查看: 6577|回复: 11
2012 破解方法 疑問
发表于 2013-12-31 09:20 | 显示全部楼层 |阅读模式
1) Copy "dcam.paf" to C:\dcam\config\pass\
2 q& t1 _$ c! F0 o# t- T1 y( b4 K+ x' ^  A5 G3 Z
        Emulator for Win32
. R" }4 I: ~4 ^4 l. o; e5 [
- Z1 J9 t; o7 R; y7 _: W1) Copy folder "MultiKey32" to C:7 A6 _& b+ z- [; f3 g6 V! T
- V- _4 P1 G, h) O; W2) Run "MultiKey32\remove.cmd"
. T: T! V0 R% ~$ P, M2 L: `) a! V8 q0 P- t, i+ @7 D  w, e) q
3) Run cmd > regedit and delete [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\MultiKey] if exist
6 ?$ \6 S- i, E  H9 _" e4 }0 L$ a) J& X
4) Run "dcam_18.2.reg" and confirm to add info into Windows Registry
6 A; P$ K9 i; F  P
3 |- i( i- l" h; q% E5) Run "MultiKey32\install.cmd" and wait until system will install new device (Sentinel SuperPro/UltraPro )% s. O4 c4 o% \
* y* u- `$ L; O6 @7 J
6) Plug any Sentinel UltraPro Dongle key to computer
9 V. O2 \2 ~: Z* |8 P  E2 A/ T( V% {
that's all you can use:
6 z7 `1 w! W; `6 ~8 Q2 [. b5 G PowerMill2010sp0...sp11
7 W: }( X& P# k4 g; C3 f" z/ F( E PowerMILL2011sp0...sp11, @1 }, ~3 `$ z8 }7 U2 n5 z
PowerMILL2012sp0...sp4
- @2 L) o9 V" H: h3 |1 t$ O0 @/ V* \( q; ]7 p7 G; ^# _
+ D  `5 T# O: j" X/ Z) ^. m$ D
        Emulator for Win64* b! N7 F6 ^: \6 [+ B! u5 }
, {  @/ E2 t3 T( W6 jCopy folder "MultiKey64" to C:7 E, l6 J5 L  W5 `/ D; e) l
% {/ }. q4 Y. D+ X
To install Emulator x64 select folder corresponding your 64bit OS ( XP, Vista or Win7)( f- Q' i. V9 B7 B
/ n5 s" x% @% S( |4 K7 a# B
Do the same as for Win32,  but on 64bit Win Vista/Win7 befor installing Emulator you need to boot computer using F8 > Desable unsigned drivers enforsment mode
5 _. g: x' _7 T0 z3 x/ {Also you need F8 mode at every Vista\Win7 64bit computer reboot
; K4 k& J( J# y( T4 @+ W4 w; P' V/ J$ L9 M
Cracked by Team-SolidSQUAD$ o# Z# b1 l; c/ |
/ p1 @; s; J) f1 T2 }7 C& R$ c
1 w2 L5 |' w; q: ^  _: |! _' b/ T2 H3 p( t5 I5 w* [8 ?
可以幫我翻譯一下嗎 安裝WIN32是不是比較簡單 需要加載電子狗嗎?
* o8 A! |4 v1 w5 j6 S安裝步驟 32跟64 差異在哪?
: r. e5 o9 ^! I7 V% `$ D- a小弟2012總是安裝不了 幫個忙吧5 K( _3 b4 |: F) x5 v9 r
. l4 @$ Q. i: G2 K
发表于 2013-12-31 09:58 | 显示全部楼层
会看复制和运行就可以了!我小学没毕业一样可以装上!
 楼主| 发表于 2013-12-31 10:26 | 显示全部楼层
版主 可以教一下嗎* s/ h; V" e3 V& a. e
发表于 2013-12-31 13:45 | 显示全部楼层
ug4034222 发表于 2013-12-31 09:583 C- {% s) `+ Z+ O
% p. T8 Y  o1 `7 Q/ T! h8 r9 c这个破解叶轮不好使啊  我试过 你好使??* `5 ]  T3 h$ z$ G+ q: F1 L
发表于 2013-12-31 21:21 | 显示全部楼层
ug4034222 发表于 2013-12-31 09:586 @$ l$ ?& Z! ?; d1 U4 u
' A: p; y$ V, ~' r
你还真是爱好论坛,经常现身$ r5 d5 B. n2 X% }3 A* |
发表于 2013-12-31 22:09 | 显示全部楼层
已有完美破解不用狗不改时间的
发表于 2014-1-1 02:38 | 显示全部楼层
"已有完美破解不用狗不改时间的"( A* N1 c9 v) l1 h  r
兄弟共享一下下。
 楼主| 发表于 2014-1-3 09:15 | 显示全部楼层
yangaichun 发表于 2013-12-31 22:093 ?8 H9 T! K- i: N
已有完美破解不用狗不改时间的
( [5 K& p  K! l+ E
我這個聽說不用改時間/ C0 c# i6 G+ U8 I. `. i
不過就是裝不上3 h, q' q7 a. ]3 L" R
會裝的 也不肯教....就樓上的大爺...# D/ u( g2 C8 k" f: F2 D5 _
. b% S8 B/ b3 ]
发表于 2014-1-3 17:19 | 显示全部楼层
 楼主| 发表于 2014-1-5 18:21 | 显示全部楼层
akela 发表于 2014-1-3 17:19  c1 x$ b4 d$ y
1 o; h' g5 d3 j( N6 ~4 v! c3 B2 T
妳了不起 能夠說說嗎
. R! E4 W. ~/ b! @  K) J
GMT+8, 2025-7-21 02:59 , Processed in 0.232180 second(s), 20 queries .
