查看: 1690|回复: 23
给你这些点,可以用UG画出一条曲线么
发表于 2013-12-17 11:43 | 显示全部楼层 |阅读模式
nx这个功能在哪里可以找到啊???
0 d0 ^, e& Z  u" g6 Y( `+ f$ U3 Q2 _
给你这些点,可以用ug画出一条曲线么?
6 R5 E" I. v) u4 Ix     y    z
0 N* b8 o" M: ^4 C85mm -44.78mm 39.43mm
$ z5 E6 I7 Z/ _1 q2 a3 i& a84.956mm -46.777mm 39.422mm
! n# ?% D1 ]2 {" G3 l; h( p! ]84.822mm -48.777mm 39.397mm3 z4 o: h+ t5 n
84.599mm -50.777mm 39.355mm
* V7 W6 O8 V& Y# l84.284mm -52.777mm 39.296mm
) n0 F0 s: a* X; K7 m+ M& Z83.876mm -54.777mm 39.219mm
6 m" ~9 _! C1 e  @4 j83mm -58.05mm 39.054mm$ P' O! G2 A2 I2 W8 A6 j! z
81mm -63.326mm 38.679mm
$ ]; T* D! a$ G2 n5 z79mm -67.22mm 38.303mm) I" r9 H( q1 t
77mm -70.371mm 37.928mm2 I% ]9 o/ w. q# E2 `
75mm -73.028mm 37.552mm
7 `6 z( n2 s0 o1 I6 g: ]& n73mm -75.32mm 37.177mm
& e) K1 f$ ]" M71mm -77.325mm 36.801mm* Z$ F5 [3 y% N. ?1 \& s7 b
69mm -79.093mm 36.426mm
' \) a2 ]9 D% d8 i67mm -80.659mm 36.05mm' M/ u2 k8 N2 w! Y
65mm -82.048mm 35.675mm
* i4 I1 \0 a3 S63mm -83.28mm 35.299mm
1 i4 ~* S; o; D7 I) n61mm -84.37mm 34.924mm  }% n9 W; t4 O' h- _. z
59mm -85.33mm 34.548mm
" M( f! d- u4 {1 G' R) s8 S57mm -86.16mm 34.172mm8 A% j) M- e) _4 R8 s" m  K1 `
55mm -86.89mm 33.797mm+ A  g2 t% V$ h# ]# M- ]1 [
53mm -87.5mm 33.421mm
. ~: t# k; `+ a$ r; ?5 p51mm -88.01mm 33.046mm
2 s" `1 q7 I2 X% f( v6 L8 X( I* Z0 V49mm -88.41mm 32.67mm4 x9 u' i+ V7 L( t
47mm -88.72mm 32.295mm
) d& w. S0 L; I' S5 n/ V# q45mm -88.94mm 31.919mm
* b, B7 D3 B- [" q+ h43mm -89.06mm 31.544mm
; ^5 R1 i# k" u0 k! a41mm -89.082mm 31.168mm/ _* C* m4 b3 N' u9 _. Q' c
39mm -89.014mm 30.793mm
% N0 t5 T- i) B37mm -88.852mm 30.417mm( i/ Q4 w1 v8 @* T2 W4 P
35mm -88.595mm 30.042mm- o7 Z* a% p2 C
33mm -88.242mm 29.666mm
- D; g2 c, H- R$ G% W7 }4 H6 l4 L31mm -87.789mm 29.29mm
: A- W  n' b' ~4 h: @29mm -87.234mm 28.915mm" [. b+ \9 }: b: ^$ y
27mm -86.573mm 28.539mm
3 }; R9 D( H7 _" z25mm -85.8mm 28.164mm
" o$ f7 S) C) C% [" t-15mm -69.015mm 20.653mm/ v& d8 ]9 L7 W: P+ }
0 Q2 x9 c- t; @  l
) Y$ q1 V2 y7 o2 r
- z  o2 _* _6 ?) E% f
+ f  G' Z- {5 m! i6 d1 ^3 F/ e
发表于 2013-12-17 14:23 | 显示全部楼层
UG有云点功能可以导入外部的文本。
 楼主| 发表于 2013-12-18 14:04 | 显示全部楼层
我说的,可不可以生成曲线,而不是点?
发表于 2013-12-19 12:57 | 显示全部楼层
点都有了,还差曲线??!!!!动一动脑筋!
 楼主| 发表于 2013-12-19 14:37 | 显示全部楼层
你有什么好的方法么?
 楼主| 发表于 2013-12-19 14:39 | 显示全部楼层
我的意思是直接生成曲线,而不是先生成点,再用样条连起来。你懂的!!
发表于 2013-12-21 09:12 | 显示全部楼层
CATIA里面会  UG里面不会弄
发表于 2013-12-21 15:42 | 显示全部楼层
看帖看完了至少要顶一下,还可以加入到淘帖哦!
 楼主| 发表于 2013-12-21 16:46 | 显示全部楼层
leejayi 发表于 2013-12-21 09:12
+ d+ L$ {# Z1 ]- _5 lCATIA里面会  UG里面不会弄
* z- s9 U3 |6 g( r0 x" K7 Q哦                                       哦8 {, v1 m1 l& P; B+ O% B
 楼主| 发表于 2013-12-21 16:47 | 显示全部楼层
ugii 发表于 2013-12-17 14:23/ c2 ^$ r: ~; F% Y' H' y$ ]0 H, A  ^
UG有云点功能可以导入外部的文本。
$ M& D- F$ @2 [% p+ m
可以直接搞成曲线么?
7 |# k! s  f2 L! H! H
GMT+8, 2025-3-7 04:05 , Processed in 0.050319 second(s), 21 queries .
