entity/pt(100),ln(100),cr(100),obj1(100),obj2(100),ent(100)9 F b- e/ J$ J1 k6 Y! r
number/nd,ndi,nr,k,wd,wr,mat1(12),mat2(12),mat3(12),mat4(12),mat5(12)0 `) B, T! o# P" e; [
data/ndi,23,k,2507 i2 T: k1 \9 Q$ `
ln(1)=line/0,-100,0,100
7 ~6 R! H/ X" W' cmat1=matrix/mirror,ln(1)$ l: C/ y! x( ~3 s' I
$$---------------------轮胎--------------------$$6 x9 M T' d& o( C: W
$$输入轮胎相应尺寸参数
, x1 d& f! C8 zback:
+ U3 q z# u1 F3 r) o7 Zparam/'输入参数','轮辋直径(in)',ndi,'轮胎宽度(mm)',k,rsp8 ~" M, J8 {+ g2 F8 i% j" h! ^
jump/back:,cancel:,ok:,rsp& r4 `# t- R( e, l5 x4 J
ok:
: m) T% x6 e7 ^8 I( b$$判断参数正误
8 }! g! q6 b5 C! X; l1 Nifthen/ndi<14 or ndi>25
+ [2 [5 S8 I$ Smessg/'轮辋直径超出范围(14-25),请重新输入': q& p) T O$ C3 R1 P) p
jump/back:
2 y; T/ I! ]8 `) y; u" J9 Kelse7 }% C F' U. ?
jump/l1:8 ?& d8 f. _* ^0 M8 E- r
endif* n1 ~8 v& h* U% ?4 j( {1 o) E
l1:
9 `/ n- m9 E2 h# K8 bifthen/k<150 or k>350* T3 I6 z4 `3 b' Z8 R. O: Q6 p
messg/'轮胎宽度超出范围(150-350),请重新输入'
! X% d6 U3 |. i% c- kjump/back:
# u8 c0 G1 P" j6 \1 e" R2 D/ Gelse
. M" V( n) X2 m, n5 a0 `jump/l2:8 b* d8 G9 a* A
endif
2 x, z* @6 s: p) b) J' f7 H/ ~l2:" ~& V5 B8 }# [3 i1 A; r
nd=ndi*1000/36
& a4 Z! h0 K; z- @5 H }9 C: r& A( dwd=1.5*nd
& W' o7 n" R" vnr=nd/2
* j3 Y) K7 R/ d& d; y; K! w0 mwr=wd/2
& R; _, n5 N; {- c+ f7 M: j$$生成半轮胎周向截面点、线 L4 X. x0 D0 \* Z/ f4 G+ f
pt(1)=point/(-k/2*0.93),(0.98*wr)2 E1 D+ J3 o' {6 Z* L
pt(2)=point/(-k/4),(0.99*wr)
4 j5 q* b @9 s, {( L$ ~pt(3)=point/0,wr
7 K4 ^5 S$ O- H3 k Y: k ypt(4)=point/(-k/2),(wr+nr)/2* i! ^# F* k* w6 [0 W4 ]
pt(5)=point/(-k/2*0.93),nr
; v$ L: g' }' E7 Y0 ]6 a) Wpt(6)=point/pt(5),delta,(k/30),(-0.1*nr),0; o- m$ J' I1 M- i- z
pt(7)=point/0,0.9*nr9 i; ~0 h3 V* s: x
pt(8)=point/pt(1),delta,5,-5,0
1 i5 Z6 B' R: I- i; i2 x0 y3 Q/ Rpt(9)=point/pt(6),delta,5,5,0
f; o3 m! @2 A# \, q$ z! W# h; i! _pt(10)=point/pt(5),delta,5,0,0
7 j: u4 h3 T6 `& wcr(1)=circle/pt(3),pt(2),pt(1)
- v2 E3 {3 d$ I9 t7 jcr(2)=circle/pt(1),pt(4),pt(5)
$ f, M, K. ^. ~: Q( H) o* Pln(2)=line/pt(5),pt(6)
; m- ^$ q. z$ t. z, H; P, ?6 J7 fln(3)=line/pt(6),pt(7)
, H `5 y9 n2 S) yln(4)=line/pt(7),pt(3)4 k( P9 g+ e' u, D! |
$$倒角处理4 [$ G0 A7 ~7 ~5 _
obj1(1)=fillet/cr(1),cr(2),center,pt(8),radius,15
* t. w) q6 q3 r7 t9 f! a8 qobj1(2)=fillet/cr(2),ln(2),center,pt(10),radius,15
! v( J1 c% K5 D6 J5 pobj1(3)=fillet/ln(2),ln(3),center,pt(9),radius,154 ^# h: z2 O& g3 I' `
$$旋转0 t t2 V2 X* b" d: T7 P
ent(1)=solrev/cr(1..2),ln(2..4),obj1(1..3),origin,0,0,0,atangl,360,axis,1,0,0
2 ~6 L& N& ?& u7 D! S. S3 h$$花纹线
8 K9 Y) K5 ~' y9 w) t/ R% kln(5)=line/-k/2,k/8,wr+10,-k/4,k/8,wr+10* b) S l3 s( e
ln(6)=line/-k/4,k/8,wr+10,-k/6,0,wr+10; }% m2 r9 B! N' M' A
ln(7)=line/-k/2,k/8,wr+10,-k/2,k/4,wr+10
6 E0 l( o: U3 D Uln(8)=line/-k/2,k/4,wr+10,-k/5,k/4,wr+10
' b" | f5 b% o, W) K5 kln(9)=line/-k/5,k/4,wr+10,-k/24,0,wr+10
( P# K8 g a! f2 j, v; d" Tln(10)=line/-k/24,0,wr+10,-k/6,0,wr+10
9 ?+ C/ y7 C- x% D0 o, L( q0 P$$切花纹6 T. d9 a% K" P! n7 L) Y4 O
mat2=matrix/mirror,ln(10): \; G# E% a) T0 v1 H3 f3 M8 I7 U
obj1(5)=solext/ln(5..10),height,10+wr/30,axis,0,0,-1
3 ~ b( ? W! C4 A- nobj1(6)=transf/mat2,obj1(5)
( m" }$ C4 n) s, J( r, sobj1(7)=unite/obj1(5),with,obj1(6)
+ u2 i/ R t* i) {/ A0 f& f( O6 p- hi=intf(3.1415926*wd/(3*k/8))
6 C6 F5 C' q+ p/ f6 ]0 jn=1
, J. |$ t T9 G. j w$ q7 w7 \7 y# a" R8 |j=8
# x f# H! [8 axh1:4 b; {! `! j" T9 ?( }
ifthen/n<=i-16 a! |7 x0 e$ h! o
mat3=matrix/yzrot,n*(360/i)
0 a! t0 w/ T6 L9 k. A8 Vobj1(j)=transf/mat3,obj1(7)
7 x( \: g0 Y2 V$ c+ R' w5 {j=j+15 ]$ y$ \. J- E, h3 B! X
n=n+1
/ v1 ]% r1 m5 z+ l, P: Ojump/xh1:
5 p+ j/ ~: P! w2 S7 d) Lendif
, _& U8 P$ E( S9 v4 Qent(2)=subtra/ent(1),with,obj1(7..j-1)+ P, h4 `! [+ S D( a
ent(3)=transf/mat1,ent(2)
, i8 b; X! W0 W- s& y( L; Kmat4=matrix/yzrot,360/i/2
6 |7 W: i" r* z# i/ F, j" u8 O5 rent(4)=transf/mat4,ent(3),move* R* f3 J1 f" S0 L6 g! V
ent(5)=unite/ent(2),with,ent(4)+ g) Z+ I7 b0 H2 j+ v5 T, Z9 g$ R
&color(ent(5))=&gray
- L, I: E- y" \) z" b6 Z$$----------------------轮毂--------------------$$
& s& _, x8 l" d9 w3 \$$轮毂截面点、线
C2 \ X( c; Z7 Apt(11)=transf/mat1,pt(6)
' U1 k" [* ~! Zpt(12)=point/pt(6),delta,0,-wd/40,0
s$ B0 q8 I+ s5 C8 _5 C" e$ ypt(13)=transf/mat1,pt(12)3 E- t O. Y2 ~% I( t) ]8 W# I
pt(14)=point/pt(7),delta,0,-wd/40*2,06 u; }: K& ?4 s8 e1 J. `3 t
ln(11)=line/pt(11),pt(6)! e+ k$ \5 K+ k) L- V- ]+ i9 s, Q7 s
ln(12)=line/pt(6),pt(12)
R+ U4 Z1 g- q2 @, Fln(13)=line/pt(11),pt(13)
1 e, _3 E: g: }2 Zcr(3)=circle/pt(12),pt(14),pt(13)
7 Q W3 b5 P5 _. [pt(15)=point/pt(14),delta,-k/5,wd/30,0. z5 g7 i$ B( x n w+ w
pt(16)=point/pt(15),delta,-k/10,0,0
+ h" |! f$ X3 b' N qln(14)=line/pt(15),pt(16)% V5 |5 T. e( z; x( c0 }1 D ^
pt(17)=point/pt(15),delta,-k/30,-0.2*nr,05 H) }' w" t [( Q
pt(18)=point/pt(17),delta,-k/15,-0.2*nr,0% j0 O6 C9 t! @0 T! h( z" w
pt(19)=point/pt(18),delta,-k/10,-0.2*nr,0
2 d1 z' N) M) O, v$ ]4 u/ v4 Bpt(20)=point/-0.4*k,0
' Y, Y @% F7 {8 T3 Wpt(21)=point/pt(17),delta,-k/10,0,0& c8 s* U% T, s2 X2 t6 U0 T6 [
pt(22)=point/pt(18),delta,-k/10,0,0
# R8 o- ^* m% h; o. tpt(23)=point/pt(19),delta,-k/10,0,0
: w, t* b0 v& \; s. z: }pt(24)=point/-0.5*k,0
5 {* r: v3 L! gcr(4)=circle/pt(18),pt(17),pt(15)( C7 Q& n* a5 v4 t6 j
cr(5)=circle/pt(18),pt(19),pt(20)' ]* Y" Z6 {( k2 L$ \
cr(6)=circle/pt(22),pt(21),pt(16)$ L# C) Q' E4 T
cr(7)=circle/pt(22),pt(23),pt(24)
4 ~3 g3 c7 Y0 O4 F$ G3 u( Q$ V6 B# o ~ln(15)=line/pt(20),pt(24)
$ N! n/ A+ J" Y- W$ `" ^6 N$$旋转、倒棱
% {( S+ T1 x0 m0 A& P; Hent(6)=solrev/ln(11..13),cr(3),origin,0,0,0,atangl,360,axis,1,0,0
- x& M1 G& A, V; `blend/ent(6),radius,10
6 A8 |5 z. M3 o; j8 uent(7)=solrev/ln(14..15),cr(4..7),origin,0,0,0,atangl,360,axis,1,0,0
. U8 e$ r+ ?0 Q6 `: }3 I* Bent(8)=unite/ent(6),with,ent(7)
! Y0 L; A# M5 \9 O- s1 O&color(ent(8))=&white
1 l) q4 Y6 j" k7 {. S+ h$$修型
) G# U" ]0 m" V, l$ x* Y5 M0 eobj2(1)=solcyl/origin,-k,0,0,height,k*2,diamtr,0.3*nr,axis,1,0,0. f/ J' h9 d: F8 H
ent(9)=subtra/ent(8),with,obj2(1)
/ x* `: K- a; h. n7 I; iobj2(2)=solcyl/origin,-k,0.6*nr,0,height,2*k,diamtr,0.2*nr,axis,1,0,0. h; ` L4 A: h& S8 D* U
m=intf(3.1415926*nr/(0.4*nr))
$ f3 ?3 o# Z; ^- Vg=1
: n1 |$ L- d* @4 q/ @0 m7 \9 H( h+ ]w=3. k$ o9 a/ B" n- m
xh2:
' g2 |( n( L+ _- mifthen/g<=m-1
8 W/ p0 O2 O' ]7 s( Qmat5=matrix/yzrot,g*(360/m)
8 x. X$ q( W" Z/ hobj2(w)=transf/mat5,obj2(2): a$ ?- I! M, a! C/ R/ Y
w=w+1
; p# W# X7 L# c% F+ ?g=g+1
: w5 F/ M1 `/ Cjump/xh2:' ]+ R% d" {( D9 y0 {+ t7 G1 S/ i# E
endif
; K% R; w& `& X, U- Yent(10)=subtra/ent(9),with,obj2(2..w-1)& ~7 H0 r: D% a1 K: m
$$消隐辅助点、线+ x9 w# L* B3 c+ P5 G# z7 `
blank/pt(1..24),cr(1..7),ln(1..15),obj1(1..3)
0 v7 E) H% y- z `/ Fcancel:+ f W9 ~' I( D6 @
halt |
