设置切削方式参数 UF_PARAM_DPM_CUT_PATTERN , G1 ^ F/ ]# E9 |+ O5 w: R3 l
设置stepover 方式参数UF_PARAM_STEPOVER_TYPE
6 N4 F+ e4 o4 o) b2 ^6 S
5 g2 l7 ?' {) @3 R# _- I# a" g; I }, |
' o H5 J% ?; s7 @( K+ T
例: UF_PARAM_set_int_value(oper_tag[0],UF_PARAM_STEPOVER_TYPE, UF_PARAM_stepover_type_scallop_height); UF_PARAM_set_double_value(oper_tag[0],UF_PARAM_STEPOVER_SCALLOP,0.005); 0 _6 r: S/ ^ Y, X/ Y4 ?) q; `* R
UF_PARAM_set_int_value(oper_tag[0],UF_PARAM_DPM_CUT_PATTERN, UF_PARAM_dpm_cut_pattern_profile);
8 S: Q4 \$ @% v( o
UF_PARAM_set_double_value(oper_tag[0],UF_PARAM_SPINDLE_RPM,20.0);
, {% k" g7 A/ Y5 B+ k
5 {7 d1 m; Z! m) _$ F) b . | B3 M( Z. J/ y
$ |1 n+ s' g" n- H$ P
3 V; c4 A: A( {: S! r以上摘自之前编写的《ug API开发组培训手册》
9 l1 ~, U: N5 o. S |
