这种命令不是很简单吗? 复制一个完整的
' B( r! L. y5 L- C4 \6 I! m
( j8 _/ c; ~ \# o/*===================================================================, D( m# s( ?# Y5 g
5 x$ d0 E& W( \1 A( a; F Copyright (c) 1998 Unigraphics Solutions Corporation% y- k$ ^& `& q0 I% @
Unpublished - All rights reserved4 p9 G+ [, Y( Z# N M
) D: z; e# r" s" U===================================================================*/3 v# o+ t! n; p. f
8 r3 K0 T2 o, }. f* T6 a4 Y1 g, `
/******************************************************************************" ]! B( }# L' R% p7 I% s( N1 A
* *6 N2 i X; V: F/ ]: {7 ~5 ^/ \
* DESCRIPTION - *
% N/ a2 ^# b* ]+ I2 E9 p$ W- D8 X * This program shows how to use the following UG/Open API routine(s): *0 U; R+ s& ~: f, G
* *1 @. T' p0 K- O4 O6 V# I
* UF_UI_select_with_single_dialog *
6 F4 s* n) g7 q) F. ^& j8 ]# _ * *! B! o; }2 U: q$ g3 Q: K' q' _
* PROGRAM DESCRIPTION - ** D9 K: I: s1 B% g
* This example requires an open part. The exampe demonstrates presenting *
4 [( q$ K/ X) k: u$ z" P * the single select dialog and using the initialization procedure to set *8 W; i/ l3 c5 V1 X" M6 @1 `, I
* the object type mask to only lines and edges. *0 S8 `( w3 H/ V( L8 d5 ^! O/ g
* *3 l, R9 y1 Q4 c, v+ s' @
% U, I; Y7 [8 @" ^ * *
4 I! y3 R7 O4 Y3 ]4 q: ? ******************************************************************************/
7 V1 U, |, }& [: d, [
4 E. k$ g5 y# u3 Y; |#include <stdio.h>5 @$ K3 d" N& F/ ~: Y- e+ x% G( _. ^
#include <uf.h>) ]1 e- A- t' [2 J8 z
#include <uf_ui.h>5 s' s0 Q5 R; x. B2 B
#include <uf_object_types.h>. X* R% z* I- N; I( k8 d
#include <uf_disp.h>
3 m5 X# r% J$ E: b T) S% u#include <uf_modl.h>
# A' v* \- Y4 V6 ?#include <uf_obj.h>
4 K/ {! `" x" i5 [4 L. w) Z; n0 w" g6 q q
static int init_proc(UF_UI_selection_p_t select, 3 g) X# U$ `2 f6 U
void *user_data);
& F P2 r6 u8 w) _: M, i' [" ]: |7 d5 R. c- k9 n7 Z# w& f* e
#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
1 y. o* i) M G1 {$ r: \$ I) p% X3 y$ o
static int report( char *file, int line, char *call, int irc)5 T# V7 O! M7 p( R" g" B. N
{) k4 |- f5 j' W: N8 ?9 F v5 m6 |
if (irc)
( D) s" r. M6 Q: d6 e {" {! C/ c' G' Q I
char messg[133];! y9 f9 @! b6 ]/ \2 A/ E
printf("%s, line %d: %s\n", file, line, call);
" T; s) m' I5 O" E (UF_get_fail_message(irc, messg)) ?) f& f- x. t' w0 \8 Y
printf(" returned a %d\n", irc) :. X" s( l) c; o8 B1 S
printf(" returned error %d: %s\n", irc, messg);
) ~) K$ O/ U; l }
. S- C- a" w. e2 p2 C, Y return(irc);! X$ M) e6 i/ G
}, i) w' u* s5 E2 u r
3 a \) z% |$ ]6 b$ U$ u7 D8 i5 @static void do_ugopen_api(void)
p( {. m1 J: U& U2 U{/ b( P1 l9 Z: q1 l4 ~" k: h
char cue[] = "选择对象";
" B$ G {& L I ~% F" c char title[] = "对象选择对话框";
9 c$ {, ^5 F3 Q% r int response=0;" D% q6 p0 v$ [0 V9 I) a" T; i
tag_p_t object;
) _& l1 ~ g1 G, P8 } int count=0;
+ g+ m6 [" A; i, {/ U8 J int i=0; $ O( m: C, c6 M5 Q$ [ }
double pt[3]={0,0,0};! H( p- K" [" E$ e' @7 G6 @
double z1[3]={0,0,1};
9 h5 J8 R! _- w$ _& X UF_OBJ_translucency_t cyt=0;
6 V: o( G2 J- }0 W: r. h 6 Z: H/ ]1 l z9 M+ M! D5 R
* P9 S; @9 N* ? m$ y! @* Z6 ]
UF_UI_select_with_class_dialog(cue,title,0, init_proc, NULL,&response,&count, &object); //选择对象 object需要定义为tag_p_t
! K& [$ o+ H( z4 u8 F : ?: R- w, {4 t9 Q2 v3 k+ U
if (response == UF_UI_OK&&count>0){
- }- [# i2 P! ^
0 A' e6 n; ?: u; H V' V7 C for(i=0;i<count;i++){ 1 e! |; {4 I* Y9 [5 j8 G: A; i
# d- I0 i% x6 E6 T. y" K. O UF_OBJ_set_color(object[i],55); //设置对象颜色,55为UG中对应的颜色号,如果是生成的特征需要转换对象UF_MODL_ask_feat_body
+ B, Y; U$ A+ c# r' e. a 4 H3 w0 Q: ?* X" m* n6 d
UF_DISP_set_highlight(object[i],0);//取消对象的高亮显示4 E: l# I' p3 J K$ ?/ }
! ^* {9 [! g; g UF_OBJ_set_translucency(object[i],cyt); //设置透明度, d1 } T3 [5 f. L6 ]6 @, ]9 J
}9 k$ G6 B: {: f: b* ?) w
) d) {/ g1 o) P 1 m0 _. ?7 d1 c2 g: w6 E
' |, a; r7 I* {7 _& |$ c! h% e, R% \ u2 `4 x+ U& C* X0 [# m
}1 A0 C/ V4 w. ~/ x
+ u( _5 k0 E7 r i5 ?2 q/* selection initialization procedure */
1 t! W9 O5 }% ]: z g! Ustatic int init_proc(
2 n, h' e2 A5 i3 P UF_UI_selection_p_t select,! [" ]$ E) y: z$ R4 X, ~
void* user_data)- T+ G* Y/ M/ q* t
{' l) G9 Y" g2 m! _
int num_triples = 2;
& h9 ]/ P6 D1 P; B UF_UI_mask_t mask_triples[] = {/ T9 k2 s$ O1 `& ]
UF_face_type,0,0,8 l7 |) z/ h/ B5 o& Z
UF_solid_type,1,0( H, g% J! l* |6 y
};/ v- Z g% `: R& h; y+ z" _
//过滤对象选择
, U3 x" ?5 _4 K+ [) |" J
3 s& [9 K5 s) ?1 @0 ]6 D
5 }. L" ?9 @; [4 Q2 A* }1 j" \4 r" x /* enable only lines and edges */, f4 |7 y3 _3 ]; ^; r1 D
if((UF_CALL(UF_UI_set_sel_mask(select,0 ?3 E, J% w9 V0 [9 e, t
UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC,# J8 T' |+ o& K4 [8 Y; K: |
num_triples, mask_triples))) == 0)
) w8 q$ X( Y: ^( F {
+ A4 @# B5 \" A' S return (UF_UI_SEL_SUCCESS); f1 j. t/ b& N
8 s) d9 V( J8 a& f/ A7 x% ` else+ Z$ d7 T7 o: ~- B# Q' I
{6 r; P+ r9 e3 W/ @* h
return (UF_UI_SEL_FAILURE);: \5 H$ F! S, Z, d
}) V4 l6 R, b8 j7 |
, V. s$ S8 ~" k$ f$ e/*ARGSUSED*/
7 e/ o& b0 _) ^ l; vvoid ufusr(char *param, int *retcode, int param_len)
0 R4 B$ |: B$ a{
9 R u* q" p& Z if (!UF_CALL(UF_initialize()))8 D+ x5 N2 y/ M- I0 c0 s( R
1 P3 f2 u9 R! b; Q do_ugopen_api();
6 }4 e4 c+ @) h9 }: V UF_CALL(UF_terminate());: |* p. J' [; y o. g
}" P- b$ `7 j( S4 b. `
}( z! S- b. w% y6 J! S, k/ L
/ |0 A" y' b3 e7 B7 Y; G3 u
int ufusr_ask_unload(void)
) \8 w( C# K) g3 J) {: o8 Q. w, k8 O{
- i# ` @4 B; S+ k% J! ^8 J return (UF_UNLOAD_IMMEDIATELY);
) u- X* c* P1 |6 H3 h}
5 Y" \' K9 S& L6 T4 _5 a9 Z. r5 d3 b
