: p; g% g6 i" C$ [. L' x3 Y
NX VERSION 3.0 CDROM 1 of 1
9 I* e1 \5 d4 O" x; w* |1 Y$ t4 O6 F8 |; m. n$ \
Windows 2000/XP (32 Bit) Issued: Sep 20048 V7 ]" a' E y3 p
+ F" ?) k; C9 X* b! Y3 u9 k Files on this CDROM are for use on the Windows 2000 or Windows XP 4 _" W1 r8 r) E" E6 F, I
(32 Bit) platform only, they are NOT supported on Windows NT4., \0 a5 J) X4 L
. K: P [' b) X) O, M( Q6 n1 @
_______________________________________________________________________
6 G: D# @9 B2 D* O0 H7 D5 _% Y. d: M
NOTE: The installation of NX 3 on the Windows platform will ' y- y1 `7 s4 z2 \: O
automatically update your version of the Windows Installer
0 N5 |5 f, N! t2 ? (to version 2.0) if necessary. If the Windows Installer is- E8 h( I( u$ @5 U3 {! |
updated, then a reboot of the system will be required.% u. j; @5 G4 z' I# F
7 J( C! C. q' B! f! K& V# b
You can determine the version of Windows Installer you are $ W0 ~0 J2 `( S! ^* j5 }, l2 Y
running by either using File Properties on the file:% t4 e C) G5 N- X
\winnt\system32\msiexec.exe, and looking at the version, or
( H1 \5 e& U3 g+ ^/ W from a Command Prompt window entering the command: msiexec -h# T; P! @, R( |, B" {* U1 E
If the version displayed is less than 2.00.2600.2, then by
' y. y$ H; c% g+ x z9 O starting the NX 3 installation Windows Installer will 2 @ Q$ {' C/ P
be automatically updated, and a reboot will be required.
5 _8 |3 O, h/ b- k" z" g( J h% ^- P ^; d% h
The NX 3 installation will prompt you for a reboot, ' I9 S8 a$ M1 b9 ?" O7 L
only if it had to upgrade the Windows Installer.
. s3 ?+ }+ M3 V. s
8 N+ k7 T! M2 L$ b1 G5 I; x If your system already has Windows Installer version 2.00.2600.2,
9 |- x# t/ A: p: [+ c' e then the NX 3 installation will not prompt for a
) g& z1 C/ }9 l b& `/ x! O2 P. U reboot, as it is not required.
+ R: @2 n7 q0 j X! R* P0 p! ]: E4 ?5 ^4 J' O7 w
_______________________________________________________________________' O% D8 K& o2 v l; ?& ^* N
INSTALLATIONS:
8 g/ Q& y2 {; G0 o
* ]" }3 j. `: f, p' n/ p2 t. R To install the products on this CDROM, run the 'launch' program at) L" L0 p3 {- a# {- `# d+ P, T# c
the top level, or change directory to the product directory, then
4 F% T7 u1 K# Y. j5 r: W run the setup program contained within that directory. % d1 Q- W6 T8 J& U: J
0 p( b# \; y% ~, X+ w
4 F) V1 f: [1 m8 ~ K' [ DOCS:
7 E: k# S0 a& z( |* e6 H9 M3 G; T: J3 q8 |7 a+ H# y
The 'docs' folder contains Installation documents and other related
3 {3 d/ \" i3 N; U7 z, U W' L% m documents, which may be viewed or printed with your browser.
1 K; J: O2 k9 _$ n7 q" X- }
. m9 [7 P3 G( u% z4 n+ j1 V, Y Further information is contained in the README file located in
( h1 j2 k. a2 O7 R) z the "docs" folder.# i; k, j8 E! {8 Q' s% D
$ @; O8 ?# i" ]/ ^( j NOTE: Viewing Documentation directly from the CDROM Launcher will
+ I3 k6 V( O- M- S6 e require that the Adobe Acrobat plug-in is installed on your
! k# }; T1 v7 m system. No errors are given if the plug-in is not available.' V V0 W Y* b
% ]3 {& ]+ c5 \( X Download the plug-in from: http://www.adobe.com/acrobat) j* M) V' N |6 ?) |5 ~, k
2 e% M) G. }5 d5 ~ _______________________________________________________________________
5 g F4 Q' A& q8 ]: t1 _ RELEASE INFORMATION:6 q- z; R( I. _! O! V0 q+ y7 A
& i3 F! Z, D& K) W1 }3 t O
The What's New Guide and the Release Notes are contained in the
8 p- \- A* ^4 Z% H5 T REL_INFO kit in the NX 3 kit. This will be installed by
, |6 R# Q, L& y" Y* N7 q7 a default with the Typical installation option. If you use the Custom
' G) `* _! Z2 _+ R4 V" B. D installation option, it is recommended that you select the . y" q; i" K8 }# P3 \' M
'REL_INFO' kit.
" c$ i8 |8 s+ P! Z
" {& M+ `; ]& m! J) l0 M3 H Once installed, both documents can be viewed from the start menu:
( q* ~2 C, J5 U
+ E: I) u" L( Q Start -> Programs -> NX 3.0 -> Release Information ->
5 t% y" N0 @+ H6 ?! ^- o9 D: v
3 a! ]: Y( L1 L *Whats New
$ I9 ~9 O a- `- c- s9 ]* X! P *Release Notes ]5 F4 P8 i, @" [
5 N6 ^' ^1 C5 o) r1 }$ y9 g Note: The PR Fixed list (Customer Responses) is separate from the' M" L3 }! _/ S, i
Release Letter and is available in the docs folder.
1 h4 @) M2 C. C: ` See the docs\README file.
8 A9 c" J6 a7 y: L) _* x. S- N8 W* U0 l& A! O
. V5 L2 {& B( M4 }( v0 s$ L( w( T6 I& _& k$ K! c: _
