查看: 1267|回复: 1
[疑难] 哪们兄台指点一下这段代码
发表于 2013-6-7 12:06 | 显示全部楼层 |阅读模式
怎么写才能隐藏它们相同体积的实体,谢谢!!
! m1 l" ]) E5 V0 d( Q' F
 楼主| 发表于 2013-6-7 12:07 | 显示全部楼层
   ENTITY /body,obj(1000)
: s% x9 F4 C* S( ]! Y4 }    NUMBER /n(42),r(42),density,d,dd) z0 y$ U' M# j& ~! o! J! V
% e1 h: w# [1 h- S
density=1
6 {0 L5 c; J; s/ P% b, o' W" X' T. U! y
l10:4 h* r0 M, k) m0 ^. ]" Y# Q
   mask/70+ `/ C* z) C& c8 E3 ^
   ident/'选择实体',body,resp
; E5 A/ p; h& b( {; y/ A   jump /l10:,end:,,,resp
9 o# r3 W+ q  Z/ ~% b% A0 g9 E   &sdens(body)=density
1 b1 t7 ~( b7 m6 |8 }# Y   anlsis/solid,body,gcm,n' Y+ p: C% h) h: W
   d=n(3)*1000
( d3 Z* V; y- B1 T' O- O; V3 q7 ]- O$ z( t   $$messg/'该物体的重量为'+fstr(d)+'克'  ^2 _, R; \& f# c  u; d; ]0 v
$ _7 E: U! X+ i, @1 D
: _$ E1 [- E+ n. d7 n9 ol20:
7 B" ~! x' O6 F+ ?$ Y1 Q   mask/70
+ W, I5 F* @( ]4 C  k. A1 Z3 k! s   ident/'选择实体',obj,cnt,u,resp- m. R$ Y, e4 f* V5 |
   jump /l10:,end:,,,resp1 T" p  n1 o1 @! T0 ^( m$ B7 \+ i
# j1 a2 |4 u/ ?, ]* `
l30:
# O. ^7 A/ U  _& J   do/l40:,i,1,u
6 F, ]- S$ j! |. l1 Q1 ~* g   &sdens(obj(i))=density
: h4 x5 p' Q. y+ N$ Z8 W   anlsis/solid,obj(i),gcm,r
2 O$ K8 N! {4 f- E) L   dd=r(3)*1000
# j, @* ^# M/ {7 B6 G. B   print/'该物体的重量为'+fstr(dd)+'克'
4 Q- s6 e: }+ ]! R; X0 I+ B7 _l40:
/ A( X- m! q' E% S/ K/ K( _7 xl50:' ?' ?9 j+ y5 r+ _. ?/ i
   do/l60:,v,1,u
3 M2 E) }' A5 e' Z5 F& U   ifthen/dd==d
1 l3 Z0 w( E5 L. p! J% y1 K; ^, f   blank/obj(v): V% `2 H) g$ S- p' h
     else
" j. H% O  y# m( X" W; p3 x   jump /l50:
: E1 `, [; I$ k' W% Z: F0 u     endif
, k  W+ H5 a$ H; m0 |3 E& nl60:5 {7 \, X; T7 Z5 i3 u
( i& Q; u* C+ e( {6 U# {
3 j4 w, k6 n$ w3 d" L  B- \$ [# p" L  Z! F
& f7 b3 y& ~, p5 o( Y9 \
end:  $$ 跳到此处结束
' ]- t( `4 D! D     HALT
GMT+8, 2025-6-7 19:18 , Processed in 0.053017 second(s), 23 queries .
