查看: 1034|回复: 0
[疑难] UG/OPEN打印
发表于 2013-11-9 20:23 | 显示全部楼层 |阅读模式
/* Include files */
; f6 L$ S/ F4 A4 l/ j#include <stdio.h> - W: m; G& y: c) f0 L" m* p
#include <uf.h> ( u6 U; O" o! {" j+ g3 S
#include <uf_obj.h> - ?! z* Z% N) @- ^
#include <uf_part.h> ( s1 i+ `2 W! s6 @  L4 Q
#include <uf_plot.h>
& j  D, o, N/ o1 F- {#include <uf_ui.h> $ _' Y0 d, }; d( o0 {2 e! H% a
#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X))) 4 }- q1 b' B3 B0 q$ `' G
) j  d6 X" U( Q9 Y+ `  @' T5 S
static int report_error( char *file, int line, char *call, int irc)
1 S8 C2 [7 p( \' f1 f{
- r% D$ i" L. M9 r) H# q2 w  ]if (irc)
2 S5 r! a' p3 @{ - E% _# D& N( q0 @5 @' h: O/ e5 e! f( P
char err[133],
4 b3 e0 b% }3 I: Z0 q) s; p2 Smsg[133]; ) I& I5 N" I: Q
3 G/ ]9 C5 E8 \' J: [& l9 Esprintf(msg, "*** ERROR code %d at line %d in %s:\n+++ ",
: E, w: i; Q& d- D. J) E, b; ^4 }irc, line, file);
, x! D, G( }0 KUF_get_fail_message(irc, err);
" r0 s: y3 A( N) Y5 X7 q3 i; J$ h! \; H$ y5 F1 X% U
UF_print_syslog(msg, FALSE); & E$ X5 E& s7 C/ T. B% Y+ X" `
UF_print_syslog(err, FALSE); 5 Z5 M3 R3 b" j* I2 H
UF_print_syslog("\n", FALSE);
. W& E$ N" i" y& N9 DUF_print_syslog(call, FALSE);
$ Q  ?2 N/ s# @, v5 Y2 q3 T+ @UF_print_syslog(";\n", FALSE); , w; J- m1 g( U1 U0 _& u1 e9 u% C% P
: t' l( L- F! j' @. u' y* {; eif (!UF_UI_open_listing_window()) . Q- n6 X: t5 @$ T. h& \
{ & X) F1 j4 y5 A9 _! \: }- j# w! m
UF_UI_write_listing_window(msg);
. e) e) ]& H" I" u. bUF_UI_write_listing_window(err); & n! ]  u6 A0 n, T4 C, b
UF_UI_write_listing_window("\n");
9 Z1 _; L- P0 lUF_UI_write_listing_window(call); 3 W4 \* A+ \9 d% E
UF_UI_write_listing_window(";\n"); 4 r# x+ _; W1 H  F/ u' a( o0 n
% o# i. y& `! G9 o% d# W}
' \4 W' ^! y% N2 L/ }& p, n+ U8 N7 S4 z9 C( r# q( i( _' x& {3 ~/ b
return(irc);
4 z7 T7 ^, s7 a. N} ; o3 m. M4 N# j- J) u
$ m! T% b6 k8 H( C" _3 N0 a6 }
extern DllExport void ufusr( char *parm, int *returnCode, int rlen ) ( Y9 o, D: x( ~* h, [
' o# i) R: t' a: U/ q/ EUF_PLOT_job_options_t job_options;
; w1 v2 G  x# a! ]; K2 l& _  S' iUF_PLOT_banner_options_t banner_options; 6 v1 r8 F+ |, Y5 l. S2 t
char *job_name;
0 s: }7 C1 c" w& a9 g& _int copies; . W+ P7 [5 u4 u. f3 u
tag_t display_part;
% `6 l' k) {- \5 |4 b9 U6 D- Jtag_t drawing_sheet;
% i; D7 G5 W+ `, T' I% l# C% P$ R8 x2 z1 G' ~  x. B
/* Initialize the API environment */ * y/ Z( E! M( Y1 Y5 Z) y9 [' {
if( UF_CALL(UF_initialize()) ) * s/ f6 l% x: m- j
# x! g! _, q. a8 x& _- b/* Failed to initialize */ ( O& u, X* i  L  \( I# S5 m
return; , F3 T! t, ?9 P* u( ~
} . s; ~" f$ k3 B/ O! r% Q
! _! ~% a& u/ q; {7 G- S/* If no part is displayed, do nothing. */ - C+ X# n8 o( B; G
$ h! }0 ?  z0 z1 m/ n0 ~display_part = UF_PART_ask_display_part();
0 c# K. j) L; `6 mif (display_part == NULL_TAG) * C' b5 F% w8 m
6 w' F0 L5 A; D! T/ Areturn;
# }) i4 O0 B5 o/ ?) i# C1 p- m} 3 ~1 ?5 r5 Z0 P& b3 h
/* : ]& _( A6 i, N9 g& d
Get the default job options and banner options for use in " A4 L/ s  A" w& M6 D7 E6 V
the "print" call for each sheet . v: ~' j& \" U6 g# }, K
+ V) x7 D3 d3 K4 o% i& aUF_CALL( UF_PLOT_ask_default_job_options( &job_options) );
! m3 D8 e& T% ^* ?; K3 nUF_CALL( UF_PLOT_ask_default_banner_options( &banner_options ) );
  j: o: o' T* H. e  N1 |( Y; r# i' I9 K% Z  q( o
copies = 1; , g4 B/ K1 ?* P2 s
+ S( c4 e) {  X# g7 gdrawing_sheet = NULL_TAG;
+ ]6 p9 ~* z- K( X1 mwhile ((UF_CALL(UF_OBJ_cycle_objs_in_part(display_part, 8 z  X6 I: d; I  }- }7 i4 a/ j0 n
UF_drawing_type, , P. V* P8 g3 O2 l) `4 p7 f8 u
&drawing_sheet)) == ERROR_OK) && ' \$ r, `6 o; c1 J5 x- K/ i! s
(drawing_sheet != NULL_TAG))
9 Q! n( [6 c+ [2 u+ ]. Q{
  s. c7 e; R; ?! G/ I$ K) e" q6 O/* Supplying a drawing sheet tag causes the default job
9 S- p3 Q& ]/ y/ j4 h3 y: l: dname to have the sheet name appended to it
6 n/ N% c1 J+ _+ J3 ~7 G0 U8 i*/ 1 t, J1 s' K) Z- [$ R+ R( B
UF_CALL( UF_PLOT_ask_default_job_name( drawing_sheet, &job_name ) );
5 \4 K; f# o$ P' P) z
* u; n* }+ b1 X; C5 |, H/* Print the sheet. The "Printer One" printer MUST be
4 d: |% H: A/ }9 J* Z8 z8 q% ddefined in the default Printer group for your system.
3 B3 I. }1 Z7 O/ a8 Q, J& NThe "<System Profile>" profile is the default SDI - a* U- M4 j7 I; M% u
profile. You can alter these two parameters to match ; {+ x' m( g7 R( ]# K( R0 F
your installation.
! V: z, k' s( \! Z: I*/
, }5 W& S: j( w+ Y* kUF_CALL( UF_PLOT_print( drawing_sheet, &job_options, job_name,
0 {, A8 X9 \# Z3 t% N9 [/ T( r8 k&banner_options, "Printer One",
% s1 X4 U- F5 J' Y& c; U) j$ z"<System Profile>", copies ) );
0 ^/ N" a+ l' IUF_free( job_name ); 6 V9 i1 q; N: a
} ! C5 W4 ~! y  N* s4 x- ]2 W) k
5 t) i' j) b8 B
/* Terminate the API environment */
8 \1 z' S  T* w, }( a6 qUF_CALL(UF_terminate()); , `. X8 ^3 l9 W; ]6 e
}   s0 B0 n  c) T
2 J6 ~6 W! D, L3 ~- D% e$ f+ j, `
5 a$ U& c# o9 W# U$ ?- d** Utilities
: ~! W* g% ~0 |+ [, w7 U4 f*****************************************************************************/ 4 Z! Y: p- O7 {6 P9 o
4 e9 V6 [/ ]7 j2 g3 c8 `/* Unload Handler
7 L) S- y; ~9 l** This function specifies when to unload your application from Unigraphics.
% O) m5 W, S2 O& p7 H  e** If your application registers a callback (from a MenuScript item or a   \6 Y2 {* r* w( F, p; [) q  `
** User Defined Object for example), this function MUST return
& G: K4 k1 P6 X, ^+ V+ m+ t% s** "UF_UNLOAD_ug_TERMINATE". */
3 I- E' [, e; Q" d& v9 ]8 j+ Oextern int ufusr_ask_unload( void ) 4 K5 Q/ Z4 T& n4 U( @
9 y9 s8 Y  ?' Jreturn( UF_UNLOAD_IMMEDIATELY );
, e4 `/ U# n& A+ X) q+ U& {; Y} 7 A3 x; @! \4 [/ b. F$ E; _
⊕本文来自: www.2mould.com 详细出处参考:http://www.2mould.com/News_show/2006/11/18/19455.html8 J1 X. c. j+ y
以上代码运生成了DLL文件,
5 B% A' x, N' \( v  B! K可是执行时确出现错误5 x5 j& i( I5 P+ l( r" l5 s9 q  O
$ |# s' f- w, F* lUF_PLOT_print( drawing_sheet, &job_options, job_name, $ q. ?% j# x0 D! h; ~6 {  c$ V
&banner_options, NULL,NULL,1 ); 1 n3 Q' I7 _2 ]* @: [" v( y# P$ H
这段代码我出错,
4 T/ o% w) N4 M- S请问下有哪个高手知道道怎么回事???$ V9 ~/ c5 C/ b( v' `
GMT+8, 2025-6-29 02:35 , Processed in 0.051470 second(s), 21 queries .
