ST0:
A1 M0 C4 M; d6 w- v MASK/70
; }- g, s1 { \$ S
8 A: q+ G: e# b% H. ^4 H O_NUM=1 1 a$ u2 n; V; t
INEXTE/ALL
% H1 R7 @7 {; U0 G
3 d& r; K2 I, c2 X) B4 `! q5 k ST1: ; Q# v- h& |; c) ^& Y
OBJ(O_NUM)=NEXTE/IFEND,ST3:/ u* w5 [0 y) M; A: E
PRINT/'零件'+ISTR(O_NUM)+' '* Y/ C( o) W, Z8 w+ D1 h# V. T
TT=TT+19 Y# ^( X: s& }9 l
A_NUM=&NATTR(OBJ(O_NUM))
4 e u. {0 I O- g IFTHEN/A_NUM>1" T+ y6 k* Y0 Y4 Z# S2 T
ANLSIS/SOLID,ACCRCY,0.99,OBJ(O_NUM),KGM,VARS
# v' K* y) N, R9 N ATT(1)='体积'
, d& M: m0 i% |* E* F+ G ATT(2)=FSTRL(VARS(2)*1000000)" W) V: @5 O9 z5 i# `( q
ATT(3)='面积'
i/ v, W, C+ w N7 w: F ATT(4)=FSTRL(VARS(1)*1000000)
3 O+ c+ Y2 z5 r ATT(5)='作者'
" l1 o1 X! |; R, F e$ I+ N! z ATT(6)='张昭辉'' l6 E$ h p/ j* u4 |: @) P+ O6 P+ D
ASATT/OBJ(O_NUM),ATT: j: {, q7 m- h& a2 g \
$$PRINT/'体积为:'+FSTRL(VARS(2)*1000000)+'面积为:'+FSTRL(VARS(1)*1000000)' R, C4 j3 \2 s# I; I4 L
BLANK/OBJ(O_NUM)
}$ e, g2 a' o( x y$ V, ?7 e VAL_NUM(O_NUM)=14 \7 E' N( x" v+ }# `, N/ g
DO/ST2:,I,1,A_NUM
7 u5 K( l: J9 I6 t+ [* B TIT(O_NUM,I)=&ATTTL(OBJ(O_NUM),I)' r& w2 d2 P0 K8 y6 ?
VAL(O_NUM,I)=&ATTVL(OBJ(O_NUM),TIT(O_NUM,I),IFERR,ST3 # c' D' j; ]0 ]# o, D! S4 @0 f
PRINT/' '+TIT(O_NUM,I)+': '+VAL(O_NUM,I)
) Q" W- |) g2 [% V( d) L ST2:
- T1 a/ { V! a ENDIF
l+ L/ F" W8 a8 R$ r) ]. `; k PRINT/' ' A& E# S% |! P6 E
O_NUM=O_NUM+11 C- p) o; e9 K( |2 C/ h3 Z$ a
JUMP/ST1:
: P: ?7 a, Q" v0 rST3:
K8 c" }4 H7 i+ X3 m8 p
2 y0 \9 G7 R) r
9 _/ T' w: | Y6 T1 S+ s9 qTRM:
; U$ C+ ^1 A; q6 P& x! EHALT |
