3 c9 P" _. u* B3 ? }* W
0 W4 q% J& N5 j8 _, A% f( ]( n我在启动Powershape出现这样的提示 为什么 怎么解决 ( [$ K9 G# }& S" a: [' l
. r P) S: ]$ [7 K+ [5 F$ r
: V* s6 \9 A2 Z C+ W0 J' o
( P, ?; D: w7 d% \+ e. ]8 }+ i
0 \% N8 ~+ o6 t3 N* k+ C
启动日志显示 / h$ ~1 s8 D& n
PowerSHAPE Startup Log
4 T& ?- T/ J* _8 [( l0 o ====================== ; ]3 S0 h( s- k6 X3 m
# w7 q3 @) n3 b, O
Check Level : 5 ( Q, e7 x) k- _3 J
Current Time : Sun Apr 15 20:30:08 2007 / u! _( r, a' Q1 @( f
- k* H( c) t4 h- }. \- D. s3 Z k% L$ j
Results
# H9 Z5 A" z" i: r======= $ i5 W* W- D) t. S
' Z8 l- P9 e2 ^2 u/ h! W1) PowerSHAPE installation ok(Check Level 1)
' H+ i- D0 {6 B9 t, M+ N
, U9 ?5 C3 `% c# B, r2) Shareddb installation ok(Check Level 1) / e( I$ O( D" ?( K. A4 l9 a
; o6 K/ C7 ?7 k! d" O
3) Shareddb files ok(Check Level 4) ) H( V2 h7 ]/ t) J3 V M
g5 c7 U6 B& M# f4) Users home directory (C:\pshape5\) ok.(Check Level 1)
+ E; \+ E' X; @( S
1 R" e! E2 h3 x: q$ y2 L6 Y1 C5) Error - The temp directory
6 O! T* s( {- k! ndoes not exist.(Check Level 1) ! M3 v+ {8 k% F. B3 F1 n
3 K4 M8 m4 Q( ]/ R
6) Parts directory ok(Check Level 1)
' s# X% O( C" j4 K, ?6 @& Y- G6 J9 E6 g# F1 `0 J# D e
7) Disk C:\ 8015Mb {of 14293Mb} free, ok(Check Level 3) ; H* O# H* i! V% q/ T/ C* O+ h
/ W# I: F( {" }+ I. m
8) Disk D:\ 3498Mb {of 19077Mb} free, ok(Check Level 3)
) P0 C7 p3 x0 M
- \# I# d) c5 e1 W. HTo start PowerSHAPE and run checks only use the -check_only argument
) ?& h+ C/ _/ w+ F/ w5 ATo disable startup checks use the -check_level 0 argument
: f, ?" r8 t2 k: OTo enable all checks and start PowerSHAPE use the -check_level max argument + [$ M5 F/ r- {
