查看: 7035|回复: 21
青华NX CAM 二次开发工具使用说明书
发表于 2013-6-24 09:31 | 显示全部楼层 |阅读模式
# Y' l! R5 h- ]8 L) [: k  T* h5 y, {8 W1 y& T) G
3 B" G: r& n: d& S( u6 q目 录0 z: E7 ]& \: I6 n
1. 电极设计工具 ................................................................................................ 1
# Q: m2 X( }$ _7 N; |1.1.简单电极 .................................................................................................................................................. 1" C& f7 S% L+ ]3 h0 B" l1 W
1.2.三面清角电极 .......................................................................................................................................... 2
# g7 R# u' D+ A1.3.超级电极盒 .............................................................................................................................................. 3
& Q, N7 N! j5 R/ a6 H1.4.平面修剪 .................................................................................................................................................. 4
. b3 z( x/ C$ A6 j! U) l1.5.平面分割 .................................................................................................................................................. 5/ z8 U% F: S% B% O0 x; a3 ]% D
1.6.电极座(生成电极) .............................................................................................................................. 6
. m0 x1 J% Z& v! W& Z0 _- ]9 y3 U, C1.7.旋转平移实体加电极座(复制实体) .................................................................................................. 7& J% `4 Q8 T+ B% W, S# z
1.8.旋转平移实体加电极座(移动实体) .................................................................................................. 9
" f9 i! ~$ B6 F% F2 B0 M/ ?1.9.旋转平移电极 ......................................................................................................................................... 11
1 D* `! h9 p- V3 [( @6 Y7 }' a2 R1.10.删除电极座 ......................................................................................................................................... 12
- K; v& ~% ]3 ~+ B0 q1.11.放电面颜色 ......................................................................................................................................... 134 U4 q$ b4 q, [' g8 D
1.12.电极座底面透明 ................................................................................................................................. 14; H1 J6 V- q7 _) S" W1 V' V
1.13.电极倒扣检查 ..................................................................................................................................... 14" ~0 q1 J& {. F/ b7 c& I  j5 \: B
1.14.电极干涉检查 ..................................................................................................................................... 15
3 T9 q* n. G. W2 z8 [" D$ A! S1.15.放电图纸 ............................................................................................................................................. 16
7 Q7 V5 l/ X" K4 Z  f9 [( M1.16.电极 BOM ........................................................................................................................................... 18& g$ p( h2 P( n" `% t' V+ B! _% H
1.17.电极批量导出其它格式档案 ............................................................................................................. 19
' q6 n, m( b8 ]: Q2. 编程工具 ....................................................................................................... 20/ n1 e; Z6 c% o% o. P& p
2.1.全自动电极编程 .................................................................................................................................... 20( M' {. R, u& N' g
2.2.电极辅助编程 ........................................................................................................................................ 23
( b" _/ ~6 G' t- U# Z# p2.3.模仁正反面钻孔 .................................................................................................................................... 25
" i1 H  d3 t5 y/ _4 i$ ^& z: S2.4.模仁侧面水孔 ........................................................................................................................................ 29
# p, M# ?6 e. W8 c6 `3 |  h, L2.5.程式组更名 ............................................................................................................................................ 30
+ ]; a$ d: @0 Q2.6.计算最短刀长 ........................................................................................................................................ 313 p0 J  ]7 F9 C! }0 H
2.7.EXCEL格式工单 .................................................................................................................................... 313 s, y& I* n5 a
2.8.批量多种格式后处理 ............................................................................................................................ 33
) n  z( b% t7 n3. 小工具 ........................................................................................................... 34
* S4 u1 @' b' O; |0 F3.1.根据实体底面(Z-方向)移动实体 .................................................................................................... 34
' _( h5 L9 U8 Z% m# g3 h: s3.2.移动实体 ................................................................................................................................................ 35
) {8 ^' J' J7 G; M3.3.旋转实体 ................................................................................................................................................ 36$ A  o: k! p" H2 {0 P. ?$ ~1 G4 I
3.4.面改颜色 ................................................................................................................................................ 370 d. N, |4 m8 ]+ n: M: l& i7 T
3.5.用户自动义颜色设置 ............................................................................................................................ 38" M8 Y, E( m: Q  [% S7 K( U0 T  k! O
3.6.图层、图纸快速翻页 ............................................................................................................................ 39, W6 l& f, `: I3 g
3.7.点、线、实体、进阶移除参数 ............................................................................................................ 39
& y$ V: `2 q1 @1; h: ^% E5 ~3 k) s
1. 电极设计工具4 `/ @$ `. E3 [- y! D  C! @
1.1. 简单电极
* H- ~4 ], z( K# k  x8 k点击
. ?" W5 d- }4 J启动界面; M6 ?; ^8 S% A' F' a
! k, x: ]+ ?5 {5 a9 X选择需要放电的关键面,程序找到相关的凹槽面。
* n1 D! D! U* v% ^. U3 U 3.jpg 0 g7 b0 A- U; G+ ~/ `( f
一次可选择多个放电的关键面,点击“确定”或者“套用”生成电极头$ N! p) a" J% N& t( Z4 O- U
4.jpg # \# J% a! M4 x* M7 c
1.2. 三面清角电极
% I: ], c3 p  u) s/ U点击
/ l% I. i- ]8 H3 B5 n 1.jpg ( \$ f+ M5 ~6 c" g
启动界面. }! W  U, p6 z" _" S
- }) V, v3 F% A  o选择需要清角的两个侧面,程序自动找到底面,预览电极大小  u3 Q" i0 ~& W% U+ w% v3 q* n1 H5 J
( B$ W: N) K* h3 S: J7 c+ ^% _清角电极的大小可在界面中修改3 ?* v* O# [2 a( A8 W! `
1.jpg , |" I' N7 C1 a$ x$ g( G8 q. s6 a7 S
点击“确定”或者“套用”生成电极头
发表于 2013-6-24 09:57 | 显示全部楼层
有外挂就会用!
发表于 2013-6-24 10:43 | 显示全部楼层
ganxie分享
发表于 2013-6-25 19:02 | 显示全部楼层
可以了 青华来的
* Q1 T3 C9 \$ k8 S1 D
发表于 2013-6-25 20:44 | 显示全部楼层
看帖看完了至少要顶一下,还可以加入到淘帖哦!
发表于 2013-6-25 21:32 | 显示全部楼层
支持青华  感谢分享
发表于 2013-6-25 21:57 | 显示全部楼层
看上去很好用
发表于 2013-6-25 22:46 | 显示全部楼层
支持青华  感谢分享
发表于 2013-6-27 19:21 | 显示全部楼层
  前十必火~~!!
发表于 2013-6-27 19:24 | 显示全部楼层
  果断试用,前十有我必火!~~
GMT+8, 2025-10-11 23:40 , Processed in 0.062753 second(s), 27 queries .
