查看: 2849|回复: 2
[分享] UG二次开发中定位约束孔的建立
发表于 2008-7-4 17:14 | 显示全部楼层 |阅读模式
#include <stdio.h>  B7 p) a" Y9 Y  t2 i# P- @
#include <uf.h>
: ^" B9 e0 f: e1 |% Y* G#include <uf_modl.h>: P' A/ D. S& `/ e. r
#include <uf_ui.h>5 D4 M+ u: {$ f% y- n1 R
#include <malloc.h>
6 L2 @! ^# C! D6 B# L$ R
* i' k# Z# M( V1 g/ J% D/*定义全局变量,用于转递相对定位的目标边*/
2 K  E# v9 n+ }8 v( o$ J/ Jtag_t target_edge;  v' S& A7 d9 P' C- d4 X9 s- i
# M, E& q; _, v4 X% J
/*注册孔定位的用户函数*/% U$ V# q0 Y0 g2 @: P$ H* A
int rpo_routine_hole(tag_t obj_id)  L$ N8 N, v5 L) o% ?
{- p; E1 l7 L+ S% v* O
  int irc;
# C: w0 Q- Z9 {9 Y* H- c! t3 `  uf_list_p_t edge_list;
+ w) B' J" g: H  t* b
. t  _( h" K  t7 e% A  tag_t obj_id_target[1],obj_id_tool[1];
# v8 b7 ~0 A) f, j1 S" a/ t  char *constraint_value[]={"0.0"};4 E2 N6 C! ^/ f' m9 J! D* o
  char *constraint_array[]={"PARA_DIST_PARMS"};
! }% T- W+ x4 ]- Q  int target_qualifier[]={UF_MODL_ARC_CENTER};
9 T. X' r* }4 \; {+ W: [0 i  int tool_qualifier[]={UF_MODL_ARC_CENTER};
5 `& O) a: P) h( l
' P/ f# G" H8 T+ O  UF_MODL_ask_feat_edges(obj_id, &edge_list );
2 `$ P) D! n  ~# f  UF_MODL_ask_list_item(edge_list, 0, &obj_id_tool[0]);
& W2 v0 R1 V8 z" ^4 C3 L  UF_MODL_delete_list(&edge_list);
  s% z6 A7 s' {2 [" j: r. e+ o1 @. S7 u$ k/ A* ~* e: _
  obj_id_target[0] = target_edge;
1 d3 x$ E3 P' m! h! L  {: e6 q; |7 Z  |; X* {& y+ [$ ~- l
  irc=UF_MODL_create_rpo_constraints(obj_id,NULL_TAG,NULL_TAG,obj_id_target,
! u0 n# A7 C6 K7 P  target_qualifier,obj_id_tool,tool_qualifier,constraint_value,constraint_array,1);
) {% h6 \9 S! D- Y% Q
+ L( {; F0 r/ l  h  return irc;
0 {! U. y; c3 A. _- |, Q1 Z# j; _8 b}
( M- b, P/ z' V$ B  H
, Q, x, J- w& f, [  ]# [static void create_hole(void)
9 T) d6 g% c7 k9 w8 ?, D2 Y8 `{
( t% s6 K& N5 x' u1 P% g- _  UF_FEATURE_SIGN sign = UF_NULLSIGN;
/ b! _$ K# `7 w+ g1 o  double origin[ 3 ] = {0, 0, 0};3 p* z( Y  d& {+ r2 }9 ^7 H
  char * height = "10";
% m& i- a* R8 E% n( N9 |5 n( i  char * diam = "50";4 W3 l3 o  y$ h; U# [- J' k
  double direction[ 3 ] = {0, 0, 1};
# @9 C: A: A7 }7 I7 i) A  tag_t cyl_obj_id;
1 I" A" b) P& l/ o" n  y0 v  uf_list_p_t face_list, edge_list;
' U$ Q1 C. e  D/ D! v- y2 _1 k  tag_t placement_face, thru_face;0 k+ c+ b* l% @9 ]3 F
  #if CREATE_HOLE_DEBug
& Y8 l( f( T# w) k! a  tag_t face_tag, edge_tag;
. `7 ]4 u% ?$ ]$ l4 N* K  int count, i;4 O' ?% P$ j' y# a" q+ Y
  char buff[100], name[255];
6 J# s; f* K) i( U% }% F+ k# \  #endif4 c6 D6 o# H* O( w& K* M5 l. ^
6 M3 T4 d9 J3 P5 O2 h- G
  double location[ 3 ] = {0, 0, 20};
9 s! D2 b7 B# V2 R  double direction1[ 3 ] = {0, 0, -1};7 L+ K* T: }0 }; i0 N
  char * diame = "40";; m: }: _% L- Y3 \6 ?
  char *depth = "100";
! [, Y$ a' P5 \. r; l& }  char *angle = "0";$ B/ R/ N$ H& \0 E$ @( i
  tag_t hole_tag;. p( s- m" z3 A6 J  V4 z
; ]: f& ?6 k0 t* t. A8 T) v/*create cylinder*/
' J7 f4 |7 e# Q5 f4 @  UF_MODL_create_cyl1(sign, origin, height, diam, direction, &cyl_obj_id );% Y) I" ^+ v8 ]& Y9 E
% x/ C) o" N# l. H( x  t+ @/*find placement face and thru face*/
3 v5 M6 E0 v. Z& X7 |, b  r  UF_MODL_ask_feat_faces(cyl_obj_id, &face_list );
; p, L( E3 W7 U& z  #if CREATE_HOLE_DEBUG9 H4 s* X3 }& Z+ ]
  UF_MODL_ask_list_count(face_list, &count );, I, E! g2 V# \
  for (i=0; i<count; i++)+ ^% O. T; b2 p  u
  {' O- ?; y( G9 z9 q* i, ^3 d
    UF_MODL_ask_list_item(face_list, i, &face_tag);
+ k% x) u" w3 f7 {+ l    sprintf(buff, "%d", i);! [. ?  J6 [, T4 b& o5 j. ^
    strcpy(name, "face");
( r* ~8 D9 v/ y; E3 C. O    strcat(name, buff);8 l: w5 ~0 U4 c- q, j
    UF_OBJ_set_name (face_tag, name );& ~: a9 H7 K) |+ h8 u
  }( x9 k# b) i. V$ {" \2 b; p
  #endif$ C- b" Q/ H. c# y; w$ v+ j& {
  UF_MODL_ask_list_item(face_list, 0, &placement_face);
' ]4 i% N& K, p* ]8 v) S2 x  UF_MODL_ask_list_item(face_list, 1, &thru_face);?
) I! d9 v7 o+ b. v0 V  /*delete the uf_list_p_t data*/
1 ~" e" z6 x: ~( g) q. ]  UF_MODL_delete_list(&face_list);$ }) l( B6 r: v* C4 |* `
7 [; g1 o" W+ R% k8 ~" B  /*获得块上边的标识,用于相对定位*/& Y8 h: j- Q9 I/ X! M# o
  UF_MODL_ask_feat_edges(cyl_obj_id, &edge_list);% s2 x/ H0 w4 o# Y- ?% [9 B
  #if CREATE_HOLE_DEBUG. f/ I' j) o& e  i. S
  UF_MODL_ask_list_count(edge_list, &count );
: o$ W9 d# j9 U. H- d: ?4 n  for (i=0; i<count; i++): q4 ^1 a2 {/ \
! A$ j$ c9 A2 V6 D. G, y* W+ A' f& R* q    UF_MODL_ask_list_item(edge_list, i, &edge_tag);
0 @% h: c% l# Y7 _% O( @8 ?    sprintf(buff, "%d", i);$ h4 C( q8 }! e- ~  t
    strcpy(name, "edge");+ m5 t* i/ h* K" O7 W, a' ]& y
    strcat(name, buff);
' X% _3 E' j4 Z! w4 r    UF_OBJ_set_name(edge_tag, name );3 Y' s+ D7 I* m% B# `0 x2 d9 B: `
  }" ^% e9 h/ s# V
  #endif/ @% w. {& c" b! s0 I; m  u
  UF_MODL_ask_list_item(edge_list, 1, &target_edge);: C3 E$ \+ `& m& `8 j3 @
& y  U: H* ?0 I( D. q( f0 v2 E' H! P2 o! @) G
  /*register constrain function*/
7 w4 R6 h" u0 _4 R# g2 ~0 [  UF_MODL_register_rpo_routine(rpo_routine_hole);?; E# t/ w, K5 R/ \0 T3 S2 @
  /*create hole*/
" s$ k* a8 ]- a" S; H  UF_MODL_create_simple_hole(location, direction1,?, v/ `, J2 ]% Y8 y9 ~+ u- A
  diame, depth, angle,?$ ~) Q$ o4 i: _+ p: @
  placement_face, thru_face,. p1 M$ [$ Y  P5 t) [) [' I! i
  &hole_tag);& [9 x  H- w( t* J
8 Y2 f- S" s1 o) ^  j" W  /*remove register constrain function*/! n8 J, g# Q% L
  UF_MODL_unregister_rpo_routine();
8 d+ \; c3 G& x5 t; P}
" M6 b  e8 G8 D6 O; I+ T! E; {
void ufusr(char *param, int *retcode, int paramLen)
# p9 J  b  S/ w4 O{) W9 d# e5 o8 M3 o1 B
  if (UF_initialize() != 0)
0 e! S; j% B% |3 C# i% n) k5 `  return;  _! Q' @! v9 u4 y" b
  create_hole();+ \4 ?' a  [% M5 X
  UF_terminate();+ ?6 b# l; n5 \
5 c% T+ p3 W3 I$ Y, o! ?+ @" v3 Sint ufusr_ask_unload(void). p# s, U4 @! T
{5 B4 x* d9 N" X' N
  return (UF_UNLOAD_IMMEDIATELY);
' T9 K- L  \. i1 }) w; l}
发表于 2008-10-8 14:06 | 显示全部楼层
師傳..4 h& G% J, w+ `2 z
我來學習及..; p% ?5 R$ r# ~8 ~
- |0 \& X1 U: s4 n  `3 D
( S2 S+ [8 Z' [) f# @
发表于 2011-1-16 15:08 | 显示全部楼层
请问CREATE_HOLE_DEBUG是什么意思
GMT+8, 2025-6-29 07:30 , Processed in 0.153741 second(s), 24 queries .
