该函数的用法UF_MODL_replace_features 问题描述:8 f3 s8 e3 H( U! O0 Y' C: `1 T
现在画两条线,将其中一条拉伸成面,然后进行如下操作:用未拉伸的线去替换拉伸的线,并使得拉伸的面也移动到未拉伸的线出,也就是子特征也拷贝过去,我用上面的函数UF_MODL_replace_features操作发现拉伸特征并没有拷贝过去,单步调试发现返回值不为0,最后一个参数n_parent_map为巨大的负数,看了英文帮助发现有点难懂,遂请大侠帮忙看看如何实现我的功能单靠这个函数是否能实现,如果能我的参数设置是不是错误了,错在哪儿?
- _5 R# O u( v; I. I代码:
0 G" E# [ r1 ]( \: x UF_MODL_replace_features_t *replm_map=NULL;//帮助写可为输入/输出参数,我作为输入,不知道正确与否
L* m! _# V+ G# }3 l int n_replm_map;//
$ b6 ~; Q6 P3 J6 {. y; |0 _ errorCode =UF_MODL_replace_features(&first_element,1,&second_element,1,true,true,&replm_map,&n_replm_map);
# i( T% I) W6 O7 I- z. P9 E
2 k6 F' l& a9 L. K# h' Q0 A4 ^函数注释:(小弟英文水平和理解力有限请大侠帮忙)
+ U0 f# R- d0 n$ _1 F. r9 \This function replaces the features in original_features[] by the
" c' U7 [# e% c0 lfeatures in replacement_features[] or the copies of features in - f H8 N9 l$ @6 D- d
replacement_features[] if original_features[] are features on bodies,
5 [0 \1 a) B1 W3 O6 ]2 s& E) Ecurve features and datum features. The children of the original_features[] : G; @; Y! [# p2 K' z
will be reparented to the replacement_features[] or copies. + g7 n* d& T& ?$ H& D5 D
" d# R* E2 s9 R+ ]9 NThe original features will be deleted. ) H& V! \4 I4 C
0 r0 X' j8 u7 X" }; O4 C: `, R, {- U, y( `
original_features[] can contain: features on the same body, curve features,
8 F+ l& H* R0 ]) ^( p4 Qdatum plane and datum axis features. ' G% d/ `2 q' h4 g$ v8 @
f# h" Q2 U2 }" v1 s3 w4 J. C$ |replacement_features[] must contain: features on other bodies (if
7 N( c" S; ]% Z. horiginal_features[] contains features on a body), other curve features
. _ a) C, J# A; A. ~- \& o" a5 X(if original_features[] contains curve features) and other datum plane
$ e8 R9 u; S/ R+ i* Oand other datum axis features (if original_features[] contains datum plane ) w7 U" U8 k+ D! M7 \
or datum axis features).
* ]4 o6 F7 v" \1 ^7 C; O; y5 z5 p' E
Note that original_features[] and replacement_features[] must contain : `5 v/ O. {8 d0 \; I$ {
features that are in the same part file. Also, for features on a body, the
/ C+ ~& i; e* oparents of each of the features in replacement_features[] must be either
+ u8 k5 z. A' uanother feature in the replacement_features[] or must be a feature which
6 j, t9 z, j. |; ^1 z! D3 Cis before the earliest feature in the original_features[].
2 u- n/ Z# T- o/ s( O/ H% \
. E4 a1 ~, n4 T. e2 |% ~. @parent_map[] maps entities created by the original_features[] to the
( n- U) y3 _0 b+ ^+ q+ j) y3 p1 W lcorresponding entities on the replacement_features[]. In addition to the / P, _' S0 f J" [. F1 o
original_features[] and replacement_features[] you will have to provide a map
' C. v l% N. G5 Wof edges and faces on the original_features[] to the corresponding edges and ' A) _# V/ R9 O. }: D0 @$ _4 P
faces of the replacement_features[]. 5 B4 h3 s6 s& }8 ^- w3 r) y
# e# E; R8 U1 F |/ B5 q- FYou will specify the map as a array of objects of type 6 E# E4 B% @( R2 @
UF_MODL_replace_features_t described below. The children of the 0 j8 J) O- U- f* V" K' v2 ]
original_features[] will be reparented to copies of the corresponding
1 u( f1 G' ~( X, E; oentities on the replacement_features[] that are specified in the parent_map[].
( k# X X: E: @+ n- ?; A# R( }
" \# p' w0 u( v* i2 @ I9 ICalling this function with return_map as true does not perform the replacement
( p* [7 V9 A9 D& _: d) g- Y# W$ Fbut returns a parent_map[] each of whose original_entity elements are edges + }! v3 e- }$ r; B0 ^2 j9 n
and faces created by original_features[]. Only those edges and faces that are
* H7 M7 b. C! Oparents of downstream features are returned in the parent_map[]. The 0 e4 b4 s c+ e3 U
replacement_entity elements of all the structures in the parent_map[] are 0. 9 \8 i |4 z' n Q# q. |& \( ~
You will have to assign the appropriate replacement_entity for each of
N7 U+ x* F* V3 h. Q9 i" v& Tthe structures returned in the parent_map[] before calling this function with
8 D L1 b" h$ Q5 F$ \: n9 q' oreturn_map as false to perform the actual replace.
8 ^& h4 r2 ~, B; m参数示意:
9 p2 O8 s) j+ f! E7 O' a7 s5 i% |
- L- b2 a t6 q* B4 C[ 本帖最后由 mydear 于 2008-6-25 12:20 编辑 ] |
