//////////////////////////////////////////////////////////////////////////////2 K* h' @, ^- _ V* b% `9 E
2 H5 Z$ r5 C* {. e! V. d3 E// ug10.cpp/ J, X! U$ @) k; w7 B' n
//5 P$ s- v8 L K' ?7 q8 `6 ^% [
// Description:
% ^3 N7 v9 U6 X, R9 K# U$ M( Z: l// Contains Unigraphics entry points for the application.
, C4 X1 i$ |1 j//. A' X# k1 w; V* S4 y
) F" ] ]9 @0 }, L3 l& p/ g {- O* t: B5 y! Q7 [
// Include files
. b' v5 e" R$ P6 X. |#include <uf.h># U+ e) X4 T/ ^
#include <uf_exit.h>
* z. g0 Q# q% i8 A% M#include <uf_ui.h>3 x) ^5 P0 ~3 p* J; p! y; M9 Z
#include <afx.h>
* D1 k5 y( W* M, v' E7 `#include <stdio.h>$ ^6 L! Z3 \" Y
#include <stdlib.h>. O, b/ y" F" i; j; Y
#include <uf.h>
) D* s v; A5 v7 k#include <uf_defs.h>$ }! }' e. k& u
#include <uf_disp.h>
3 f2 F0 x* w" b#include <uf_modl.h>8 w# Z0 H) `4 m2 C" W! g' R* K
#include <uf_ui.h>8 N' h6 j0 R5 c. P8 E2 S' A9 k
#include <uf_object_types.h>* ?/ q8 f& M! o% s- e/ k0 {
#include <uf_assem.h>
) L/ `( w' q1 E y. k2 G7 @! u2 E#include <uf_drf.h>
* k2 j# n! e, v7 `3 d' R; P#include <uf_obj.h># q3 m7 H0 o" ?! D2 q8 E
#include <uf_part.h>
; r( l9 z9 P5 g5 I- J#include <uf_gdt.h>0 `9 V8 | O8 Y" ?" b' U
#include <uf_vec.h>8 D0 B6 f3 Z. N% W/ q
#include <string.h>
! N$ r4 n. X) x3 h) U& t#include <uf_attr.h>
0 N0 I5 V* ` w5 C2 w0 P#include <uf_curve.h>
+ I3 G# p0 W$ V- ~& ~#include <uf.h>5 W1 ], ^0 K6 L! w% c3 [2 d
1 h5 y7 L' w, f o h9 d#include <uf_ui.h>
4 ~0 U T# m$ K$ n% m4 |#if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun )/ c6 L2 U' B; J# k5 S
# include <strstream>* v5 P! G6 v' S) J
# include <iostream>
) Y7 l. n% _, z2 t9 Busing std: strstream;/ }/ d! v! h' k; \) M
using std::endl; . y! J, v5 g" Z0 X
using std::ends;: I' ~: Z# n0 p8 h: Q& M$ X
using std::cerr;
$ b0 V, v$ {1 b: A) k5 R) q( A7 J#else& c& D$ q4 ^/ [2 W3 W9 @8 u
# include <strstream.h>
3 }" K/ r! ^' a- p u" F$ z+ X" x# include <iostream.h>
6 L: G- ^6 b$ u# R. T. n1 u#endif* F6 e. F* c7 O, p; }* k
#include "UG10.h"
1 I. i0 Q; r/ I: i5 `) Y" E8 L7 O8 l- I& M
3 O: O# J7 w. y9 I& \' uvoid do_ug_open()
. p+ w: }% g; r7 w{' g* I# V* x- V$ l. c5 I) o7 y
char error_message[133] = "",dim_value_string[100],str[100];
- n3 P+ U& t6 b- h/ `; X6 A int ifail = 0,z=0;
# _' z& g( F0 j I; q2 B int type, subtype;+ w$ B$ x! {. H* S1 r
tag_t gdt_symbol_tag = NULL_TAG;# s! S5 `/ q0 {8 T0 A
double gdt_symbol_origin[ 3 ];
- f. u1 O6 f5 R: Z2 b8 c! N. z int a1=0,a2[50];" K0 N/ `1 A( C* |8 u1 w2 i
UF_DRF_gdt_symbol_info_t *gdt_symbol_info;
, \0 F2 P- ^# C& _9 o5 {/ y3 O7 b /* Initialize User Function. */! B+ ]! e: Y4 k" i- o
ifail = UF_initialize();4 P; L, ]. h1 x
UF_UI_open_listing_window();
& V; [2 y) Y+ q /* Find the tag of a drafting entity. */$ A, V, e! d$ r3 x0 ~/ F
ifail = UF_OBJ_cycle_objs_in_part( UF_ASSEM_ask_work_part(),
# _8 D6 Y4 i$ \( e8 R6 R UF_drafting_entity_type,
( {7 e; ^# P7 c$ J2 C7 H &gdt_symbol_tag ); N2 l' l+ S* B9 ^: n% d& c
while( !ifail && gdt_symbol_tag )0 ^% B+ k: F+ q+ J2 d; i
( K' C: A2 p, ^& H6 \1 I ifail = UF_OBJ_ask_type_and_subtype( gdt_symbol_tag, &type,
. K2 r1 N( [; ~! ?# [0 { &subtype );) |2 l: X; I6 l* C$ ^; A
/* Test type for the GD&T Symbol. */! W& k6 N1 f3 \; E
if( !ifail && subtype == UF_draft_fpt_subtype )$ R# D% t! d/ {, u2 A( {
{0 r# k5 N/ K; I/ X9 k7 S' I- r: ]. h" u
/* Retrieve GD&T Symbol information. */
$ ]2 D- n) j) L# r" ^+ E3 q3 _ ifail = UF_DRF_ask_gdt_symbol_info (
, u6 ?5 U) Q) A* n; ~" g gdt_symbol_tag,9 E+ I. y) K' [3 f
&gdt_symbol_origin[0],. N7 J- g' i' b0 @# s4 T% ^
&gdt_symbol_info);0 g% D q! L2 u! p! u
& c5 b; K, y Z$ O6 L strcpy(dim_value_string, gdt_symbol_info->text_info[0].text[0].full_string);5 s5 L! ~* N/ n
CString s=dim_value_string,reason,Result,o,fai,xiangguanyaoqiu,jizhun[100],yaosu[100],fai1,q1[100];6 _% B# a* n" s O7 W
sprintf(str, "字符串长度:%d", strlen(dim_value_string)); 2 Q, v& V# m% G; X
UF_UI_write_listing_window(str);* A f& C7 Y+ y3 |- ]
UF_UI_write_listing_window(" ");7 ]5 a2 ?* z4 m) h' x! K
UF_UI_write_listing_window(s);
; t# @4 W: }' {+ }# _" H9 \
- g- B Q; x9 b/ g. G( T- c: y( C$ S1 n
for(z=0;z<6;z++)
5 E M, I; w/ J0 z! _ {
: L% i4 ]" I J& r if (s.Mid(z,1)=="+")
# d3 ~0 g% \/ D6 B2 C' h {* m0 ]* w) k# ]( e+ J
6 E: v! n# p! {9 H, ~' Z s.Find("+",a2[a1]);
) ]8 `& l1 g+ i& ^ ~; W0 c a1=a1+1;: V2 p7 ^6 h# |7 z2 h) o4 r, @
/ A+ {' q0 e, p2 g1 M9 k+ j5 i3 ~ , l# C* Z7 i& w1 G- F5 \
UF_UI_write_listing_window(s.Mid(z,1));
1 F6 r2 C* V+ _6 d1 c }
2 Z" g6 T4 S( `6 g$ H, b
x) y" |$ u5 C" j" E: e6 l 1 q% b* Z) `% I) m3 z0 e6 c
/* free text string first */% o/ X5 ]( ]2 J
ifail = UF_DRF_free_gdtsymbol( &gdt_symbol_info );
/ N5 H6 X* g1 k" n1 h t& E' Q }/ I o+ I' B- Y, `9 a- B
/* Find the tag of next drafting entity. */
% w2 G- |$ [2 x$ O) W if ( !ifail )% B2 z# A4 n) j) f+ ` Y
! u4 ]1 U2 s+ G) I& z UF_ASSEM_ask_work_part(),
. Y3 b1 Z/ i) X& x3 s8 R UF_drafting_entity_type,
6 ^, N9 O) r; k+ Y1 z" m7 E' C' \ &gdt_symbol_tag );
, v* |) n2 n3 h, }9 U }
8 f' |. O, H: x* }, D printf( "UF_DRF_ask_gdt_symbol_info sample " );. i4 [' n( G- V4 `5 U, G( |* X
if( ifail )
6 L0 P9 B- G( r5 l- f { E& c- b4 C9 l
ifail = UF_get_fail_message( ifail, error_message );% O1 O* s6 C5 I3 N3 i
printf( "fails.\nError is: %s\n", error_message );7 R: G! u6 z. p1 }+ h
}' s1 j; \/ T- w- G
else
* E8 F, a& R5 _* A( w4 e printf( "is successful.\n" );$ j, I) V6 o3 S
UF_terminate();
- I* h. z5 V @# v1 v$ P} V8 g1 F5 A2 }/ r; F! @- C
8 R# S* b; U7 ~4 H( D5 a
; e" k) d }1 R4 X
/ w H! T9 R5 u/ b2 }//----------------------------------------------------------------------------$ e$ ?8 C j7 m n. z
// Activation Methods: _1 q! A) ~5 F0 y' J
# F& e% j" p- p3 g9 `+ o8 [/ | B/ t6 Y4 `& i% t4 Q' `* ~
// Unigraphics Startup. J- s8 `+ F1 U$ p
// This entry point activates the application at Unigraphics startup h; l( H$ |0 K! N$ m/ ]8 K
extern "C" DllExport void ufsta( char *param, int *returnCode, int rlen )
' U! l7 q. |- A6 f( b+ o{
- k$ s- B( j8 ^ /* Initialize the API environment */
; Z; s" C P1 t0 V5 b2 W int errorCode = UF_initialize();
6 J! L/ B7 e; m
5 v1 d/ y, X( ?( i7 t( E/ n; G if ( 0 == errorCode )
# q$ l& l, d8 p' {% ]$ p. j {
0 f% ^, `+ D T8 U( l do_ug_open();9 o1 L; n, @% s
/* TODO: Add your application code here */5 E- `4 T0 N7 S. B( t$ b8 b) S
+ o( Z' }2 o4 ?2 H; _* [. h /* Terminate the API environment */7 f2 |5 I0 _- W9 \* }% s
errorCode = UF_terminate(); T6 B; n6 R8 {2 z
, b* h8 C# Y& s4 {6 U5 [/ I
) e5 R* e9 P* p) l4 N /* Print out any error messages */
' B* x; u9 d6 i% c PrintErrorMessage( errorCode );
) p) {( w, F8 B) p) H7 I}
6 p# g1 u8 ]- P( `) h& I5 r% ]6 E- Z; z2 ^. c8 b
1 E) j3 R4 Z5 b7 g" f// Utilities
$ Q( G8 C: I/ j) E! s$ ^//----------------------------------------------------------------------------
/ \' X4 h1 f6 \9 Z* E" S, x. n1 }! r& y& t' u
// Unload Handler
. z" T4 h# b3 j# L# ]4 X( V// This function specifies when to unload your application from Unigraphics.
0 m! i, Y) p2 x* Q* D& }: b// If your application registers a callback (from a MenuScript item or a8 S. v+ Q+ B7 j1 K' o
// User Defined Object for example), this function MUST return
& i9 p, x7 a/ K2 Q8 }7 z* H8 ^# k// "UF_UNLOAD_UG_TERMINATE".
3 |" F# O. o2 @) eextern "C" int ufusr_ask_unload( void )7 S" C, S: x* v) e7 G7 U
{# ^6 n w/ Y0 U/ {) A" _
return( UF_UNLOAD_IMMEDIATELY );
# G6 \1 l& {& n" f. d% D' p& |}. ]4 s7 ^5 j( D# v' I1 A. z$ f. ?$ y
# B2 Y, ` C" d% H. W' w
/* PrintErrorMessage
- i% w4 ^; D0 K**
* K2 t; ?: z% E9 @0 ?& `- t** Prints error messages to standard error and the Unigraphics status* F. v4 o; q+ i$ y" N% @
** line. */' l6 E( f7 } p7 ^
static void PrintErrorMessage( int errorCode )
- X7 J- S( T1 I) ^# ^4 e! z, Z) [{
Q! [ h+ F1 L5 ~ if ( 0 != errorCode )
# g J) E6 |- \# H+ T {3 \2 m9 \7 @3 c; t9 v
/* Retrieve the associated error message */
$ J9 [" ^6 m* ^7 y char message[133];
5 Q& @% X9 z E UF_get_fail_message( errorCode, message );$ P' m4 v5 w1 X- Z9 d2 w/ w
3 S) A6 @8 x0 f5 \' `) E5 Y /* Print out the message */& _! j* X0 u& @9 L, \/ |! o( r
UF_UI_set_status( message );
6 }, L2 V; Y% Q& I4 k# ]( a t % V2 l( A. g/ b$ K/ L
// Construct a buffer to hold the text.
( r3 `# i6 |; e8 G/ S ostrstream error_message;
g/ F& }0 v2 K 5 o! S" n: P" E/ i
// Initialize the buffer with the required text.; [' ]3 O: W7 t9 ?, x$ I5 }
error_message << endl
, ^4 i9 q" ~& [& l+ S: h+ E- E7 Z << "Error:" << endl) f# F' t4 w" h L
<< message
$ R0 M% J p6 r; I: J << endl << endl << ends;
) t" X- }' }5 d- X7 l
& ]$ r5 C! f( s // Write the message to standard error @. I# @/ b0 _2 W
cerr << error_message.str();
$ K0 I( K- K1 @) v! @ }# U8 g/ F0 p' p5 ?7 F S; z( x
9 R+ |6 @+ N! j- G0 D* _6 s* o; A* H. J& k
为什么FOR循环根本就没反应,z一直都是0,根本没办法一个一个提取字符,这是为什么呢??? |
