查看: 2534|回复: 3
求大侠写一个注册表或者批处理(bat)加UG环境变量
发表于 2013-6-20 02:10 | 显示全部楼层 |阅读模式
KASA_DIR=D:\Kasa. [) s& y4 e0 R
ugII_SITE_DIR=D:\Kasa9 s0 i( \" ]1 k
UGII_CAM_POST_DIR=D:\Kasa\Postprocessor\; w+ d3 U  m1 w5 F, W. R/ a9 f
UGII_CAM_POST_OUTPUT_DIR=E:\NC
1 _8 E4 [/ b2 ?  L2 A7 ?UGII_CHARACTER_FONT_DIR=D:\Kasa\ugfonts- k) O3 ]6 B( d% o* A/ L1 O
UGII_DMX_NX502=1- B. N2 M6 Z: n, v; o& X$ O
UGII_ENABLE_TRANSFORM_LEGACY_OPTIONS=1
* m6 _! m; p' r2 I" r
) o' h( W; h5 e) m- B! U自己写的加进去了,无效,不知道怎么回事。
! s/ U- R* V1 I
发表于 2013-6-22 09:20 | 显示全部楼层
好简单的啊。
回复 支持 1 反对 0
发表于 2013-6-22 15:13 | 显示全部楼层
给你个批处理文件参考一下,其实很简单
: g& H2 z6 E' E- N1 V' S@echo off
/ |" \& r. z6 qset UGII_LANG=Simpl_chinese0 ^1 R3 Y0 L5 G7 W
set UGII_CAM_POST_OUTPUT_DIR=D:\NC\
* V* L/ A# c9 q% Iset UGII_SYMBOL_LIBRARY_DIR=D:\***\symbol\
) H' I! b9 q% N8 y0 F0 O5 Jset UGII_CHARACTER_FONT_DIR=D:\***\ugfonts\; r+ K! [- }& ~! _% |8 f
set UGII_CAM_POST_DIR=D:\***\postprocessor\
4 W# i% p+ `$ u* I, h# lset UGII_CAM_TEMPLATE_SET_DIR=D:\***\template_set\
- i% o* B" b2 Gset UGII_LOCAL_USER_DEFAULTS=D:\***\setup\nx4_user.dpv8 b% P3 J8 x& |
set UGII_USER_DIR=D:\***\
9 A7 q9 _* E3 Q) j& x" [; Dset UGII_CUSTOM_DIRECTORY_FILE=D:\***\setup\custom_dirs.dat9 Y# c* i$ t* t
copy/y "d:\ju_conf\application\elec_draw_a_48.dll" "d:\ju_conf\application\elec_draw_a.dll": _4 c+ V! @; F1 i& ~/ @, t
copy/y "d:\ju_conf\application\elec_draw_48.dll" "d:\ju_conf\application\elec_draw.dll"3 _* [: p5 }; N9 Y# m0 z! [3 a- F
copy/y "d:\ju_conf\application\elec_draw3_48.dll" "d:\ju_conf\application\elec_draw3.dll"
7 u* n6 I# X6 O9 y0 o* }- Ncopy/y "d:\ju_conf\application\elec_draw5_48.dll" "d:\ju_conf\application\elec_draw5.dll"; F& ^$ v$ z" T$ n( _
copy/y "d:\ju_conf\application\elec_draw15_48.dll" "d:\ju_conf\application\elec_draw15.dll"% O3 t0 @* L% g- y6 T2 q4 O
copy/y "d:\ju_conf\application\post_prog_act_48.dll" "d:\ju_conf\application\post_prog_act.dll"3 [' C$ |( J2 Z3 Q- N! v
copy/y "d:\ju_conf\application\post_prog_select_48.dll" "d:\ju_conf\application\post_prog_select.dll"8 V: z, A8 U3 F6 R3 o& d4 {
copy/y "d:\ju_conf\application\post_prog_48.dll" "d:\ju_conf\application\post_prog.dll"3 j! d' ^: C8 p' Z, Q
copy/y "d:\***\startup\***_nx4" "D:\***\startup\***.tbr"
1 ]" @) W% h, f. P4 istart "Title" "D:\***\setup\NX 4.0.lnk" %*
2 E3 h  r8 [3 R. p, e; T+ \exit. D/ k- G$ V: C1 G" _" H
 楼主| 发表于 2013-6-22 15:30 | 显示全部楼层
xhujun2 发表于 2013-6-22 15:13 + S1 R7 M. _- f
给你个批处理文件参考一下,其实很简单- ]7 G$ M% ^$ l$ H, L) L) @
@echo off
' W. n2 M, w8 ?; ?+ H+ Q8 |4 Oset UGII_LANG=Simpl_chinese
$ x5 ^) L" T' H& H谢谢你,看到你的头像很熟悉。真心谢谢,我去试试看。
GMT+8, 2025-5-16 20:53 , Processed in 0.098432 second(s), 21 queries .
