楼主 |
发表于 2008-8-17 14:34
显示全部楼层
Date: 15 July 2008
$ K: f& v' K# ^2 u7 t9 I' _
+ b6 @' p& a9 w- H9 _Subject: Maintenance Pack 1 for NX 6.0.0.24
/ P% `. U, V5 x5 R4 \. V8 c8 t3 V- I+ l* c
To: All users of NX 6.0.0.24
C3 N5 j- j* g/ T7 o* \+ E1 r- P
3 U6 L. W4 v6 ^+ b5 K
F- i) |) g+ |; `& U& h$ a--------------------------------------------------------------------------------
7 n6 K0 l2 T6 n5 l& m$ z( O, Z% @/ Q! E+ b$ P
We are pleased to inform you that fixes are available for the problems listed below. A maintenance pack (MP1), built for installation on top of Windows XP32, Windows XP64, and Linux64 images of NX 6.0.0.24, can now be downloaded from the Siemens FTP server. This maintenance pack fixes an accumulation of problems listed in the table below.
" K3 c( q& ?9 B5 x* S % x0 V2 x7 k" H' U- ?" f
2 Y4 j% G: q' P" K. Y3 s
Release! b1 \" d: O( h9 `5 s+ u
PR Number, w* b7 z' f5 m$ J
Problem Description
6 M9 f0 b; F( W. z ( [( R# Q. K: P! i7 S: l
MP1- b& n; I1 K8 U; v8 O- G
1612198
! @& S3 n5 K0 I! Y6 c The problem in Translators where annotations by expression were exported incorrectly to IGES is fixed.
+ x, }) R! a ~- L. d
4 j' n; `7 q$ E4 \MP1+ I/ t e9 o! J+ I- t( E" _" I$ N
1637759
0 b2 j8 x$ K) V6 i4 m* q1 j The problem in PMI where some dimensions did not update properly after changing the Current Feature is fixed.) N1 J: }9 @4 X
+ H( l" B: j2 z0 }MP1
4 H" D0 j8 K; J7 x3 X3 [8 E M, K 1653781
# q. C) @3 M5 M& r$ | The problem where synchronizing the Routing Bill of Material and the Drafting Parts List in Teamcenter Integration for NX caused errors is fixed.3 A+ a& a3 J" O8 }
: O$ n- H# l. u7 S9 @3 O4 }MP1
; v1 g- e5 A2 _- @1 p; F 16625299 x V% ?/ O e" N; S4 {2 w( O' ?& Q
1667944
' x- N) b) k; `3 n/ ] The problem where some out of date bookmark files were not able to load the assembly is fixed.4 I! d" d/ J% J& x5 x( n
# J- V7 n0 V6 |0 G1 SMP18 z1 e1 w1 T, ]
1670906( k/ i& t* u6 a# X9 z
5973653# q) m! X) p; O2 \5 `! [6 {- j
The problem in Translators where some STEP files failed to import is fixed.; \# M- I8 ^7 d* H% R
6 X0 T8 W1 A6 P( q8 j# Z( n5 B
MP1
) R3 M% r$ E) @& s. d0 i! Z% {4 j 2098357
$ D' V4 g3 S$ L, v3 u1 W: Z; | z: ^ The problem in CAE where the NX session terminated when a Japanese name was entered as a Graph title is fixed.
, r8 Y& H2 a3 y* B( Y1 \3 Z' v/ R
. a% H0 m4 w0 ^& {MP1
9 V3 Q+ w, F/ d! C3 z0 U2 | 2100564
& P, O$ z- Q8 k& O, o( X: I4 T The problem where dragging a spline point changed the spline's planar characteristics is fixed.' \$ x) ^ H% K, k
9 X6 X+ y* Q; w& K# t! k+ Z
MP1. Y% b" T& W$ l
2100659
* f& Q4 R' o7 C- Y! k, G1 n The problem in CAE where there was an error exporting some MSC Nastran bulk data files is fixed.
2 V1 L5 G/ A0 ^4 N' {, U $ a$ P+ z% d. }
MP1# e- l' z) \$ j/ u+ ~2 v0 P
59248227 ^7 D: k9 q f2 _# C" s0 `
5941874
8 t, S* Q9 u: k7 A! u- X: ? The problem where some GRIP commands with mixed case view names did not work is fixed.* G* o5 Y% ?* q& Y$ D0 I, h2 g
7 a# | |+ {; o5 BMP13 F2 R" K/ b+ S! h9 x! o ?3 X, [
5968976: F1 V: G g! F; H( s6 h; Q
The problem where the Incremental Dynamic preference was ignored when editing a Bridge Curve is fixed.
0 o" R( t6 X Y4 M. @: P6 k % f# e: K* l$ D0 m4 L
MP1
# D3 V1 T+ @+ \8 q) T% w9 y 5989423
* O$ N" ^$ P, ?/ j9 n5989215- f2 K* V* j' I4 Y
5997101
) _% g% F A0 R3 C `# u3 w7 E5999269
7 z/ s' `! ]3 U: | o6000881
9 g0 f/ a) h. w( P' g The problem where changing applications and certain licensing operations didn't function properly is fixed.
5 O& R3 H- G6 z" L, t: i2 w% e
, P) }; l/ H5 q4 B% Y- W4 B6 w1 z; P+ U* q) ]6 O" R& Z: x
9 P3 \/ c$ m1 v* M+ e2 p7 t3 o2 h+ |) L5 T t* [$ g B4 I
: q7 C! E$ l" A5 ]5 J# f7 t- w- a! q8 n, e
Windows update instructions# k* _5 q" u' I- x4 U
* A8 g* q6 U$ h1 P- ^3 L3 w
- k" D7 z' u8 u* y( r9 H
\4 f+ v* Y2 i% ~, }4 T, w
The files contained in nx-6.0.0.24.mp01.zip are provided as replacements for previously installed NX 6 products. j; u1 v% l/ v, {6 W/ f
" A% x+ q5 F7 \" w* \
' {% N5 c; b+ Y
' u9 ]/ ]( T7 b( e7 ^# H! u- [For the Windows XP32 platform, you should have at least 520 MB of free space to unzip this file. " Q, m# ?0 L. O: r/ u$ d
% B5 k! i( J* W8 ^! b; j
+ y+ ?! k5 B, d' P- r$ k/ q; k
. |$ D) ^& u- m/ p4 RFor the Windows XP64 platform, you should have at least 1.00 GB of free space to unzip this file.
1 i3 K+ j* S5 v1 C& i
- g; k. M& u; b1 `
1 D7 z7 k7 p1 ?" tVersion NX 6.0.0.24 must be installed before updating to version NX 6.0.0.24.mp01. Please be aware that these updated MP files will be superseded by the next maintenance release or maintenance pack installed on your machines.
& O" ~: \/ a! l( d4 c0 Q' a, }, {( H$ t7 Z& e4 \9 a, i
To use this update, change to the directory where you unzipped the nx-6.0.0.24.mp01.zip file, make sure the entire set of new patch files have execute access, then execute the “ugs_update.bat” script.+ B& q& @% d2 D V b
8 S9 C' E" _9 a7 {
# B- K2 U6 A* k0 Mcd NX600_mp01
8 _+ c, d0 T4 z/ d) _8 O O, s" n/ o- h8 F
ugs_update.bat /v( _2 M+ Y; W$ U2 ~0 d
$ ^0 L9 P4 v. u
: l3 A( r& z: _1 H z6 l
" s4 H5 m5 M. j' B/ F' P3 WThe normal operation of the script is non-verbose; stop to confirm default answers.
7 a8 F) _- Y3 x" N+ L) x/ U( a
; {4 Z3 j1 z9 @$ l/ }) c& H1 sThe update script supports 2 switches:
: P% f3 J. v1 V3 n- s) b: e: W0 @% r; x. D5 |3 E# n6 _6 e2 `: T
/v = Display verbose messages.
9 ~% n9 J2 I' s1 n- u1 A8 d1 X+ e; P' r& G$ O \! J1 |* B3 Z
/d = Take all default answers (i.e.: script will not stop to ask questions).
' p# t h3 ~* m9 n7 @0 a2 K1 X" u$ J, K+ ?) c
$ X h& T: [- x5 v4 j, H4 J7 o) i" v2 [5 m- x
Note: Before running the ugs_update.bat script, please make sure the environment variable %UGII_BASE_DIR% is set to the base directory of the NX 5 release. For example:
* R3 e5 {# f* R) ~! u! Q0 x0 ^" j$ k4 E/ \/ T
set UGII_BASE_DIR=C:\Program Files\UGS\NX 66 r% {# f- J/ k' w/ t0 y, E
& ?5 r* ~4 s: n( l) E / k3 \5 j# N& m2 G$ {& x" x
( Z2 K6 Y7 A) L) w2 `1 N# Z
Or set to the appropriate installed directory on your system.
/ F6 n+ _6 v, R q$ [
0 {4 v% c! Y: a7 C `/ E
! R) L9 V4 G* E8 _* v% y0 T1 N/ g4 I! p4 w# G
$ u" Y/ D/ ~9 |- g4 o7 s6 C$ |1 h; B
% M! x; C0 K3 o# _: F% vLINUX update instructions - z/ y6 o$ A5 b* s: H {7 u
3 U* H8 G. y. r& C% j* p( e
7 p5 ?- ?1 F9 v2 z
% Q" l7 m& L5 l& h3 g0 oThe files contained in nx-6.0.0.24.mp01.tar.Z are provided as replacements for previously installed NX 6 products.
# x' G# x% y5 ^2 v3 L/ }
" @0 H! d9 }) z" E- A0 E* @( @4 ?5 [ & a# N# J; z$ Q. O3 \1 ]
2 s" ^, l" }2 [$ m3 JFor the Linux64 platform, you should have at least 710 MB of free space.
' C" E7 u4 Y/ x* P! e/ ~8 U. \9 E! b7 q$ t3 h. X
) B# k8 |. y' B( ?2 s5 L( W# q0 L( H; e. Q- z* M2 G# {
) O; t3 {) W F- m- }2 @6 ~# ~( h, c' E, v& w4 F- H! x
# w; Y1 b$ \( I- w# _" Q# l. h# {6 u! F
To use this update, change to the directory where you extracted the nx-6.0.0.24.mp01.tar.Z distribution file, make sure the entire set of new patch files have execute access, then execute the “ugs_update” script.
, L Q( [$ j6 ?' z6 L' L
' d+ ^7 L* b3 [1 `5 t- d: j$ }
( B9 K& r) t) e C# B. d/ C# [3 f# m+ a1 X0 p5 [: y
cd NX600_mp010 W8 ?8 g" w. N- V0 S, h) H1 b
1 C) U+ n' t) h* Xchmod 555 *6 v3 \# u3 ?" C' k8 Q6 {) l
& _: a8 t" P V/ n7 j% f
./ugs_update -v! ]. h) F7 A8 A1 E, E
H# @1 j' ]7 O, X. @1 S* S: a0 b% n: t
8 O d9 J7 w1 m
. A" C4 j6 A- L" s S R, E
The script will interrogate your installed NX directory, and update the installed files. The normal operation of the script is non-verbose; stop to confirm default answers.
7 c# n' v! { G; `. M( K0 Q: a* t/ A; x; N& I& g1 e
9 K( S7 b& c7 k, B, ^
$ n0 X$ o' ^' k6 f) \8 ZThe update script supports 2 switches:
: y8 ^5 }' }6 s7 \% `' z7 L* r/ m# U2 Y
-v = Display verbose messages.
% i( X! f6 y7 z1 T# k% O
5 M5 K( [+ n" G8 {5 S4 q8 ?+ w-d = Take all default answers (i.e.: script will not stop to ask questions).! C) T& v8 [- h3 n5 |
9 |: V1 t& B5 m2 M% y2 ]( a : ~. `2 b) L% ^8 j1 C# b K
9 m; m5 D+ g$ i8 BAfter the MP update has run successfully, the following identifying text will be written into the system log of every NX session:% @- O( [# E6 x$ a& K: A+ w3 t5 |
, @- W" E4 t3 d, x- G1 O+ T
6 E# p* t$ |+ L, F& t' @) ^, M2 _* b( c5 P7 l
"NX 6.0.0.24 MP1, 15Jul08. See Maintenance Pack letter for detailed list of fixes."
: t' A% I* g1 R9 ?8 e3 {& d" y$ m& Z' A8 X4 K
7 b" _6 R! j5 P4 H: l) x
) P' u- ~8 k6 f; v/ f" BIf you have any issues with the installation or support of these fixes, please contact your local GTAC support group.% c# O5 T# F. m. d
7 r) `; h4 k: i- ~! t* a8 a S1 M8 S5 L
4 Y7 ]) E1 g: H, m9 V8 T
& y; y+ d+ V# D5 b* `. H; \Sincerely,
% Y) @5 P" k' h* o; H: F# h
0 P# e1 d. [" s. T " e0 t0 ] q, a0 ]/ J9 Z
7 D$ U0 M* W( m" y8 O- } \0 m4 _The Siemens NX Team |
