查看: 2555|回复: 2
[疑难] 哪位高手帮我看看我这程序,我的这个怎么画不出图来呢
发表于 2008-5-25 10:02 | 显示全部楼层 |阅读模式
#include <stdio.h> 5 d+ E- z2 ^( v
#include <uf.h>' m1 }1 _: k: F5 c. v" S- T) y
#include <uf_defs.h>* {2 q# q5 y( R5 x5 ?- {  l  X
#include <uf_exit.h>
0 t9 J! g( y" P% d. t& u) X#include <uf_ui.h>) Y4 h. G! }( i* |3 E: Z
#include <uf_styler.h>
$ O! F" a7 y$ f2 ?" h#include <uf_mb.h> : _% P. z: Z& c" y  _  V
#include <C:\Documents and Settings\Administrator\My Documents\bsurface\新建文件夹\bsurface\bsurface.h>
5 W% ?" a' e9 G: ~& W) j; `
7 l. N1 A; O  \. T#include <stdlib.h>//后加
& l2 H, o2 ?; k# v  U8 N* S: w8 `  H9 m#include <uf_part.h>
. |$ T" d3 a+ L- ]1 J# H. H( o#include <uf_defs.h>+ u; e2 {  e8 U% L- @8 S
#include <uf_modl.h>
/ H" _1 P' H3 h: a6 k: c- {& R2 X# w7 J3 o7 _
#define UF_CALL  u" e0 I$ B4 m2 R. R
#define BSURFACE_CB_COUNT ( 4 + 1 ) /* Add 1 for the terminator */' L5 u, f& o7 o$ q. |
static UF_STYLER_callback_info_t BSURFACE_cbs[BSURFACE_CB_COUNT] =
! P: \7 a& S% t; [1 d) }# Q% g{
! S) B- B$ ?- v. |5 N8 L7 ^ {UF_STYLER_DIALOG_INDEX, UF_STYLER_CONSTRUCTOR_CB  , 0, BSURFACE_constructor_cb},5 v) {0 d7 h7 g  L
{UF_STYLER_DIALOG_INDEX, UF_STYLER_DESTRUCTOR_CB   , 0, BSURFACE_destructor_cb},
+ a. B" N2 u8 B9 n- b* N {UF_STYLER_DIALOG_INDEX, UF_STYLER_OK_CB           , 0, BSURFACE_ok_cb},& ^( a) s+ v* S' f8 W
{UF_STYLER_DIALOG_INDEX, UF_STYLER_CANCEL_CB       , 0, BSURFACE_cancle_cb},
5 D& h! y' H7 ^2 f1 e* C4 M4 J {UF_STYLER_NULL_OBJECT, UF_STYLER_NO_CB, 0, 0 }
: c. H, H# d: _4 `};: @$ \& X! a8 {1 M9 }
+ s  b4 [  h- d
static UF_MB_styler_actions_t actions[] = {  H& M- t. ~, Q! u
    { "bsurface.dlg",  NULL,   BSURFACE_cbs,  UF_MB_STYLER_IS_NOT_TOP },
/ a! ?' ?" [8 P3 B" ~    { NULL,  NULL,  NULL,  0 } /* This is a NULL terminated list */( u, P! q$ V- N! n1 n! H
7 J5 R/ s2 K  K9 f$ @3 d
: W2 W; {) o& s4 K' |; d" Kstatic void do_ugopen_api(void)
7 e1 ?/ o9 z* g. V4 W( d{! X1 I" `  m$ R# b1 O  c6 \
% g/ {5 w3 j: W$ s4 x6 k7 P
  char    *prtnam = "create_bsurf"; ; R/ I& _0 b; h+ @% t  J
2 M2 a' e+ d, k9 U  /* Points for B-surface  */+ `- ~  S/ g6 i
  double points[16][3] = { X1, Y1, Z1,4 ~" N! ^5 x. d. g
                                       X2, Y2, Z2,
+ w/ N9 N; m( o* H" i! T                                       X3, Y3, Z3,7 e& E; w' o  J( V$ j0 p5 ^
                                       X4, Y4, Z4,
% Y. f' ?1 x: N& C/ b; S8 Y                                       X5, Y5, Z5,
* z: p5 [% B7 s+ \% M* C$ Z                                       X6, Y6, Z6,
/ b* O+ n" E- k9 i                                       X7, Y7, Z7,8 Q2 f- C+ B, Y! E& [! |" H4 i
                                       X8, Y8, Z8,7 d; r) w4 \8 x, E1 J; |
                                       X9, Y9, Z9,
- M, `  V1 b7 D1 |                                       X10, Y10, Z10,9 \) c& i9 H; j( s) f
                                       X11, Y11, Z11,1 q  n) T  C8 E) b& @2 ]7 w' o9 i% r1 T
                                       X12, Y12, Z12,
+ T* M2 p. w1 _                                       X13, Y13, Z13,
& F3 E. K: R& H. h' [. R3 ^, ^5 p                                       X14, Y14, Z14,% j6 r/ X2 i) |1 }4 Z! g
                                       X15, Y15, Z15,9 U1 S4 [/ W* ~+ z  D: H
                                       X16, Y16, Z16 };          X8 T( Z% Q+ ?; R6 w7 ]8 @/ K
2 }0 Z) }" N; o2 \4 q$ R' w: g  int create_mode = 1;, }- I; b; L  d% h/ R8 u
  int u_closed_status = 0;3 O! S. L  i9 h7 [3 x
  int v_closed_status = 0;
6 z! ]2 [4 Q1 t) W  int u_degree = 3;
( r& |) j- ?+ r7 c/ s: g  int v_degree = 3;. [9 N% U. K  R3 S8 D6 U8 P. C
  int num_rows = 4;
( O+ f$ V, V' v. X/ a4 t5 t  int pts_per_row[4] = {4, 4, 4, 4};
5 n- Y" U5 F& w+ o8 q$ [8 r9 O. a' G" o' v    7 K$ {# H2 `& m( n
  int ii, jj, kk, indx;
. e' e, R- d. u5 p        ; l! J* `2 K' A  B- `
  tag_t   part_tag;6 j" r; U. ^+ b# a
  tag_t   bsurf_obj_id = NULL_TAG;
* L8 ^9 Y# L* k% ]9 F# Q2 X% n2 X
  [+ W: M" [% i: [, P  UF_MODL_bsurf_row_info_t *pts_info_per_row; /* pts info for each row */
" q: \$ \/ l; W' R/ b  UF_MODL_bsurface_t   bsurf;
/ ^3 K! b/ ~1 ]: X) `% u) [
' [) ~! V9 B: l- r4 s
# R% n, ]; h" v8 K3 r  /* Open a new part */& w% J  V, u+ @. q
  UF_CALL( UF_PART_new(prtnam, METRIC, &part_tag) );4 ?$ G! W$ s' ]& ^
/ V# q6 ^8 ]+ S( r# k# X4 Y
  pts_info_per_row = ( UF_MODL_bsurf_row_info_t *)malloc( num_rows *+ I% B0 |. b& x
                       sizeof(UF_MODL_bsurf_row_info_t) );( m- _0 Z, {; [6 U
   ; n1 s. M* Q# q4 K. U, A0 }) e; a# Z
  /* allocate and load point and other information for each row of points */: o$ w' o) K# J, s% c! W' R
  indx = 0;4 m6 u5 Y' L/ R
  for (ii=0; ii<num_rows; ii++)) s4 f. d$ q7 k7 Q4 M
& r5 \7 g6 d1 P0 e/ X' S( }    pts_info_per_row[ii].num_points = pts_per_row[ii];  /* can vary */
' Q# E% T/ d' F: _% I    pts_info_per_row[ii].points = (double *)malloc( pts_per_row[ii] * 3 *
% u0 W8 X2 \. m" ~3 P# B4 E2 d                                   sizeof(double) );
& @! s3 w/ g! t. t. }/ @' C1 W6 V& e. U
$ r1 q- ^9 D5 u3 B' q! h    pts_info_per_row[ii].weight = (double *)malloc( pts_per_row[ii] *
8 u) |. C6 x" p2 m! |5 p                                   sizeof(double) );
" m7 [$ G& ^$ P' _; I) z# J; k
/ Q( n9 Y9 k) f0 s% N$ Q9 B( Y    /* load up point and weight info */( ?0 z1 d( s/ \
    for (jj=0, kk = 0; kk<pts_per_row[ii]; kk++, jj+=3, indx++)  ~. B, M2 ?' f  w2 C, F" x: J, f
+ ?* l$ V, Y, c' g9 W. Q& k      pts_info_per_row[ii].points[jj] = points[indx][0];6 _3 G5 ?8 k8 F; N
      pts_info_per_row[ii].points[jj+1] = points[indx][1];$ D& }; p2 _  N$ f) Y* B
      pts_info_per_row[ii].points[jj+2] = points[indx][2];8 c; L+ X6 U8 O' i# w$ f. T
      pts_info_per_row[ii].weight[kk] = 1.0;
3 P* C5 G6 i2 [7 G, h% ~5 w4 I    . }! J% u3 o3 _  @9 u& f% \! z
    }- ]0 U* q5 X0 M: q  w
, P7 j2 o& G2 D5 X9 b0 c! b  2 x! S: R% \& k) v
  /* create B-surface */( L, [0 B: e7 d2 I: X! o! ^" _
  UF_CALL(UF_MODL_create_bsurf_thru_pts( create_mode, u_closed_status, $ f7 `# h4 _6 g* N2 @& p  r
                                         v_closed_status, u_degree,
% p) h0 s- K$ m' I) _                                         v_degree, num_rows, pts_info_per_row,5 ~- X! r5 Z" X/ b& H! J' y  C1 c! g
                                         &bsurf_obj_id));% ]' w5 j+ H) z% p# g+ H2 s
                   . N3 f0 D5 n0 g: Q. C. [
  if ( bsurf_obj_id == NULL_TAG ), A* l6 w* n* `* L
    printf("*** ERROR CREATING B-SURFACE ***\n");
$ J) E1 [) o8 U9 S1 J  P- m: v# m6 P( F7 k
  /* free allocated memory */
) e+ d' s$ B2 Q# ?  for (ii=0; ii<num_rows; ii++)
3 B7 A8 _9 O2 \7 ~# a3 N' d4 ?  {% Q6 B9 u/ g9 w6 w6 T- [  C( d
    free(pts_info_per_row[ii].points);% d1 |8 b) B8 Z) J* s
    free(pts_info_per_row[ii].weight);
, M% [# P2 D7 A& n# N' d1 ?; c  }# c. p$ h+ b- P( |7 D2 I, t
" c+ V( D  z' w/ S$ B4 o; r1 W  free(pts_info_per_row);
, W9 i; ?4 E/ e    ( x5 E- c/ q( q7 n. ~  U
    - M0 K' R5 f$ c0 L5 v+ D* E
  /* ask the B-surface information */7 q3 ]) t: H" p, i  t' i0 h
  UF_CALL(UF_MODL_ask_bsurf( bsurf_obj_id, &bsurf ));, F; ^/ @: Y9 I7 n3 P. U6 Y
; ^- ]* g1 M# ^% \4 H  /* validate the surface *// a' O6 ?2 A, n& |
  if ( (bsurf.order_u != u_degree+1) || (bsurf.order_v != v_degree+1) )& Y! k- V8 X& k$ a( m! v* f
    printf("*** ERROR ASKING B-SURFACE ***\n");
' d' Q4 K& ?- I/ r
3 ~  d  T* v. }! ]- m  UF_CALL(UF_MODL_free_bsurf_data(&bsurf));; [2 S+ A$ E& q, p8 ]  ?
& ~0 S, W! R) L( a" S9 h
, {% R& m, ^  [2 y7 P* M# H6 |& Q# h}
- r/ [' M* \$ j, s$ M! Fextern DllExport void ufsta (char *param, int *retcode, int rlen)5 Q% t0 O+ B! R2 {, h, {
* t! @. j2 p# q. i, k* s    int  error_code;& c2 q0 v$ Q' n& J5 I
8 H/ ~/ X/ n3 k2 ?% \' W4 p
    if ( (UF_initialize()) != 0)
: [, D; S' P8 x$ R% t! `, u        do_UGopen_api();
! O$ E; |. w! U7 W0 m                return;) F/ k  _# G  P  b2 C: e5 r
6 r* b) M4 j8 G4 H6 V7 ]    if ( (error_code = UF_MB_add_styler_actions ( actions ) ) != 0 )
. K! G' q; ~4 E" A7 P; o7 N    {5 ~- m$ u5 a- z% e( l# u4 {
          char fail_message[133];# }6 T; t$ P! E0 A, I$ ~/ L
            j) e# V' P5 k- k
          UF_get_fail_message(error_code, fail_message);
$ w3 ?, G9 @6 ?# y0 T          printf ( "%s\n", fail_message ); 0 w  S$ j. |4 ~0 g. k% Z: ~5 D
, q1 L: s* ]3 L                                                 / Y& T" b! Q7 _+ P( R
    UF_terminate();                             ( Q9 l  v" J! S; N- W0 ]
    return;
- K- K# _+ z, j/ C}0 ~: o% U" v, y3 F
extern int LaunchBsurfaceDialog ( int *response )- |5 D9 x7 t4 K' j' @! V( c3 `5 {( a
{8 k4 x) z* O) p2 _6 a+ Y
    int  error_code = 0;
' x( r9 a  y6 q
, Q. k1 f1 B$ m9 {8 E    if ( ( error_code = UF_initialize() ) != 0 ) 4 E! K. ~3 u9 C0 l
           return (0) ;
; r" R: h, C, E. N7 Y4 L- H1 a6 O! F$ F) u; [
    if ( ( error_code = UF_STYLER_create_dialog ( "bsurface.dlg",% ^' }  o+ n# p, k
           BSURFACE_cbs,      /* Callbacks from dialog */
7 s0 N  O* e7 y+ \7 L           BSURFACE_CB_COUNT, /* number of callbacks*/
/ r  @$ _+ ]  [  J8 z2 L4 K& t. Z8 V1 d. _           NULL,        /* This is your client data */
( \' ^, r! Z" L  R1 [( `# h           response ) ) != 0 )
- [! t0 [$ ^$ E& N  U/ v+ q    {
& m- g) e3 Y% ~! ^0 R          char fail_message[133];
6 Z: {) s1 \2 `! W& \
% Q; J; k, K4 ~2 L. E: |          /* Get the user function fail message based on the fail code.*/; w: O: N/ l- y* j& t
: {! T7 K# G' t) t          UF_UI_set_status (fail_message);
+ e( }: a* w2 U! _4 @. [          printf ( "%s\n", fail_message ); 1 H  ?( k: V# G* g  ?9 ^* o
    }: z5 x2 y# V) D4 t
1 g$ s) \& D# M8 x) Z) O
2 m& o. \- N; p8 w( a4 |& u    UF_terminate();
8 B9 P! M  ~: m6 ~    return (error_code);2 O" G- M+ F) |2 T$ f5 u6 o
. E, U" e8 ~3 ~5 I7 I7 F/ l; o  S7 V- m. V# b
extern int ufusr_ask_unload (void): J8 m! F6 E5 t2 K1 Y0 Y( S9 _
{( e  q$ L! C( n- e# q
     /* unload immediately after application exits*/
3 z7 Z' M9 P, a3 ^/ |  b6 d. w     return ( UF_UNLOAD_IMMEDIATELY );$ E/ _2 ^( i' H$ d
}( _: U% \- V: U) j6 `9 C
extern void ufusr_cleanup (void)( o+ t' C5 J  u) O4 C$ u* b& c
* `  U; T- d0 b  ?2 |5 u4 v2 ~. O    return;! S" o9 u! e. F7 H
# L0 X5 r. `6 b#endif
 楼主| 发表于 2008-5-25 10:06 | 显示全部楼层
各位帮忙啊
求高手帮忙看看那这程序急用啊
 楼主| 发表于 2008-5-25 10:35 | 显示全部楼层
少了一块
int BSURFACE_ok_cb ( int dialog_id,: ~' n% Y" C3 A; W- g  z
             void * client_data,! O) d& g# z4 Q" J% b, `* a4 n) i
             UF_STYLER_item_value_type_p_t callback_data)
, A# T. ?) I$ J1 ^4 w4 D{
5 @! K$ f3 q3 o" Q  z5 s     /* Make sure User Function is available. */
; x' W  ]7 g! ?7 C: E+ Y     if ( UF_initialize() != 0) & V. L, T0 l0 Y3 ~; H
          return ( UF_UI_CB_CONTINUE_DIALOG );
" G: @! S3 H6 V. `8 K& @0 N; t% F1 g$ X
* ]. i. j8 E/ M7 S     /*获取对话框数据*/
+ ?8 y8 R. F& [8 [; ~
& D7 c7 {3 h' {         UF_STYLER_item_value_type_t data;# n: c9 ~- @' x/ i# s' C1 M
         data.item_attr=UF_STYLER_VALUE;
' F. U% g5 h; ?/ D         6 q- O$ b0 L4 y1 u& ?; u) t6 `9 Q
         data.item_id=BSURFACE_REAL_X1;
  Z4 h# b' C) P. \: [) H         UF_STYLER_ask_value(dialog_id,&data);
( F0 T; \" U7 J6 Q: v         X1=data.value.real;
/ m- ]% M2 n! ~" _: @( C1 o- ]1 W0 `
8 k- \% y& l8 I* E; H5 p         data.item_id=BSURFACE_REAL_Y1;  r+ @9 ?, q' E5 W6 ?9 [
* y) [" }, H, d         Y1=data.value.real;
) U% [1 a/ y/ E- Y- B' e" h: Y! s
" m2 ~8 z) m6 x3 |& q     data.item_id=BSURFACE_REAL_Z1;
! [4 b& s& f  y' q, s         UF_STYLER_ask_value(dialog_id,&data);
1 n& G# s3 E3 G  z1 a         Z1=data.value.real;! n( \- Y6 G% c' u) g! S! z
         5 C, x5 q" D" x% ~, X( f
         data.item_id=BSURFACE_REAL_X2;) G* R. T6 d; C5 e
         UF_STYLER_ask_value(dialog_id,&data);3 I' K5 ?) T- [" c: Y
         X2=data.value.real;+ @% J1 k# d6 r. V1 a& v
4 O/ _$ R# O, f; M( r7 D+ P         data.item_id=BSURFACE_REAL_Y2;3 o, H+ _: a# R
$ B' T5 m& v2 {9 M, R# C         Y2=data.value.real;# m( s. u9 J  z! A  {9 z- }& `3 O
         % G/ q/ j+ U6 Q: }5 ^. G) N+ R
         data.item_id=BSURFACE_REAL_Z2;+ I7 n* H% N' ~  [' q9 j3 }+ x4 G
         UF_STYLER_ask_value(dialog_id,&data);+ p& W  r3 G+ n+ u/ z
         Z2=data.value.real;1 f2 N/ L& b- \4 w1 G4 H
3 @2 D1 v* `  Q/ x6 @- m         data.item_id=BSURFACE_REAL_X3;$ d, l8 D2 f( x3 F& j8 ^4 h/ ]% X4 S
: w. P6 ]* S, S, j) i- H9 p% S6 p         X3=data.value.real;
% X1 s0 l/ ~% i+ m9 p1 j         3 J8 \$ c: H7 M7 ~7 j
         data.item_id=BSURFACE_REAL_Y3;
# S  S$ Z3 h/ B* \) {         UF_STYLER_ask_value(dialog_id,&data);
: K1 v; l1 F, L; W& D# ]         Y3=data.value.real;
' L# C+ A; k0 x% S7 C% P! v( H           E5 O  U) v) Q' i( {: o
         data.item_id=BSURFACE_REAL_Z3;
4 ^8 n( Q" S& B; V# s         UF_STYLER_ask_value(dialog_id,&data);, h' J* R% Y8 }  Y/ V7 ~& a
         Z3=data.value.real;
. |* K1 S; [- \) u
" V) |( ^$ g" T6 M2 z  i         data.item_id=BSURFACE_REAL_X4;' ?, ^1 ^# P1 n& r4 U
         UF_STYLER_ask_value(dialog_id,&data);, x; v1 ~* G* F( a- W) G) A* z8 }6 X$ J
         X4=data.value.real;7 b: k% h9 {2 M0 T" r" H/ I9 y
7 S- L1 y" Y5 l) T9 b% F
         data.item_id=BSURFACE_REAL_Y4;
! G8 L4 e& q5 w3 E( c         UF_STYLER_ask_value(dialog_id,&data);
& P. J5 G* G, j4 e4 m+ U         Y4=data.value.real;
9 U/ A5 T1 V" f5 {' I1 ]
  I/ A+ z! V+ j2 K5 Z; k/ k) D         data.item_id=BSURFACE_REAL_Z4;
* _( C4 C0 W  J         UF_STYLER_ask_value(dialog_id,&data);
2 X- m" T2 w4 ]         Z4=data.value.real;
: J& }  q) |0 a# w- i9 J4 j, ^         3 T6 r& D) a% [# M
         data.item_id=BSURFACE_REAL_X5;' B$ y. z/ O1 V0 m
9 W" g$ k+ `1 L' w         X5=data.value.real;
- v( ]) z9 G, r" B
0 }  @, B9 m* C, L0 b2 k2 ~         data.item_id=BSURFACE_REAL_Y5;
6 y6 Y& K7 _/ z         UF_STYLER_ask_value(dialog_id,&data);
% e1 ?5 D; n- ^0 {* b8 i1 U         Y5=data.value.real;# w$ d, i' s3 O3 E
- F, ?8 D' y% O         data.item_id=BSURFACE_REAL_Z5;
* k; _/ w# w$ A' O         UF_STYLER_ask_value(dialog_id,&data);
" j! E' J+ j1 K: L; m. S         Z5=data.value.real;% e3 O1 d  o- b5 W
         ) ^5 o  n0 X! [$ \$ q% w6 c  v& k
         data.item_id=BSURFACE_REAL_X6;
" r) Q6 k; `* {: Z; F         UF_STYLER_ask_value(dialog_id,&data);# w  m8 S) A! m' o+ u# F- ~
         X6=data.value.real;
7 g4 T+ N$ \, |+ q8 z- I
6 F9 j' B3 M! }: C% L4 I9 B' r         data.item_id=BSURFACE_REAL_Y6;' J9 x* v! F# w
2 L. L  o* Y& ]" S9 t         Y6=data.value.real;. W. L, T3 I6 H% }6 q+ p
0 Y' H/ k$ i) f  O* b9 F         data.item_id=BSURFACE_REAL_Z6;6 w# u( x2 t! E
, f. b8 \+ Q% ~: s         Z6=data.value.real;1 J1 }, Z. D4 f- K; w; B
         9 s& p. e* ~  B% Z% x  P  w$ L+ Z$ R
         data.item_id=BSURFACE_REAL_X7;
$ o! B+ ?8 N$ e% B2 m8 q5 e& J7 @         UF_STYLER_ask_value(dialog_id,&data);' i9 I/ }- w5 H: G! k- A
         X7=data.value.real;
$ k) l* p  e7 m2 J. H
& p, D7 y" h& ?! t" s$ M$ n& U2 @- A         data.item_id=BSURFACE_REAL_Y7;
! b+ @  @3 U* z% o3 q, L: }$ |         UF_STYLER_ask_value(dialog_id,&data);) ^5 Z) x6 l0 _8 Q7 e
         Y7=data.value.real;
! |* m8 l  Q7 M& P
) K4 q" P4 q3 q         data.item_id=BSURFACE_REAL_Z7;2 ]' W  O6 H" w
         UF_STYLER_ask_value(dialog_id,&data);1 ?# a7 C" @( E) B# [5 w6 |3 W/ Z0 z/ E
         Z7=data.value.real;
, m& x* |& q! h3 P* m7 U+ M8 f- s3 V         ' x% }  R# r, ~, d! i  m
         data.item_id=BSURFACE_REAL_X8;
6 c9 s# a! o2 i) E5 g         UF_STYLER_ask_value(dialog_id,&data);
+ |0 v+ m" I) i1 P         X8=data.value.real;
4 H, N7 J$ M( h; R" u         ! Z* S7 X' {! @8 M
         data.item_id=BSURFACE_REAL_Y8;
6 j" L8 V* y% L! \0 Z6 }         UF_STYLER_ask_value(dialog_id,&data);& E& K% q0 I: f
         Y8=data.value.real;! e! S* i9 H8 R
         / W4 a1 [- O7 s) N2 d
         data.item_id=BSURFACE_REAL_Z8;2 J* M* M$ h9 ]' e% A
         UF_STYLER_ask_value(dialog_id,&data);' t0 x5 f) u) n- R  K# H* R
         Z8=data.value.real;
* o% ^% q* [- b! ?! b$ c% A
$ i) @0 T) C2 I         data.item_id=BSURFACE_REAL_X9;
! s) w+ y9 r4 C) |         UF_STYLER_ask_value(dialog_id,&data);
6 i: [- m5 _6 ~# O/ Y; ^9 v         X9=data.value.real;
$ Z% {! p5 V1 v7 H  x         : R7 t1 I- J, |& [! |2 ~$ n6 {2 a& \
         data.item_id=BSURFACE_REAL_Y9;
4 k1 I* S2 y. n3 u& P* ~/ |         UF_STYLER_ask_value(dialog_id,&data);- |: |9 I) M3 {( F4 ]
         Y9=data.value.real;& J5 v  R1 h9 t' B) g
         5 h* ^. R: U, \  s+ S8 ?
         data.item_id=BSURFACE_REAL_Z9;* S/ D& p6 F+ t* |: V! M; {
0 C- Y+ N9 f7 S+ _         Z9=data.value.real;
5 d5 n  T- k/ Y  t+ {! s2 z$ e         : [) H: z, A/ [8 H
         data.item_id=BSURFACE_REAL_X10;
$ d) ]( I7 R6 j9 J5 V         UF_STYLER_ask_value(dialog_id,&data);
9 e+ S' P' M: r4 ], g* L0 h         X10=data.value.real;! O- z! ?# `& o- N7 }6 q
: s5 B, R8 I, X3 ?1 f         data.item_id=BSURFACE_REAL_Y10;
4 c: w$ l& S, C3 s, o         UF_STYLER_ask_value(dialog_id,&data);( G3 f: e5 U' n! I# n6 P  M4 x
         Y10=data.value.real;+ E* I# I  g6 s$ G, h2 l  o
         # s2 g8 l+ w$ P2 x2 N& |2 {
         data.item_id=BSURFACE_REAL_Z10;( T9 A+ ]" I( B: R  E: o4 y. r. r
         UF_STYLER_ask_value(dialog_id,&data);0 O+ O) {: l% E; s0 S' V- P
         Z10=data.value.real;
2 ?5 C+ B9 ?3 f/ U: f$ F4 w6 N
" ^, m8 z' J4 s. o; l         data.item_id=BSURFACE_REAL_X11;, m! e# f- c5 x; w' _
         UF_STYLER_ask_value(dialog_id,&data);" y, E5 y7 J4 d( E
         X11=data.value.real;
8 [7 Y# f- I+ K/ r: d) V
+ D0 c* d: @2 c4 h( v! F& O3 b2 H+ o         data.item_id=BSURFACE_REAL_Y11;% ?5 ~0 V5 h: f. L$ K1 A) T
         UF_STYLER_ask_value(dialog_id,&data);. @3 T: {" Z8 Y/ D+ ]
         Y11=data.value.real;
# _6 j2 m) ?6 `8 c: `6 w' l% H% e7 b" f         $ V. `, v5 z$ g, ?
         data.item_id=BSURFACE_REAL_Z11;
  K( U6 X' W- i+ \6 b         UF_STYLER_ask_value(dialog_id,&data);: e; P( Z' A4 g
         Z11=data.value.real;
$ |, U8 z, C) S% _( m/ Q
) }3 j: a6 F& d         data.item_id=BSURFACE_REAL_X12;
; Q$ t! G* O5 w; W+ u" U/ ^7 u9 B: f         UF_STYLER_ask_value(dialog_id,&data);
4 [- o, @! I- D. b         X12=data.value.real;# G3 W( _4 G; W( t
" A: s2 P0 {3 N- T* t         data.item_id=BSURFACE_REAL_Y12;
3 x( b( z; [# m5 N3 `5 X6 c% C         UF_STYLER_ask_value(dialog_id,&data);
$ e$ G. ~" t! Q8 `5 p         Y12=data.value.real;
5 Z, y; k/ [8 g* |& l4 x3 P! X) l7 V         + r6 R# ?' E# E/ y
         data.item_id=BSURFACE_REAL_Z12;0 I! J/ L- a. p% t# k
$ g3 {8 l, A8 t1 I) l( ^5 L9 x3 b         Z12=data.value.real;
: A' v2 s4 a2 K7 S# n1 H
# B- Q6 S" y! h- U8 X2 A" A         data.item_id=BSURFACE_REAL_X13;
% C: \. Y2 A. ?" a         UF_STYLER_ask_value(dialog_id,&data);* D; c2 s, F2 J! w! C9 U( N! x: d
         X13=data.value.real;
: x2 A0 b9 Z+ T" R9 o7 A0 n         0 P8 ?+ j7 o$ ^9 b, f
         data.item_id=BSURFACE_REAL_Y13;
; c9 }: }( j) o) L         UF_STYLER_ask_value(dialog_id,&data);" X6 U( X( L+ i7 r8 k
         Y13=data.value.real;+ k' ^. x2 u& q. f6 G& ^
3 M$ z; {8 l, n. n# c" A% v
     data.item_id=BSURFACE_REAL_Z13;" _$ L. |  C( ~9 C7 M0 F4 ]+ w
         UF_STYLER_ask_value(dialog_id,&data);5 H( x, T) @  \1 d) R+ V1 E; ~
         Z13=data.value.real;
4 }* \4 }/ Z" H7 ]# I+ M& _- e, m: V  y3 B  a( _
         data.item_id=BSURFACE_REAL_X14;
5 b5 j( s( i3 k9 B" c         UF_STYLER_ask_value(dialog_id,&data);4 i3 L# {+ @" E. H; V
         X14=data.value.real;
; Z6 {+ R& W- |; j2 v! G
5 A# t" D& }; o, ~# s' J         data.item_id=BSURFACE_REAL_Y14;
4 H+ T- b  a* n9 h* {) e         UF_STYLER_ask_value(dialog_id,&data);: r6 A6 d4 c0 w! N* m7 t' b
         Y14=data.value.real;' H# T# G4 n) n$ O' D7 J
" ?3 X; I7 u2 D7 \9 [0 a
     data.item_id=BSURFACE_REAL_Z14;( c8 ^  ^  d; Q
; k) \6 ~1 L+ r         Z14=data.value.real;& ~" ^- V, l" a4 b4 W9 {% P: H/ }
0 O* P: B5 S) V; {         data.item_id=BSURFACE_REAL_X15;
# c' t. m7 G3 Z8 V# A         UF_STYLER_ask_value(dialog_id,&data);
: `# i! N9 U) B% D! f9 M         X15=data.value.real;! n6 R0 P& d3 h: D, n6 V- }
         & s: ?7 M" k9 X
         data.item_id=BSURFACE_REAL_Y15;
) Y$ L5 b1 _. d/ s6 @# g         UF_STYLER_ask_value(dialog_id,&data);
/ l! m2 m! E: S5 e. k7 i         Y15=data.value.real;
+ a; V) G3 m* y+ r: ]) F4 M' u! ]% b
     data.item_id=BSURFACE_REAL_Z15;
; C) R, {; G5 y" ~4 X         UF_STYLER_ask_value(dialog_id,&data);
2 l9 i0 T. `7 ?5 Q/ d0 `/ L$ z         Z15=data.value.real;
" C/ p& a; r0 r0 c" i6 H+ u
9 D0 }1 P# Z5 C' E( g0 k* y         data.item_id=BSURFACE_REAL_X16;
9 F& N* f+ w: k1 O8 g         UF_STYLER_ask_value(dialog_id,&data);* Q+ t+ ?" g9 x% A! @. j/ j* t7 @
         X16=data.value.real;
* O- F9 \6 g7 ]: B+ A% k2 u1 B
8 [& S9 x, d( I: o! F/ C         data.item_id=BSURFACE_REAL_Y16;
. S; g- |9 i9 I3 h         UF_STYLER_ask_value(dialog_id,&data);
' q6 [  f. G) g         Y16=data.value.real;4 o! N3 O! D. ~- }. P. D! ~: \
+ u3 o: P. l% W( x0 D1 w     data.item_id=BSURFACE_REAL_Z16;
2 {  h9 G4 F. _% f2 Y* x. _         UF_STYLER_ask_value(dialog_id,&data);
4 d5 U+ ?: y) r         Z16=data.value.real;
9 ]9 T$ h( Y& J. k: ~& C
1 N' K* L5 `- F9 c) S     UF_terminate ();: g# c. d+ c: ~. a+ }
$ X6 m1 B* ]+ c4 r. ]    /* Callback acknowledged, terminate dialog             */
1 q; ^3 ^, H. W6 \    /* It is STRONGLY recommended that you exit your       */0 M( |& S- }4 [% [2 \
    /* callback with UF_UI_CB_EXIT_DIALOG in a ok callback.*/' |: t9 s# u+ X7 F( C: u4 R8 Y
    /* return ( UF_UI_CB_EXIT_DIALOG );                    */
5 W5 n! a  G9 H) r3 `6 v! \    return (UF_UI_CB_EXIT_DIALOG);
' u" s, |$ S) F* K
0 ^9 \" A$ i! x  A6 P5 [}
4 _% o0 O& M3 Oextern int LaunchBsurfaceDialog ( int *response ); Y+ Q# Y& H( R; p7 `) A2 [
{0 H! t" _5 P* s$ L6 n# ^7 r5 @
    int  error_code = 0;+ D% Y4 G! _7 p) N$ j7 ?
1 K* g& l& b1 D" }    if ( ( error_code = UF_initialize() ) != 0 )
. S9 p) Q. I( |% y: q( Y0 l           return (0) ;
7 P8 \, S5 d  _0 m
3 b2 u  x! s5 Y" O. u8 N    if ( ( error_code = UF_STYLER_create_dialog ( "bsurface.dlg",! o3 C" i" C% r' _, P
           BSURFACE_cbs,      /* Callbacks from dialog */# ]" |. N- h4 I( `5 C1 q
           BSURFACE_CB_COUNT, /* number of callbacks*/- y3 e% I0 D# Z3 z3 I  n8 e3 d
           NULL,        /* This is your client data */5 ~) i# m8 u8 O% Z
           response ) ) != 0 )- p" _$ D. }7 m, @
5 ?9 C( `# O3 }% R9 G6 e" ]          char fail_message[133];( [2 `' h" U( W$ s+ d. l
+ j* J: ]2 V$ ^1 ~          /* Get the user function fail message based on the fail code.*/, s% T9 Q, c: W9 d. Q7 g
/ j) W  T' u. C* ?) _$ ^' R6 E* u          UF_UI_set_status (fail_message);
# w1 w* L2 S% C! V- [          printf ( "%s\n", fail_message );
7 q  X1 m/ O( W- o7 ~# }+ ~! x    }' ~( a1 ^6 i# {: ?. @
5 K0 c& R: r& ~
# y: F0 U# Q; Q& J! X, ?' `, Z    UF_terminate();
5 L+ u, M! ^; k1 h* X# ?  J    return (error_code);
# F6 Y5 ?  K0 d, v  S2 W" W: x}
GMT+8, 2025-9-18 06:48 , Processed in 0.059535 second(s), 25 queries .
