######################################################################. m3 m; k& J- V: F% z" J
( t( e# s. r% w4 {" u# S H O P D O C _ P R O G R A M V I E W _ T E X T . T C L
" {2 U, s( X& ?+ Y- J! C0 Z4 [+ \( m. j3 B. G######################################################################9 `$ \: T1 c0 K" L$ S5 e; h
: Q9 U1 ~7 X. y# EVENT HANDLER SECTION $ [0 E$ c4 C2 C/ M; X- _! C: ]
8 B: R; }% Y8 a' Y$ M7 M A# This section contains the control section for creating an operation list 1 x2 I# {$ F. V$ K1 K$ j
! U F9 \! L0 ? o2 ^- l# 8 F1 J- V$ K0 j* Z# Q1 Y( k& E. s: j- k* ]4 C4 ]
# CAM will loop thru each event in the path and call the procedure
8 a4 S1 k; d" A9 v: c8 ?% Z# e+ _+ f2 j% z0 r# whose name is the name of the event.
2 L$ `* M! |6 m" v7 }8 u, Q! g" U5 G# Y9 U( h g& Y# J#
. o0 E& o" r- u+ |8 R4 }" [0 h! O- ~- @1 L' E' j, }# F7 ]/ ]- e7 ~#/ a3 d- i S9 g _1 i' m1 |6 G$ k0 p
" ]# U; G/ Q: G3 K3 X9 ^4 m' m% a. C9 R5 M#) Q6 H" w" ]* F
* p! q/ H+ b- `# v#_______________________________________________________________________________- j: t2 E2 r+ C; `. i/ g
. |# t I, ]; E1 ~8 Y# Here you should define any global variables that will be used in any one
* Z3 y$ b5 }9 n4 \0 r4 T4 @! b. A% ?' B1 f, u# of the event handler.3 T$ h9 W- y. v4 B" I! E. J
- F* C# C, ]. @% c4 @$ T7 W#_______________________________________________________________________________0 p" L" _7 t: ~+ s2 I
+ C& G7 L3 T6 p# d8 T9 I" ?7 @set mom_source_directory [MOM_ask_env_var UGII_CAM_SHOP_DOC_DIR]6 L3 o' |3 t3 p5 X6 G. j/ d: A8 w
. r- S% K9 r3 l5 h. T6 Nsource "$mom_source_directory/shopdoc_header.tcl"+ L' y; o( \$ l. `9 `. g* D. l' m/ G
set line_flag 0. u6 c' h7 h% g7 |$ e1 c- d
; W7 B: b( I, W& G: Yset template_type ""+ u) ]; M! i' ?
( m/ o) j3 G# t; a' Yset template_subtype ""4 X! Q2 T4 u) d. y0 @" s5 L/ X; i) E, X6 w* G3 W, J2 \6 n2 P
# This procedure creates a part documentation., j! x7 T* |5 r) [! K, v0 n+ @. \# I/ P+ f
#_______________________________________________________________________________1 @ Y. q9 F. r
+ ^ o" I$ H/ U P: E#==============================================================================/ U3 A+ `# Q5 X( T
/ O0 T- H* W4 Y1 \proc MOM_Start_Part_Documentation {} {9 f# ~5 Q2 v( g' ? A9 I. r/ d+ d) | l- l, R) ^
, [+ l$ |; `5 w0 l1 A9 w, t9 X# y+ D) l( c6 v& e # Calls the shopdocs header1 L8 ]# y9 H6 ^) y5 h& B- r- ^
* V, h( A# g' ~* t0 C4 k, Q3 U( ~! ` global mom_sys_output_file_suffix
& V. a* z8 ?9 T$ Y' K* b8 r# w" n) t set mom_sys_output_file_suffix "txt"/ {5 Q) ^" @% V- L0 ~
& G, R" Q6 A, N" o+ m7 W9 D# t7 d6 R- [( C
% t3 U9 J1 w0 w9 C, H9 e2 }* ^1 T Open_Files
$ Q+ {" p. g* v' X" y' B& T# z2 k. |: V. |1 ^ ShopDoc_Header_text
5 Z9 t4 v+ Y; G8 ^' V4 O9 z3 G0 b0 p# C$ g% l- w}
+ B8 ~! x2 k) ^! p9 L3 s. |3 |; q" ~' s- a#==============================================================================% F0 k3 E: [# F& a7 u, D. H+ x. Y1 H7 }2 R: I/ D
proc MOM_Part_Documentation {} {) L8 |5 \. L$ C( b
6 K- f- T5 c" y/ i( N' d#==============================================================================
; v! O# e- L2 @5 ?. }) i) [" Q. v6 f0 i MOM_do_template_file "[MOM_ask_env_var UGII_CAM_SHOP_DOC_DIR]shopdoc_programview_text.tpl"* e. G0 X2 Z1 K1 f6 |
8 X: w; c/ E) c' G6 z}
0 C! z* k, U& B* B* W! r* } _4 S#==============================================================================
# ^$ P9 ?. |8 j# a7 w: t4 S% M3 n: S/ Z$ oproc MOM_End_Part_Documentation {} {$ Z6 J/ l4 M6 U: ^1 c& L0 k# S+ d8 l; }5 m
#==============================================================================, m& r$ }" U- ?% h7 ^
- E |( N# p# W* Z1 z U} _% | I& ~' }/ r' I+ q( k, L1 s% o3 e! d; D9 K
#===============================================================================8 V7 _' ? |4 _( n' W! S7 |- e
" F) Y% y6 f, s3 {6 W3 |2 T# Setup
$ g$ t/ u" O$ l& N/ V# t0 i' ^; P) S G, o3 _& E4 {1 x: r#===============================================================================' @5 l! S4 `* @' E! d# u. q( S! B m& r9 ?0 V" n& V, ]8 F
#==============================================================================4 b( ^6 y7 G1 z N% E) Y
5 C* y1 v: v9 B6 a8 J* B% V) {proc MOM_SETUP_HDR {} {+ ~+ d* j; R: y/ h
1 Y) I# i% s& a! [& O#==============================================================================5 P. V, E) p( K: F l& P- a, B- v+ V2 w1 t6 N0 Z9 A* b' V
# Calls the setup header2 u2 X5 A/ h7 c% \; L
& u: M: G0 @2 z Setup_Header_text% e, o4 C2 N U1 e, D+ b+ Y
, d Z' f0 b6 \- P2 f7 x}* b1 `0 R/ E2 r( F
7 H7 G( ~2 [/ a- F$ A* g/ q5 y" W7 Z
}! m7 }) M5 H#============================================================================== q8 t: l& w8 c: d
+ w9 v0 C% D. t' @% G1 I- D" Gproc MOM_SETUP_BODY {} {& ~2 Z2 C- p _; o9 V: y) Z! @
* ]# K+ c z# z X3 L2 G# z' D/ R#==============================================================================8 r* Z+ ?6 R* @) A) a# b9 O4 |9 g0 v! D" m: y$ \! @1 ?
global mom_template_type% F4 ?2 ~" y8 z
& M- G! D' g8 i2 c! U5 f global mom_template_subtype- y1 n/ z t$ u: C7 Z- d1 w j
8 I$ T2 E+ c0 ?9 R MOM_output_literal " OPERATION LIST BY PROGRAM"- {# N( y) }0 z/ s- a8 Y
4 Q) d- h; k0 w W% R% K: N5 j1 P MOM_output_literal " ********* **** ** *******"
% L# j) V4 s! c6 \0 {% L$ `6 n) o/ A: K( Y' M% ^, ?: @}3 j" N& Z, z" b% r3 C0 s
! Z+ ^# d3 E1 m# @, u- U' Q6 k+ C, i- G; D8 H% `+ T2 \. q( t; b
/ O! @; Z& T# i3 x+ x#============================================================================== z8 p2 s; s- D4 ]% w1 F# u0 S; h
proc MOM_SETUP_FTR {} {7 A6 L) d" [! ^1 ^% Y/ \" U, \; e$ l
- a1 _8 S$ Q6 D8 A9 C$ u, }#==============================================================================1 ^- c4 ^- l. \6 P1 u' G6 y
( g* K; \+ G0 k" J/ Y- D% G}' a9 p; o, x' e2 O. o4 x, v9 p! v1 K' d) U i$ I
) n4 d. e# }2 O
6 B$ M; p* y+ Z9 X7 _5 ^8 h#===============================================================================
{1 [" s% N8 \% h1 _' p o8 Y, H# Operation( y! H2 N6 p, G& x) {, ~
" L7 \$ ^9 `- T) L2 K( a+ [#===============================================================================0 T0 G+ M2 @& |$ p# ~
* R3 N6 ]5 _& U# p3 z4 d' m# ?6 r% V#===============================================================================, Q2 y- z5 K" [9 U3 w) V, d! N
( `. ^7 U8 d) ^% z2 iproc MOM_OPER_BODY { } {
1 Q0 B V) J" m, k# w2 S: F. @- c' q1 Y9 N! z#===============================================================================4 K$ y0 T+ N/ s) M. q+ C1 F
& S5 y* D; d4 ?0 A5 U global mom_template_type0 \3 M ~: u6 y- o: H9 s7 N
3 K1 i$ \# Y. g global mom_template_subtype, k7 V9 y0 X% i) U z
N6 U4 |4 {5 L' ]% P3 O global template_type
# o' f! d) {$ r! D6 c+ ^' Y! {. h; a7 r f# n global template_subtype
* G* |* y- |% h- z# p$ {5 m) P: E* C1 x* p% p# y3 B9 _ global mom_operation_name& a2 W- S+ T5 W' g* i7 a: R2 C- X; q; Z) s& x/ s' m
global mom_operation_type
/ s9 O6 |4 n0 @7 p) m) i; S8 l' X% I0 c/ {- Y: _: y set template_type $mom_template_type
8 W1 _/ W) Q. A1 W3 y& Q! o6 Z. |" [! ?0 H set template_subtype $mom_template_subtype
d$ x" X. r2 [% i* n2 E5 e3 L7 ]) Y3 |1 Q J1 s$ A, f( A n# ~ if { $mom_operation_type == "Wire EDM" } \7 V, Q& v' i- k3 e( Y* p& k8 m/ A% q' i" @- L
{2 H- s: i- D: X
3 s! d5 u; [, C) Q8 z- u$ O set oper_desc "$template_type/$template_subtype"
2 f: A8 \( b- j' E% c/ D4 ]3 a4 d' }* I set output [format "%-30s %-35s %5s \n" $mom_operation_name \& e. Q2 \" Y5 u3 _" N! K& k: N2 I: I0 U4 w/ s+ O
$oper_desc "WIRE"]8 h5 I/ p. S0 v0 o4 ]( u e, U; X
1 t3 l$ O/ R8 X# \ MOM_output_literal "$output"
% }0 Z8 Q: ?6 L( ]& G$ E/ m6 r8 G4 ?7 _ }6 A" P$ {2 q8 k: _* z$ M
: @/ B* E! {4 m: x) p4 p) K}0 r: l; {# K0 _9 C
# t0 W' u! J; G5 ^#==============================================================================' X# m8 n2 l- h- _& z, A9 v( R7 Y" T; n; S. w
proc MOM_TOOL_BODY {} {9 e, M: E. g" |) Z
8 o5 c% j, z5 g' F#==============================================================================
& @3 x. o6 U+ ^$ \. [# _9 _ q* F x( `) B2 C# u3 O6 q global mom_operation_name2 S$ F% L- ^7 b# G3 h, [& z: B' Q" Q7 A; H
global mom_operation_type `* K' A, ?9 o0 e
$ f. Z# }6 C x2 i6 x global template_type- A& w+ g9 F5 E7 i: }" C) l: M
" D& H( P3 U z7 w* K global template_subtype3 E8 Y# p- G$ v. i4 o2 w/ B" z
8 |- p+ u+ V& r2 ]$ ~, b: a9 p, X9 d global mom_tool_name6 V$ N2 l5 c/ s' W7 R
3 z4 D2 k2 U+ z4 ~/ k global line_flag9 E/ O/ n1 v' Q- o
$ Y' P3 G; j1 {! g3 l( c global mom_stock_part Q0 f+ q( v% F- X+ T: `8 P9 e
; R& b$ W- @( J6 s0 W global mom_stepover_distance6 _3 i8 I1 v& E; ~- O$ a' i
7 I. x% }2 k3 x% ^% C4 h global mom_tool_length
7 m% Y( X1 [6 m/ `2 h. |: a' g4 `5 i4 b: [. K( o' S global mom_inside_outside_tolerances3 M# `1 x6 H5 c5 K; N; [
' z* c) v# ?# F4 w set oper_name "OPERATION NAME"
/ |: x& H. V; n" _$ x+ k* B. E& u0 y! H8 Y9 {9 s8 w set oper_type "OPERATION DESCRIPTION"
# a; C# f" |. X0 V( l- n: z9 y, p# S+ h$ l1 t3 s: X* a set tool_name "TOOL NAME"5 f9 t# g+ L& ^5 |+ L4 d' h, \; L
' x- ]; H) y, D0 x& D set stock_part "STOCK"! T6 o: R3 c& Z4 [
7 S' E8 K& U$ V0 J8 c- B set stepover_distance "stepover"9 i, M; _. h* T! `/ ^& x* N3 _8 O
& X6 m" p& Z3 S0 \: d; P* U4 _ set tool_length "length"2 t$ M" S. F8 Y. r- K" ~& Z' }
* B0 |! R) r7 ~, Q" G0 p set inside_outside_tolerances(0) "toll in"$ X& I: ]4 J3 M3 i Q' s
) y: U* N# j. Q" D0 B5 I set inside_outside_tolerances(1) "toll out"; o5 S3 r9 S' ?
- h4 M' K0 ?/ I; D! {
. a$ c' ^1 U& u6 Q/ U: @, _9 p+ P0 o if {!$line_flag} \2 d3 c* M5 J# W; w( t! V" Y) O3 m
. _! Q7 R; _9 z, s, R2 M {# p# O$ K2 S2 h: i) B1 K
7 d; m) S. f. H+ h) m5 g+ o$ c MOM_output_literal "-----------------------------------------------------------------------------------------------"0 N9 m5 ^5 R6 G5 \
. D7 R$ i2 `8 A# {/ a7 B: H, K set output [format "%-30s %-35s %-25s %-25s %-25s %-25s %-25s %-25s" $oper_name $oper_type $tool_name $stock_part $stepover_distance $tool_length $inside_outside_tolerances(0) $inside_outside_tolerances(1) ]
7 Q! M" }6 R- K: I( _* [3 b( v+ `$ M! x# \2 F/ I$ m7 y MOM_output_literal $output
: F Y, a z, v2 I! k. J8 x& U5 }% ?% e2 O8 A MOM_output_literal "-----------------------------------------------------------------------------------------------"" T6 I! o) f: _* m+ V
2 N u3 | D5 g R& Q7 G) T set line_flag 1" w$ c1 y, q) _% a8 J+ b, o6 r" t6 ~1 l9 {$ `5 }* i' m" C
}+ P( q3 E- ]( u* k) J4 q$ ^
/ y7 ]3 u, E3 R: A- P if { $template_type == "" && $template_subtype == ""} \
* z) }/ p% b; K$ y) M) M' j0 u! P: s! }1 F( N, l {' [- p! p9 V& `/ w
- v/ X5 C' u) u5 G% L, d& A set oper_desc "--/--": K3 F a. ~1 ^6 b; V5 ^ ~3 z' [" E1 M; t
} elseif { $template_type == "" } \
0 R7 [! t, x7 o" {/ C, V- {( [ r6 Z5 l {8 `) k. M9 M: ^
& l/ F/ Z2 L4 E- P: F2 l/ K set oper_desc "--/"* g3 z: ^) b s, n. \' U
" j* x& K, ^: Q- W `0 C7 a$ L append oper_desc $template_type0 a$ m5 K# z- L( k7 Y* e
/ U5 t4 k! f9 D; i* P } elseif { $template_subtype == ""} \) m8 M2 ^6 a6 z! ^& Y
5 C5 M" G: l; w$ P. Y t$ w/ M, s {) H4 c8 V4 A4 r
l% T& @/ C' K7 n1 } set oper_desc "$template_type/", h: v* D" H2 r8 X! @- D5 I
$ i0 d) o6 A! ^ append oper_desc "--"# f4 c; k' [9 [ \2 _& N
# b3 ^# k, B1 ^+ z } else \' M! C; S: k0 G4 G0 o, V( N
# U" I$ C; {4 V2 |6 D1 k5 v. _ {
1 Y4 |( N5 k6 z& F7 V/ i! z5 l# G1 ?$ X( o set oper_desc "$template_type/$template_subtype"1 r) n( ^5 s( a5 X5 O7 [/ b1 j
' @# Q# O! Q( G: @+ g# \ }
& t: L% H }4 ] }& L* f( V* A$ O% Z set output [format "%-30s %-35s %-25s %-25s %-25s %-25s %-25s %-25s\n" $mom_operation_name \. C- n" }% k0 Y- A' Z% B
7 Q, k" M4 v5 n. a $oper_desc $mom_tool_name $mom_stock_part $mom_stepover_distance $mom_tool_length $mom_inside_outside_tolerances(0) $mom_inside_outside_tolerances(1)]( P5 [3 h1 c/ y3 [- _5 j% q$ `# r3 ?7 G) u1 l7 }; C9 h
" w$ e \3 m& p2 d3 P3 ?# |. f. P; e! m. P, R$ a3 K set template_type ""; W: O- Z% F4 ~5 ]- m0 S
# d4 ~2 n) Z% a0 O: u# a0 s, s* T set template_subtype ""/ K* ^" S" R' m) {
1 i2 e/ @) z% v6 i# r% e/ A}& R5 a3 L# R5 q6 e4 T3 V0 t* o+ C3 m5 b) m2 _9 m* D9 u
proc MOM_PROGRAMVIEW_HDR {} {; M& W n8 o3 Y5 b. n( ~9 k
" p5 F7 e% N9 L* Z( a global mom_member_nest_level& w3 O& T9 O# R$ z' t# p
) o! _/ m' Z# B! z+ I/ s$ ~: Q}6 _: |$ s4 X: M; T6 L: V
* ]7 `# H/ m( r& x! G$ ?& |" t
2 P3 \8 ~4 ~" K6 H% V3 g1 D2 ~- Z4 p5 h( _/ p" F#==============================================================================" J; o/ @( L" u1 Y' I' r
) K0 M! r& E# l: x* }proc MOM_PROGRAMVIEW_FTR {} {
8 J5 @1 @- I' Q ^' v: \$ I9 T+ m* X$ t2 v$ p#==============================================================================! {0 P7 l/ \; p5 Z! Y+ N! K3 Y& X
2 i, y' u$ t( ^6 n5 K! m% C$ c}# |8 H( a* V! Q+ q" [ k$ A' g) J: _( r! {& F8 ~
#==============================================================================6 `* v7 H: n- O; ^) _
3 A6 m$ n ]7 P( F- \proc MOM_PROGRAM_BODY {} {
) O; H1 m: w4 L, }5 M) R7 ]9 w8 c! g( e- C& @9 V/ m& f2 |7 e#==============================================================================
4 v! |) K( V( c0 v$ C& _6 B( k p+ o" N. X. a' F global mom_member_nest_level. Z8 k: G% c0 j# m% r. [4 L, l9 k' D, G7 E" ~3 r
global mom_object_name
* q/ ]$ G; _& I; f9 b3 ?% m2 w7 r2 ` Y# i* c% U0 |3 T/ H global line_flag
5 v. E: Q! @9 \1 K. q; T& \# U% L* J! {, B j$ [/ m global mom_stock_part) t- c* T& w6 r
3 [! N/ R, F8 E global mom_stepover_distance
/ V& q: O0 d! G6 R/ n3 _/ J' K4 A3 P global mom_tool_length" ?& j$ T ]. ]4 v1 T! |1 g' Q1 v. y5 m g- ?% C, ]" i, p
global mom_inside_outside_tolerances' V+ v2 z* x) H C
3 k1 ~- j% n) h' X) w4 ~ Y I, g set oper_name "OPERATION NAME"( x* ~' l2 P' I h: A8 f
9 h0 ~! \8 q( z" |: J; J set oper_type "OPERATION DESCRIPTION"& t8 I6 R$ F$ |7 X _
1 c7 ^* e) i) U2 Q( M set tool_name "TOOL NAME"! ^6 n; l, I5 @! u l- |# q4 m! v+ A
, o. k4 K( Y& T5 [2 d/ y set stock_part "STOCK"
! V7 b7 k% D" C# u! @2 E2 B8 C# H% A set stepover_distance "步距"3 f9 y) d" {+ U1 u+ ^. k* v) [- }
( k7 X y% X+ \ set tool_length "刀长"4 f1 E6 e; k7 [4 T, {6 ^0 z N) V1 Z5 O6 @
set inside_outside_tolerances(0) "内公差"/ q7 H/ k0 P% J, B) O' x7 Z" S% S1 n3 b2 {- S# B
set inside_outside_tolerances(1) "外公差", x8 @% X4 i/ c9 ~
' j+ F2 g* c. Z( T' u3 ]
B/ } r4 U+ a+ [6 I, L' }0 L' l3 c! n) S0 v if {$line_flag} \
I7 X- R3 A+ ~# H' L _) u4 d. M: j4 K0 W/ ^2 { {' A0 ?/ | L" }9 \9 ], D
# s5 C# `) Z7 p MOM_output_literal "-----------------------------------------------------------------------------------------------"
; B6 k/ e7 m: k! X! G K) i% Z: B6 e, Q2 x. i8 W+ x( w3 k; m MOM_output_literal " "1 J' ^; K% u$ g6 \/ N5 Q# c; C# U" w5 ^; |" P
set line_flag 0# z6 t* w/ A* [4 W4 d3 ]
2 L5 c0 {+ b! N+ j5 {9 N6 e* u }
( M5 W0 G4 E; [4 ?& ?8 Z% t$ z% n) ?, B set output [format "PROGRAM NAME : %-25s" $mom_object_name]6 M9 b' m, ~; I* f2 l
1 R) Q/ E. F$ Q' u6 B1 S! I MOM_output_literal "$output" m* d3 O1 Y0 U5 ~' W
) j$ ~/ o3 R1 z% _- ~ # puts the header only for the operations
0 x. Y$ {- w9 o/ `- X+ A( X6 P% G- Y+ {: \: F; I MOM_output_literal "-----------------------------------------------------------------------------------------------"% l4 z% t( j+ ?; e
" k; e, H: d) p/ p) d% j+ m8 ? set output [format "%-30s %-35s %-25s %-25s %-25s %-25s %-25s %-25s" $oper_name $oper_type $tool_name $stock_part $stepover_distance $tool_length $inside_outside_tolerances(0) $inside_outside_tolerances(1)]
3 v p* ^3 C0 s- D; e9 A$ }) E8 P- \& R9 q: @ ? MOM_output_literal $output; |4 p2 f# z: S3 ~: R* q L( d' o a
- x- F1 n$ j1 Z3 \ MOM_output_literal "-----------------------------------------------------------------------------------------------" D: n7 K. ?7 _$ D# n
5 ]% E: m' R4 `% D: t set line_flag 1, U9 S: a0 X& Q6 E3 ^) `; I, L
. z c4 T+ y: {! T! I
) d1 S0 l) [) [, }8 g1 Q4 t! g}4 T) I7 J2 r( U. [
* H# u n/ D/ n" `#==============================================================================4 ?$ J6 {0 Y4 Q& c) ?# D5 Y3 O2 t- ?6 s" C$ d! C; Q
proc MOM_MEMBERS_FTR {} {3 ~ I" G& r! G, x _
. R8 \8 a& f+ |7 u2 K3 m#==============================================================================
: P: r- c# A, n; j2 d- h" V j. j# @8 S/ Q3 ~: } global line_flag9 t5 z2 m% B, T6 U" X$ z3 o7 F- o
$ ~8 \. {7 }2 V5 s: z9 h if {$line_flag} \- n6 o2 D$ s, k- b# M: T( ^
- ~3 d4 [( o' H$ o7 s6 v# Y- u {6 \# N, {: I+ V& F2 y" B$ M
9 P L9 B/ a; m4 D0 W MOM_output_literal "-----------------------------------------------------------------------------------------------"- u0 x3 u: H8 D! A3 ]: {" {
! z' H8 A& e1 d( r- q( I6 X; v MOM_output_literal " "6 E% V8 }4 [, W D6 |2 E$ T
7 ~. ?) u' a. t8 d3 B set line_flag 0& u/ a0 d* `. e K6 X+ m. {, y1 `6 U" u, a7 \( P T1 \# T% s8 T
}" T$ k( z3 X: T6 _7 H) l
7 U+ q8 Y3 ~3 _0 ^, i}% N7 C3 x, J+ L6 b9 \7 O
' }6 k& K% g9 q$ S/ ~9 ~; }3 L
# b* s8 N P7 I" ~% A o, d1 |1 z, k#==============================================================================6 p8 H9 Y" @% Z8 b0 ~
# a5 a& k2 N! K/ E1 W8 }5 @proc MOM_MEMBERS_HRD {} {- m3 q0 Y! ^* R7 q5 R- o
5 G$ B2 i# E" {. X8 R#==============================================================================) m) T: T# f* a& a# e: n
* r8 C% |. }* X+ i+ f( I} |
