'如何得到Object.Tag
. p& P5 ]0 }( [( o$ k- H( B '遍历得到所有body的Tag
" E3 Z2 K/ b, \8 S 'theUfSession.Obj.CycleObjsInPart(workPart.Tag, 70, objTag)
% M) |: w# u5 ~4 G2 n
3 V" ~& f, t4 E1 R5 t& T2 t9 wSub ExportPart(ByRef part_tag As Tag)
& W0 j, M# x; V0 E4 Q Dim theSession As Session = Session.GetSession()
- t g Q. F8 G% ] Dim theUI As UI = UI.GetUI()8 @( E, E2 v$ y8 Q) B. |4 a' P
Dim theUfSession As UFSession = UFSession.GetUFSession()
: P3 n' T% q, x: }* g; A& y( e Dim workPart As Part = theSession.Parts.Work
0 z1 q/ @# \, e' E7 a. Q } Dim displayPart As Part = theSession.Parts.Display
. z$ o0 i# Y- X% o: y Dim body As Body = CType(NXObjectManager.Get(part_tag), Body)0 A6 I7 X# _; N
Dim part_id As String = body.GetStringAttribute("part_id") '得到属性“part_id”作为零件名称,可以自己设置其他内容9 s+ o/ ?4 t( C7 O) B ?$ F
Try8 U$ L9 B! \! m
Dim fileNew1 As FileNew* l: Z9 t, [2 o# W5 c. \
fileNew1 = theSession.Parts.FileNew(): A1 S) t: G6 c8 e9 }) z2 c
fileNew1.TemplateFileName = "model-plain-1-mm-template.prt" '导出模板名称
7 d6 s6 }2 R6 s fileNew1.Application = FileNewApplication.Modeling* a6 w# [; D$ g6 h5 I( |
fileNew1.Units = Part.Units.Millimeters
& N# \6 P9 l- [) X6 G# R: T- p. L fileNew1.TemplateType = FileNewTemplateType.Item& G$ x* B$ X. w3 R4 }
fileNew1.NewFileName = "D:\" & part_id & ".prt" '保存路径* r4 F- G& C' e8 h6 e; H: I- S+ p
fileNew1.MasterFileName = ""4 O0 P" q4 x1 X1 Y
fileNew1.UseBlankTemplate = False
& j1 P) {- }. p, _4 u7 v8 ? fileNew1.MakeDisplayedPart = False% s/ [+ ~6 _, c x/ H
8 G5 D4 @6 s% B. I) ]8 F Dim createNewComponentBuilder As Assemblies.CreateNewComponentBuilder
" D) s+ A2 a! f! i8 }' t) K$ P createNewComponentBuilder = workPart.AssemblyManager.CreateNewComponentBuilder()
! i& F: J' i* a- v5 d/ g z/ c; K createNewComponentBuilder.ReferenceSetName = "Model"6 ~5 K) h' |; F% p
createNewComponentBuilder.OriginalObjectsDeleted = True '一般设置成False,删除源文件中的对象
3 I2 s! S: Z) q createNewComponentBuilder.NewComponentName = part_id
* G/ o7 R t% O+ d+ J" ]& Y. D4 f Dim added1 As Boolean# b7 X$ {* U1 v! C" E& q
added1 = createNewComponentBuilder.ObjectForNewComponent.Add(body)
( x! [, l: ` I/ D) T createNewComponentBuilder.NewFile = fileNew1
- ^- @4 z6 k8 |! S* {" W+ _" t8 T Dim nXObject1 As NXObject" k, a" |) F* M5 ~& B! {
nXObject1 = createNewComponentBuilder.Commit()% m1 G/ a) m& [' H5 q7 i
createNewComponentBuilder.Destroy()
: b# q x. ^8 g* o8 P# l Catch ex As Exception8 T$ K* ?. E/ |8 H
MsgBox(ex.Message)
y1 \6 v! M$ r5 Q: @# L) K End Try
. W1 P6 N Z) ?6 S. ~7 V End Sub- }1 t* J* g' z4 q) R) Y0 I: I
