我用NX7.0生成了一个Block styler 的.dlx文件,同时还有.cpp和.hpp文件,我把.cpp和.hpp文件放入VS2005里面,但是运行的话在 theDialogName = "ZW_Centerline.dlx";: o& e1 f# n) w3 ^! {( s
theDialog = ZW_Centerline::theUI->CreateDialog(theDialogName.c_str());' I7 e' X: O7 y6 K
/ `$ H# m, Z c2 D; N0 G0 {; k( a1 B public: NXOpen::BlockStyler::BlockDialog * CreateDialog
% s$ _* u) f9 _: G (( t0 h) }0 R0 G% D! Q j
const NXString & dialogName /** Dialog name <br> NOTE: The full Unicode character set is not supported for this parameter. <br> */
* i5 h/ s( _6 B7 E p1 w! P, t* k: H );5 \' h5 t' s8 y5 S+ K8 F
" f# r3 W% m% p4 G8 i; F
始终提示:warning C4003: not enough actual parameters for macro 'CreateDialogA'
( g3 l0 r0 Y8 nerror C2059: syntax error : ',' |
