//铸入型起重棒$ @# c9 a R# D
/* These include files are needed for the following template code. */0 w: {, `; U: J% M% V. t
#include <stdio.h>7 x/ Y' ?1 c; j8 B- L
#include <uf.h>
# N* T9 F( P) ?! W6 a7 b5 Y#include <uf_defs.h>
( S$ A$ [+ V, `/ r#include <uf_exit.h>
- _' J& d0 i! h8 W#include <uf_ui.h>
: i1 L3 u# q, O#include <uf_styler.h>
; ]7 n& n( s. {6 [#include <uf_mb.h>' {# l+ @/ K& g4 ]! c
#include "CCHF.h"
& O9 k6 F$ ^" G2 Y z4 n#include <uf_modl.h>
6 m: y8 k) g* X! K3 R2 v#include <uf_obj.h>
) w& [* X" Y9 w4 ^& ]#include <math.h> /* The following definition defines the number of callback entries */
& k8 R* D4 n5 F ]# T/ _4 P7 h/* in the callback structure: */1 K g$ ^* u7 t& ]. S
/* UF_STYLER_callback_info_t CCHF_cbs */
& Q P- Y. ^& W) {# {5 k( L#define CCHF_CB_COUNT ( 6 + 1 ) /* Add 1 for the terminator */ /*--------------------------------------------------------------------------
, o- a S( T+ N$ T5 e2 l5 HThe following structure defines the callback entries used by the' @1 [, g, E3 y1 |: M
styler file. This structure MUST be passed into the user function,
" U; G0 f+ K7 E$ }" h5 A( cUF_STYLER_create_dialog along with CCHF_CB_COUNT.
1 P+ Z( r' z8 Q' I6 x/ e( [. V1 h--------------------------------------------------------------------------*/
6 ~; c% T; _8 E6 M8 G. O; k" i2 |/ [static UF_STYLER_callback_info_t CCHF_cbs[CCHF_CB_COUNT] =
$ S1 N6 [* O+ c9 P( f Z$ b{' B9 z* [; q, h$ s! e
{UF_STYLER_DIALOG_INDEX, UF_STYLER_CONSTRUCTOR_CB , 0, CCHF_con_cb},
: T0 t: O, q# N) G9 C{UF_STYLER_DIALOG_INDEX, UF_STYLER_OK_CB , 0, CCHF_apply_cb},
0 y5 w, z, Q+ ~{UF_STYLER_DIALOG_INDEX, UF_STYLER_APPLY_CB , 0, CCHF_apply_cb}, M4 N3 m8 H. _1 _3 ~
{UF_STYLER_DIALOG_INDEX, UF_STYLER_CANCEL_CB , 0, CCHF_cancel_cb},
0 q" w2 N+ G; d% P. x{CCHF_TYPE , UF_STYLER_VALUE_CHANGED_CB, 0, CCHF_type_cb},0 a8 v0 s& x: B3 t; F* D- L
{CCHF_OPTION_D , UF_STYLER_ACTIVATE_CB , 0, CCHF_D_cb},& Z: J m2 F, u/ d
{UF_STYLER_NULL_OBJECT, UF_STYLER_NO_CB, 0, 0 }0 [% M; p( k8 V# I# n6 E. D6 G& X
" _1 W& B8 V6 c# V% qstatic UF_MB_styler_actions_t actions[] = {# E r' B4 b- G {; X
{ "CCHF.dlg", NULL, CCHF_cbs, UF_MB_STYLER_IS_NOT_TOP },, E: x' c6 t3 |% V( k6 i* Z
{ NULL, NULL, NULL, 0 } /* This is a NULL terminated list */# s8 P% R8 R9 Y, S4 g# w2 S
}; char * strings_D[6]={"25","32","36","40","50","70"};
6 w' T4 y/ d! _ Rchar * D;
& J" A: E n: \int user_click=0;* c4 X% [" j. ]9 }8 J4 P
int cancel_click=0;1 h+ ?, k6 N4 Q4 O5 ?( L
int type,D_int; extern void ufusr (char *param, int *retcode, int rlen); X, Y: H+ h0 h3 C
{" B, ]1 K" G% l+ ]
int response = 0;
; h+ R7 S) S% c6 m) R+ e' O6 Rint error_code = 0; int choice;( H, {0 d5 j' N- r
int defalt[2];# w( D7 K' Y/ I8 ~; R7 E
double point1[3],point2[3],point3[3],point4[3],point5[3],point6[3];( b/ g: |) q; \2 S3 N. l/ C
double direction[3]={0,1,0};
% b. h. |+ l9 Y( j) ]% i! R$ T// int i; char * D1, * D2, * T, * A, * B, * C, * E;' @3 `. t5 y) C% {' I, B
char * R1;- T1 A$ k" N! _ n' o- k
char * block_len[3];
' r8 t7 y# R& {' |0 w3 JUF_FEATURE_SIGN sign = UF_NULLSIGN; //建立一个新的目标体, ^7 G0 O9 C+ T* w: ]
UF_FEATURE_SIGN sign1 = UF_NEGATIVE; //减去目标实体* @ g" H& K; [' V3 o
UF_FEATURE_SIGN sign2 = UF_POSITIVE; //加目标实体
J0 ^$ M5 G3 j j2 \" Y/ Q/ gtag_t cyl1_obj,cyl1_fea,cyl2_obj,cyl3_obj,cyl4_obj,cyl5_obj,blk_obj;3 {+ j8 x( Y+ b* D% @. N
tag_t blend1_tag,blend2_tag,blend3_tag,blend4_tag; uf_list_p_t edge_list,object_list; if ( ( UF_initialize() ) != 0 )
2 u: t: r( z8 b; [7 Y, }8 P& @return; if ( ( error_code = UF_STYLER_create_dialog ( "CCHF.dlg",
: G1 l- O1 h$ ^* q5 d, JCCHF_cbs, /* Callbacks from dialog */! m+ z. W3 S- e0 @! e
CCHF_CB_COUNT, /* number of callbacks*/
5 Z* Q2 q- P. _' o+ Q$ oNULL, /* This is your client data */
4 ~# {- H; x* p4 f&response ) ) != 0 )
c# J0 m# J: C8 _/ [ n$ p{ r) O0 x# v7 U) n. r
char fail_message[133]; /* Get the user function fail message based on the fail code.*/' h6 `# S4 O5 @2 ]. r: U F M
UF_get_fail_message(error_code, fail_message);, {( [6 G6 q8 P8 ]- }; p# U9 _
UF_UI_set_status (fail_message);% |6 r' J/ J; Y
printf ( "%s\n", fail_message );
4 B0 k5 [+ p2 `4 Q} if(cancel_click==1)
$ n+ w+ B6 u6 B V) s# p{9 D/ V: {: r, e, t& F
UF_terminate();
! v6 |8 o, ~1 Greturn;
5 E- t; `! \- R4 W$ s- {1 L, I} switch(D_int)* D% u" z X( P! A2 r3 z4 V& k( t
8 C, Q1 A3 m i0 V: S) }! O. dcase 0:" }- J' Q' j. z9 `0 {: {
D1="46";
. q, C# y- |2 C9 r% x& Y# y( iD2="36";+ O) o) \- T3 C% M" P) |" _& ]
T="12.6";
- X$ a8 W5 h. u7 y v" wA="25";
0 P. \& C2 I% b, E1 h0 OB="30";+ c& n, T* Y) R' {, T
C="15";
i- _5 y. o" q3 D2 g% CE="16.6";$ ]; W( t( K6 |/ r% z( d
if(type==1)3 V$ Q/ A* ^* e' a7 f7 Q
{3 J4 Y1 w4 a8 ?) r4 Y1 A5 z+ j
D1="60";# u' t3 u) g+ _4 B8 e8 E2 r
, A# F w, Z( I5 W% J% p nbreak;
& o$ \/ t, a- A6 t, ?9 G0 h" e; dcase 1:3 I; R) O+ D5 _5 y( m
D1="55";
- N4 F! A1 X2 X" i" DD2="42";8 q' h7 F7 x0 C5 U( v5 S2 q
T="13.1";
1 }. M. _1 F4 C+ cA="30";. r8 m p: K) b" X( V
B="40";3 H0 Q" d d3 o3 y* a' F
C="20";8 }# Z5 {8 h: @) R$ l1 @/ M) F
E="16.8";/ @- \% B, M$ F; b5 B
if(type==1)
8 A/ v5 T- S) u) v" l3 z9 A5 C{/ S: j% m7 q: t" Q
D1="70";2 R6 R' E n2 Y* a
}9 i5 Q( J v9 U0 a; B S& e5 Q9 u
break;
5 r; W6 \3 ^, X# B+ p6 E8 W! hcase 2:
; \, ?/ i0 \* M4 r% D9 @D1="60";
7 l( ^. Q9 J6 N/ h$ J# gD2="46";
" a$ }: R+ n( H, AT="18.5";% [: F( ^/ O7 e( Q/ R
A="35";
9 |" f' a0 _! Q+ }% C- O( UB="45";- r# m; S5 G3 x1 x; M
C="25";
6 D3 s4 W) Q; f1 v1 W$ m& `1 dE="17";
) B0 h: w, t& j! Dif(type==1)
+ q$ E6 g1 D: w$ N5 E1 }2 s$ O0 ], e{
( q- B& G9 t( U3 E" O: `D1="80";
! x5 ?, Z& Q- b' ]4 a}
( \5 J3 V, O$ p2 h& v" B% xbreak;
. l* V5 H+ h2 mcase 3:
9 s1 @8 l7 G' f, i4 p; k% w' d' gD1="70";# I" P* d5 t( C: p m
D2="55";
. h" ~, s" H1 v) d+ ^& p7 c/ }+ `& S. kT="18.9";
* J& k# _0 I. U7 o+ L2 ^! z* tA="35";
, R; A7 F4 C, I6 _9 EB="60";4 x( q/ X ~4 `8 d- ~
C="30";
- B, N$ N! G+ J$ Z3 `# F: G1 ~E="17.4";
8 ?6 `, A3 I" { T, Xif(type==1)
' F- I( P' h2 G3 e6 Q{
% c- W+ W& k% j P# \D1="90";
* g4 r, f: D2 _- Y7 p& Q}7 B5 h1 P$ O5 r5 y% ] f
break;
& t6 G8 p) n+ z; A* R3 Hcase 4:
" k8 {8 a2 |+ E% Y6 y8 ED1="90";1 H2 x5 b/ q" B7 y# E& ^
D2="70";& D% z. q6 W1 b0 m% {( ^
T="25.2";
5 I; `3 s d0 B4 T0 f v: U) wA="35";
) O9 N! F9 q" t" b$ d: [B="70";5 n+ y' G8 j2 R# [% @+ E
C="40";
+ H/ ^7 ~3 d9 n2 w: `8 yE="18.1"; K1 c3 J9 K, B3 N3 u1 C9 \. l
if(type==1)( m' \5 O. U- s( _0 c4 v
& d; i$ v8 A) l5 B0 j4 E5 `D1="120";
" Q. o* W, O* L* F" G7 ?}
$ `% Z# N& s7 o8 h* _break;
$ r' m: V, m1 Z( `6 K5 rcase 5:& O1 C. g# ?. h
D1="120";/ K) P& C$ h( k, |' a
D2="100";& [1 _+ p7 n: p: ^% Y! m% R
T="31.1";$ x1 F/ a8 N- M5 R6 m
A="40";! [. x2 R- L; `- f
B="80";; M0 }! S+ v6 G- `; Y5 b7 x; {8 W
C="40";
5 N' k6 }# Y& G0 p' aE="19.4";$ H, J" k$ K+ c7 {( Q9 O
if(type==1)* W5 {6 B* q. G2 W2 X$ x- z
{6 |+ h& `+ b4 N, x1 R- @0 e0 M
D1="140";
1 t" M: p; F9 R* E: ^}( F: ~3 [( F* C4 h2 g+ M! v9 E
break;
5 m/ i0 N- A5 j# r$ L. P( s n) Cdefault:& V5 o$ s n7 t( t3 ]' z4 X
break;. y: C7 V3 d X# f$ h# }
} if (user_click==1)! z' Y6 y- |" n9 r4 W
6 l' Z8 S4 d- \2 D( ^, fchoice = uc1616("指定插入点", defalt, 0, point1);
# Z/ p' N. Z1 {; X0 y1 m: Sif(choice == 2) //判断退出对话框
+ {* v6 a; T, F5 A* O5 a7 S5 t2 h{
' }! w1 H* ? T* f' T% EUF_terminate();* i5 ^4 s/ T9 L
return;
% Q/ N# k9 r& c$ ?$ }" s} R1="2";
: ^3 q! \ u, a1 Xif(type==1)2 X* t% r' G; t. i5 g- `. f* j# o1 t2 ?
& v1 u7 X% @3 l3 C" [9 O( A( t* NR1="4";
5 b) q6 f3 \1 r( J9 W/ r% q}5 X) C6 X! O. H. S% K9 x. q
//cyl11 S$ S! k& ?4 U$ G
UF_MODL_create_cyl1 (sign,point1,T,D1,direction,&cyl1_obj);
! ~" X+ g# }- p0 {UF_MODL_ask_feat_body(cyl1_obj,&cyl1_fea);
& F8 ]4 s1 y. }, {, Q% lUF_OBJ_set_color (cyl1_fea, 9); //设置实体颜色 UF_MODL_create_list(&edge_list);
, v5 J. w$ m# J! ^UF_MODL_ask_feat_edges (cyl1_obj, &edge_list);+ r4 \0 {4 X% L2 a* u) a- t
UF_MODL_create_blend (R1, edge_list, 0, 0, 0, 0.5, &blend1_tag); //倒圆角cyl1
# U9 ]9 o+ X8 y3 PUF_MODL_delete_list(&edge_list);3 P. K5 M' k! F) Y# K7 w1 \
//cyl28 S- s' _0 m q- i+ \0 I
point2[0]=point1[0];
2 T+ Q" `" l, ~; R; S% G8 Opoint2[1]=point1[1]+atof(T);
# p" {" D$ ]1 b0 j& I" hpoint2[2]=point1[2];' f0 u+ U" m$ v
UF_MODL_create_cyl1 (sign2,point2,A,D,direction,&cyl2_obj);) y0 n9 L' Y( |& E+ k. U
//cyl3
4 v2 }1 L3 @4 {* p" E( t/ ]& l, Spoint3[0]=point1[0];1 d, ~9 S5 i2 a# c
point3[1]=point2[1]+atof(A);' p/ _ p' d; u% G' D/ Q
point3[2]=point1[2];
% I. v- P8 A* k) M4 oUF_MODL_create_cyl1 (sign2,point3,B,D2,direction,&cyl3_obj);
3 o1 O# C+ X+ b, S4 p V8 }8 t* v//cyl45 f' C, s e2 e8 G- H
point4[0]=point1[0];9 ~' ^! n/ N. N; c( y, @1 E
point4[1]=point3[1]+atof(B);
, x4 \2 n9 ?; D/ Z% W9 m3 @+ Npoint4[2]=point1[2];
$ z, m* h/ `2 P7 JUF_MODL_create_cyl1 (sign2,point4,C,D,direction,&cyl4_obj);
" O& u8 Z$ o5 c) Y' G, R//cyl5 Z4 h% E9 G. g# _+ p4 T8 T# ~! t
point5[0]=point1[0]; W) i, n# I$ s' v" b* u
point5[1]=point4[1]+atof(C);
6 s0 @* o9 E! G4 m9 ^point5[2]=point1[2];
B7 s- p4 M- wUF_MODL_create_cyl1 (sign2,point5,E,D2,direction,&cyl5_obj);4 U. V0 i. a' P& s3 Y0 s& L
//倒圆角9 P; n/ l# R$ W8 y3 G5 Z
UF_MODL_create_list(&edge_list);, ^: G( d& Q$ c6 Y$ p( c5 F
UF_MODL_ask_feat_edges (cyl2_obj, &edge_list);/ S, J& E( W1 E$ ?6 o8 H/ P1 }" F/ J% {" s
UF_MODL_create_blend ("5", edge_list, 0, 0, 0, 0.5, &blend2_tag); //倒圆角cyl22 K! E3 |$ U7 ~% _& i
UF_MODL_delete_list(&edge_list); UF_MODL_create_list(&edge_list);
% c2 Z. H$ h8 D+ f4 bUF_MODL_ask_feat_edges (cyl4_obj, &edge_list);1 e/ |, r$ ]+ P- f- `4 ~
UF_MODL_create_blend ("3", edge_list, 0, 0, 0, 0.5, &blend3_tag); //倒圆角cyl4! x1 I( t# p# n) x( A9 U) d$ n! o
UF_MODL_delete_list(&edge_list); UF_MODL_create_list(&edge_list);, O0 L$ q. A3 n1 ~
UF_MODL_ask_feat_edges (cyl5_obj, &edge_list);7 k3 z: j5 S! h6 s/ o3 d
UF_MODL_create_blend ("3", edge_list, 0, 0, 0, 0.5, &blend4_tag); //倒圆角cyl5
8 v0 t8 [( K ^UF_MODL_delete_list(&edge_list);
/ M$ |: S2 O: O+ f//减体用blk
7 F% |( y# D5 I* Vblock_len[0] = D2;
7 C2 |) y8 x+ o+ K: C/ D3 {block_len[1] = D2;* q* W; ~ _0 s+ t0 M) t
block_len[2] = D2;
/ E" {/ b; E# Y+ A. Rpoint6[0]=point1[0]+atof(D)/2;
- @' [0 t$ P6 J B& Y# Tpoint6[1]=point5[1]-8;
0 i5 k+ y4 H$ a* W D. E5 qpoint6[2]=point1[2]-atof(D2)/2;
, g8 o! X. v f4 T& K* Y2 O9 l* aUF_MODL_create_block1 (sign1, point6, block_len, &blk_obj);7 Y) ]1 @! d5 ?7 n5 L4 ^9 I
//消参: Z. C ]9 t; S [( z. J
UF_MODL_create_list(&object_list);. ~1 M8 K) Q" P( ~1 b/ X, \1 G
UF_MODL_put_list_item(object_list, cyl1_fea);
9 ~3 s2 z: ^: Q+ I7 ^UF_MODL_delete_object_parms (object_list);% [6 N* ?8 b/ _4 y Q1 _, @. {
UF_MODL_delete_list(&object_list);
; ?9 `) R5 ?" v" X9 h/ u6 z} UF_terminate();& k7 f3 K! D. u+ d+ I# o
return;! D& w# q; j. E/ b4 x7 b
}+ A7 S% E: Z- L
extern int ufusr_ask_unload (void)
8 d, m; |& h5 U% ^# Z! F/ E0 c v{" z, ^3 e: @8 \# E6 Q
/* unload immediately after application exits*/. B& h* V& V; U
return ( UF_UNLOAD_IMMEDIATELY ); /*via the unload selection dialog... */) v7 p. M. P; A( K8 v
/*return ( UF_UNLOAD_SEL_DIALOG ); */* a: R" a: O, U- @$ G
/*when ug terminates... */' @. P) C8 \# \, g
/*return ( UF_UNLOAD_UG_TERMINATE ); */& O( E" x0 `* |' C
} extern void ufusr_cleanup (void)" O; B% g+ ]3 `
/ o" C2 {& Z! c; ~/ }1 ^9 Ureturn;9 N; D, V( G. Y: n8 h: O
, M R$ {2 s4 Z; r7 {- A# n5 _int CCHF_con_cb ( int dialog_id,
u7 z' W# S; v7 Q/ Lvoid * client_data,
: k# b: x; }0 v" HUF_STYLER_item_value_type_p_t callback_data)( B, i: U0 l6 x% k8 C9 k* U) P& h
{2 V! J6 [$ Q4 ?- y# e( g' k& o
/* Make sure User Function is available. */2 G e# h# U0 x0 ]1 X
UF_STYLER_item_value_type_t data; if ( UF_initialize() != 0)
, q! @) j4 n1 x/ yreturn ( UF_UI_CB_CONTINUE_DIALOG ); /* ---- Enter your callback code here ----- */
1 B( i' p3 ~4 \data.item_id = CCHF_OPTION_D;) a$ |. y# J4 [; q
data.item_attr = UF_STYLER_SUBITEM_VALUES;0 O4 w3 e, P& W) z4 p
data.count = 6;
2 u( @5 u7 \. o" _' z p4 @data.value.strings = strings_D;
5 a$ E8 G0 l9 ?5 u' WUF_STYLER_set_value(dialog_id,&data); data.item_id = CCHF_WIDE_STRING;
3 u& y6 L, O- W Wdata.item_attr = UF_STYLER_VALUE;
' U& Y% T' q* M @data.value.string = "三住标准/材质:S25C";
8 y, K. D% S# l" X4 ?. A; kUF_STYLER_set_value(dialog_id,&data); D="25";, f3 [ l, p: ]
type=0;
# z7 O+ K7 _! P XD_int=0; UF_terminate (); /* Callback acknowledged, do not terminate dialog */; T: w3 U; {; F: O8 c" {
return (UF_UI_CB_CONTINUE_DIALOG);
7 s# ^5 T6 o; ]' I5 b/* A return value of UF_UI_CB_EXIT_DIALOG will not be accepted */: |" R* e- L5 p5 U
/* for this callback type. You must continue dialog construction.*/ } int CCHF_apply_cb ( int dialog_id,0 Q; s0 q. q) c$ s
void * client_data,
7 j. {* o, R( v2 X O& |7 i$ S# _5 kUF_STYLER_item_value_type_p_t callback_data)
1 S6 A- S7 Y- K) n, ~: K! h+ _{4 j, y9 T, Z$ n0 P& g0 p
/* Make sure User Function is available. */3 M2 ]' ]0 U f0 w& `1 w2 j
' a5 t0 C3 X. ureturn ( UF_UI_CB_CONTINUE_DIALOG ); /* ---- Enter your callback code here ----- */8 R. g1 Q" d5 Q1 Y
user_click=1; UF_terminate (); /* Callback acknowledged, terminate dialog */7 Y0 Y" W! Q+ {/ ^
/* It is STRONGLY recommended that you exit your */' T. H A, c z- _# C3 o* W0 D
/* callback with UF_UI_CB_EXIT_DIALOG in a ok callback.*/
7 A+ y, L9 t- @/* return ( UF_UI_CB_EXIT_DIALOG ); */
# C# s5 |9 t: wreturn (UF_UI_CB_EXIT_DIALOG); } int CCHF_cancel_cb ( int dialog_id," V3 ?; v5 {) q/ }) G; r1 n A: R. U+ N
void * client_data,
3 D6 Q* L$ @! A3 x8 k" `2 ?UF_STYLER_item_value_type_p_t callback_data)
0 t3 \7 B& \. [) q4 S4 s5 G o6 E{4 S+ }7 P3 ]8 S" I8 C2 k# q
/* Make sure User Function is available. */' l# e% S( T- ~# G
if ( UF_initialize() != 0): b. N! q/ d( q, o
return ( UF_UI_CB_CONTINUE_DIALOG ); /* ---- Enter your callback code here ----- *// q# w' \/ O7 }( l
cancel_click=1; UF_terminate (); /* Callback acknowledged, terminate dialog */2 s( i# _" t& Q" k4 O$ R
& r( W1 f U! t) ^* `9 t V/* callback with UF_UI_CB_EXIT_DIALOG in a cancel call */
, q$ k4 o1 }8 B/* back rather than UF_UI_CB_CONTINUE_DIALOG. */
8 k) r1 J$ N* o; ~ Yreturn ( UF_UI_CB_EXIT_DIALOG ); } int CCHF_type_cb ( int dialog_id,* ?) w( j1 {1 t5 Y+ C# t* Y
void * client_data,
3 E4 E5 U& a9 S# D0 e/ NUF_STYLER_item_value_type_p_t callback_data)" [; ?/ P- g% J0 p& N: n8 z! {
) w3 d$ W c( E" U/* Make sure User Function is available. */: e+ e- @" \9 Z2 _6 N9 v) v5 w
UF_STYLER_item_value_type_t data; if ( UF_initialize() != 0)0 W5 G# D" X) T. a6 g9 l
return ( UF_UI_CB_CONTINUE_DIALOG ); /* ---- Enter your callback code here ----- */1 `2 \$ ]0 a! `' `: k4 f
data.item_id = CCHF_TYPE;
/ D& S; B0 I. V# T# F; M/ C/ W. H* qdata.item_attr = UF_STYLER_VALUE;
7 {8 ~: k4 T- R! l2 FUF_STYLER_ask_value(dialog_id,&data); type=data.value.integer; UF_terminate (); /* Callback acknowledged, do not terminate dialog */1 l2 h. X0 B k
return (UF_UI_CB_CONTINUE_DIALOG); /* or Callback acknowledged, terminate dialog. */; N, T" ~: ?& Y. b& P8 x6 a2 Z9 V
/* return ( UF_UI_CB_EXIT_DIALOG ); */ } int CCHF_D_cb ( int dialog_id,: \0 S. n% y+ q+ W
void * client_data,
. W R L2 C0 S+ S. {) i( TUF_STYLER_item_value_type_p_t callback_data). T6 P3 q2 z }4 w
$ w, g& F1 B* W5 M/* Make sure User Function is available. */; H& E8 {8 k' C0 d
UF_STYLER_item_value_type_t data; if ( UF_initialize() != 0)7 z$ o, C1 ?4 f; g, _8 q, V
return ( UF_UI_CB_CONTINUE_DIALOG ); /* ---- Enter your callback code here ----- */' ]0 d8 `; e5 {) }9 ~% t
/ @ w) _+ s7 F7 l# ^& zdata.item_attr = UF_STYLER_VALUE;
9 R* [8 D- v% D5 }1 BUF_STYLER_ask_value(dialog_id,&data); D_int=data.value.integer;
+ H9 _ k8 {7 oD=strings_D[D_int]; UF_terminate (); /* Callback acknowledged, do not terminate dialog */
9 Y0 e: U/ Q5 |5 E3 X8 B# Dreturn (UF_UI_CB_CONTINUE_DIALOG); /* or Callback acknowledged, terminate dialog. */, N! N2 |0 k5 U8 h
/* return ( UF_UI_CB_EXIT_DIALOG ); */ } , l2 R( X6 o" W9 z7 m8 ^- H: s9 o$ f# g
' S, w" N! k5 n8 r/ h8 n* H! g |
