Moldflow Plastic Insight & MDL 5.0: v% `' h/ y2 ?8 ~; ^! v0 C
% R- B- a' i) }. z& y& f% {) U
" A: L) r6 U, m3 O1 ?! I1. Run setup and install the program as a server and client. Reboot
! w( R5 e- w! O9 s: L0 T, }# _# ` at the end of the installations., ^; U5 W4 v' E0 y
+ p: U% d3 S3 _- ]2 \ P2 u2. Run setup for the MPI 5.0.1 and install the update.# k+ c& Z/ `1 v" V& |( }
; `5 e& o( ?* ^( E5 q3. Run setup and install MDL 5.0 (if you have it). Cancel the Solidworks junk if+ W$ H7 J, P& p! J4 O$ `
you don't want it.
C, S4 t8 R. a w+ l, G9 _6 b. b
' N/ X; t/ N# X ^9 J; m2 s/ n4. In the control panel, stop the service "Moldflow Product Security".$ N% m8 U2 V$ Y2 }+ q* h p
( O- f& y( V, _& v6 {9 O5. Open "X:\Program Files\Moldflow\Product Security\" and change the properties
2 T+ s H3 G/ z) M) L! E, o of "mfpsd.exe" by deselecting the read only box.* r5 s6 }% x. \6 K' e/ L
2 |5 m s; w1 \ l2 l6. Copy the "keyfile" and mfpsd.exe to "X:\Program Files\Moldflow\Product Security\"# `7 X, b; t" R! v) B" [+ H
and over write the old file.5 T) b$ E' S) V8 Z
( X+ w, s: S# s- m8 ^4 `7. In the control panel, restart the service "Moldflow Product Security".
' u9 L: b4 F4 V% K3 |5 S/ F$ d% z5 F- E0 P4 a* r
8. Run the program |
