查看: 11204|回复: 19
[资料分享] 某工厂项目工程师多年的辛苦积累——塑胶模具英语中的口语
发表于 2014-2-27 10:33 | 显示全部楼层 |阅读模式
今天奉献出某工厂项目工程师多年,在模具英语口语上面的积累,今天一分钱不要,免费送给大家,愿各位成为《技术+英语》的双向人才!
塑胶模具英语中的口语.zip
17.8 KB, 下载次数: 332, 下载积分: G币 -1
发表于 2014-2-27 13:22 | 显示全部楼层
1XXX!你现在有空吗,我可以问你一些问题吗?4 Z7 @' e3 n' T* c4 h' k& B7 A) t
Could I ask you some questions if you are free?/ Are you free now? May I ask you some questions (a question)?
3 M6 J9 g% i8 x5 V$ t7 W2. 请问此产品的面是否为外观面?表面做什么处理?是晒纹/抛光?
5 y, V3 H+ `+ e7 K, `Can you tell me whether the surface of this part is a visible/esthetic one? What will we do for its
. }1 T3 p: @& N5 N# G' fsurface? Texture or Polishing?
, \7 T% G7 [4 G4 M4 g1 m6 Z4 Z3. 请问产品这个面可否加顶针或顶块?产品允许加扁顶针吗?
( [1 a% @* d/ K+ x: g1 E& w( z. j  ADoes this part need an ejector pin or an ejector bar? Can we add an ejector blade?3 P' C, _- \) s8 e. C
4. 这个产品的柱位我们打算做司筒。(或镶针)可以吗?
  N' ^0 Z- R+ z3 ZCan we add ejector sleeves or ejector pins in the boss of this part?$ W( `8 O. E) G9 o7 a" E/ A4 f; W
5. 产品的这个位置不能出模,我们打算做行位,在此面上会有分模线,你接受吗?6 X6 w; R  |& _) P
There's an undercut at this position and it needs a slider. It will also have a parting line on
7 v4 g7 o* ?. t0 P9 Qthis side, is that OK?0 S' j; K  Z: g. Q( o' q: d
6. 产品里面的这个位置我们打算做斜顶或内行位,有问题吗?$ I* g+ [9 L( F: I/ J
We will make the lifter and (inner) slider in this position, will that be a problem?
( h  o  m1 B9 H6 e8 V* r7. 你提供的2D产品图与3D产品图不一致,请问以哪一个图面为准?
3 ]6 ?5 x' |3 e" H! nThe 2D and 3D drawing you provided is not the same, can you tell me which one is correct?, |6 Z7 f& t! X
8. 你提供的3D产品图有的地方没有出模角,有的地方胶位太厚,有的地方胶位太溥,这些产品问题我们可以自
! T: i+ ?* W: Y( y2 p  h0 a
- ~% v+ _' H# f5 B3 J己修改吗?修改后会给交给你确认。
& M# S% ?& T7 YThere is no draft angle in the 3D drawing, some materials are too thick, and some place are too / D9 ?2 m6 Q( i' k7 n1 R9 L
( A) o0 u* v2 s
thin. Can we modify this part by ourselves? We will send the drawing to you for you to check after we modify it.6 \4 w  [7 w1 \
9. 按你们提供的缩水率千分之五,这个模具的尺寸已经做到了模具图面要求。但注塑出来的产品不符合你们的& Q) N, @) v8 x! z
8 K! z& o& Q2 ]
产品图。
% F* j' o- T$ ?7 O6 G4 P+ j请确认你们的材料的缩水率是否正确?
2 i6 y8 W' F  L) t& _( lAccoring to the shrinkage one over two hundred, the mold has been done in the right dimension, but the part falls short to your part drawing, are you sure the shrinkage is right?1 V8 r) M" X: D! u
10. 产品的这个位置太小,导致模具钢料太溥,能够加宽这个位置吗?8 T1 C9 g2 ^+ H6 _
This position is too small and will make the steel material here too thin, can we widen it here?
11. 斜顶与后面的柱位空间太小,斜顶在运动时会干涉到柱子,能移动这个柱子的位置吗?
) i1 l8 u  h8 [/ m' [0 j  s' kThe angular lifter interferes with the boss during ejection. Please consider changing the position of the boss.) E. x6 p$ h' k. \% o; v& u4 t
12. 这个筋骨位胶厚太溥,而且高度偏高,注塑时很难填充这个筋位,可以增加这个筋骨位的厚度吗?8 r! N! m4 V2 A
The rib here is too thin and on the high side, so it will be difficult to fill here when we do the 5 T- D; C6 o+ y4 J5 W# q' D3 j: v
injection, can you inrcease the thickness of this rib?4 j, H5 i+ ?' b0 E% t
13. 你是想将此筋骨位的高度加高/减低吗?加胶的位置我们将用铜公放电加深。但减胶的位置有两种做. @; N6 E3 D" J$ e; T
     法,1、做镶件;2、烧焊;因为镶件的底部有运水,我们简单的做法是烧焊处理,你可以接受吗?
( ^1 w- @3 L6 H0 d$ s2 a6 n0 Z' I2 u. gWill you increase/decrease the material on this rib? We will use EDM if you add material, but there
7 m- I- R" X( V/ N& M# h1 {5 k3 D, o
' j4 ]. L# e9 \: [  Z* U2 ?/ ], B  X1 ?are two option if you choose to decrease:1.Make inserts;2.Welding, because there is water in the
! s  \' X0 W- f2 i" B- h* D
/ ?0 |4 s5 e0 h5 hbottom of the insert, is that OK?
2 A9 f+ c% m7 Q6 o14. 这个样板的筋骨位底部烧焦,是因为排气不良,我们可以在筋骨位的中间增加一个镶件。$ K, c3 P) u2 Q* b# r7 n( g4 ^
This sample has been burned in the bottom because the venting is not good, we can add an insert in the middle of the rib.
) w" M/ v# [6 |. y15. 重做镶件大约需要5-6天时间,你能接受吗?3 y3 o* S& a0 u, k/ r
It will take about 5 or 6 days to redo the insert, is that OK?
+ ^. N, g5 u7 n  x16. 产品的这个面我们已经做了晒纹处理,如果需要加胶,这个面我们需要重新外发晒纹。可能需要几天的时间. D. W+ u6 U1 D. q; N8 s# C* G) Q9 b
: z0 s3 s; w7 D; m  K% L" a- ]3 V
. s5 D6 V# S4 \: H/ n     所以我们直接以铜公放电的火花纹取代你要求的纹路,你可以接受吗?
9 E3 O- A$ ^4 _' cWe have made the texture on this side, if we add material, it will take some days to remake the
9 @. M* m9 w1 u
$ Z  o/ ?; F* V! S3 Stexture by out-resourcing, so we suggest using the texture by EDM instead, is that OK?( a4 }. ]( Y: w/ K
17. 模具是用公制/英制的配件?需要备用件吗?
9 Q% u0 L* n1 ]- U7 R; n; L0 G$ A4 wIs this mold dimension measured in inches or meters? Does it need spare parts?" r2 x6 `/ j. a7 [& m6 C
18. 模具上铭牌上的刻字内容是由你们提供吗?你们什么时候可以这些刻字资料。
( B2 i; A& @" r  n7 mWill you provide the engraving content of the plate of this mold to us? When will you send it?0 ^$ G4 D' F! i" f
19. 可否提供此模具生产时,注塑机的型号及相关资料。如:啤机大小、呵林柱尺寸、顶棍孔尺寸等! k* d1 j2 g2 T0 \
Can you provide the type of injection machine and other related information of this mold to us? $ ]+ ]5 ?8 S3 m
  z: k1 K$ f- f6 N
Such as the boss dimension, the hole's dimension of the ejector pin and the size of the injection ; d3 y0 u$ W2 K, _
3 \/ y" [% L: S( T5 T, Jmachine and so on.4 I+ p; _& q+ W/ M5 z
20. 这个问题我需要同其它同事商议会再答复你。2 k, n' q/ U) y9 |- o' V+ |
I need to discuss this problem with the other colleagues and then I will reply back to you.
21. 我们将尽力达成你的计划,如有异常,会及时通知你。
8 \( M6 d) ^8 D0 _5 H1 {  g) X# \We will try our best to complete your plan, if there are any complications, we will notify you # N8 p. E4 u) {4 F6 ?
$ Y8 q( F! d; P# c: y
immediately. ; \8 M0 ~5 [4 r- t9 D8 m  n
22.这个产品的长度为330.12MM,宽度为78.96MM,高度为45MM.胶厚为2MM,重量为70.63g,试模注塑机型号为250,
2 V7 z7 q6 @$ u
' p6 b/ Z! X( q' d! s2 k- F2 z5 s胶料颜色为黑色,产品外表2 W* D7 A  f/ }& K; \
  面晒纹处理,内表面为抛光.需要日期章、环保章、材料章.前后模用2344氮硬,斜顶和行位座用738H,以上模具信息正确吗?请确认!. V, |' j# p. n* c' k# k
"The length of this part is 330.12MM, Width is 78.96MM, height is 45MM, thickness is 2MM, weight is % g8 ^( h+ i1 R  ~5 o1 o
% f0 b7 {; P- v. [70.63g, the injection machine is 250T,the material is black, the outside of the part has texture, ( S" E& O( {8 {- K9 i2 ^9 P
: s' {1 F/ I) K/ ~* p2 oinner side needs polishing, and it also needs a date and recycle stamp,
. t# ]# \( |  Q0 V- W
  c4 ~" |. T" z) ethe core&cavity is 2344 nitridng, the lifter and slider shelf is 728H. Please check the information
& h$ v" L+ H+ [' L( Q9 n  }6 K  dabove!"
9 f" J- o( y5 E* \/ n# n& E' H23. 现在到了吃午钣的时间,我们下午再继续好吗?) C( q7 p+ F$ L. F+ c; _0 R# a
It is time to have lunch, let's discuss this project later this afternoon?8 j% M6 h- @( u5 m, I4 Y* n
24.和滑塊干涉的倒勾請加料填平至滑塊可以順利滑動) O7 p( z; ?* A9 }, o/ \
(The undercut area interferes with the slide block and needs to be filled with material to help the slider move smoothly.)9 v' ?: Q7 p( Y+ |, w
25. 加肉太多    (The thickness added is too thick.)
* W9 E$ p& F2 v1 P4 ~2 T. u26. 加肉面積太大 (The thickening area is too wide.)
+ {2 s( L1 O7 o27.GATE位置移位 ( The gate position is moved.)
/ ~2 ^1 I/ L: B" f4 n6 O28. 滑塊拆的位置 (The split line of slide block or the area of slide.)
- p# [% y: K5 p! a6 X% _29. 此處有尖角,填充困難 (It is hard to fill this area due to the sharp feature.)
4 B# C" ?  _/ l30. 此處鋼材太薄,強度不足而且不容易冷卻. e' B+ N7 X5 z1 H5 ^1 G9 f
(The strength of this area is too weak and it is hard to cool because the steel is too thin.)" ^) _- ]8 l/ F. q& L
31. 圓柱特徵要有一半圓不可以拆在滑塊上,以免粘滑塊造成拉白,拉斷
, t  ?& Y$ T6 [(We avoid designing the semicircle of the cylinder on the slide block because it will be pulled ) D/ e5 s. q# ^/ G% f5 {
% r! K8 J' C7 k0 K; P6 Qapart or cause drag marks.)
1 k% k- i1 E* [32. 此處做斜銷在作動時會削到成品肉厚" X- Z- X2 P- Y
(The part will be damaged if we make the lifter in this area.)" L2 @; i' r  E
33. 這個面是裝配面,不能加料. ~* E; c$ n" b+ C/ i
(This is a critical surface where we cannot add additional material.)1 [' m7 \2 F6 ?3 A  |& ?" M  b' M
34. 此處料位太厚,會有縮水,建議減料改善
2 i9 G- C/ T- l% u(Because of the shrinkage of the thickness, we suggest reducing some wall thickness to improve it.)
8 z2 M- O) f* I& m" ?35. 此面是不是外觀面,此處做滑塊的話會有夾線,是否可以接受
2 k0 @. l, T. L* ~! g"(Please confirm whether it is a critical surface or not. Also, confirm whether it is acceptable to
& E6 n! o5 K& N) \have a slide split line if we have a slide in this area. )"
, s# m" W# a% ^# t% w5 C36. 此處有倒勾,能否減料,使公母模靠破,不做滑塊和斜銷( b; v5 O9 e8 K5 z. w
"(Please confirm whether we can reduce material to the area where we have an undercut as indicated to have shut off
& B  P5 |# w+ G% z- a- i- ~- Ron cavity side. No slide block and lifter will be made. )"
2 K& ]1 X" |6 p37. 請盡快確認這種拆模方式和結構,否則會影響模期
+ B( i4 P& ^4 d( e+ M9 c(Please confirm the issues of Parting line, Gate position...Etc. as soon as possible; otherwise, ) Z. t& a9 E+ g( I
7 ?( b% a- d. D! ythe lead-time will be extended.)
/ r! j2 V( g) z( w5 q" `& W38. 此面是否有特殊要求,能否有頂針印
* I7 ^, {% e4 g7 ^# [( Y(Please confirm whether it is a critical surface or not and if we can have E.J. pin marks on it.)/ r' t2 A; O3 Q/ ]( G4 T) b. e1 A2 D; @
39. P.L面開在此處,模具上會有尖角和刀口,對模具壽命有影響$ k) p+ f7 W' s
(There are sharp edges if we set the parting line here, It will reduce the tool life)1 C2 i" h, n5 H
40. 加大拔模角,以便脫模順利   We suggest enlarging the draft angle to help release the tool.)
41. GATE做在此處的話有兩個缺點:1.蓋子打開時可以看到GATE的修剪部位; 2.兩個斜銷在同一側,頂出也不是很平衡.
* E' ^9 G) D; f& K" Z(There are two problems if the gate is to be designed in this area:! n: Q7 [* l* F3 n! S6 c8 }+ a0 Y
a). It is easy to see the gate mark when you open the cap.
+ P5 V; x" j/ vb). The ejectors are unbalanced when two lifters are on the same side)
7 u+ s1 G  ~# a8 Z42. GATE做在此處的話.蓋子打開後看不到GATE的修剪部位
+ c( T- x+ ?2 |& f3 w, G(The gate mark is not visible if the gate position is designed like this.)2 s: _- c) ]8 a, t; x; K. x, p
43. 如果GATE一定要做在你們指定的位置的話,那還不如做在這一側,這樣的話還可以減小這個位置的縮水
# m+ S7 w) N4 S9 ?"(If you insist that the gate position has to be like the original design, then we would further
9 N. R- f0 \% F1 {) u$ A6 |recommend to have
' S+ w/ n) ?1 A# n! @+ b5 Eit to the area indicated so it can avoid a shrink problem in this area.)"
% \# d/ E4 z4 o$ i0 B2 y44. 在此處GATE做潛頂針的話,背後的外觀面會有沖料痕,而且成品又是黑色的,會最明顯
5 E% k5 L: C& _1 F1 C8 D(If the design of the gate has to be a sub. Gate, then the back surface of the part will have & q# H  [. ]0 z7 q
# c" @2 Z. Q, a- h: k* z
serious flow marks due to the black colour.)
8 N$ X; T- e/ O1 y2 v22. P.L開在此處不合理,模具加工困難,P.L應改為和圖示的一樣
% |' o. X1 W9 ?* t  o' y6 O"(This area is not suitable to have a Parting line because the tool will become more complicated;
7 u" K5 S" K# M" c2 ktherefore, we recommend to have the Parting line as indicated.)"
. p$ h- F" I! c! t( x45。产品粘母模的機會很大,能否在公模加倒勾,拉料頂針或者公模保留E.D.M紋,開模時使成品留在公模一側  a4 X9 a% D6 J* B+ v+ B
"(There is possible sticking on cavity; therefore, please confirm whether it can make undercuts, ' K) \. @# p0 v( A9 u
snatch pins or leave coarse E.D.M. on the core to snatch the part on)   "8 a3 B# S& U& ~: }, r
46.此處料厚段差很大,成品表面會有應力痕,是否接受
* w4 b9 p( Q) K9 r4 z, h5 ^(Please confirm whether it is acceptable to have stress lines on the surface because the thickness is not equal.)
' y/ U6 J/ ?! m4 i47. 請注明何處為外觀面,能否提供2D圖和注意事項: i6 Z" ]- {+ @  F0 B4 n' ?8 [
(Please advise where the critical surface is. Please also provide us a 2D drawing with critical
' l& I5 \. \+ a) L7 S3 Cdimensions. )
3 c; ~, |" `3 S2 _; K; q( K48. 紅色所示處是有問題的地方,請特別注意$ e( T; j, {* \$ l3 x; O# L
(Please note the red highlights because those areas have problems.)/ D  j4 m. Q2 t2 |1 N$ v! v
49. 成品設計此處有問題,建議如下圖所示修改0 p, i0 s9 u9 r- X' D
(We would suggest using the attached part design as the current design has problems.)& c: X5 p1 A1 b, p* S7 u. a6 C
50. 此處改為一個球形的凹槽 (We suggest modifying it as a globe recess.)
51. 圓柱特征要有一半不可以拆在滑塊裡,以防拉斷 (this issue is the same as no.8)
: I6 ?( y6 o4 J/ N1 c52. 此處大滑塊上走小滑塊,小滑塊要先退,大滑塊要做延遲
' w# ?; S. i$ W" E& \7 ^- E(The inside small slide block will recede first and the parent slide block have to postpone
; x2 M, o& e2 R3 \/ i+ t) p& jsliding.)* W1 M, O% w$ a3 r
53. 滑塊要用液壓油缸抽芯以保証開合模順序  % q( w$ [: M# V2 M' C$ g% Y
(The slide pins will use an oil cylinder to assure that the process is in proper order.)  ; T  v- P% v5 E6 w6 V0 @
54. 這個面有裝配,加料的話裝配時會頂住,如圖所示9 `+ F9 p$ r* q. {
"(We cannot add material to this surface because it will intervene between the two parts when it is assembled. Please see the sketch attached. )"
* j$ n9 R2 K& D  y5 Y' N55. 可降低斜銷面,增加成品些許肉厚來做變化; _- E, R: B/ q6 l
(To descend the surface of lifter in order to thicken the part.)
# J, B" L/ a" w: n0 x56. 一半做斜銷,一半做自然 (One half side will have the lifter and the other half will be : D( W! t0 I9 {& @6 ^
  ]/ T5 Y5 [, l0 W9 x: z$ l, lsolid/nature.)
0 J8 X( X3 |9 G1 s57. 此處兩個柱子重疊,有倒勾,不能做自然,要做SLIDE1 D; x, n( W8 E0 K
"(These two bosses are overlapping with undercut therefore it can not be made as solid. We
' p4 D, H/ E! n4 g# M+ L' dsuggest making it with a slide block.)": g! {( C- J9 ~
58. 此處強迫頂出 (This area needs force ejection.)
& \' E& ~& }1 c% `- m59. 公模兩段開模,這個地方先退 (Here will be a double ejection for forward and receding.)
% L/ R& C1 O3 k, Q60. 此處做鑲件會有夾線,能否接受   Please confirm whether it is acceptable that there will be a split line here.)
61. 此面公母模1度靠破,會有段差,可否接受
% W7 v0 G& r/ v6 ]/ [(Please confirm whether it is ok to have mismatch to the area where there is 1 degree of shut off in Core / Cavity side.)0 a' p9 K! H# d6 ~8 O& ]) a: |5 {
62. 這個尺寸能否加大 (Please confirm whether we can enlarge this dimension.)
- W# ^/ O$ _7 }4 a63. 此處加一個凹槽,膠片的彈出效果會更好一些,試模後看裝配的效果再做修正
: c- Z( W$ T  a"(It will affect the elastic of the film better if we add a recess. See how it will affect the
/ a+ N/ F, G! s7 |) ]assembly parts, and then make your decision.)"
5 |, ]; z! {9 h. A2 X6 j- o1 G64. 此處有倒勾,建議將剖面線所示部位CUT即可避免此處的倒勾3 p6 ^' |' s: n, B% I% _' ?5 U6 {
(There is an undercut here, we suggest cutting out the indicated part as it highlighted to avoid an undercut.)) Y* R1 g1 j8 o9 X9 u  T* k1 M% t* k
65. 成型後SUB GATE要修平 (The gate (sub gate) needs to be trimmed evenly after being moulded.)
6 }# b" g' H* \% e66. 此處倒勾先垂直頂出,之後再手動取出
8 M6 I  R- l* f. |5 m(This area of the undercut needs to be ejected vertically, then taken out manually.)" Z! ?5 s8 y8 z) u& A3 i# d
67. 這兩個面都有滑塊,GATE改在此處改不到
) h, V7 P; n. a0 ?6 W& n8 g0 M4 D(The gate is not suitable in this area becuase there are two sliding blocks sealing off this area.)
! M# ?- c3 y' ?' A8 }68. 此處加做一個旋轉GATE,射出時方便調整成品的品質# b. |2 W/ |0 H: x: Z1 G
(We would suggest placing a runner shut-off insert to adjust the volume of part filling.), ?- ~9 Z7 @8 S/ W3 y, U: i2 p
69. 此倒勾在滑塊上強迫脫模,倒勾是否可以減小到0.6: U% ]; r3 L  W; ?
(This undercut will be force ejected out, Please confirm whether it can be reduced to 0.6 mm.)' r" p7 l& ?+ l' B' w: n5 N2 N1 x
70. 此柱子無法脫模,請確認是否是在轉圖時錯位,能否提供客戶的原始圖檔 data. )
3 F  [2 D( @; q, i& G(This boss is not releasable. Please check the file again and if possible, pleas re-send us the original draft
71. 此柱子是實心的,會縮水 (This boss will shrink because it is a solid boss.)
' Y% y! k1 m6 B3 m0 n* \72. 這個面是否要咬花,咬花番號是什麼,最小的拔模角要多大9 ^7 ~7 z, T/ r9 [/ p4 `
(Please confirm whether this surface needs to be textured or not. Please advise texture specs.
# p# s+ t1 l& A/ ~5 Y( sAlso,  what's the min. draft. )
$ B" w$ q0 A' t) G) y73. 這個面是否要打光,貼標簽
  y0 t" ~' i4 z$ v( c( B; q(Please confirm whether this surface needs to be polished and stuck on a sticker.)/ i# X3 a6 ]7 x, x1 b9 W+ H$ O
74. 紅色顯示的幾個面拔模角太小,出模時會拉傷,建議加大拔模角1 a6 ], ?: w# I
"(The red highlighted area has a problem of a small draft angle. We suggest enlarging the( @  p& E5 A$ q2 I% ~8 ~) A6 z" T
draft to avoid casuing drag marks on the part.)"
2 C! u9 E: j. |- @' L75. RIB太薄,會填充不足 (This rib can not be filled properly because it is too thin.)
0 R% z* [% B8 Q$ g76. RIB太厚,會縮水 (This rib will have a shrink problem because it is too thick.)" A0 w4 r4 k; D$ W
77. 此處倒勾出模困難,建議先不做倒勾,成型後再二次加工,但要做治具,費用要另外算
% k  L1 {) @* q(There are problems with this current design, we recommend doing this undercut as an alternative but there will be additional costs.)2 ~! L& q# {! l! c7 S* Z9 b8 C# i
78. 柱子底部都要做火山口1 w- F$ ?0 X9 {& Y% S
(The base of all bosses require a crater to avoid shrinkage.)/ w8 ^0 {) p) ]1 m# \
1.镶件,P.L.面有充足排气坑,P.L.面要开环形排气槽,并能将气体排到模外。
3 b5 `3 G4 ?, W* MInsert/PL should have adequate venting,PL should have around slot for venting.$ f- }  }1 v. _" |- g3 l
79.顶棍孔镶件端面距离底板面0,5mm,m20;
% d: t' R9 R; z/ x8 ~" jthe surface of KO insert shound below bottom plate 0.5mm,thread M20.0 `2 h* u) C9 \# t7 S
80.回针,中托司与模胚部份避空0.5mm$ T% m- Q2 [! m
RP,EGP should have 0.5mm gap with the moldbase.( c0 G' `$ r: I( Q/ G
81.排气槽距封胶位10-15mm9 o: L  X( z+ D4 Z! f3 `
Venting slot distance from the seal off position 10-15mm6 {& t5 \& A7 M3 K
82.运水进用 E  ,运水出用  S   % D1 n0 }  R. t5 D$ v+ v1 F( G* ]
Intake"E",Outtake"S"$ d6 b8 }) J  V( G
83.底面板均要有隔热板,DME规格1/4厚;
) E; I- `  n: X- q+ XTop/Bottom plate must have insulator plate,DME standard 1/4'H
- q- l3 ]* q2 p4 z84.吊环要在模具的重心(保证吊模时的平衡);
! M. E" g; t2 T+ @) u7 Q- m* d0 UEyebolt should on the center of the mold(for balance)
/ M8 E# i5 a0 s  K7 N# p85.吊模螺丝的位置要在前/后模部份的重心,保持平衡;. \6 b8 Y1 j7 g5 s
The eyebolt position  on the cavity/core side should on the center of gravity for balance
; O7 p  p' t3 U2 ?# w! V* m86.唧嘴分试模唧嘴/走模唧嘴;; F$ ?$ B: U; L. ?0 x+ q3 d; o# k
Sprue type:Trial/Delivery
9 o; n% g7 k! w! D- u; K' A5 K87.喉塞选用:NPT规格;
1 x* w2 f9 s' a1 yPlug use NPT spec.( U2 Y- s% `) H3 L2 l' @
88.中托司采用HASCO滚珠形式.
1 f7 ?" {2 T) \7 A8 r" YUse HASCO ball EGP8 {* T9 p7 c7 ]8 c& U; B9 R
89.水咀采用法国标准:1/4"的水咀写:RPL08-1151, i" Z/ y6 X2 J% E% S, r2 `. p+ A; B4 y
Jiffy Use French Standard: 1/4" mark:RPL08-1151
All in English& Imperial Unit全部使用英文和英制单位
& z, r3 h) D% J1 [8 ]( x/ y9 v( `' e5 yAre part dimensions to print plus shrink?请检查内模尺寸有否乘缩水?
" N  E+ ^2 X! r+ w/ y4 |All wires protected from sharp corners?凡有电线通过的角位要改为R角,是否完成?- |2 R1 O7 f9 s' K
All replaceable components must be standard components.所有替换的元件必须是标准件。- Z- |; j5 D+ M+ A* G( k, N+ h4 b
Add shot counter?是否加啤塑总计器?
4 r; l! O3 v* E3 Z/ tA complicated mould with thorough design consideration to overcome the numerous design contraints.
" `$ Y7 Z( [' a" ]0 `! ~- ?" X' @一个复杂的模具,设计经过周详考虑,成功地克服了各种设计上的限制。0 J) Y$ `" z! _# }  w' U) T
All moving components should use hardened steel : all slides should be installed with hardend or lubricated alloy wear plates and gibs, and with positive slide retainer.
! G2 g% \" f3 v" j8 U% m  r. v所有移动的零件应使用硬钢料,行位必须用硬垫板和硬线条,而且必须有限位及定位锁。
BOM including water fittings,ejectors&custom components.BOM的内容应包含运水接头,顶针和自制的零件.
- w# ]1 d6 X2 Q( [3 w) jBeCu for lifters if w/o water circuits。若没有运水回路,斜顶为铍铜。
4 e  F. U+ \! S* ~' w' j5 [
6 s9 H8 _' z$ GCorresponding components mirrored at core&cavity对应的部件在前、后模平面视图中镜像/ J3 T. R& Q' L7 p1 T
Check polish for line of draw finish?有否省光就出模?
! ^6 V: k. X! J# v0 }# jCore pull slot mechanism installed and O.K.4 H  Z$ O7 J4 {2 Z+ ~
Crane capacity and loading clearance.模具须用多大吊机才可搬动。
! t  b. N2 Y* u8 hConduct  moldflow &mold warp analysis.经流道及变形电脑模拟分析。3 a* f* V. M8 M1 l, ?' G
Component and/or 3D mould design drawing.散件图或3D模具图
- L7 R' s# C: \4 `Cooling less important when dimensions are not important.若尺寸不重要,适量冷却也可。
% l0 x6 v% U. ~! B0 T% pCombine a traditional 4 cavity edge gate and a 4 cavities reverse gate mould which help to double the moulding capacity and reduce production cost.
$ a/ {8 _- y5 ?# s3 O将一个标准四模腔大水口模具与一个四模腔倒转大水口模具结合成为一套可于同一大小的注塑机,生产量可增加一倍的层板模具,并且可降低成本。9 {2 N# ?( j& |$ E8 z7 ]! W$ O6 J
Can be seperated into two individual moulds for moulding in two different mould shops.
! h4 p4 ?0 q/ O此模具最大的特式是,可将模具分开变成两套,在不同地方生产,增加生产的灵活性。
. l+ }+ }- d+ L0 `Consists of all standard mould components which facilitates mould maintenance.
) Y  n# L; C6 i" |4 ^4 y/ F由于全套模具均利用模具标准零件制成,在维修及换零件上比较方便。
Die draw called out出模方向的标示/ `6 d3 ^& U; O' ~1 l7 h. G
Dimension all the opening , travel & clearance标出前、后模距离,滑动部件滑动距离和塑件脱离的位置( z1 ]& S- Z' A. k# G  N4 E% i
DME egr. Water fittings recessed and marked?是否使用DME运水接头及编号?
( `& u3 S; f, t: \4 y8 DDelivery right side up , or in two halves?开箱后是否容易吊出模具及是否分开前/后模运输?
/ V! {- T5 {- Q( J3 x' ~Eyebolt size and balance in 2 sides吊模孔尺寸,平衡,4边都要有  I# g) |5 E( M  V  `- E
Ejection stroke & slide, lifter travel dimensioned出行程、行位、斜顶行程的标注。6 V* o+ b2 p! t; `
Ejection study if  lifter adopted若有斜顶,做出分析。- w8 O( w5 ]! V+ N
Ejection extended at the most顶出到极限位置5 b3 e2 _9 u* P3 G7 Q: K. O3 |
Ejector guide pins installation .顶针导柱的安装。
7 j8 f, f" W/ `& G+ WEyebolts for inserts more than 50lbs.重量大于50lbs的镶件必须要有吊模孔。9 H( p* F, \! z$ ]4 v; O7 e! i$ z& E
Edge gate or sprue gate requiring secondary operation acceptable.边缘型或直入型水口都可以接受。
4 point in HRC different to lifters contacting or cavity steel。斜顶和与其接触的内模或镶件在硬度上有4度的差别(HRC)。
0 j: ?# x. k$ c* E8 O. X4X size section , dimensioned to reflect the actual size.水口及水口顶针的4倍放大视图,按实际尺寸标注。
- n8 ~" Y, W& e9 U; M( S# M& G; q3 x. a* b( e& a
General ,safety and handling 常规、安全和搬运要求
, M" V' ]) x3 O6 IGuided ejection recommended for mould above 100 tons clamp capacity, ejector pins of 1.5mm or smaller, or ejector stroke longer than 50mm.
$ N. a5 \4 Z8 O5 E# i建设模具用于锁模力超过100吨的注塑机,或有1.5mm以下的顶针或顶出行程超过50mm时,应装上顶针板导柱。! Y! N. R. W; o
Guide pin cleared and vented?边钉插入模板有否顶着及加疏气空?
Hot manifold wired to print and checked? 热咀电线接位有否编号?. m' Y  z; C* L9 v0 ~4 s1 Y& C
Horn pin clearance hole?斜边与行位有否空间?7 u. R) a0 `1 |; s- P+ V. o( D
Hydraulic actuated slide together with electrical  limit switch.行位采用油压推动,配合安全电制。+ ]; X" P3 }1 t( i
Heaters fitted+0.002/-.000, leads tagged and connected to terminal.热嘴装配,电线源头、尾有否安装稳固。(+0.002/.000
2 X- V; P- v# L) v
1 E; T9 Z, _# @% N& a  PInserts keyed and numbered to prevent incorrect assembly.镶件定位和编号以防止不正确的组装。
  ]0 y! c$ k5 J4 c* N
& E0 [1 t  ~  h5 r) [$ WJaw angle 3 deg.more than angle pins(<25 degree).斜面角度要比行位斜边角度大3(<25)
# P7 \5 X1 L( q  s4 D5 G2 B$ i9 `3 l1 _) c+ `0 I/ g
Keep enough space to run waterline at slide /lifter/major inserts.在行位、斜顶、主要镶件处保留足够位置(空间)布置水槽。
Lifter angle less than 15 degree.斜顶角度小于15度。2 W7 F- |) O" J+ [# v! [4 G
Lifter rods dia, less than 1".斜顶杆直径不能少于1"
) S' O. s0 {8 {: |  @Limit switch in tact and protected.是否已安装限位制?
Moldbase and steel dimensioned模坯和钢料号的标注
- h% ~7 \0 I# s9 T, D% xMinimum 5 deg.for shut-off.斜顶镶件最小5度插穿。( m0 h8 \  e0 q$ C
Mechanism for sequence动作机构是否正确?! Q; w3 B" \  D
Mold safety straps installed and painted red?是否已安装安全带及喷上正确颜色在模坯上?; Q6 F( u4 R: [/ Q
Mould flow and simulation should be carried out for the best gate location, filling analysis, / `! u9 E4 w" B: d# g. W& {
' \9 l7 Y7 N$ l! j* }pressure distribution and heat distribution.
+ Z$ X; w5 d+ b2 w: H* s' ^适宜应用模拟的模具注塑过程,注射分析、压力分布及温度分布以确定最佳入水位置、流道尺寸和疏气位置等。/ Q1 F3 {* M, L
Mould should be designed with maximum cooling and with appropriate amount of ejection points.
: ~: n2 {; P, d* z0 [7 t8 n) v' T模具在设计上要做到尽快冷却,上、下内模高温点应该有个别的冷却,应有适量顶针。. E0 i! H/ r, D3 _( }
Mould should be able to run fully automatic. Large part should be picked up by robot.) p6 J, }# H3 F  _% z9 Z0 I: F
模具能够全自动生产,大的零件应由机械手拿出。
  v: l9 Q7 j, }' [7 G8 sMould should be tested to meet a defined Cpk quality standard.模具经过测试,符合预定的Cpk质量标准。
0 M" d" q) o, PMould should have safety features to protect accidental damage, incorrect assembly and set up of mould.: B; G5 O6 c$ Y  ?) n% o# {
模具应具备可以预防意外损害及错误安装等安全特性。
0 }5 X; b' G2 c- i3 d& [7 mMould halves requiring accurate alignment of core and cavity, and shut off should have appropriate part line locks.5 o3 ]* w+ s+ d/ C
上、下模需要精确配合或有擦位的地方, 模具一定要有直身锁。, g- {  ^* B' K+ y, @
Mould requiring heating should have insulator plate.需要加热的模具,必须有隔热板。
1 ~3 G* v7 C% k8 h$ H: J  }Mould preferred to run automatic; self-degating whenever possible.模具最好能自动生产,模具尽可能自断水口。
No obstructions on buttom surface of mold? 模具必须稳定位置如有凸出物请加脚座,是否完成?+ Q! P$ w" A% Z7 ]- D* Z! D4 r
; X$ k# [* P: W
Overall mold size of the moldbase & shut height模坯长宽和模厚(模架的长宽)
1 v6 G* ]$ O6 R" T6 LOutlets accessible and marked " IN OUT and NUMBER"?出入水位有否打上IN OUT 字码?
Protruding items shown and protected。画出突出部件并做好保护。
# n0 i% k' D: W2 Y2 ?9 v; JParting line at the acceptable surface.合模分布在合理可接受的表面。* y  E( h4 L4 L9 _; Q" H
Put waterline as much as possible/wherever possible。尽可能布置多的运水。
0 [" l' @! k! z  |3 Q+ L* p# aPut waterline for slide /lifter/insert wherever possible.尽可能在行位、斜、镶件布置运水。- T9 ]+ i  k; D( k
Parting line cleared and released properly?分模线是否正确?) o! D2 u- Q0 [6 _: Y: N
Proper locating ring and diameter?定位圈尺寸及直径是否正确?; U( e+ X5 n7 ^  s" a, |: t3 w( G1 x
Proper radius and orifice on sprue bushing and keyed.唧嘴R及管钉是否正确?
8 f( w  ?  c5 k( mPart line lock recommended when there is shut off.当有擦位时,最好有直身锁保护。4 E, M" L. g& a
Protruding items shown and protected.如有零件凸出,模坯请加保护物。
; O8 V+ r6 I$ k6 E: VProper K.O. holes size and location.顶棍孔尺寸及位置是否正确?
Runners to be balanced. 流道必平衡。7 F' ~' |3 o! |! E6 X& `/ S
Runners cross section type and size as per standard.流道切面形状和尺寸符合标准。
# D; [" X& ?  R86.Runner and parts should be ejected automatically .Multiple ejection should be avoided.
! x0 _) F% b4 G顶出方法可使流道与产品自动掉下,避免运用多次顶出方法。
Sufficient view and section足够的视图和切面图
& m* |3 O6 S+ i# u, a! c/ g  O* fSafety Strap in red模块藏入模坯,要涂成红色。
7 U5 u7 |8 R) Y& |3 N: r6 bStanding steel supported to keep stable.加撑脚以保前、后模能平稳放置。
1 Q" @: E3 s; T3 e- W+ d5 `Support pillars>50% part projection area , steel :1040。撑头面积大于50%的产品投影面积,材料:1040.4 X# y$ x- j, S9 B1 I
Safety strap clear tie bar?锁模块与哥林柱冲突吗?. Y: C9 s9 }& O3 y+ J1 j3 P2 {7 j6 n* p
Sucker with reverse 10 deg. Undercut10度倒扣的流道拉料杆。. e. ^) M4 y$ w/ C. N3 A% K3 L: [
Steel type & hardness of slide &heel blocks行位和压条的料号和硬度。
* V9 S( ~6 p# ?/ n% N* LSufficient stroke of lifters(1/16"+ undercut size)?斜顶是否有足够的行程(1/16”+倒扣尺寸)?
5 G- @5 ^7 p0 F3 P" d, z# c. k# n; |Sufficient stroke for floating plate?浮动板是否有足够的行程?' N3 L. h8 S5 [6 K- D( f3 r1 O
Sufficient stroke as well as part and runner falls clear.是否有足够的行程使品和流道脱落?
. ]1 [: ~. u+ t: n- Y7 {Spring around return pins and press ratio<33?是否有回针的弹簧及其压缩比(<33%)?
  c3 E! U# ~) O" M# ?; K- [0 s" ]Special instruction stamped on top and operator side?客户如有特别指示请打在模坯顶及操作面上,有否完成?
$ ^' Q' n! o0 y! F. Y8 kScrews tight and all installed?螺丝是否全部收紧?- f* L. X4 @  y( v
Support posts ground and screwed to clamp plate and pre-loaded.撑头是否高出方铁?% f. [' o5 r0 j; B& l
Spring pockets correct depth , spring deflection max.40%?全部弹弓压缩比是否为1/3 S- S  H4 ^4 U2 Y% {* ~7 Y% [8 ]
Standing steel well supported?成品与内模之间的钢材是否足够?& g* H% x( U* P0 g
Single drop of cold sprue gating is designed after moldflow analysis, which ensures a balance flow , I8 o4 W" p4 `5 Y
# \: u. K5 s( ^6 V0 zof plastic and easy for moulding.
% v& k: e& h1 ]9 S7 z  P1 _1 J/ w6 n2 ~moldflow分析决定产品的入水位置,使胶料分流平均,易于注塑。  C* S* R, c! V: C! V* N8 a/ `
Self-degating whenever possible .Hot runner system should be considered.
+ C. X# l7 d7 x$ M6 G, j4 jStandard components should be used.尽量使用标准件。
9 l+ R& C/ @$ G1 p8 M3 uSemi-automatic and use of mould release acceptable.半自动工手放镶件也可
Update title block/revision.更新标题栏/版本. r0 p+ @  U0 i* c. Z$ A
Use standard components when appropriate.适当的时候使用标准件。% g! Y) [' a2 f& m: o* c! ^. d0 z) J
2 c+ L8 d$ `# r1 O6 X/ y* N, v
View of deepest point最深点(位置)的剖切视图
Water circuits should run out form the ejection box.运水应从出水槽中流出。
0 W5 P: Y" ?6 S0 q) t) YWaterlines clear tie bar and clamp slot?运水是否同哥林柱和模槽有冲突?
- T" l% v* Y/ f& R& uWill mould fit in quoted press?可否配合客户啤机?
2 k5 V) v, c6 oWaterlines clear tie bars.运水喉咀接驳位要离开啤机呵林柱咀接驳。0 W, G9 D+ ]8 ^6 e
Waterline clear clamp slot.运水喉咀接驳位要离开啤机码模坑。
发表于 2014-6-5 18:30 | 显示全部楼层
很需要,谢谢
发表于 2014-6-5 18:59 | 显示全部楼层
楼主好人 啊
发表于 2014-6-5 19:00 | 显示全部楼层
发表于 2014-6-5 19:05 | 显示全部楼层
发表于 2014-6-5 19:34 | 显示全部楼层
这个不错哈   好东东,谢谢了
发表于 2014-7-10 22:56 | 显示全部楼层
嗯,跟老外打交道的用得着
发表于 2014-12-6 12:57 | 显示全部楼层
感谢楼主的无私分享
发表于 2014-12-10 15:46 | 显示全部楼层
ksdajf;qwer[ikj[fewofsadkf[oqe
GMT+8, 2025-10-15 05:48 , Processed in 0.076878 second(s), 27 queries .
