查看: 1856|回复: 6
[疑难] 求直线和实体的交点
发表于 2013-7-7 19:00 | 显示全部楼层 |阅读模式
求直线和实体的交点的函数
发表于 2013-7-27 16:14 | 显示全部楼层
不错啊 写得好
回复 支持 0 反对 1
发表于 2013-7-8 17:26 | 显示全部楼层
try "UF_CURVE_intersect"
 楼主| 发表于 2013-8-6 23:22 | 显示全部楼层
zx513520 发表于 2013-7-8 17:26
. ?* ~, I2 Y! x. U3 e2 z" itry "UF_CURVE_intersect"
5 ?) z" {' Q/ }7 H' w5 j
额,要GIPR的...谢谢啦
发表于 2015-8-27 10:04 | 显示全部楼层
Overview | Statement List | Example
# @6 z8 t4 Z0 ^: i  ]  N8 t
) C2 ]5 H# F; b) i2 ]; X0 ?7 Z! k/ E
" e; A; k1 x6 C/ H. t% T. r0 g* `2 t+ b2 P
Intersection Point/ C( N& e$ C2 E8 K4 @& `# X" x
Synopsis
0 J! Z* p+ {+ c0 ?9 `" s8 Lobj = POINT/[{"PMOD2"|point},]INTOF,obj1,obj2[,IFERR,label:]/ M& \" y# Y: S; I
/ r, D# t! {. y; ]1 ZDescription/ R/ _$ J: N5 j$ v  _0 `
Creates a point at the intersection of two previously defined objects. A reference point must be specified to indicate the desired point in the case of multiple intersections of the two objects. The intersection is determined by looking down the z-axis of the WCS.
1 |# p6 e( J  M# A0 T/ B0 @4 e' o
" I! }9 h3 d/ J8 S" b1 fParameters6 F* r/ e9 ?- k1 w6 f8 d8 p% c
Parameter: M# e3 \& J, L  p# K; D7 P
Description
! Y  m5 d6 @. G0 ]
& w5 x  n6 A  `; I& KPMOD2/ X/ j! x& ?# k7 _  A* M
A two dimensional positional modifier which may be used to indicate which intersection to use when multiple intersections exist. The direction is in reference to the work coordinate system.- H. I. Y: k2 j; w: a# C+ f7 E( q
$ m+ r2 z/ x1 y( Lpoint* p$ w7 K' e" c) K
Reference point, closest to the desired intersection, which may be used instead of the positional modifier, when both objects are curves. If the desired point is the intersection of a curve and a surface or plane, a previously defined point must be used.. s6 D/ {# f0 h2 i4 }" U. k
: q- w, k- c6 c2 b* S8 Z7 J2 wA positional modifier is used to assign a reference point. This calculated reference point may not yield the expected results.
' H9 s# n# Y/ h
, C  Q" i/ e1 W+ X- O6 mINTOF
3 k8 e: S1 ^2 {0 |* Z Minor word that indicates that the point defined is a unique intersection of two objects.4 v" r8 G- n$ }# u- H  Y
9 Y6 r8 Z: k  L& O
obj1,obj29 I7 f: {6 Q5 |) e4 l$ O& o
Two existing objects which are not parallel in the work view. Object one must be a curve. Object two may be a curve, face, body with a single face, or a plane.
8 s* }( R& Z! q9 _. F- d9 U7 M# O* F
4 {7 W; s4 T# z' i/ ^) `, @IFERR,label:+ R- G' K: o% H+ o# ?( n
Specifies label to which program execution jumps if no intersection is found.
, S6 v5 j. U( W+ |% T' v % F6 i" A( n# v: ?. d
GMT+8, 2025-9-18 19:40 , Processed in 0.070072 second(s), 20 queries .
