IGES to UG' W& _& ~ q, I, e
! INFO- NX V7.0 / IGES Specification 5.34 X5 s, a) l& B: C) e/ V/ x
! INFO-
% L9 u y( f& e1 K( d- y- G! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM
8 K0 f% j$ a% u3 y# q! INFO- 6 a* j0 o9 n+ k# I3 ~. r3 ~$ j
! STATUS- Converting Part: F:\01.03\GMT.IGS
4 x" Q. I/ P/ m3 ~2 v7 V! INFO- SolidWorks IGES file using analytic representation for surfaces
@& w9 ~ e! B& m1 P! SUMMARY-
. Q! S/ G1 g- [- n8 u; ?! SUMMARY- Summary of Supported IGES Entities in file; @7 t& b9 O. _/ W) b6 ]
! SUMMARY- 0 T" |) y7 Y+ \8 a
! SUMMARY- Entity Type Count4 q3 l4 Z E, \8 g
! SUMMARY- ----------- -----
( T7 R# t0 w7 F' \# ~1 a, ` T! l! SUMMARY- Line (110/0).................: 680
. M( S9 m6 h, x# g# D! SUMMARY- Circular Arc (100/0).........: 4305 O- Z4 e. S) \! n* c
! SUMMARY- B-Spline Curve (126/0-4).....: 1335
8 U+ Z8 U& a" j! SUMMARY- Composite Curve (102/0)......: 448
* Y' u1 Y; x' A3 ?( U v: V! SUMMARY- Surface of Rev (120/0).......: 92) Y$ O* ]+ j: H9 E
! SUMMARY- B-Spline Surface (128/0-9)...: 126$ O7 w1 l2 T, Z) d1 ~' Q' ~
! SUMMARY- Curve of Surface (142/0).....: 224
& x: }- k2 `9 r( V, E8 L) o7 M2 c! SUMMARY- Trimmed Surface (144/0)......: 218
5 o# r0 o5 j& c) Q- H/ U$ _! SUMMARY- Trans Matrix (124/0,1,10,12).: 3288 }9 n i4 v% w+ ~
! SUMMARY- Color Definition (314/0,1)...: 1
1 I# m: c2 B7 I N1 Z( z! SUMMARY- ------ y3 a5 I U* q! a* B
! SUMMARY- Total 3882
# \0 v/ s5 y" l, ^! STATUS- ) R$ W/ m5 Q- a4 |
! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM1 K! B4 P$ `: x* v, }
! STATUS- $ t( X0 c' G' R' Z8 d3 x' B
! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM- h0 ]! ]$ [9 e6 I, Z7 c1 C
! INFO- Degeneracy in b-spline entity 851 was corrected at or around these! v, r% e, m* q8 G) i" s; y5 l
! INFO- locations. A shape change has resulted:4 p, \( v2 [5 F, p. C6 S
! INFO- 0.666707 0.386276 0.000000
. N- n- S* Q2 h4 P8 p! INFO- Degeneracy in b-spline entity 939 was corrected at or around these
% c0 x7 ^& @2 A! INFO- locations. A shape change has resulted:, T4 M* _/ ?5 o6 S$ L
! INFO- 0.333082 0.386447 0.000000/ k/ v+ g! N+ c9 O1 `
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these) n9 u% q8 q$ ?, L4 Z
9 o1 @( i* V) F! INFO- 0.017365 0.057973 0.000000
7 }& e& [* D: a/ L: C+ ]1 X! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these
2 ]# `2 {" K: q* N9 h8 K1 K! INFO- locations. A shape change has resulted:5 e3 M, T3 a5 o8 N8 A8 e
! INFO- 0.982661 0.058577 0.000000
* }9 i; P& t6 Q# `* G2 f! INFO- Filing Part ..: F:\01.03\GMT_igs.prt S z3 Y( b3 L. n
! SUMMARY-
8 v, z, B8 M- Y3 A7 z! V& U! SUMMARY- Summary of Unigraphics Input Entities
- y! C; T. [( Z1 L! SUMMARY- 2 M$ R u2 l% S1 F/ x# P, ]& e
! SUMMARY- Entities Processed Count; e: ~) g2 b7 v- E. y* ^
! SUMMARY- ------------------ -----. L. I& W! S4 D4 A3 a% d% P: `
! SUMMARY- Part Attribute ..............: 8' b* M+ [ _, Z, }# X O. s! V
! SUMMARY- Solid .......................: 218
' r: ^9 z! v, B) D6 J! SUMMARY- -----
/ d' {" z" W$ D! SUMMARY- Total 226$ V6 P, f$ s" C S
! INFO- _2 h: G+ `' r% N$ W* K* d
! INFO- End of Translation: 3-JAN-2011 12:11:38 PM
6 M6 p- i4 V2 f7 O% q" v. c! INFO- ! [; y8 j! z% U! t" |9 e$ c
IGES to UG* ^2 Z: z/ \) g, y: I& _
, t. N% G G+ u2 n2 M t! INFO- 3 X$ Q0 v2 q, [( \9 R- p
" d$ G3 j; n0 L) a1 l8 j3 T! INFO- & T) E% p' C. X0 _
$ `9 P$ q6 n) \' ?0 f, C# H' j! INFO- SolidWorks IGES file using analytic representation for surfaces H: x* }) `6 `$ z% B0 Y
! SUMMARY-
8 @9 e4 ~/ w6 e1 K: R( e+ A# V! SUMMARY- Summary of Supported IGES Entities in file
[9 B6 `' x2 z% l5 k" T! SUMMARY- 7 t. I0 {8 A* S4 ]# W/ K# t( f
5 _6 l! I0 `% H0 E A% c! SUMMARY- ----------- ------ P7 Y8 D2 u1 |3 k( P
! SUMMARY- Line (110/0).................: 6807 J$ w/ x( h E5 w, [9 F% I
! SUMMARY- Circular Arc (100/0).........: 430! C" \( p6 w0 D% u1 n
! SUMMARY- B-Spline Curve (126/0-4).....: 1335" T9 Y1 u1 ~: W G9 h5 N+ F i
! SUMMARY- Composite Curve (102/0)......: 4481 h2 S- Y9 R" t
8 w6 g0 q# G6 _9 Z) M2 J% C9 s+ _! SUMMARY- B-Spline Surface (128/0-9)...: 126
. V+ u' f( `' z, D! SUMMARY- Curve of Surface (142/0).....: 224
) A; Q- x& a7 Q& ~; b9 v! SUMMARY- Trimmed Surface (144/0)......: 218
7 B; ?" Y3 X% K2 `" f! SUMMARY- Trans Matrix (124/0,1,10,12).: 328+ A( Q2 ^+ ~& V6 H9 D& h
! SUMMARY- Color Definition (314/0,1)...: 18 n1 |' k7 l, j
! SUMMARY- -----
/ L) P! A% C9 X7 B( o, M3 ]$ L# z! SUMMARY- Total 3882* H5 |; u8 ~# T/ i- ?- n ?1 g
! STATUS-
. C# k) e, \) Q& N! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM
, S) G; p7 g. @, X! STATUS- ) c7 @1 c7 o: z. ~, n% x9 ^
6 q8 w2 f, q8 e! INFO- Degeneracy in b-spline entity 851 was corrected at or around these
5 l* R5 }' C( a* g% J! INFO- locations. A shape change has resulted:
\0 d5 Q" n) {) m4 `' J5 W! INFO- 0.666707 0.386276 0.000000& S# e t) h; R5 E: p. d p
! INFO- Degeneracy in b-spline entity 939 was corrected at or around these: b8 w% l9 \+ l8 M2 b: A/ i
! INFO- locations. A shape change has resulted:( V% y( T l7 N
! INFO- 0.333082 0.386447 0.000000! u7 E1 [. x2 S; m; }3 v7 W
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these7 O9 T5 n+ m3 N& M0 Q6 P
! INFO- locations. A shape change has resulted:4 h2 f9 l; _; }, s4 O9 y
2 F) U' E% w' |, b. q: L! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these
! g. }7 T# e, T! `& o! INFO- locations. A shape change has resulted:
' w( M, ?. w8 d7 r: F+ R7 Q" q- `! INFO- 0.982661 0.058577 0.000000# q0 |" d# g. R6 R' o; O
: F/ a9 C7 o5 {6 ^# F! SUMMARY-
# }' K+ y; X% h/ A- a# G! SUMMARY- Summary of Unigraphics Input Entities7 m) E$ i. K" t" i, B# l, f, D4 G& j
! SUMMARY- ( ^2 D" p# g; L0 R- T- b
! SUMMARY- Entities Processed Count, ~, ]* S0 @* h3 R1 E
! SUMMARY- ------------------ -----* V5 r2 ]/ W6 Z- T
! SUMMARY- Part Attribute ..............: 8( R. i: Y1 Y) w/ g1 Z& L% G& K3 q
! SUMMARY- Solid .......................: 2183 N+ B/ x$ z% e7 y% B3 }: H
! SUMMARY- -----
3 ?+ ^& X" F$ W2 L+ d! SUMMARY- Total 226
9 S9 B4 ~7 q- V5 L( Z# U! INFO-
8 V9 _% B) V; R. m- O! INFO- End of Translation: 3-JAN-2011 12:11:38 PM6 M T' j0 [% b. g) m9 B
! INFO-
: q- \" `' S' e; j* EIGES to UG
0 N/ k& f" `6 f! v; Y/ i! INFO- NX V7.0 / IGES Specification 5.3% w5 c+ \8 p# v" Y9 ^+ u6 O
! INFO- : [0 E) d2 f, p5 x
g4 y$ j N/ m+ x( |7 R1 w2 q) T2 T2 R! INFO- 1 M0 @# i v1 w. i
: n( n9 v1 J3 l8 T6 K- \! INFO- SolidWorks IGES file using analytic representation for surfaces
2 B6 ]0 z, G1 S* d! SUMMARY-
. q! k n# n4 U! A& S8 u! SUMMARY- Summary of Supported IGES Entities in file0 q9 j) t6 Y3 d. M @
! SUMMARY-
9 Z. T. [ X, u2 l8 ]9 M" {! SUMMARY- Entity Type Count4 V4 q; v0 ^, R: S# M5 B$ |. `
+ R8 A/ D8 T2 m! SUMMARY- Line (110/0).................: 680
: T) ~, Z* ?$ v$ a9 |& S! SUMMARY- Circular Arc (100/0).........: 430
+ R* `" V" a' n3 N6 V+ {1 X! SUMMARY- B-Spline Curve (126/0-4).....: 1335
# T4 k0 _. ?; T! i/ J0 R! SUMMARY- Composite Curve (102/0)......: 448
4 `* ]1 P" u0 b/ u! SUMMARY- Surface of Rev (120/0).......: 92
K d" u* c: V$ F2 U7 V" N( o! SUMMARY- B-Spline Surface (128/0-9)...: 126; m0 n: `/ D4 r. @( Q% _# V/ p
}$ T7 w J1 Z. v$ j, E/ L: t! SUMMARY- Trimmed Surface (144/0)......: 2189 A, G/ V( R1 `- p; E% X
! SUMMARY- Trans Matrix (124/0,1,10,12).: 328; `; \2 g! L7 ?
" X# [- e8 i/ m3 L! SUMMARY- -----
% n2 v4 l9 ~" \$ x" J! SUMMARY- Total 3882
( F( ^0 G" G' X* @! STATUS- / D6 p9 Q% o+ p c) H& [4 N0 @% _. o
! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM9 k) }( `' l5 ?& Z: ^6 `
! STATUS-
8 p$ Q8 H, l% A* F6 C) G% H! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM
0 _# Q$ C" S7 S) Y' B1 S9 Q* Q! INFO- Degeneracy in b-spline entity 851 was corrected at or around these& N4 [$ j, _; I* h& j( P j: c
0 p% t# m, ?! i+ s( C! INFO- 0.666707 0.386276 0.0000005 i6 i6 l6 D' M4 Y( \. _9 t
w9 t* X$ D# o6 r% Z7 b! INFO- locations. A shape change has resulted:& {, ` H7 C- P i8 x7 \4 F
! INFO- 0.333082 0.386447 0.000000( [/ V, _4 }! [1 D" [* [3 W8 O
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these h3 t: H+ C4 n. S, B- j' i
! INFO- locations. A shape change has resulted:& |+ l U) ^6 a f1 ]
, r7 I0 [* N0 x, U% S6 H @! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these
7 D) @4 `. d* }- X) A& q- t! INFO- locations. A shape change has resulted:
4 g: ~4 B1 z" V# H5 R6 w- S% F! INFO- 0.982661 0.058577 0.000000
$ }2 X0 v6 |6 d$ `& ]% |0 V! INFO- Filing Part ..: F:\01.03\GMT_igs.prt1 t4 x' S) w5 i! b
! SUMMARY- s( D I- t' O, { G
% P+ H3 ?* E5 I) y$ N! SUMMARY- " \& L, a& k4 g2 Z/ e: R
# m; q' T# m/ W" X/ J0 p+ Y! SUMMARY- ------------------ -----
% H+ ^: A% a* q( T: d! SUMMARY- Part Attribute ..............: 8; _" y+ l3 `* x: a$ y% H! ^3 e0 @4 I M
! SUMMARY- Solid .......................: 2187 B: |1 e! ?5 ]& S0 f, x9 k! E
! SUMMARY- -----
3 S+ x# I# h- b: y; T! m! SUMMARY- Total 226% `. M: H1 M- e7 q6 x5 Z$ |: x- D$ I
! INFO-
) ? Z/ c6 }& J4 ]9 a. L! INFO- End of Translation: 3-JAN-2011 12:11:38 PM
" H! [9 ]% M! }* S! INFO-
. ]* q* ^( l; ]IGES to UG* _; J; F3 V) o9 l
! INFO- NX V7.0 / IGES Specification 5.3% q8 e! p" G; B/ y9 i2 w
! INFO-
. l5 s0 o0 z8 U! k7 p! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM7 V( o8 e" J1 W+ |. y9 {
! INFO-
- L ~5 F3 l7 m/ c! STATUS- Converting Part: F:\01.03\GMT.IGS
" M; @( q# K/ m/ J4 z! INFO- SolidWorks IGES file using analytic representation for surfaces
, C2 h+ m9 G, x1 M0 W8 t! SUMMARY-
" B0 s4 z; R$ U! SUMMARY- Summary of Supported IGES Entities in file) `) y# x6 r* R, h. B& a: X& S: {
! SUMMARY- - @. a+ p% P2 `9 S
; C2 e' t8 P# k3 r9 V& z: W m! SUMMARY- ----------- -----, A3 W- b' W+ q0 t- K0 b% C
! SUMMARY- Line (110/0).................: 6806 e, I0 x1 } [* a) V- }- d. s
! SUMMARY- Circular Arc (100/0).........: 430: ]* S+ J+ D+ u! \
! SUMMARY- B-Spline Curve (126/0-4).....: 1335# N* m9 \/ d: i! M. H( i2 V
! SUMMARY- Composite Curve (102/0)......: 448 L. }+ Z' u, t2 w( P- x% Q1 h
- r" X5 [, k( G5 G; G! SUMMARY- B-Spline Surface (128/0-9)...: 126
& h6 V% x6 h7 d# ?2 _$ u6 ?! SUMMARY- Curve of Surface (142/0).....: 224
0 Q$ g! a2 Q7 I/ a) W, s! SUMMARY- Trimmed Surface (144/0)......: 218! C" i- g( K8 t& g! b8 Q7 D
! SUMMARY- Trans Matrix (124/0,1,10,12).: 328- ~/ t; j( K5 ?4 \* c+ @1 h
! SUMMARY- Color Definition (314/0,1)...: 1, W$ X0 A, K& I/ g# L0 O# n
! SUMMARY- -----
, T3 Z) H- p) R8 w3 i0 E* _- x* b! SUMMARY- Total 3882
$ R; Z4 J/ N! p: S$ ~; d& e- Y; W! STATUS- # z& S; T2 l3 I6 |8 ~% e
6 }. m( [" A% m5 @- q( V) h- d! STATUS-
) }2 I2 C2 o5 b$ E0 K! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM
( |7 c4 ?& `9 y/ o- G+ B# R) {2 B! INFO- Degeneracy in b-spline entity 851 was corrected at or around these
4 s+ S7 p) ] |1 ?6 \5 n1 R5 j; e! INFO- locations. A shape change has resulted:
`0 Z& Z6 J, i7 C Y2 F1 h. r! u! INFO- 0.666707 0.386276 0.000000- b! M. B! N7 l- P, @* p" o% ?
6 ^, V- s& ~/ X; T! INFO- locations. A shape change has resulted:6 o/ D% i. Z$ d4 D. _. i$ {, z
! INFO- 0.333082 0.386447 0.000000+ x4 T# p! p! y
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these/ ]) D: _0 w7 V, i
! INFO- locations. A shape change has resulted:! C; ?# D6 T- m4 Z4 B0 w& w
) v: ? f4 M; p6 h9 g1 E. s! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these
# K0 j7 I* }9 a! INFO- locations. A shape change has resulted:6 w. m6 t8 s: Z' n' P% e
" S6 r8 c4 n9 }, Q5 ~! INFO- Filing Part ..: F:\01.03\GMT_igs.prt
( e% C. q' f& e7 U! }! SUMMARY-
+ C( ?2 ^, q. j! SUMMARY- Summary of Unigraphics Input Entities
/ |2 J& e' ~. |! SUMMARY- " m! s5 H9 ?! C; V3 w a2 O
J7 o9 Q' M* K' o6 k3 A! SUMMARY- ------------------ -----; b- }* Y" c0 f7 E0 I) Q. X7 L
" o9 Z* }7 s3 g( n" b7 \ L7 I! SUMMARY- Solid .......................: 2180 H8 B7 b, n; [6 P# A- O9 G
! SUMMARY- -----
! F3 _5 i. {( h6 X- U% p8 R! SUMMARY- Total 226( x6 r# I9 E. n3 o
! INFO- 5 @( y; q# _$ H* _
! INFO- End of Translation: 3-JAN-2011 12:11:38 PM+ \) D8 y9 j, M! U) n8 j. u
! INFO- V9 W+ v8 f" \: ]: v, f% h6 ^
IGES to UG" n+ W3 ^" g$ i3 v, f- J b# q2 m
! INFO- NX V7.0 / IGES Specification 5.38 t I& l! k5 ]8 q
! INFO-
# D7 ?5 Y( ^ G- _+ W! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM
. G, a2 P4 U# s3 H, P4 ^ \, x/ \! INFO- , P. i; \2 Q, H
1 F/ u- J7 x, L9 n D! INFO- SolidWorks IGES file using analytic representation for surfaces
: V7 z4 J5 i l8 w! SUMMARY-
; o ]. s. K2 C1 ^4 H3 K0 J1 Y! SUMMARY- Summary of Supported IGES Entities in file1 ]6 y$ [6 G* a% [: n
! SUMMARY-
2 `2 E" _* O6 T2 H2 Q. q2 m! SUMMARY- Entity Type Count5 r4 _) @0 I. R: L% e# P/ I
$ J4 |$ M3 I5 M( v- [8 s0 J6 e! SUMMARY- Line (110/0).................: 6809 U" Q8 a5 I, P) d: z) W
! SUMMARY- Circular Arc (100/0).........: 4307 x$ u% u' z, w9 k
0 \- _. o" r- ^+ s7 a! SUMMARY- Composite Curve (102/0)......: 448; q. H, N$ T0 h# S; ?5 o$ |
9 x$ R' N. W( P% A! d7 `! SUMMARY- B-Spline Surface (128/0-9)...: 126
( w3 i% g4 p+ |+ F2 k, i! SUMMARY- Curve of Surface (142/0).....: 224
* K* [, G! u6 V! SUMMARY- Trimmed Surface (144/0)......: 218# I. y/ s/ [$ B1 p
! SUMMARY- Trans Matrix (124/0,1,10,12).: 328! O0 a( m$ O1 b
: u% I' e5 c: E/ r/ y% Z& d2 X) @! SUMMARY- -----* z" S6 [+ R6 x" q( G) k% T! q
* }( ^6 C; ^8 Q& x! S% L3 i! STATUS-
- h5 ?9 p7 a: D4 b# D! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM6 I$ ^: H7 ^! A. B! l" H/ R" l# A
! STATUS-
& T' I7 D4 c5 X" i, q' Y% L! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM. b$ ~* l6 I# f" B
2 s8 x3 q0 }* C! INFO- locations. A shape change has resulted:
' R6 ~# a5 ^# x5 w3 K! INFO- 0.666707 0.386276 0.000000
8 K7 _1 {. C3 a3 O7 P4 w! INFO- Degeneracy in b-spline entity 939 was corrected at or around these
: h9 c3 c% d5 g. U( m% r+ I! INFO- locations. A shape change has resulted:
( m- f# y) I8 O3 D. }! INFO- 0.333082 0.386447 0.000000
% P4 T( x: m [! G! a4 v) \! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these
, Y! g0 \0 l- {( {6 R) M5 l! INFO- locations. A shape change has resulted:" @; Q6 ^* y9 Q* V7 B; f- ?% D
! INFO- 0.017365 0.057973 0.0000002 k1 c q& z# ^7 S9 {6 U
! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these# E0 ^' a8 C2 W( }" j5 @, T1 H" T7 ?
! INFO- locations. A shape change has resulted:. l* A* j: q6 W( d& m6 Y! Y& n
4 e9 f# |6 p1 Y3 P2 y1 H! INFO- Filing Part ..: F:\01.03\GMT_igs.prt
V, t* U' H5 g. O, q! SUMMARY- 8 C' M( J8 Y7 g! L7 w: q6 O
/ t7 t9 r, T4 P& s. J; t6 t! SUMMARY-
$ t% w I- X$ O- _7 ]: e! SUMMARY- Entities Processed Count
$ ^; G: {& k% ?+ I# l9 w! S1 @6 `! SUMMARY- ------------------ -----, [! _/ k0 q! z( f0 I, ^
% d. B) W. u, o, w& ~) |! SUMMARY- Solid .......................: 218, q( @, N$ [5 z9 J+ i L
! SUMMARY- -----
+ J/ d) i5 ?$ T/ _/ Z) Z# Z, e9 i9 Y! SUMMARY- Total 226; }: ~- }: @4 O' Z9 A1 }2 ]
! INFO- # c( N, o D/ G7 L2 A
! INFO- End of Translation: 3-JAN-2011 12:11:38 PM& I- W/ f8 z) u* h
! INFO-
( F7 L, N4 ?' ], {" E; h! iIGES to UG G* S) d, w, q% z" Y& J6 p0 E
; ^& E3 H+ l" P8 R6 y5 P6 M$ {' R! INFO- % r1 `' H* \# I8 p& G: ^+ r
3 g: q. i$ ~1 Y5 H4 D! INFO- - [; i$ T+ H4 _; w( |/ I
9 K$ u% v- K2 z2 R! INFO- SolidWorks IGES file using analytic representation for surfaces
: u' v4 @9 r: v; w! SUMMARY- * C3 |# y8 X2 @" C, g" Y
' |! J$ t* q$ t! SUMMARY-
( q- S$ U0 y. z4 M* A* f. d' z! SUMMARY- Entity Type Count, t; R! v7 G3 { V2 R0 D
! SUMMARY- ----------- -----! A3 @! H9 M) V/ I# T( G
! SUMMARY- Line (110/0).................: 6806 H; k1 O1 _* |: f8 a% w
0 o6 k5 e) X: l- c3 q) {+ u! SUMMARY- B-Spline Curve (126/0-4).....: 13353 q0 m7 U- w0 i7 T% L
! SUMMARY- Composite Curve (102/0)......: 448% o. F% E6 z* Z
$ h1 G- l4 j6 g9 p0 v. L! SUMMARY- B-Spline Surface (128/0-9)...: 1260 K: |2 n% H% U' V) _& c. C
! Z2 p0 L1 v$ x9 o5 }$ R8 t' }! SUMMARY- Trimmed Surface (144/0)......: 218
, _( ?& ~2 P& a& E* b! SUMMARY- Trans Matrix (124/0,1,10,12).: 3287 T% g- s, O* e+ O3 l8 B
! SUMMARY- Color Definition (314/0,1)...: 1 G( C* s+ O( u
! SUMMARY- -----% R, J8 `9 `% Z
+ x. L8 u6 o& ]2 @- L! STATUS-
- H" k, T( l: `! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM
" R% {, ]+ b' L2 b. G J, x' K! STATUS-
: v; L. x1 W) s! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM
. _' D0 w2 s2 M+ _0 v. ?! INFO- Degeneracy in b-spline entity 851 was corrected at or around these
7 S7 h! q b8 F6 n. w! INFO- locations. A shape change has resulted:0 S; `. t6 {3 v6 R& G% \7 L" c8 ]
! INFO- 0.666707 0.386276 0.000000; w0 F1 R* e3 A( p* y( S! b
$ _. E! J9 L* U8 k+ K$ t+ B$ ^! INFO- locations. A shape change has resulted:. m+ y9 c: e n2 [! q* a+ D
! INFO- 0.333082 0.386447 0.000000. C; |* R7 Q6 g5 R6 _4 Y
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these" b! C3 X3 t) D6 J/ u
$ G R* B+ Z2 ~0 m3 [! INFO- 0.017365 0.057973 0.000000* Y( K; U) e5 {# E# B
! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these- O! C7 H1 Y7 f/ h$ t o
! INFO- locations. A shape change has resulted:+ `* U% e; T2 B3 `6 }: a
0 O* ]0 q! H! }$ l! INFO- Filing Part ..: F:\01.03\GMT_igs.prt
- H& p7 j/ `3 M+ z! SUMMARY- - ~" K; w' E) d2 V8 ~6 L0 T
! SUMMARY- Summary of Unigraphics Input Entities) V& r2 a4 a0 W
! SUMMARY- 2 {0 S2 L* U9 A+ w. H. f* Q/ j
! SUMMARY- Entities Processed Count" R, j( \8 Z; h4 Y$ D9 n+ j
! SUMMARY- ------------------ -----# c) p" D- `& i9 l3 S! p6 ?! F
! SUMMARY- Part Attribute ..............: 8& {3 k. k- N2 O& F" `9 C0 V
& Z2 W3 ?# `& J, p3 F! SUMMARY- -----
4 H( d3 Q5 ~) Z8 v1 ?! SUMMARY- Total 226) e0 o, T" k. s
! INFO- % N: Z8 r( S; H+ x
7 T: ~/ R! O0 |! INFO-
6 l! m: x- b0 w! jIGES to UG
7 X2 T7 x3 G' S5 b9 Y! INFO- NX V7.0 / IGES Specification 5.3
* I ^# _! u5 p( P! INFO- 0 Z T0 |, W( \* R: L Z1 L( H- n
! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM a* ?2 [( @/ ~7 d3 `
! INFO-
, v0 p# k3 e. U) o) V5 u. H j! STATUS- Converting Part: F:\01.03\GMT.IGS
- l5 y" n& |( C6 i" Q! INFO- SolidWorks IGES file using analytic representation for surfaces
8 v7 T1 Y+ y* O; }8 r, {! SUMMARY-
5 N& w* x+ q0 O T! SUMMARY- Summary of Supported IGES Entities in file8 I. l! N3 e% b" Q7 m; W0 f
! SUMMARY-
4 |& R9 `: G( P! SUMMARY- Entity Type Count
. l9 X5 c: T% Z# {9 A" C! SUMMARY- ----------- -----4 R+ I* c& p( i5 f6 Z5 u; E3 k0 o
! SUMMARY- Line (110/0).................: 6805 M( v5 @. A$ H+ O
* O* W" ~. P5 o+ O" ]) W, E! SUMMARY- B-Spline Curve (126/0-4).....: 1335- R) z( o3 O, u( i. Q, [
$ J; J7 [! J0 e4 O4 {! SUMMARY- Surface of Rev (120/0).......: 92
- O0 T* E7 G* O' T! SUMMARY- B-Spline Surface (128/0-9)...: 126 e. @" f. ]; k( t. e% P1 i
' D1 v4 M# H3 }5 K. H! y! SUMMARY- Trimmed Surface (144/0)......: 218# A0 m& S0 ~: t
% V* _: m% P3 Q# `$ ~! SUMMARY- Color Definition (314/0,1)...: 1
, S M% n* [( h! x1 v" Q! SUMMARY- -----
1 j: f/ D# J' w2 o1 `! SUMMARY- Total 38822 @% L; e1 d5 G: P. U9 w
! STATUS-
$ _/ ~* R9 u6 `; J! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM
+ U' o7 [3 S- @4 z$ v4 P& R! STATUS-
, i! h- p, t9 |5 S! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM1 X+ s# C" u0 O/ b" F8 \5 X) d0 P2 Q
! INFO- Degeneracy in b-spline entity 851 was corrected at or around these- i6 O8 z% X$ K8 A4 U3 Q$ {$ R
: r' |$ C. c+ O* T `! INFO- 0.666707 0.386276 0.000000+ o7 S; j6 m9 l1 M
! INFO- Degeneracy in b-spline entity 939 was corrected at or around these( M2 \# z3 m9 e z& p
! INFO- locations. A shape change has resulted:9 Q! t( z% T- i& P4 v4 K6 J7 ]
! INFO- 0.333082 0.386447 0.0000009 j8 R: L% q7 l+ T
/ ]; c6 S) q& \- A. Q) o. F, t! INFO- locations. A shape change has resulted:" ~4 b+ D h( b. A- h0 j1 _
! INFO- 0.017365 0.057973 0.000000: G( g ~& c$ C( Q
! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these' z' \9 a/ M* C% e; \2 R5 _+ @! n
R( ?' C4 x- J* [0 P' J' `3 [! INFO- 0.982661 0.058577 0.000000
8 g5 ~8 O# ?6 H3 a4 l! INFO- Filing Part ..: F:\01.03\GMT_igs.prt
1 H% P6 K7 W& U6 g7 B8 W4 T! SUMMARY-
' |' A c+ ~' f8 h' {& X q& a! SUMMARY- Summary of Unigraphics Input Entities- |/ g4 y" L3 `9 Z: q/ T. e4 H
! SUMMARY-
) q A9 }+ D; k# _! SUMMARY- Entities Processed Count( H! j4 R" V; o
! SUMMARY- ------------------ -----9 G" \( |% X& ~
! E/ A3 |% W+ D$ L! SUMMARY- Solid .......................: 218
1 V L& q" U1 @! SUMMARY- -----
$ P6 N/ |5 s, O! B! SUMMARY- Total 226
: y+ B* S7 ?: \4 ~ X: ~- L, c- u! INFO- 3 x: s. H% h) `) U) }
/ b; l K5 A7 t) ~0 J! INFO-
1 `$ l5 S+ f( C, B% pIGES to UG0 V3 z p; ~: k& i; A
! INFO- NX V7.0 / IGES Specification 5.3. \% N0 k2 H4 m+ [1 r
! INFO-
; t. H$ P* y: K. H5 F0 }! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM
$ z1 ~2 V9 l3 k9 t" w; ?! INFO-
! r% O: ?/ X4 N# A! STATUS- Converting Part: F:\01.03\GMT.IGS
) s5 X8 _/ ^ |( A; [( n; E% j) ]3 `4 ?! INFO- SolidWorks IGES file using analytic representation for surfaces
% g: J+ t$ \' v& h4 o0 Z/ o! SUMMARY- ' q; j ^9 H! K
! SUMMARY- Summary of Supported IGES Entities in file+ a$ v' B& a/ q! F( J
! SUMMARY- # E5 {. M* Z- S1 [2 G
! SUMMARY- Entity Type Count; w* i; ]% b* j4 e6 O; @% |0 ?
! SUMMARY- ----------- ------ Y0 p* h3 Q4 O8 N
% K v5 E3 H, R" s! SUMMARY- Circular Arc (100/0).........: 430
+ r, W5 K+ N+ s! Z' M ]# n! SUMMARY- B-Spline Curve (126/0-4).....: 1335
0 y9 l" `, b6 s- l! SUMMARY- Composite Curve (102/0)......: 448
0 S, m$ [- f5 _9 S! SUMMARY- Surface of Rev (120/0).......: 92) P" M2 B i8 q2 \; N2 \
! SUMMARY- B-Spline Surface (128/0-9)...: 126. ]% C' c7 x C: b. f: |
& A0 T& J M9 k7 \2 P! SUMMARY- Trimmed Surface (144/0)......: 218- }* i7 d0 K8 [; K. _, Z U2 @" Y
# z# [" d: @& {& v# D) h! SUMMARY- Color Definition (314/0,1)...: 1, R+ H8 t2 E" U- V; H
! SUMMARY- -----2 T6 W1 c r' R6 [( Z( n
* M# j' o1 U1 b: G. g7 B! STATUS- 9 g" K7 u4 j) ~0 Q1 ?
! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM& B% K' U3 @- d7 ]( h
! STATUS-
I; e8 r6 ?0 A" C, r! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM
* R9 O6 B( q$ e+ U8 m! INFO- Degeneracy in b-spline entity 851 was corrected at or around these. L# f$ T/ z @1 j' i, u
9 c1 Q# v2 W" ~$ S0 V! INFO- 0.666707 0.386276 0.0000007 y& |% t& p' v
8 E# J( ~: e# b+ I# I! INFO- locations. A shape change has resulted:% T2 s* }: m7 ?
! INFO- 0.333082 0.386447 0.000000$ |0 C5 W! L- [4 M7 \
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these% s5 o- j% @) ^# F8 r7 T: j- z* d; P
- Y% s7 `: R5 X; n: Q0 A; R! INFO- 0.017365 0.057973 0.0000008 r. B0 D7 P2 [$ |9 X- W3 P/ U
! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these _$ l1 M+ ~" `1 a& W& C
! INFO- locations. A shape change has resulted:. ^3 L" p/ H) x* ?) h# @1 x
L% z$ m% |9 ]! INFO- Filing Part ..: F:\01.03\GMT_igs.prt2 k5 h: t2 z% k& C! o
! SUMMARY-
. y6 T' H( l3 |! SUMMARY- Summary of Unigraphics Input Entities
w$ m# w& n; @; ^/ K- p$ h! SUMMARY-
$ b3 C! B! _( C7 X0 v' ]! Y! SUMMARY- Entities Processed Count7 L: ?! I- Q+ M
0 R2 J; [9 w" s6 j! SUMMARY- Part Attribute ..............: 8) ~( Y; e4 m/ \+ L3 ?$ h) N
! SUMMARY- Solid .......................: 2189 _- h+ l4 H! B8 S; I8 P4 l/ E$ C
! SUMMARY- -----
4 V) {7 U3 n F& p0 X" z. v- z! SUMMARY- Total 226
7 T' I. o& R. Z! INFO- , [ l l0 @' Q- ?
! INFO- End of Translation: 3-JAN-2011 12:11:38 PM# x( R X) w$ O3 P1 u
! INFO-
$ _; S' a) x- E! B6 tIGES to UG
, f: L# c9 V) W$ i2 n3 V3 x9 ?! INFO- NX V7.0 / IGES Specification 5.3$ h" Q8 ?" f2 b& \: k( t
! INFO-
2 [+ K4 _% {4 H/ |& R8 _6 {! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM
0 y3 F8 z2 C5 k4 c- L/ |" h! INFO- : H" [. J, ~; ]$ y% @
4 D' N; e7 Y& Q) w! INFO- SolidWorks IGES file using analytic representation for surfaces
) C" N. m) ?* b P( j3 ~; ^! SUMMARY-
: P1 ]) T1 S( c8 }( m" }! SUMMARY- Summary of Supported IGES Entities in file: B z) |$ u9 ~; l
! SUMMARY-
: `, M' t- ]4 Z/ J, L! SUMMARY- Entity Type Count) z9 n% j0 S. S
! SUMMARY- ----------- -----9 u% W0 W: i6 ]+ `8 Y0 |/ e# Y- N1 r
! SUMMARY- Line (110/0).................: 680. q f+ p* E6 u$ B" i
! SUMMARY- Circular Arc (100/0).........: 4300 `7 w2 X* k: Q+ v8 P) C7 y
! SUMMARY- B-Spline Curve (126/0-4).....: 1335; S: D: z1 Y7 P" T' {5 Z# J
! SUMMARY- Composite Curve (102/0)......: 4483 B, A" m4 l9 T! \
0 n4 W8 s$ [ D1 B1 @% ~! SUMMARY- B-Spline Surface (128/0-9)...: 126
* j; ?( |& [+ o E; e; v9 |- l' T$ y! SUMMARY- Curve of Surface (142/0).....: 2244 Z! L' b) b: I) Y( C0 f5 {$ w
! SUMMARY- Trimmed Surface (144/0)......: 218! F0 _- k6 O/ R2 B
, `/ M% x$ @5 T$ u Y# h: k! SUMMARY- Color Definition (314/0,1)...: 1" O7 ^2 J- Y5 ]8 y
! SUMMARY- -----
. b6 r6 v5 R" p8 |$ S8 ^0 U3 L! SUMMARY- Total 3882
; I+ f9 t# c4 o3 `6 L' j! STATUS- 5 A' W! j, y/ W9 m: G$ `
% N7 F. {* l7 Z, e! STATUS- . O b8 |2 _7 f5 D+ j: G
0 I' R% S+ M. n* j! INFO- Degeneracy in b-spline entity 851 was corrected at or around these
' q; ^& s" _, o; T4 g4 `; i! INFO- locations. A shape change has resulted:
# P% _6 L8 J7 M) X$ \& X/ g8 L! INFO- 0.666707 0.386276 0.000000
4 g$ F9 Y' ?1 ]- g! INFO- Degeneracy in b-spline entity 939 was corrected at or around these8 j4 m/ z5 N; ], G' \
4 t! P4 g2 \& U( I! INFO- 0.333082 0.386447 0.000000 ?7 c5 M' M/ q k
4 t. T% c- k# a9 F5 g4 c" a" V! INFO- locations. A shape change has resulted:8 {% z5 J; T/ {- ^" N8 T! s" T
) |8 c; p3 [8 G* w' {5 O/ `$ [5 _, u5 p! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these c' x$ c" w/ N8 I: r/ R* z
, j; K/ F1 e! l2 G; \4 E! INFO- 0.982661 0.058577 0.0000007 k' f5 B/ {5 R; w) `2 j2 V D
( }. I& x6 l( B: ~8 C! SUMMARY-
5 f! y0 B( }4 e* g. |! SUMMARY- Summary of Unigraphics Input Entities$ W& {& a- t; K: s2 k) z
! SUMMARY-
( m( N1 q) \, v+ h' K! SUMMARY- Entities Processed Count
* j% }" X( _- |1 z' g! SUMMARY- ------------------ -----& w) g: D( I" a) z& R- K9 k/ G3 v
! SUMMARY- Part Attribute ..............: 81 }6 }, `# m4 N1 D" F
' [3 z: p: Y* y& A- b. ~. V0 n! SUMMARY- -----
( m1 }; R1 ` `* r. Q! SUMMARY- Total 226! }1 `' w$ v8 m% |
! INFO- + w& j6 S: w% b. G% K
, T) H5 k2 w5 `; H" b" O- Y! INFO-
- z9 h" ^" }1 v ^ tIGES to UG
/ u; h% P9 {: I" B$ x4 i/ F! INFO- NX V7.0 / IGES Specification 5.3
0 `- L4 v' K: S* k8 @! INFO-
, R& w |, `, K! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM L# t4 M) p8 W
! INFO-
# {* _' W( I4 ^- F9 d3 g! STATUS- Converting Part: F:\01.03\GMT.IGS
3 X# d' u3 @1 ~) s* n! INFO- SolidWorks IGES file using analytic representation for surfaces
) j9 P2 a% V6 J! SUMMARY- 3 r- d% q- D6 L% B* L t( a
9 f( H3 Y" x- Z! N" _* A+ ^, T! SUMMARY-
/ b+ w5 M7 _. o' h' i! SUMMARY- Entity Type Count' O. i. @* m# F+ n2 u7 w8 n+ Z. Q$ u; T
: U1 J; e0 Q; j- @/ e/ R! SUMMARY- Line (110/0).................: 680
, q3 \3 O1 C* o9 M) r# y4 B! SUMMARY- Circular Arc (100/0).........: 430
$ s: G4 u4 e& _# r! i9 u# d, e% ~! SUMMARY- B-Spline Curve (126/0-4).....: 1335( y1 o' f6 _" n/ v
! SUMMARY- Composite Curve (102/0)......: 4481 ^1 ]5 s7 g% _/ X* x
! SUMMARY- Surface of Rev (120/0).......: 926 k( x( W2 U# n* H" m
" P$ d2 U6 M8 N* X, e# G# c! SUMMARY- Curve of Surface (142/0).....: 224: o. r: `3 z+ @: d7 B
, r5 u, L) _- l3 P3 Q$ i! SUMMARY- Trans Matrix (124/0,1,10,12).: 328
% N7 w0 J- R9 B+ w' h5 w) Y- g/ M! SUMMARY- Color Definition (314/0,1)...: 1
' |" U3 J, W" w# H; m! SUMMARY- -----+ i- j8 _0 x8 N/ M
( r- E/ ^- C0 h# R8 v! STATUS-
8 n+ {& H% `0 H# i$ I9 ?! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM
# `* Z' }( y5 d. ?$ w/ b! J+ h6 h! STATUS-
3 U+ }$ m' u8 X# l: I; H! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM5 [$ {0 N% G0 d2 ^. V. v
# z' E% F# \* e. w! INFO- locations. A shape change has resulted:- u# i' Z0 N- \1 w2 L; w
' v! `* w9 Q: i! INFO- Degeneracy in b-spline entity 939 was corrected at or around these8 m. Z5 O5 V+ g* c
/ ?. V7 R N5 m$ S7 U6 f! INFO- 0.333082 0.386447 0.000000& g" Z1 i" T' L
' w4 Z6 v: U1 |; r& y# O6 H n! INFO- locations. A shape change has resulted:* @ V, D8 M& h( u" Y6 K+ \. H4 K, Z
! INFO- 0.017365 0.057973 0.0000000 E [9 S/ R l5 K& G! S
! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these# O. Z% y" G4 f( z; |& I
! INFO- locations. A shape change has resulted:4 {+ E7 ^ ~( F" i& _ j4 d4 p- w
# E+ a& k8 o: S" P* {: U3 o1 y1 i! INFO- Filing Part ..: F:\01.03\GMT_igs.prt
; V! U; ]1 H; L5 o4 i3 u! SUMMARY-
2 \* g+ v# Z. e5 G! SUMMARY- Summary of Unigraphics Input Entities. c5 ?4 E" e) E0 k0 p7 j* X
! SUMMARY-
! x1 o5 M! H7 Y" L% L; [0 L5 d Z* [! SUMMARY- Entities Processed Count. X) S) i0 K, [3 \: _# \
! SUMMARY- ------------------ -----6 D6 z# A* ?' g: p& Q7 J
6 e! q+ P" ~. m" |# w4 }! SUMMARY- Solid .......................: 218
* e2 k4 @0 x9 N! SUMMARY- -----
, {7 P: \( Y8 W6 @& Z! SUMMARY- Total 226
* }: x/ q6 v: s( O! INFO-
3 @, j& h: J' y! INFO- End of Translation: 3-JAN-2011 12:11:38 PM
9 S- {+ E" }& K# Q6 a/ v: p- g3 T: \! INFO- * b# B3 a+ Y; |. o2 k1 W( o7 W" |
IGES to UG: x$ j4 o2 ^) g6 h2 o8 v/ E4 v# }
! INFO- NX V7.0 / IGES Specification 5.3! g0 [5 D5 X* i1 B0 h5 n
! INFO-
' }% P; x& c/ K$ Y) q5 A' j9 f+ ?* C! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM8 m) e9 V- u- Y/ f: r% U F
! INFO- 2 T' c* G7 I' N
! v* \2 o$ Y3 U* Q! INFO- SolidWorks IGES file using analytic representation for surfaces Y7 n8 L( s! q" J, D
! SUMMARY-
6 y6 M& h3 a1 f* f; C; V- c! SUMMARY- Summary of Supported IGES Entities in file
& ^! G" x g/ A( c6 g! SUMMARY- 2 Y3 A( S9 c7 o) r% f
, x& H. M8 ^- G2 ~; |! SUMMARY- ----------- -----
9 K" D( a% M( S' u O; S# t+ i! SUMMARY- Line (110/0).................: 6801 }9 N# ~7 H h' @
- E. z* n6 D8 }1 C7 ]! SUMMARY- B-Spline Curve (126/0-4).....: 13359 h& {% M% [$ o6 \% {
! SUMMARY- Composite Curve (102/0)......: 448! k- w& Y$ Q+ l; F3 x- B
! SUMMARY- Surface of Rev (120/0).......: 920 m. C) Q+ i& b+ O" I
% J3 }- I9 H: U! SUMMARY- Curve of Surface (142/0).....: 224
% Y2 P2 U$ O" }" n! SUMMARY- Trimmed Surface (144/0)......: 2180 Z* X+ @7 k% P/ c+ {
C4 i& g3 T+ J* B6 z8 G i! SUMMARY- Color Definition (314/0,1)...: 1
3 c' P" ^+ @8 D @( u* ^! SUMMARY- -----
7 c( v5 y$ }$ |0 r) H$ ~! SUMMARY- Total 3882
+ s- W+ N- k. s; o3 f! STATUS- 6 ?2 U0 }6 e, d& H2 ^( {. k( z
! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM+ X+ |# g& C# M. P- t
! STATUS- . F; H# t! z4 Y6 q
3 }8 ?# o' C" W# |5 e2 u- S! INFO- Degeneracy in b-spline entity 851 was corrected at or around these6 H" W0 k' P6 L% |$ f. P
! INFO- locations. A shape change has resulted:; f# P y7 @1 `& p1 E- C
! INFO- 0.666707 0.386276 0.0000000 y* P: j7 }. J3 Y5 W8 d! Z) D
" o8 K+ o) J9 H- I& O; A7 }4 I. u! INFO- locations. A shape change has resulted:8 e( X K; p5 t( l) O. ?' L4 u
! INFO- 0.333082 0.386447 0.000000! V8 G+ Q1 S7 B* R# A( C" O; P/ j
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these9 H {' J0 {. M) j& j8 t
! INFO- locations. A shape change has resulted:- J$ x) C `0 w/ B/ Z
! INFO- 0.017365 0.057973 0.000000 g+ R. M8 m# K' \% J
! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these0 b, m& ?6 T8 a. ?, z* O+ f* X
! INFO- locations. A shape change has resulted:1 I+ I+ T7 I1 X( {# u* w6 v8 o
! INFO- 0.982661 0.058577 0.000000; G/ d, Q, @/ Z6 e# q
5 f, s( X- N0 q9 ]! SUMMARY- 8 ^+ Y- c2 M' ?5 R: B1 ^
! SUMMARY- Summary of Unigraphics Input Entities4 X- F- p" k# ^- {6 @: {
! SUMMARY- / v/ E" @. z$ q: \* |+ b5 Q4 r9 T- q
! SUMMARY- Entities Processed Count s" ], P, F# U* D- ~, U5 Q
" g! D# U! \. Z$ y, [3 ?$ Q( c1 C! SUMMARY- Part Attribute ..............: 8
8 Z ?6 ^: k; s2 {. y8 Y9 M- h9 Z! SUMMARY- Solid .......................: 218* \; ^2 o1 C6 x. Y: }, f& D. R
! SUMMARY- -----" k9 `1 ^! f" |& J" ], ?
# P8 ^5 v2 \7 E! INFO-
; B* F/ t; k; \6 N3 p6 A/ @! `, f! INFO- End of Translation: 3-JAN-2011 12:11:38 PM2 w9 }+ L. `9 K ~/ c. i
! INFO-
2 j+ d" H# }: K1 m2 u' WIGES to UG/ ?; L! o* U: z5 G, p4 P- v
( n# N0 q+ B5 m: Q! INFO-
& E9 v1 z& M& D, p" O0 J! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM7 _2 h# Z% S% U8 x
! INFO-
; h* C6 ~! D0 S: u! E" e* l/ l& _5 v! STATUS- Converting Part: F:\01.03\GMT.IGS
' g: ?6 b x5 S! INFO- SolidWorks IGES file using analytic representation for surfaces
& W V: Q. A+ T$ Q7 Q; ?! SUMMARY-
6 c. Y( U3 @& I$ x' v/ l, J! SUMMARY- Summary of Supported IGES Entities in file+ v* _) V1 c) }
! SUMMARY- " Y" h9 n# p: n& [& `
7 O% w& M/ h1 I( z0 {! SUMMARY- ----------- -----
" n/ ~! m6 g1 u% o6 F0 B$ W/ H% `! SUMMARY- Line (110/0).................: 680
# c' m- U( @# j+ b) C( f! SUMMARY- Circular Arc (100/0).........: 430
, m1 N6 T2 [* k) M" B' Y; e! SUMMARY- B-Spline Curve (126/0-4).....: 1335+ M7 z0 a W! F7 z
! SUMMARY- Composite Curve (102/0)......: 448 J! j( X0 _3 \7 T5 p9 ]" Y1 d
2 R. ~+ F9 r/ x6 \9 @6 ]! SUMMARY- B-Spline Surface (128/0-9)...: 126
. f+ y; k) t. L, O1 s! SUMMARY- Curve of Surface (142/0).....: 224: Y+ M5 p% t: c
! SUMMARY- Trimmed Surface (144/0)......: 218& l- }2 C) _4 O& d- A
) [8 }5 N* |- J" E! r! SUMMARY- Color Definition (314/0,1)...: 1/ q) ]; [" R8 D$ \% V" ]# w
! SUMMARY- -----# H: L9 @5 h6 Z+ @
! SUMMARY- Total 38829 W1 S6 a6 h9 n+ Y
! STATUS-
" t( E0 M( P3 }$ @2 I$ F. v! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM) W7 g& x0 ?4 F8 n2 q
! STATUS- # R8 Y8 }- s) c8 m3 u# p5 N: z: d
2 U% m2 {( A. V' I/ F( Z. z% m! INFO- Degeneracy in b-spline entity 851 was corrected at or around these
6 i& @) s+ L; {) w! INFO- locations. A shape change has resulted:6 x7 {1 J. E B3 e+ z0 |! n
! INFO- 0.666707 0.386276 0.000000& U8 E8 M8 G- }, l. @2 r9 v
! INFO- Degeneracy in b-spline entity 939 was corrected at or around these3 Y" t8 q& D+ Z
; O/ a; D% ?- N3 S! INFO- 0.333082 0.386447 0.000000$ E7 f1 Y. u- d. S5 k2 }1 j
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these3 x6 U G7 p- _+ v: u: e
! INFO- locations. A shape change has resulted:) d L! M" T a6 X2 {/ e5 Z' J4 z
! INFO- 0.017365 0.057973 0.000000: y h h* Z9 h; L& _0 J; U& W( X
) u# ^2 m4 \* w6 N: m3 \0 [& e! INFO- locations. A shape change has resulted:, g2 h7 u( w' S7 l2 t" \4 W1 D
9 Z5 m& V8 o1 b/ c! J& E! INFO- Filing Part ..: F:\01.03\GMT_igs.prt3 G" t8 @8 ^& w: u
! SUMMARY-
# I( F' c0 ], q8 y" j! SUMMARY- Summary of Unigraphics Input Entities
+ R" H4 o' }1 M S$ N! SUMMARY-
- T* u1 f( l( w$ A! SUMMARY- Entities Processed Count
- b) }( ~3 t5 ]4 }9 g9 K! SUMMARY- ------------------ -----9 }; m$ L3 y" g6 p: o. `. q
! SUMMARY- Part Attribute ..............: 8) p' C% N8 a" Y- K8 }0 e
" E& U1 }3 b( @9 C s' \. O2 w! SUMMARY- -----0 @" Y/ \, e3 w" B
8 q, D5 y# c1 m( |' Q* Y2 ?) x! INFO- ^9 k/ s+ Q) Q9 V& V( f7 o
$ I& _) Q6 X3 O/ j! INFO-
2 w% [0 f2 d; C: eIGES to UG% M4 ~% O8 D) l @1 S1 x2 ^7 c A
! INFO- NX V7.0 / IGES Specification 5.3 B; w6 W9 L1 x$ O
! INFO-
8 k- J h) c# z6 S3 k! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM
2 K r& ]3 `' |% `1 C# v$ ^! INFO-
6 Z8 j/ b" a1 E: `+ ?" d. i! STATUS- Converting Part: F:\01.03\GMT.IGS
4 s2 @: e+ T$ l2 t! INFO- SolidWorks IGES file using analytic representation for surfaces
, S1 k+ ^" F# _4 g5 H8 r) Z! SUMMARY- 8 S; B4 U" J, a( P/ L/ F1 N7 m
! SUMMARY- Summary of Supported IGES Entities in file9 F0 u- b- X, Q1 {
! SUMMARY-
1 K" R* y. I9 ~6 a! SUMMARY- Entity Type Count( f f5 K: Q* U$ O4 j) x
9 g( I& J8 y9 @7 r3 \! SUMMARY- Line (110/0).................: 680
6 R4 Y( v9 _" e! SUMMARY- Circular Arc (100/0).........: 430) m$ R5 F3 h1 ^4 y- _) W' T
! SUMMARY- B-Spline Curve (126/0-4).....: 1335& r. _" q; ]& }5 j0 x' o' A* t
! SUMMARY- Composite Curve (102/0)......: 4489 A% a. }( j. t" `- B) V
! SUMMARY- Surface of Rev (120/0).......: 928 Z9 t% c+ q% R" D1 i
! SUMMARY- B-Spline Surface (128/0-9)...: 1264 X% R7 H6 v5 f
! SUMMARY- Curve of Surface (142/0).....: 224& W9 Z8 ?3 I% C2 Z
! SUMMARY- Trimmed Surface (144/0)......: 2185 s7 \- H' _# G. ]; I
! SUMMARY- Trans Matrix (124/0,1,10,12).: 3289 u6 W3 G2 K% J4 x4 s/ n% g9 f- o
! SUMMARY- Color Definition (314/0,1)...: 17 D: h8 J/ @- g, J, n
! SUMMARY- -----
8 g' O9 ?4 n, M5 n4 [! SUMMARY- Total 3882
0 ?( j" ^; ~. I: a! STATUS-
) D. B' z$ |2 |; u3 d1 ] J, m" U$ u! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM
! L) E* M" ^7 T! B8 s; _8 W! STATUS-
2 C! O2 Y8 Z3 k% y5 F0 d0 N! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM
( e5 L' R* s4 M) n6 c0 i5 V! INFO- Degeneracy in b-spline entity 851 was corrected at or around these
* V: i# X3 s6 ]& Y' E! INFO- locations. A shape change has resulted:! v9 g) Z- g+ Z! f
/ u1 q! F& f, C4 ]( `$ Z/ M9 ?/ d- D! INFO- Degeneracy in b-spline entity 939 was corrected at or around these3 n% l8 f, }& s) t/ j- E+ `# n
! INFO- locations. A shape change has resulted:1 ]- C' S5 Q$ t2 P5 N
! INFO- 0.333082 0.386447 0.000000( b' s* o0 l. X5 @0 ]
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these0 R* A4 x% \; `) K' x# s0 @
- }4 g( j7 T( K2 j' I( D! INFO- 0.017365 0.057973 0.000000% g z; g( {9 _! J0 t S
! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these/ A; C! V, g+ u, R8 z
: F8 l3 i9 D, N! r. v! INFO- 0.982661 0.058577 0.000000
3 [6 Z+ \% `1 H: n! INFO- Filing Part ..: F:\01.03\GMT_igs.prt+ F& R+ Z) \, ]9 K }
! SUMMARY- , w7 c& ~! Z, O8 c: Z2 C
! SUMMARY- Summary of Unigraphics Input Entities! G5 Y* \. K, q/ `' W; {
! SUMMARY- 7 m; B: f7 b; m9 f8 k2 z2 c
) I5 P1 D& `3 ~0 A! o! SUMMARY- ------------------ -----
5 _0 X' ~8 E! N, u" W! SUMMARY- Part Attribute ..............: 8
3 z- V$ b- C% N5 h! SUMMARY- Solid .......................: 218! f( w3 v4 w' U3 J& V9 E. f
! SUMMARY- -----
) T o4 F$ s8 x! SUMMARY- Total 226' t* D3 k! @+ t6 `
! INFO-
3 a! F r9 h% e! INFO- End of Translation: 3-JAN-2011 12:11:38 PM
& d; @& b% C: }9 S$ v$ V! INFO-
: a+ B8 q/ `5 }IGES to UG& O8 c1 ^" h- s
" U+ _$ i/ \& |. p) g+ k% l! INFO-
$ V6 ?) t7 E9 R4 i6 [$ C! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM5 P1 `7 p' o' t
! INFO-
$ {+ s4 \2 x. ?! STATUS- Converting Part: F:\01.03\GMT.IGS
: Y, G5 H) R* r* i4 L! INFO- SolidWorks IGES file using analytic representation for surfaces
" t7 i% p& O! A7 p1 H" L! SUMMARY- & ]+ K u. {" ]
4 E9 f: y. V% v0 z/ \! SUMMARY- 7 u$ i( T( D" \" `# Z- I$ {
A+ g$ o* W. }6 W) e8 k4 k& z! SUMMARY- ----------- -----
4 l- ^7 z, V# R' l* H! SUMMARY- Line (110/0).................: 680
1 G( x$ o ~0 S3 x! SUMMARY- Circular Arc (100/0).........: 430
/ C3 ?/ o7 b* z5 |! SUMMARY- B-Spline Curve (126/0-4).....: 1335
2 y! e: s% |+ H3 k+ g! SUMMARY- Composite Curve (102/0)......: 448. ^( L0 ]1 v/ f- r1 K0 C# b% z
! SUMMARY- Surface of Rev (120/0).......: 92+ }. q7 l+ ^5 c5 H; x( b& S
0 a4 O1 q" x' B A. Z! SUMMARY- Curve of Surface (142/0).....: 224, [2 b! X K4 b
! SUMMARY- Trimmed Surface (144/0)......: 2180 O1 V9 u2 F+ I# l U3 ^- y
- S- b; b# ]; v. l! SUMMARY- Color Definition (314/0,1)...: 1, y5 S# S. {/ j2 j8 ]
! SUMMARY- -----& N" `8 G% }5 M! [3 [5 E* E
! SUMMARY- Total 3882" H0 m5 q6 q( ?0 X
! STATUS- 2 Z' H- D1 `" R7 W
( @. S Q, V4 M2 X1 p; R: ~! STATUS- ) h( S( ?4 a# k' g3 P- F. D8 n0 i
4 w6 X1 ^. M+ _! INFO- Degeneracy in b-spline entity 851 was corrected at or around these
8 v2 A( t5 e$ E1 A2 c. A4 v3 J! INFO- locations. A shape change has resulted:+ c+ h3 B8 ~0 }* ~! u
; F. u# i% C2 q$ f L+ m! INFO- Degeneracy in b-spline entity 939 was corrected at or around these3 d+ }' p4 G7 b& x4 ]5 P) f+ u
! INFO- locations. A shape change has resulted:, Z8 w; x$ T' L, c. V# m
# p/ O, N+ x- v; [5 K! j2 v! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these
~8 R% y7 c, [3 P/ _! INFO- locations. A shape change has resulted:
# W# x# F5 j8 g3 P+ ?3 ?9 l! INFO- 0.017365 0.057973 0.0000006 u, Y4 ~" L! H Q2 |* s; S
3 n9 O9 P/ d& y, m$ l! i: i! INFO- locations. A shape change has resulted:9 z6 b0 U' b+ O0 M% D
+ G+ q* d4 m h! INFO- Filing Part ..: F:\01.03\GMT_igs.prt
4 y4 H2 T8 I* e/ }! SUMMARY- Z7 {& C- C+ p# a
! SUMMARY- Summary of Unigraphics Input Entities2 t% e1 { }' U
! SUMMARY- " ? _. l& U) y5 o; A1 P
! SUMMARY- Entities Processed Count0 J: M4 S& s# O0 X6 L$ t# O
! SUMMARY- ------------------ ------ z& J7 G- y5 \( n) g
! SUMMARY- Part Attribute ..............: 8/ ]# c8 }0 v4 O7 w3 l+ H
! SUMMARY- Solid .......................: 2189 m1 B$ _9 H& c+ ~0 H4 x) d# S
! SUMMARY- -----
2 p( p2 @, `. `; w; W# H! SUMMARY- Total 226
6 B7 ]/ Z+ D4 [2 o2 j L* L0 q! INFO- 1 M/ i: D0 W7 W, K1 {! \9 e
' o5 z/ L7 j9 N/ m) Q" B- p2 a% f( r! INFO- . q1 n8 N( L& @+ G% O# N
IGES to UG
/ y# G( ?" k/ U* @- f% R7 g; _! INFO- NX V7.0 / IGES Specification 5.3
4 n; l3 I6 }4 E( K% w" n! INFO- + y0 g" s' I0 ~# N6 z
! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM" f# t9 h2 E8 n
! INFO- & D+ Q! ^2 B' ^5 M% S
! STATUS- Converting Part: F:\01.03\GMT.IGS4 ~6 ]- X0 ~/ {$ N9 g+ @+ F
! INFO- SolidWorks IGES file using analytic representation for surfaces + N# [5 I' j9 y+ ^" i) Q
! SUMMARY- ; H/ J L1 k; j
! D" `4 X( m3 C+ |* Y; D# r2 v! SUMMARY- 4 Y1 j$ O7 C# v2 \6 A) K; g: x
! SUMMARY- Entity Type Count* W5 u7 d/ `( ~
! SUMMARY- ----------- -----2 P1 M5 w- h: d) I% m1 [$ I7 x
1 \$ n' _: Q3 ]8 t! SUMMARY- Circular Arc (100/0).........: 430" Y& w! o3 s: i' S$ |
! SUMMARY- B-Spline Curve (126/0-4).....: 13353 s% b8 ~8 F" O- U+ N
* H1 Z& p/ G( `: A. F! SUMMARY- Surface of Rev (120/0).......: 92
6 [8 m, s$ ^; K9 q% `! ?! SUMMARY- B-Spline Surface (128/0-9)...: 126
) x. I6 o: U( P T( b. d2 b! SUMMARY- Curve of Surface (142/0).....: 2248 p/ h# V9 Q# P% Q. O; }2 g; A
! SUMMARY- Trimmed Surface (144/0)......: 218& D" ?# A' r6 Z5 \
! SUMMARY- Trans Matrix (124/0,1,10,12).: 328; C5 H) k+ {. c% D8 U/ D& x: f3 V
# g. M8 N: W& H8 g7 E4 B$ S) Q3 o! SUMMARY- -----; {7 ?+ Q8 g% Y& N0 a9 |1 w* P: t
. r3 b. T& ^$ g7 [& {! STATUS-
- R1 d2 s1 c2 f+ n8 C7 Q" [! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM; h3 G- h( f) K0 W$ \1 s
! STATUS-
' S+ t- o. Y6 ?2 M2 n u! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM
2 s4 X5 [) y) L9 @) m! INFO- Degeneracy in b-spline entity 851 was corrected at or around these5 t/ v8 w* x+ x
4 G$ G3 y( G8 f( Y! INFO- 0.666707 0.386276 0.0000008 e. Q) c/ Z6 w$ h- ^) O& q
! INFO- Degeneracy in b-spline entity 939 was corrected at or around these! B& m) O5 o1 F& G5 A
! INFO- locations. A shape change has resulted:$ N- J' I+ C! z! {: [/ m' Q" i3 N
, B& F }' g+ `. n& v! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these
a# U( c; D* L! INFO- locations. A shape change has resulted:, C! A$ J( X' V
0 N G- ?8 \% K0 A& W$ o! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these
4 ~8 ]. E+ C) T; x! INFO- locations. A shape change has resulted:
$ D+ |$ ]) x1 b y2 C. Q3 {! INFO- 0.982661 0.058577 0.000000
5 `6 u; d# U t3 W1 o( R! INFO- Filing Part ..: F:\01.03\GMT_igs.prt
g9 X6 e5 _2 `/ O( R! SUMMARY- & ~! a* x' X: D+ {2 l
! SUMMARY- Summary of Unigraphics Input Entities! S8 g5 R# B& q, R# ]0 ^
! SUMMARY-
' k2 U7 L1 j9 W( q5 M! SUMMARY- Entities Processed Count6 B6 D* o1 f* b2 K( F7 O, T! ^* `
/ W( R' x |, |! SUMMARY- Part Attribute ..............: 8
8 T4 G4 N1 d. V9 v( P! SUMMARY- Solid .......................: 218
; x9 s6 E" f) t5 g2 S2 o! SUMMARY- -----7 u+ ^0 G% J' o; i3 s
! SUMMARY- Total 226' P' z* G, I! _: M3 j0 `
! INFO-
2 J3 I+ P, L/ U- u+ N& C5 T \! INFO- End of Translation: 3-JAN-2011 12:11:38 PM
* E7 K. K, Y1 t6 T8 v) B! INFO- ; C% T4 e: ~ T) P, G- K1 i; n
IGES to UG
V0 Z( P& T4 K1 v# [! INFO- NX V7.0 / IGES Specification 5.32 |7 Y9 P/ z2 \) o0 S
! INFO- ) @8 t5 J2 Q8 C) D2 |0 X: b3 d0 U4 w
! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM5 `( J6 L+ ?) T* E
! INFO- 9 n2 |, `; ]! ]1 E
6 C" l! ~- l* J+ \# G' ]+ P; z! INFO- SolidWorks IGES file using analytic representation for surfaces
) Z. B. x2 F D( g+ \$ j8 {. j! b! SUMMARY- 4 `+ Y3 a( n, C' W4 U$ z3 h* ~
; a# l$ W: B9 \4 n' z3 O( ^! SUMMARY- / D I4 B9 L$ u5 r
! SUMMARY- Entity Type Count k+ Q& [/ d7 `/ a7 C6 P; s5 y
! SUMMARY- ----------- -----) O$ q% n6 o2 V* V% t$ |/ O" Y% _9 o
! SUMMARY- Line (110/0).................: 680, z, c, z7 G1 u. v; c G
! D8 M( B; P1 m6 k% s9 b4 }% `! SUMMARY- B-Spline Curve (126/0-4).....: 1335
$ h( E+ b0 g4 H8 S) {# f) ~ |! SUMMARY- Composite Curve (102/0)......: 448
1 ~( Q1 [7 f# p) I" F' f: m- j+ W$ ]! SUMMARY- Surface of Rev (120/0).......: 924 O3 s6 |8 q3 R& X5 T9 X) z
7 H! M/ X Z6 p# `( Y! SUMMARY- Curve of Surface (142/0).....: 2246 v5 x$ S; p% \
! SUMMARY- Trimmed Surface (144/0)......: 218* l) q9 G$ S$ C+ m4 f
! SUMMARY- Trans Matrix (124/0,1,10,12).: 328' }. Y% m0 z: Z) ^
! SUMMARY- Color Definition (314/0,1)...: 1( K c5 G9 _, [) k6 ?
! SUMMARY- -----0 S, w- c7 I' e5 y! U( \
4 Z/ g& @; x% F( ~! B( F6 z2 @( T! STATUS-
9 w; d( b$ [0 R8 [1 Q( L! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM0 r# G3 x6 O2 Q D
! STATUS-
1 E4 V( }. ?0 r0 W! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM; ~% I/ I$ }! G) h8 B% c) S
z" Z: l/ L% ]9 E/ o4 Z4 i! INFO- locations. A shape change has resulted:
; B. f2 F! x. O4 U3 Y! INFO- 0.666707 0.386276 0.000000
: P& S3 |# y6 B- g! INFO- Degeneracy in b-spline entity 939 was corrected at or around these$ M! w+ G" Z% i1 s% c
* u# j1 \$ i/ O1 {7 j1 Z! INFO- 0.333082 0.386447 0.000000
& `3 A, H0 W& G! ]% {1 M* M u! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these5 v: ]- q. }6 h' O! z8 H
& X; V( k% b# p5 k- n! INFO- 0.017365 0.057973 0.000000
* |! M+ J8 q2 J! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these$ \- ?4 Z, n9 p3 s9 C) y0 [: g
! INFO- locations. A shape change has resulted:7 F! n, E0 v9 ^% P. t+ |
2 a; v$ ~& u5 `% \. N* b0 r7 U- ?! INFO- Filing Part ..: F:\01.03\GMT_igs.prt& y! J* {- f* i1 P- [7 q
! SUMMARY- 6 J; G' M" `6 y* i; Y- P, E9 {
: U T9 m/ J: a+ ]( V2 l! SUMMARY- * `, O9 O" f$ a
! SUMMARY- Entities Processed Count* l; ~; C# P7 {3 k! S
! SUMMARY- ------------------ -----9 p' t5 V e# t5 @- O& ~8 V ~$ i3 |
* L. U' @; X/ H! SUMMARY- Solid .......................: 218, }0 _% \7 [6 u% f# r
! SUMMARY- -----# T/ R: [1 G% v) B
~2 A# b2 s) _* f! INFO- 0 w; L. h9 |3 l! Z5 b6 |. \. W
# r4 C8 q" L/ Y! INFO-
: |4 O0 g. @4 \( NIGES to UG
7 A0 \! W5 P* v6 P5 S4 z! INFO- NX V7.0 / IGES Specification 5.3
8 g0 Y2 F: H. @% y8 B% a5 m) d! INFO- . E3 @2 U% n8 ^3 F) o3 P0 a
) U/ q. i* j& I) k* H" w% Z! INFO-
/ |* P4 Z2 N: T! STATUS- Converting Part: F:\01.03\GMT.IGS
( x5 |( T4 f% e5 \8 e% h. V$ ~! INFO- SolidWorks IGES file using analytic representation for surfaces ; {+ O6 L5 p: U3 V% }5 ]
! SUMMARY- * u( N/ X6 ~; I6 B* M6 Q
6 J! X4 x% `9 N! SUMMARY-
" D! J5 a6 {7 U2 }$ y7 G% F! SUMMARY- Entity Type Count) U" R+ M$ X4 {8 C1 h
! A# P' y# \# m9 |1 l. g1 Z! SUMMARY- Line (110/0).................: 680
6 Q2 E5 l$ ~5 P8 T! SUMMARY- Circular Arc (100/0).........: 430
2 y' s$ f8 Q {3 d& Y8 P! SUMMARY- B-Spline Curve (126/0-4).....: 1335
7 @0 S* a Z- F( x7 E: {, f! SUMMARY- Composite Curve (102/0)......: 448
9 h; o; Y- T% S5 ]- p/ n3 z! SUMMARY- Surface of Rev (120/0).......: 92
! j1 P `, ? P+ s# Q! SUMMARY- B-Spline Surface (128/0-9)...: 126
+ O# d: `8 b/ w l9 Q0 `. i' T! SUMMARY- Curve of Surface (142/0).....: 224
m8 S0 x3 ~5 S0 K1 y- c( G! SUMMARY- Trimmed Surface (144/0)......: 218
/ P; _0 a; b) l! SUMMARY- Trans Matrix (124/0,1,10,12).: 328! J' {# W/ _0 y* b
0 G* k! @3 @% b7 D) o! SUMMARY- -----
6 M1 R: V7 i' k; A5 h! SUMMARY- Total 3882
' m) b6 O8 r. L6 z u2 t! STATUS- $ @4 z3 Z O* N4 x. |; A
/ |$ e3 ?' e% e* |: y1 z! STATUS-
* v. {6 m* L& ?$ h M. G+ ^! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM
" b {2 N2 s3 b9 `; o/ r7 \" f! INFO- Degeneracy in b-spline entity 851 was corrected at or around these" _0 G3 G, q/ I4 A: ~- I7 A
! INFO- locations. A shape change has resulted:' L$ h; r0 Y* F @! N y
! INFO- 0.666707 0.386276 0.000000& I* f& `: u+ X" q
7 v6 I- c. b; ?3 M! INFO- locations. A shape change has resulted:
- Y7 g3 p5 o4 i" _! INFO- 0.333082 0.386447 0.0000005 `4 |- r! {& w( X
" }' e% p7 @! ~" i! INFO- locations. A shape change has resulted:
! O! a5 @/ b+ V4 J& U! INFO- 0.017365 0.057973 0.000000
0 c2 U: Z( R& e4 w! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these5 ]/ U- [! u. C" t- f0 k
! INFO- locations. A shape change has resulted: U( ]8 @. [& }9 _( b6 m7 k
! INFO- 0.982661 0.058577 0.000000, X q2 z9 m% H6 o
! INFO- Filing Part ..: F:\01.03\GMT_igs.prt! y m+ o+ s+ G, Q3 Q0 T, a
! SUMMARY- % A$ y, J! H1 q+ Y" G) w
) b) W& a8 Z1 \: X' F! SUMMARY-
, H5 z$ I; [: ~1 z5 f3 V3 S% o$ T! SUMMARY- Entities Processed Count
7 R5 ?* v7 Z8 u" A. t! SUMMARY- ------------------ -----
3 [( X7 L7 Q2 ~) T1 ?2 g! SUMMARY- Part Attribute ..............: 8
2 l2 E& J, K; L: M; W% s7 D3 W. J! SUMMARY- Solid .......................: 2187 q! q$ x" @% e( p" [+ O( ^
! SUMMARY- -----& o+ t3 O+ L$ [# x
4 Z: D# |# V4 y7 }6 C! INFO-
6 o* _, a5 G7 G# R! I! INFO- End of Translation: 3-JAN-2011 12:11:38 PM
# N) v. j0 W) g3 G" x" T1 I! INFO- * j0 Q! D/ e; r& c; e! b
IGES to UG
5 U# a9 I( W' f2 z5 k! INFO- NX V7.0 / IGES Specification 5.3
9 O9 U/ |7 @$ M/ t! INFO-
3 d2 o [! D. v9 b4 M; d+ C! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM
/ @! D7 B( d+ H# f9 [% h! INFO- 4 h3 u6 S& U; c5 U; ~1 |8 y5 L
! STATUS- Converting Part: F:\01.03\GMT.IGS9 W* r/ b6 G. `, q, ^
! INFO- SolidWorks IGES file using analytic representation for surfaces 0 b8 q% @+ ?: z% c6 I
! SUMMARY- 2 ^1 _( z9 {2 u0 ?& ?% K; R, s
( x: K! s5 Y# Z6 X+ Y! SUMMARY- * |4 `6 U2 F* Y, c
! SUMMARY- Entity Type Count! @5 H# x y% D3 v
& k7 e$ h. d% u$ C! SUMMARY- Line (110/0).................: 680: c# y2 m& x1 X4 `( O7 _7 f) F) `
# ?! W1 T8 M! r( V! SUMMARY- B-Spline Curve (126/0-4).....: 1335* |" `2 f* ?5 C5 i. v) ~. i6 g
! SUMMARY- Composite Curve (102/0)......: 448: A" f9 X( S# W' k) \
! SUMMARY- Surface of Rev (120/0).......: 92) {" g# E; o2 u/ X" N' o- s" F) b1 Y
0 Q" h! S h7 o# B0 ?$ O! SUMMARY- Curve of Surface (142/0).....: 224
5 I/ _' r0 ^. f6 |! SUMMARY- Trimmed Surface (144/0)......: 218: m% G; d# U- N/ o2 ?
6 ]" S' H8 Z; n6 }) D! SUMMARY- Color Definition (314/0,1)...: 1
; |+ V# M& V- l0 o% ^+ k! SUMMARY- -----
3 T4 X; G7 P, R$ ?; B; H# }! SUMMARY- Total 3882$ u- o6 i% u! K7 h0 c0 i
! STATUS-
$ o4 N2 F* T$ G; ^, R! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM
9 _1 A3 T1 G9 l3 ]/ t. q* R7 F! STATUS-
9 I9 y ]- `5 }2 o0 g! d! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM+ h) y, U; k. Q- w; D$ v
! INFO- Degeneracy in b-spline entity 851 was corrected at or around these- o4 |; t+ \- d {2 O
! INFO- locations. A shape change has resulted:9 K, p' Q: L) _
- Q0 y9 [+ C' t, G6 D! INFO- Degeneracy in b-spline entity 939 was corrected at or around these1 H5 b6 {) h; e; o* P: I7 \
/ k0 _! T y+ b" a! INFO- 0.333082 0.386447 0.0000003 k, P6 `. V e% K& e
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these5 H N0 D$ I$ A E
! INFO- locations. A shape change has resulted:3 _& L* T$ `# H5 ?) c3 r* A
4 i; ^4 \% r# S& `) j- O7 x! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these5 X4 Z1 M. e* }+ F6 F3 E: u$ M
4 V8 g) \( H% t8 ^) i! INFO- 0.982661 0.058577 0.000000! @3 V) X# R9 E8 V; g
( X4 g) B. T9 Y* Y% Q: _# G' [! SUMMARY- . V0 _- ^' R, B( t
, _+ B" C/ a: h! SUMMARY-
- T6 X1 M; Y$ o) E6 Z: T! SUMMARY- Entities Processed Count
' M1 P& p1 `! ?- `1 k! SUMMARY- ------------------ -----/ Q) L) N+ L/ B4 G5 J! ]7 ]2 E
3 r( O6 F; B8 E) k6 Q) Y8 Y7 o* ^! SUMMARY- Solid .......................: 2188 m$ H! F# g5 C% J
! SUMMARY- -----9 b- X3 O$ Z; {3 E/ x
3 S$ q" f6 k7 g- H! INFO-
: i$ s" H# f# V5 A6 C9 ^& {! INFO- End of Translation: 3-JAN-2011 12:11:38 PM
) G* A% q) g; ~6 e! INFO- % [# a( v" W. T' i; o1 _
IGES to UG u4 l4 M. p: w% d; D
! INFO- NX V7.0 / IGES Specification 5.3& _( H! f3 N D3 ~! j
! INFO-
; V+ X# J# ]+ v8 ?* j; [! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM- |, d# j6 }( `. [$ k( U: c
! INFO-
$ @1 `, K C4 x' |" `9 Y# a ~! STATUS- Converting Part: F:\01.03\GMT.IGS
7 D1 ?, ^: v4 N0 c/ Z7 K! INFO- SolidWorks IGES file using analytic representation for surfaces
7 R$ z( u& e& o* g! SUMMARY-
7 O& k Z8 m% y9 {1 g" a! SUMMARY- Summary of Supported IGES Entities in file m; `* c) j: W" e4 T$ A: S* ~. ^% Y& Y
! SUMMARY- $ r$ w# |6 E8 n4 O. z2 j/ v
+ }6 I7 s5 W \2 M f! SUMMARY- ----------- -----+ [; [: @; |! o. H
! SUMMARY- Line (110/0).................: 680! i8 D2 \$ b5 C5 a
. p8 s& ?' W; U1 i# C; \: d! SUMMARY- B-Spline Curve (126/0-4).....: 1335
" E% w0 J. d# s5 o- c4 h9 V- p! SUMMARY- Composite Curve (102/0)......: 4489 d+ r. P: @- t. {1 I7 J
! SUMMARY- Surface of Rev (120/0).......: 92& q5 L4 s9 P/ H4 z# r
! SUMMARY- B-Spline Surface (128/0-9)...: 126$ @7 w, [& ~" e8 U$ e% _
! SUMMARY- Curve of Surface (142/0).....: 224. [# j8 ^" X7 U
! SUMMARY- Trimmed Surface (144/0)......: 218- e9 \0 j0 }, S8 V# ^6 `0 H
! SUMMARY- Trans Matrix (124/0,1,10,12).: 328* S3 w; V) g, O8 i
! SUMMARY- Color Definition (314/0,1)...: 1# f4 {) R( w I- N
! SUMMARY- -----" S+ t0 h/ O7 O M- n+ D4 f
! J' U# c/ l9 E5 X& ~0 v! STATUS-
: @, c1 g% J, F5 ?8 z0 H8 n! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM* [5 V; j6 n: g4 \4 ]# W1 c, s
! STATUS-
$ K$ h u8 [5 `+ N- ^6 A! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM
& a/ V9 \" w Y! INFO- Degeneracy in b-spline entity 851 was corrected at or around these
2 O8 F( n* C6 C4 A: H! INFO- locations. A shape change has resulted:
+ j* z7 @' _# D$ @* Q; ]! INFO- 0.666707 0.386276 0.000000* m! h( I4 q* K# m8 ?8 ` O
3 T" B$ n" w5 F- s8 X% S* H! INFO- locations. A shape change has resulted:
! O/ u. i' W- n) z# U. }; Z! INFO- 0.333082 0.386447 0.000000! d: T8 Q" k" }2 Y; m+ r) z
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these+ H. W6 n2 w8 }
3 D! l8 n( {% t9 F! INFO- 0.017365 0.057973 0.0000003 L2 W1 T9 L, }" z' R; ~* v
! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these! D* @" M% j* a! Q, e; r1 t+ a
! INFO- locations. A shape change has resulted:' ?% B/ Q) d; k
' w& _6 u. J* h8 q8 j! INFO- Filing Part ..: F:\01.03\GMT_igs.prt* F' U$ Q, v# O6 R' N
! SUMMARY- ' I2 f+ {! `. [" N$ f1 k
! SUMMARY- Summary of Unigraphics Input Entities3 t7 g& Z$ q$ z* X! d
! SUMMARY- 1 S0 q6 m6 m2 x$ c: w/ ^
8 o {3 Z" E5 d' D' K6 _" e! SUMMARY- ------------------ -----
) |/ M& ?0 d+ x. z2 S' _2 l! SUMMARY- Part Attribute ..............: 8
. Q3 m) e3 q+ k L: ?7 s: S7 \( _! SUMMARY- Solid .......................: 218$ H3 R0 D3 G. v( o9 ~$ ~4 A. V) q
! SUMMARY- -----
" w5 h( q, y$ @" r5 U* ]! SUMMARY- Total 226
, [/ L& r4 s2 `, \( U& X! INFO- ; d$ k. ~! ]7 z
! INFO- End of Translation: 3-JAN-2011 12:11:38 PM9 W3 r7 n+ q1 ]5 `' x
! INFO- |
