZ~~~
真详细啊,呵呵 可惜搞定我的问题了,谢谢楼上的,呵呵,第二个选项我也是不太明白, 有谁知道的继续探讨啊,
谢谢nature365,英文刚刚地,赞一个!—— 勤 为 径 —— 2 W7 w" d7 e" T6 I0 q& L9 M
By trying several times, i got the meaning of Option_2 today. As the picture shown below: If you selecte the option, the external references (surface.4 of yellow color)  will be displayed after your operation.
GMT+8, 2025-10-11 19:08 , Processed in 0.051796 second(s), 25 queries .
