查看: 1302|回复: 1
[疑难] 请高手帮忙, 解决语法错误~!
发表于 2013-7-16 13:07 | 显示全部楼层 |阅读模式
ENTITY/obj
7 E4 r3 T' T6 T  |" a- p; z- f+ Q- s6 ~0 \6 |
: m' S4 U# N  h! d  Jstart:. x. F" h; |* d& C
        / x$ T9 z4 u$ E$ a& u! L, t
l10:
1 j) f* Q" X" l" V2 F           choose/'select a option',$$ O3 \1 t! u; ?9 o) d  N
                 '改为粉红色',$
. z/ k, \2 l# O* K                 '改为品红色',$
6 ~. V, L6 _, x1 r( _" \& ^  k                 '改为灰紫色',$/ Y% H0 H! U' h: Z8 F9 x& A8 G- L
                 '改为黄色',$2 K& ?9 X! k/ L2 \/ q, M
                 '改为橙色',$
9 U! H$ k3 Y2 F) D% S" {: Z                 '改为紫色',$- c% t& i4 I: {! ]7 P6 ?1 B) B
                 '改为绿色',$
: h) g2 t' y8 D4 ^: c                 '改为灰色',$0 m# N, Z; B1 @
                 '改为蓝色',$# g. J" ~% S: f6 g
                 '改为白色',$  r  b1 H0 `0 ^
                 '改为绿色',$
3 L7 P9 n5 @% O0 o; B+ w0 s. y* R                 '改为灰色',$6 h% k- W$ S% E$ i
                 '改为蓝色',$      3 L0 f+ m, G0 `1 v4 E+ |
                 '改为红色',resp+ Q( _/ N6 G  \# L" G  u) i
               JUMP/l10:,trm:,,,l20:,l30:,l40:,l50:,l60:,l70:,l80:,l90:,$
/ L2 e" {, D; m                       l100:,l110:,l120:,l130:,l140:,l150:,resp
' K" p1 C" O& W' b1 B, N9 h: m
; W7 e& L7 V* ~+ r% h
  H% H& O( c% ^! }/ h
& @% g& U9 d% D! f! d; ]' ^$ b5 k  \5 R  s
jump/l10:3 C( V( ?  I$ G$ E; S1 d
           4 C2 t8 H& O* H3 @! B! Q* p
l20:
$ Y8 Q! r3 I/ q: F
8 J2 [6 Y# H8 n5 ?- g3 }  R           mask/71+ _1 x( h9 v4 I" ]
    ident/'选择要改色的面(粉红色)',obj,cnt,nm,resp$ }% n0 d9 t7 S( W
    jump/start:,trm:,,,resp% _& r8 ^( b% \; p
           do/b1:,i,1,nm
8 v; Z# o& Z& q: _           &color(obj)=181
2 q- i) Z* }4 w8 h+ M. l; y: X  yb1:# n# F/ K" q$ i! J+ F4 L+ x# u1 K4 s
jump/l20:
2 p$ q; d" q$ el30:  + D; i1 q+ x* N- n( _
           5 `" m) h( I9 j2 I; M
           mask/71
. x+ B* l+ B! p" @    ident/'选择要改色的面(品红色)',obj,cnt,nm,resp
1 ]9 L6 s. X- I# M5 x& }4 E    jump/start:,trm:,,,resp4 h, ]6 H4 @( J  Z  q% @5 c$ X
           do/b2:,i,1,nm  ! z! a. R: S& y* \' i& N9 @5 z$ S  l
           &color(obj)=109
$ b4 i* C  ]7 @4 `( ?4 \b2:' E% T6 ?3 y: m8 r1 R
jump/l30:
- m9 ]' l- m+ |, d& N! Ol40:  * h4 H/ D1 K$ U
1 k& @: [9 ^9 {% P0 }5 @1 @0 P* G           mask/71( |+ V( p; e& {4 v
    ident/'选择要改色的面(灰紫色)',obj,cnt,nm,resp
  q$ W4 s; `/ t8 z% _    jump/start:,trm:,,,resp
1 ]6 b6 a* h1 C, @& n8 w           do/b3:,i,1,nm
0 b0 z' Y; n5 a# l2 @/ a" Y           &color(obj)=128# F8 ?5 s# F8 t' P
b3:; p2 x" b- E/ ?4 {) }* `
jump/l40:
. w) P$ f! a% R4 Dl50:
0 s" ]! a. ?' ?3 B           0 u( R; Z! e; I! X+ \3 @0 Q" y
           mask/719 D$ }" d$ `7 H+ [4 Q5 b
    ident/'选择要改色的面(黄色)',obj,cnt,nm,resp
' L( n4 i% }$ n( K5 U1 ~. `    jump/start:,trm:,,,resp' s: Q. ^& X% R8 `
           do/b4:,i,1,nm
# T3 |+ j4 t9 D4 o7 {6 G  s           &color(obj)=6
: |" {$ g- x' v; fb4:
, M: p; f  R* @5 Ljump/l50:' R6 l0 a: S; j7 L7 ~6 `
; E/ B% t- l1 Y1 x- c6 N) V  u, q/ N' m. E+ Q! j
+ R- c3 J+ q+ Q6 m, Q
l70:
$ F6 u1 r) P5 X3 {0 ~1 \% y           " H1 F6 S, [( S! {) ?& l' ]
           mask/71
1 ?- f& L# _% p1 Q    ident/'选择要改色的面(紫色)',obj,cnt,nm,resp+ }( K4 E- W  y+ c3 L, D1 P
4 w0 D% a1 _1 W           do/b6:,i,1,nm  ' N  J2 R8 ~. B# [0 L" s
           &color(obj)=164- _& o% d( o; [' k# g4 C
b6:* _  k2 r% ]" _; u3 W0 `# c
jump/l70:& M6 R% l, R# |3 b+ @$ a
% F' {8 \: q* f
9 n! m- g& F) w4 x  m- F. I/ C& I
l80:  + v, j* ~2 n+ q$ a( V) F
           , I( c  l$ v4 k. r
           mask/71' m# Z6 V; u1 h* a9 ~& M8 |
    ident/'选择要改色的面(绿色)',obj,cnt,nm,resp9 G! t8 X" |5 b8 q
    jump/start:,trm:,,,resp9 f; a5 V: A  `: U! X% Y1 ]# J
           do/b7:,i,1,nm  6 {+ z' b8 h* X2 C) |0 k3 x
           &color(obj)=108
! B" D) B) s+ H; X: E* j1 ^) xb7:+ b, d- X3 p  X9 T! T
jump/l80:, J! \# o/ P; C+ D5 w6 Z" N8 }
5 h* X( ~) t! f  @
" P! p! l( t8 t$ }+ O9 U$ |
l90:  / C/ [1 F6 \2 C4 n
           % J& B) J( w# j! f
           mask/71
+ g+ h8 a' a& y0 I- S( ]4 a+ a    ident/'选择要改色的面(灰色)',obj,cnt,nm,resp
$ Q' @# ^$ z- f    jump/start:,trm:,,,resp
7 m: @+ J! K0 \. L           do/b8:,i,1,nm
, [, Q+ ]0 l. F1 b3 L+ r           &color(obj)=123
5 ?' E" \2 {5 B+ k7 O$ rb8:
1 C- u2 u4 G& c3 b- Ujump/l90:
, G0 W6 Y- Z3 D8 D6 n0 B4 V; D0 |/ E6 X% ?
l100:  ! z" c( t0 P5 p# @2 B# C
           8 u  K. x3 w# x- ?9 h: G4 U
           mask/71) y" i# t/ `% z8 t6 E4 T/ q
    ident/'选择要改色的面(蓝色)',obj,cnt,nm,resp
& a) }. \6 |- s    jump/start:,trm:,,,resp
  D: s1 e; A+ N+ q* Q" C, ]           do/b9:,i,1,nm  6 q8 d, \1 o8 W: G
           &color(obj)=211
. [4 ~- O- p) H3 x' W% ub9:
0 J; R  K, Y9 k( l8 \8 o4 k" W/ Zjump/l100:; B' P# n$ z: S$ Y6 N/ V0 `% f
( ]/ L& G( S- Yl110:  / b; I5 N: K/ [
3 Y; a: g. M7 \$ X( z8 a* p8 c$ I           mask/71
9 ^6 Q! M! k+ I: V' {& G    ident/'选择要改色的面(白色)',obj,cnt,nm,resp( m# t7 |, [. m* O& `: w
    jump/start:,trm:,,,resp1 w; R' e! N* }9 l/ a
           do/b10:,i,1,nm
  k2 V- o$ O! `9 O6 r           &color(obj)=1
8 \0 ~5 o/ k, i$ M) O
) c! g* `( `4 n) Zb10:$ ^) J1 [  X: X# N$ F) C$ O& ^8 ]! [
* d8 R% d" f. t; sjump/l110:
0 ]6 B$ e( D  O7 o: t3 V' [- i
0 _) R. C* w) r# ?- t; }3 ^2 }, F  P: u+ p: V) f
l120:  : H; d+ _9 e) Z5 Y2 {  M
           % k: C: N* @7 @5 C, N. h! h: o: ]
           mask/71
" a( B: t$ t( I    ident/'选择要改色的面(青色)',obj,cnt,nm,resp
; a$ J: s( V% v( W9 Y% t) d! P4 {    jump/start:,trm:,,,resp
$ S# r1 U+ y& S           do/b11:,i,1,nm  . R( d1 W6 W, R+ T6 c6 K
           &color(obj)=315 H! O" D; Y# M, N  S1 r# U
b11:
$ U% Q" J1 \8 w- q7 Ojump/l120:& `2 j! K- A; I2 ?6 l" Y
l130:
1 M5 O. D! @% x             [. m9 k# b) J% i2 j/ G  C9 c, q9 ?
           mask/71
% i1 f- [' B1 q7 \0 l6 H    ident/'选择要改色的面(红色)',obj,cnt,nm,resp3 z- E8 m4 L$ O; y# @
    jump/start:,trm:,,,resp7 a& H: n  j, A& v: m7 y1 X! o
           do/b12:,i,1,nm
2 W) Q& g- X5 N9 F           &color(obj)=144
5 I7 ^2 ]( m) q0 D4 B4 x; rb12:
% g" E# L) ^% l( {3 i+ I; Y9 o5 p* C4 ^. Y: \: g' s
jump/l130:
4 I  w3 I3 {4 W% C+ G+ i% @) i( i
# H( Q$ m6 s: ~4 @6 \# ^) A0 ql140:
+ E$ A6 g. ~6 O
. Q4 y' d3 J- G( f! \4 x5 M           mask/71; Z. J2 ?$ i  h* j: m
    ident/'选择要改色的面(色)',obj,cnt,nm,resp9 y, k$ P0 U) \7 o. u
    jump/start:,trm:,,,resp, t' A1 D+ @0 m1 r4 y/ J6 }& d$ @7 c
           do/b13:,i,1,nm 0 n& G4 @/ \+ t3 l( Q
           &color(obj)=125
  ^8 s. r% y$ Ib13:) l: B4 G7 S$ U2 e! T( p" r1 E% P
+ v0 c: Y& d- X1 d9 v# ]/ B6 jjump/l140:5 H. Z4 X) L3 g" L
/ e1 b2 {8 y3 W: i* [# k( ~6 h) D) S: }
l150:
4 Z* ]; ^7 h8 \* d% @7 g
, L+ O5 e& G# S           mask/71( E. W9 T  j; t, |% [1 @5 a. C
% O2 v: F* P( B    jump/start:,trm:,,,resp
1 w) O2 d& n3 t+ ^           do/b14:,i,1,nm
3 h9 `1 w& B; H3 x$ b4 o           &color(obj)=188
- Z- k- M7 i" C) P5 qb14:; Q. F8 y& `2 ~7 m( R  p. C
% p* n' y! {* i$ d5 Y- Z9 r' x. `
: X+ |+ |& Y7 x% h* j! q/ K
, Z& \" B7 J1 |% ?  k7 D5 Yjump/l150:
; h7 k% H& o" @. l* y
& v  c/ \( I, M( t7 k- g, v
8 \0 [  @* H( d- j" K2 ktrm:& x$ F$ m4 C* h2 l
    HALT
发表于 2013-7-21 16:03 | 显示全部楼层
&color(obj)改为&color(obj(i))
GMT+8, 2025-7-5 14:04 , Processed in 0.173317 second(s), 19 queries .
