( c; Y: c, M; K$ q" {: s4 c4 p: |; h
刚做的德玛吉 海德汉 DMU60 HEIDENHAIN 3+2 后处理,已上机床验证OK! 8 \5 n, g- G1 ~' d/ `" B
Q3 q ~' @, c `, B& _& ]附有参考制作视频段(好压解压)7 M- L) `; D- _2 B, g4 H! g# F
2 p$ ~7 T! ~. p1 P5 m( Q有需要的请联系QQ:253232704
' q% G0 W2 Y. v: X( ~. S" b9 I$ D6 S0 X- r6 q
* S& c6 |% s v" h) G x5 kBEGIN PGM 6666 MM
( Y; i- O# T) L4 R* b8 B7 Z6 [FUNCTION RESET TCPM: C" ?1 O, U& i+ I- _
M127! ]0 S+ k. N- E: h1 D
PLANE RESET STAY! i9 `. I0 [8 s: O: }8 e( k
BLK FORM 0.1 Z X0.0 Y0.0 Z-20.& ~& e' m) k! H" z0 I. `
BLK FORM 0.2 X100. Y100. Z0.0- n0 p6 ]( o0 }! \3 x9 I3 z
CYCL DEF 247 DATUM SETTING Q339=1( {% U, w/ x1 c' h( q. N
CYCL DEF 32.0 TOLERANCE5 W% _$ }' D3 Q
CYCL DEF 32.1 T0.05) w0 M: V" {" P/ i: Y$ D
CYCL DEF 32.2 HSC-MODE:1 TA5
& H' { N8 j8 g) ]: E# z;OPERATION NAME: DRILLING_COPY
. } Y6 k& J l- n& iTOOL CALL 0 Z S1200 DL+0 DR+0
9 c/ f2 C( |# Y$ q2 l;TOOL NAME ZXZ1.5
! _' X) R; R( n9 o' E: P% I% y5 |$ \M13
! @( d( A w* Z- k4 T: w2 nPLANE RESET STAY: M* J) W0 ^, \; H4 j0 m3 o. i
CYCL DEF 7.0 DATUM SHIFT1 q" {, I* b7 x# k% {
CYCL DEF 7.1 X+02 ^* m+ G# O1 Q( }. l! Z9 e
CYCL DEF 7.2 Y+01 B: g* C8 ?6 H5 e3 B
CYCL DEF 7.3 Z+07 w; T8 O$ e# e \
7 Q) n2 ?- q9 W& |$ `% s$ ?CYCL DEF 7.1 X-13.6121
& X2 b0 C+ t ICYCL DEF 7.2 Y3.6952
2 G' P$ k9 i8 A4 O$ fCYCL DEF 7.3 Z3.3986
6 m9 D' r! e2 t. fPLANE SPATIAL SPA7.000 SPB-5.180 SPC-27.972 TURN FMAX SEQ- TABLE ROT
. }4 M! d6 \8 F* RL X0.0 Y0.0 Z50. F MAX. F5 A, n% G1 ]+ {% q
CYCL DEF 200 DRILLING ~. x, t& n e! T) p- V- M$ ?# A$ ~! D
Q200=3. ;SET-UP CLEARANCE ~3 n9 l$ y: }/ @/ C9 v
Q201=-1. ;HOLE DEPTH (incremental) ~9 t M: R& O4 H$ T. t
Q206=50. ;FEED RATE FOR PLNGNG ~* ?1 B. `6 Z- H9 s7 U3 o2 c
Q202=1. LUNGING DEPTH ~
. C- j( s8 A: j* G; K4 c& P$ YQ210=0.0 ;DWELL TIME AT TOP ~2 d6 ~8 I. h; g; g- e. G
Q203=0.0 ;SURFACE COORDINATE (absolute) ~
0 u% ~. N* [: z9 h" ?1 w* g8 YQ204=3. ;2ND SET-UP CLEARANCE (incremental) ~
`- J8 {6 T$ e, @5 e$ pQ211=0 ;DWELL TIME AT DEPTH q% Z( z9 H7 C
L X0.0 Y0.0 F MAX M99
+ K6 ?: Z* u# @$ l' ]9 C& bL Z50. F MAX
# M" V$ Y( G5 ~8 Y# DL Z100. F MAX
' J! h3 t3 a0 N$ y# |7 gCYCL DEF 7.0 DATUM SHIFT, b2 z, l6 ?6 B3 D" o2 r; x, l
CYCL DEF 7.1 X0
" S( Q) V9 \/ G/ ^: FCYCL DEF 7.2 Y0
% w. {& P; B) ~# W- O4 K% r; hCYCL DEF 7.3 Z09 G2 w: X2 a5 a- c, P6 A* ~) h
PLANE RESET STAY
; C0 T- y- f- ^$ P5 C$ A' Q+ D;OPERATION NAME: MM_COPY_1
( s$ n' z- D# |1 GTOOL CALL 0 Z DL+0 DR+06 k; ^$ ]( X8 B9 |+ ^
;TOOL NAME ZXZ1.5, p! V: }- m5 [, ]1 h2 s# L
M13. O! |. x( o+ J3 t; R: M a, Q& C) [$ j
PLANE RESET STAY
( ^* D8 R" c2 ]/ mCYCL DEF 7.0 DATUM SHIFT( v2 m" C9 p8 E* i6 ` f! f
CYCL DEF 7.1 X+0
' _1 `( e* v2 e, U: L6 vCYCL DEF 7.2 Y+0
/ x2 D( {8 M' z6 _: o& {; VCYCL DEF 7.3 Z+0( O/ W% B. [7 j! D! ?9 U
CYCL DEF 7.0 DATUM SHIFT3 {. o& G! U; p
8 j/ b" m3 w; W6 T+ G V% qCYCL DEF 7.2 Y-3.6952
1 N, R7 z% I/ D, ]6 f) F" LCYCL DEF 7.3 Z3.39863 \; Z8 y) H% P1 p" {/ k
PLANE SPATIAL SPA-7.000 SPB-5.180 SPC-29.242 TURN FMAX SEQ- TABLE ROT! |- c5 q$ h5 l. J3 S* |
L X0.0 Y0.0 Z50. F MAX2 X" p7 C) K2 Y/ `1 a+ a W
CYCL DEF 200 DRILLING ~& I! n" D" g- f8 ]
9 G3 x7 V( x1 m) _% C+ m6 kQ201=-1. ;HOLE DEPTH (incremental) ~
% N" V* W. B( gQ206=50. ;FEED RATE FOR PLNGNG ~
) a; K0 F) S5 O CQ202=1. LUNGING DEPTH ~
9 N$ V5 j, r6 m6 WQ210=0.0 ;DWELL TIME AT TOP ~
' X- o, C5 y) m0 F, ~5 tQ203=0.0 ;SURFACE COORDINATE (absolute) ~
7 U; n; e3 Y$ i# }1 q# F+ _Q204=3. ;2ND SET-UP CLEARANCE (incremental) ~5 g( f; b" E5 M/ u
* j/ c4 O. V9 H* _6 p" @7 EL X0.0 Y0.0 F MAX M99( f7 }$ _& ]3 V- L8 P( P" f% z
L Z50. F MAX7 B# y, O+ g, C* @
L Z100. F MAX$ c3 [2 I& S2 H, h
CYCL DEF 7.0 DATUM SHIFT* h+ P# g& i7 _, @
CYCL DEF 7.1 X0" v1 I9 b' J! E& |
CYCL DEF 7.2 Y05 r% L. O7 F- t' ]# o
CYCL DEF 7.3 Z0" s& r0 C9 W4 T0 ?4 b- C
PLANE RESET STAY& m. _! U0 s- g0 s* d' h
;OPERATION NAME: MM_COPY_COPY_1: a; C# P) V# E& b
* l4 v& u1 T2 l8 U. D( Y;TOOL NAME ZXZ1.5 F/ Y9 F0 |5 K% J4 N& h& k% m+ j( `4 e
M133 g; h; E0 v4 \# I
PLANE RESET STAY
! r& y" F5 Z: J9 SCYCL DEF 7.0 DATUM SHIFT7 v% [+ v9 |+ j+ T& }7 c8 [
CYCL DEF 7.1 X+0; d' W" u1 G% ?1 t |5 W- j3 [4 F
CYCL DEF 7.2 Y+0- A" g0 N: G% B# V) S( h
CYCL DEF 7.3 Z+0; G- {5 A0 E9 H* ~
" q" y. f3 Z4 m5 s1 c0 p- PCYCL DEF 7.1 X3.59982 H7 h6 J i* X0 J+ j
CYCL DEF 7.2 Y3.66134 m. T8 |! d9 M
CYCL DEF 7.3 Z2.9588% x& A, g [4 K% ]9 G1 ?, i. G
PLANE SPATIAL SPA7.000 SPB0.000 SPC-28.606 TURN FMAX SEQ- TABLE ROT
1 i0 ~% s1 `% N; ~/ ~L X0.0 Y0.0 Z50. F MAX1 Z6 [. n% l, j
CYCL DEF 200 DRILLING ~3 Y1 S0 s; e+ x/ T( m0 u
! Y( g+ w, d( R) rQ201=-1. ;HOLE DEPTH (incremental) ~; s( U9 ^ u: n% Q
9 ~2 x6 N! J" W' p" s3 r2 wQ202=1. LUNGING DEPTH ~
# q) ^/ m; o/ k) f* |Q210=0.0 ;DWELL TIME AT TOP ~, {/ t( i8 d% M0 P4 Z. f
+ g* ]' l3 `& y' ]: q4 DQ204=3. ;2ND SET-UP CLEARANCE (incremental) ~
1 _% s3 f( H$ o4 ]: A- a" vQ211=0 ;DWELL TIME AT DEPTH/ t/ J' Y/ a9 E4 o3 M
L X0.0 Y0.0 F MAX M99. H# ?; S5 k% u0 L& s. Y/ m
L Z50. F MAX7 a2 c9 B; X+ V# h" b$ n
L Z100. F MAX
$ `0 w1 n/ K9 @0 e9 v0 ~0 RCYCL DEF 7.0 DATUM SHIFT# w: E* }( e# B j" ?% q
CYCL DEF 7.1 X04 w/ f$ W8 Q+ w" o
CYCL DEF 7.2 Y0: D$ [9 w$ s! G
CYCL DEF 7.3 Z08 d: ]& U' N( a; g
PLANE RESET STAY, `: z9 H6 ]4 P$ p, B5 a' W
;OPERATION NAME: MM_COPY_COPY_COPY_11 I, `, S7 l8 h4 [$ j3 N
' R1 {4 Q; g$ Y* t: `% g;TOOL NAME ZXZ1.51 m# y$ `+ D4 [4 {5 e( b
M13
; H" r! f4 t- e- ]+ M' ^, iPLANE RESET STAY( E5 S3 d0 U `& Z. L' n& @1 b
CYCL DEF 7.0 DATUM SHIFT/ X: D$ A# I, S2 M+ J" C1 a
CYCL DEF 7.1 X+0
) o1 a& ~. `+ O( i1 t$ I+ hCYCL DEF 7.2 Y+0& ?; F7 h# z, D9 @, O2 P+ B& P$ [
CYCL DEF 7.3 Z+0
& M& O6 g# L" N6 K5 X" _' U( `% GCYCL DEF 7.0 DATUM SHIFT
9 P, F- m' x0 bCYCL DEF 7.1 X3.5998
+ L, U0 t0 m7 S6 G/ Y% NCYCL DEF 7.2 Y-3.6613
6 u r) y- X+ m" o$ uCYCL DEF 7.3 Z2.9588/ S9 R% }9 S" h$ \7 g7 [4 o5 P
PLANE SPATIAL SPA-7.000 SPB0.000 SPC-28.606 TURN FMAX SEQ- TABLE ROT0 m" P6 t1 ` @4 g: q' V
2 n1 ^2 R, Q& h9 j$ T0 S. s3 kCYCL DEF 200 DRILLING ~
9 i+ h, X/ }4 i" L& I% [" B+ bQ200=3. ;SET-UP CLEARANCE ~: s& [0 H0 ]) f4 R' M) ]
2 r# R9 X( ?- u7 @0 EQ206=50. ;FEED RATE FOR PLNGNG ~( Z: `+ o0 D# g- S0 t6 w: z
- u" R( F6 g5 z8 n' c! ^& FQ210=0.0 ;DWELL TIME AT TOP ~
$ w# V" [4 y. k% K, Q, GQ203=0.0 ;SURFACE COORDINATE (absolute) ~2 E* b5 e+ H% r( S
Q204=3. ;2ND SET-UP CLEARANCE (incremental) ~$ W7 V3 G; f& }: O
Q211=0 ;DWELL TIME AT DEPTH6 q) R" u& Z1 ^6 h& a
L X0.0 Y0.0 F MAX M996 D* {: B2 }% E t/ e) p# C, E
L Z50. F MAX
, |( l7 l3 S) }: O6 gL Z100. F MAX: U, J0 F( b/ t+ g: j& \
# l. ]2 k, V, r6 `% nCYCL DEF 7.1 X0
* S5 U/ k0 c" I% B. u8 ICYCL DEF 7.2 Y0
! y- M' x3 Z2 C. ZCYCL DEF 7.3 Z0
' G# [6 ~7 ^" m* WPLANE RESET STAY! y! F' i' l. H3 U/ i# q2 E. Z
;OPERATION NAME: MM_COPY_COPY_COPY_COPY_1
- X, u. N7 x/ S: @: {( N3 zTOOL CALL 0 Z DL+0 DR+0
* W6 d& d7 F- W0 M;TOOL NAME ZXZ1.5
# w: E2 p$ i( r5 y9 Q* ~M13' e4 w9 I! y% l- L( @0 h
PLANE RESET STAY
2 w P7 v4 Q5 }% q% f; m/ dCYCL DEF 7.0 DATUM SHIFT" h/ i/ [- a3 }4 w) D) {6 Y, g
CYCL DEF 7.1 X+02 H/ }4 n( s% l' N
CYCL DEF 7.2 Y+0
: K; _2 T# |4 s% T$ s+ r3 M& ICYCL DEF 7.3 Z+07 d& x( P+ `1 I2 O+ n' m0 _
CYCL DEF 7.0 DATUM SHIFT- J% G( t2 v3 l8 A# f) ?' @
CYCL DEF 7.1 X13.6118+ s2 n/ X( m$ S) a" R
7 t5 O. G* I$ I3 FCYCL DEF 7.3 Z3.39859 u5 @& Y0 Z# b( A
PLANE SPATIAL SPA-7.000 SPB5.180 SPC-28.606 TURN FMAX SEQ- TABLE ROT
3 A& E9 ?/ T1 EL X0.0 Y0.0 Z50. F MAX# [5 M! \ i- S9 M' g. h
CYCL DEF 200 DRILLING ~+ l0 O+ B, e# R, |
' \/ |* Z, X! ]7 e% JQ201=-1. ;HOLE DEPTH (incremental) ~
2 }6 H9 U1 o5 a2 u, AQ206=50. ;FEED RATE FOR PLNGNG ~0 y0 B/ i9 l& y, K5 C$ g' d
0 I$ M* r& l. V' {+ F7 r8 G! f- BQ210=0.0 ;DWELL TIME AT TOP ~
# V+ x; W! y3 c& b/ fQ203=0.0 ;SURFACE COORDINATE (absolute) ~" K8 T1 x( w" k. |5 W0 X9 p' D) K
Q204=3. ;2ND SET-UP CLEARANCE (incremental) ~' S. \0 B9 ~! F# w+ @' a4 h
7 ^) N- J8 X$ z; l% u- ?L X0.0 Y0.0 F MAX M99+ t" K# p" k: d" p3 i+ }2 l1 }
L Z50. F MAX
$ \- X; `4 l( e" \: v. `9 cL Z100. F MAX
/ u5 g- V8 D |5 L( R: @CYCL DEF 7.0 DATUM SHIFT. e' e3 g$ h4 u5 x0 |: z
CYCL DEF 7.1 X0; o4 n1 z' h' d
CYCL DEF 7.2 Y0
) D; K$ |# |9 s2 Y, aCYCL DEF 7.3 Z0
& |- U1 b# Y9 _# n9 v5 i3 @PLANE RESET STAY
! h. l; T/ B+ S5 ~6 H- [/ j% D. T;OPERATION NAME: MM_COPY_COPY_COPY_COPY_COPY
' h" N7 L0 D" N6 K: L( d! O. GTOOL CALL 0 Z DL+0 DR+0; Z9 X) T/ }6 u; z, B6 L3 } B& A
;TOOL NAME ZXZ1.5 a& U8 j0 P5 d6 n9 W. K
M13- k1 }$ h3 ^' b: C, C! h1 w. B% ?
PLANE RESET STAY
( J' x5 p5 q# w9 v9 wCYCL DEF 7.0 DATUM SHIFT4 j+ N T v1 X" y. m
CYCL DEF 7.1 X+0
) A0 C6 [4 E4 @; v- gCYCL DEF 7.2 Y+09 ? Z1 }' H! r3 |# @* Q. }
CYCL DEF 7.3 Z+0; R, K- P! @$ C3 z' r
CYCL DEF 7.0 DATUM SHIFT8 Z, g- } D$ Y2 z& S d
CYCL DEF 7.1 X13.6118' _& N' _) V9 K# }1 W% t
CYCL DEF 7.2 Y3.6952- E* r7 @7 Y" {0 O
" j1 v, T h9 b( G! d7 PPLANE SPATIAL SPA7.000 SPB5.180 SPC-29.876 TURN FMAX SEQ- TABLE ROT, N- v- u, q" S/ Y1 T! L# t
L X0.0 Y0.0 Z50. F MAX% J. e: C! z; S8 I3 J/ `4 K1 N6 Z
CYCL DEF 200 DRILLING ~, W7 ^" {- I8 h- _/ o1 p5 g9 O+ E
/ U/ l) v3 N f3 }6 L4 }Q201=-1. ;HOLE DEPTH (incremental) ~; I( C% l& b/ _$ G7 k5 v# w; }
Q206=50. ;FEED RATE FOR PLNGNG ~7 p* b. ~9 j! Z9 G% ~& f2 N
Q202=1. LUNGING DEPTH ~$ x- i5 t3 H0 Y" t& z
Q210=0.0 ;DWELL TIME AT TOP ~! s0 s" k# J4 ?3 @% ~1 c( s; c2 K3 k
( {" c- {' Z. B# W& SQ204=3. ;2ND SET-UP CLEARANCE (incremental) ~1 b3 n8 \& @$ B( _1 D
- G- y+ X) ?- B! Q5 A' ^, kL X0.0 Y0.0 F MAX M99( F1 G8 |6 Y! c. i0 e
L Z50. F MAX, p- p/ {% ]) g! k( _
L Z100. F MAX1 A5 Q! q2 j# k( T; q( M6 f1 I1 Z
2 k6 d$ M/ u7 b- nCYCL DEF 7.1 X0
+ S$ s# ^8 d- i- ZCYCL DEF 7.2 Y0# M6 `) u6 c5 q- K1 w6 F; R& U' A
CYCL DEF 7.3 Z0
0 ?8 B- ~/ A! `5 R- SPLANE RESET STAY
9 r9 g0 d+ D3 b% n;OPERATION NAME: DRILLING_1_COPY_2
! b9 m8 [! w$ M% N' O6 bTOOL CALL 0 Z DL+0 DR+05 `+ t9 R6 h5 k b$ l+ f- p) M9 L
;TOOL NAME ZXZ1.5
7 \* Z4 U% k- KM13
k/ i4 a) d/ K9 B ZPLANE RESET STAY
]/ O$ q {# `5 J. L, F! c5 ~0 k" vCYCL DEF 7.0 DATUM SHIFT+ l" w/ M4 t3 ]/ m+ z( h& i. Q, F$ b
CYCL DEF 7.1 X+0( p+ }0 G9 w* v
CYCL DEF 7.2 Y+0: l9 d% n- x' Y
CYCL DEF 7.3 Z+0) D8 r2 J a1 f, {- H
N; c# ~0 Z: W) I3 DCYCL DEF 7.1 X-11.4916( U) m1 ?1 U. e2 G3 r! z) {" j4 n# l9 U
CYCL DEF 7.2 Y3.7112( q4 r* B8 F; C4 t; j; {3 A
CYCL DEF 7.3 Z3.2683
0 v' k$ A0 H8 W* F' r4 x1 c4 ZPLANE SPATIAL SPA7.000 SPB-5.180 SPC-29.876 TURN FMAX SEQ- TABLE ROT" {8 @& C0 R; M; u
" f/ ?/ M: w# M; f+ B- i& rCYCL DEF 200 DRILLING ~1 U1 a9 g. v( m1 r1 l) W5 a
/ m0 k- @) P# j) e! W' D4 oQ201=-1. ;HOLE DEPTH (incremental) ~
. ?. V( k: J% T W" }Q206=50. ;FEED RATE FOR PLNGNG ~) I7 ]" I! A+ K
. a( F' k0 r( k8 nQ210=0.0 ;DWELL TIME AT TOP ~
: @* K7 K% W; l- T a: AQ203=0.0 ;SURFACE COORDINATE (absolute) ~" Q' V6 `% s7 ^; D) \3 b8 `
6 T9 @6 M$ E$ W9 XQ211=0 ;DWELL TIME AT DEPTH: Q; x' C2 Y( X% }# y% u, h9 U3 z5 W
L X0.0 Y0.0 F MAX M99 V+ u# h* Y1 c5 r% C/ f
L Z50. F MAX E' l4 z3 `* Q% M9 f' Q, k, J
L Z100. F MAX2 t' Q! L( [2 e% j3 _
CYCL DEF 7.0 DATUM SHIFT- O: B0 A$ B0 k
CYCL DEF 7.1 X0
9 j1 ?+ M( V/ ]" e nCYCL DEF 7.2 Y0# z) v! N, L. x w
CYCL DEF 7.3 Z0
9 _; |& b# b0 @+ _8 ^: E3 Y+ uPLANE RESET STAY
& p9 s8 V& T; W; \;OPERATION NAME: DRILLING_1_COPY_COPY_2
9 ?0 E& e0 V" j7 ?0 e. p% P8 X$ CTOOL CALL 0 Z DL+0 DR+0
1 A. X$ s9 O, O;TOOL NAME ZXZ1.5
0 ] M0 w- R }3 X6 hM13
+ I1 {8 B( J. v0 @. E# YPLANE RESET STAY
& Z9 k) g1 X& z' |: X+ oCYCL DEF 7.0 DATUM SHIFT) b! W% e6 S: d' h
CYCL DEF 7.1 X+06 f, z, N3 c. _( } [7 i
CYCL DEF 7.2 Y+0
3 H! Q/ ~# d+ {- P3 D9 MCYCL DEF 7.3 Z+0
; G& A, Q- X s4 N( f3 a* eCYCL DEF 7.0 DATUM SHIFT: a) d; L6 |8 K
$ |' }) x* r" z8 Z7 {CYCL DEF 7.2 Y-3.7112
* B6 t0 f2 c0 W4 v; ~5 YCYCL DEF 7.3 Z3.2683
# L% j3 w; l; iPLANE SPATIAL SPA-7.000 SPB-5.180 SPC-31.146 TURN FMAX SEQ- TABLE ROT
8 j/ ?; q& ?% vL X0.0 Y0.0 Z50. F MAX2 `" Q2 A% Q4 u/ u5 C7 f
CYCL DEF 200 DRILLING ~7 ~7 H$ G- D. `" M. z
]* b+ c& a: y' ] tQ201=-1. ;HOLE DEPTH (incremental) ~" s3 G2 G1 W. c+ ^+ L3 i1 v+ `
Q206=50. ;FEED RATE FOR PLNGNG ~- M" [4 v7 G# }9 u+ U
; j$ Z6 L' l/ \Q210=0.0 ;DWELL TIME AT TOP ~' q$ _+ b3 w! k \! |" q
. F( i: g& u7 u" @Q204=3. ;2ND SET-UP CLEARANCE (incremental) ~
/ N& d+ S/ A* r% M. u; hQ211=0 ;DWELL TIME AT DEPTH% Y! _. B5 l- r
, D! G1 w3 x5 Y& c' D lL Z50. F MAX
7 A) J6 N/ L1 jL Z100. F MAX' B$ @6 a* a) w
CYCL DEF 7.0 DATUM SHIFT: q! p4 X2 K9 y, U/ j
CYCL DEF 7.1 X0
8 O8 i, R: i- [* w* J9 \* W4 C; B4 Q0 mCYCL DEF 7.2 Y0
5 `$ a3 O+ W( q" N( Z4 HCYCL DEF 7.3 Z0
8 K4 \* Z. F: _' g# APLANE RESET STAY( t* r( B% P# D+ a& ^1 q$ }
;OPERATION NAME: DRILLING_1_COPY_COPY_COPY_2
0 B$ K. z2 ]. Z2 {! Z* aTOOL CALL 0 Z DL+0 DR+0% J$ o7 J/ X6 B5 |1 e& O) s
;TOOL NAME ZXZ1.5
0 w$ {9 f8 F) u% M2 qM13/ y. `* y; @* T. y6 X
PLANE RESET STAY
6 M( w6 K; r* dCYCL DEF 7.0 DATUM SHIFT4 B5 }" C% Q9 w
CYCL DEF 7.1 X+0
3 ]9 m+ D: ~' Q2 @0 }. vCYCL DEF 7.2 Y+0$ X1 b( ]$ K' R1 e: U" C4 ]
CYCL DEF 7.3 Z+08 Z3 M5 n* |5 V0 O* Y1 Y4 K3 F1 h5 E8 s
2 I9 {7 G# e/ @2 y8 nCYCL DEF 7.1 X-5.7002
: J. [3 l+ W" R; iCYCL DEF 7.2 Y3.6554
( ~8 L; s, U) @1 t6 [! P7 MCYCL DEF 7.3 Z3.0067
+ Z6 ?* I1 w$ h) o6 _; U- bPLANE SPATIAL SPA7.000 SPB0.000 SPC-30.510 TURN FMAX SEQ- TABLE ROT. i$ _" H* M l1 N* Z
L X0.0 Y0.0 Z50. F MAX: R( s* G1 G' d) x- W( o
' x0 F8 s* r' D, GQ200=3. ;SET-UP CLEARANCE ~
% F' C3 T( M* ^" n G5 yQ201=-1. ;HOLE DEPTH (incremental) ~
/ H, `2 I, [, {; g2 rQ206=50. ;FEED RATE FOR PLNGNG ~
& a+ t+ \0 }, q0 r' b- P. r& TQ202=1. LUNGING DEPTH ~
9 [, ^& E! C0 g- Q' E1 oQ210=0.0 ;DWELL TIME AT TOP ~
. f' c8 f z+ ?1 q n- P; VQ203=0.0 ;SURFACE COORDINATE (absolute) ~4 @3 u$ Z* X0 v T1 y
Q204=3. ;2ND SET-UP CLEARANCE (incremental) ~8 w% d/ _; Z' V& ]9 v8 `% Y q
! g4 f) U4 m' K/ TL X0.0 Y0.0 F MAX M99
$ G) z( o q0 z: `5 i1 w7 g5 u3 A% @L Z50. F MAX4 \/ x6 Z/ o+ }, X8 h q0 B& s; [
L Z100. F MAX
4 Z! e, Q2 Z( O4 s1 R% QCYCL DEF 7.0 DATUM SHIFT9 f( U f; t! O! p
CYCL DEF 7.1 X0 p- m2 I6 d5 k
CYCL DEF 7.2 Y0
$ B0 s6 L/ }; I* F' C* j1 k! M8 q* b7 bCYCL DEF 7.3 Z0
, Z+ s! A4 P( k) w' B; I9 W, B( mPLANE RESET STAY
8 |$ h3 W/ |! V+ u- dL Z200. F MAX0 z% B# B9 o' `3 T N' F# f' p
M126
1 d1 P# E6 C. f. B1 S* YL B0 F MAX
9 t( \% i% C rL C0 F MAX+ X: p8 F" B& ~* e
M127' p. _; ]$ K% H6 @
M5
8 J; }! e- m* r& C% K0 RM9
7 v/ u/ U s1 g' U& B& F3 ~+ AM30! u/ D1 j8 y/ O" H' [- z
;MACHINE TIME 0.95 MIN
1 z- Q# q0 l+ x" r T% B2 yEND PGM 6666 MM$ W/ R* E$ B+ `+ M' t) z E5 A- b9 `
, Y3 O' Y5 D4 G* |- ^ j* C( ?2 J: ]) T! L$ w9 R
) }7 f* z/ n8 ?; b |
DMU60-1.haozip01.zip
1000 KB, 下载次数: 723, 下载积分: G币 -1
售价: 1 G币 [记录]
DMU60-1.haozip02.zip
1000 KB, 下载次数: 587, 下载积分: G币 -1
售价: 1 G币 [记录]
DMU60-1.haozip03.zip
1000 KB, 下载次数: 589, 下载积分: G币 -1
售价: 1 G币 [记录]
DMU60-1.haozip04.zip
1000 KB, 下载次数: 529, 下载积分: G币 -1
售价: 1 G币 [记录]
DMU60-1.haozip05.zip
928.96 KB, 下载次数: 653, 下载积分: G币 -1
售价: 1 G币 [记录]
