查看: 1519|回复: 0
[教程] 今天把之前说的“干涉的例子”放出来
发表于 2014-2-28 09:47 | 显示全部楼层 |阅读模式
今天把之前说的“干涉的例子”放出来
. R  K5 x0 s2 [" [5 Z2 Y0 B" D8 s
6 E, e. G" w. C文章原地址:http://www.ugufun.com/?p=69' I  D4 U5 t" U% f+ I+ u+ j" ~$ T/ A
% w- k- X4 U: V# x! Z0 E: x& @- ]; o* R' Q4 P/ T$ F
/ D% a2 J1 X9 Y. G1 n
#include <stdio.h>
#include <string.h>
#include <uf.h>
#include <uf_ui.h>
#include <uf_modl.h>
#include <uf_assem.h>
#include <uf_obj.h>
#include <uf_wave.h>
#include <uf_so.h>
* a7 v$ F  \& b$ J/ `( Q0 X8 i, F
8 @7 ]3 ~! v9 h9 H) [- @9 ^" a, H5 L0 i
#define UF_CALL(X) (report_error(     FILE    ,     LINE    , #X, (X)))
) W# i* i+ {: G) x! o
' _7 Q7 W7 {: b8 y- b; V+ H1 ^
static int report_error( char *file, int line, char *call, int irc)
if (irc)
char err[133], msg[133];
- L* g3 H% e$ D7 h4 ?
! f8 p' i- y; E+ q7 z
sprintf(msg, "*** ERROR code %d at line %d in %s:\n+++ ", irc, line, file);
UF_get_fail_message(irc, err);
/*   NOTE:    UF_print_syslog is new in V18 */ UF_print_syslog(msg, FALSE);
UF_print_syslog(err, FALSE); UF_print_syslog("\n", FALSE); UF_print_syslog(call, FALSE); UF_print_syslog(";\n", FALSE);
- U6 l7 \+ a# ~8 g" [2 C; J
3 B6 A3 N1 x+ U! V, t5 }  E
if (!UF_UI_open_listing_window())
UF_UI_write_listing_window(msg); UF_UI_write_listing_window(err); UF_UI_write_listing_window("\n"); UF_UI_write_listing_window(call); UF_UI_write_listing_window(";\n");
  t9 H- r5 b. E2 m! d4 ^9 l& D& O5 h% i9 ]) c
return(irc);
' q+ m" e* ~, d) l/ c
8 Q, G* p' z( c0 H( a+ }) x
/*ARGSUSED*/
static int mask_for_solid_bodies( UF_UI_selection_p_t select, void *type)
UF_UI_mask_t
mask = { UF_solid_type, 0, UF_UI_SEL_FEATURE_SOLID_BODY };
2 m. _* U+ b- K$ q: [; r* R& s% S9 i7 z
if (!UF_CALL(UF_UI_set_sel_mask(select, UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC, 1, &mask)))
return (UF_UI_SEL_SUCCESS);
* y( K! s) B5 Z4 P; K2 y
! X- q  s& n  b6 G" ^. k; K4 r! |
else
( B# S- U9 {8 b4 V
+ l# s- J6 d% {) Q4 }( \/ a( f
$ r; a4 n( e6 f& h9 P8 {6 x% c
" K5 ]1 Y0 J' o2 `# q/ R# ]0 ]% t6 [* H# @. q
return (UF_UI_SEL_FAILURE);
& T; K, b% @% u' C# i
. ~' U% F- {7 [7 M+ K
7 c7 O2 C9 v  I% }- j$ q
1 a" r# ~0 M- e5 e
static tag_t select_a_solid(char *prompt)
double cp[3];
% C& E2 _7 b4 n) `* B. N4 \+ K2 w: U
int
1 }0 o8 l2 |3 b& |! ]$ ?: ~$ n- p9 D$ z: j/ @
tag_t
& B) R) E4 r" C
5 {2 V( j1 d3 p2 q6 a! b
/ y" h+ f& ~' Q8 c7 @4 [; l
resp;
2 C  g5 ^6 D7 L
2 X, ~2 j7 o7 n- s+ L3 J% ]
object, view;
( W9 D1 j- N! \
3 S" x; k6 J6 b# A1 o/ F4 C
UF_CALL(UF_UI_select_with_single_dialog( "Select a solid", prompt, UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY, mask_for_solid_bodies, NULL, &resp,
&object, cp, &view));
5 R, Y) A: G# O8 D) F
! L, Z7 P: a9 p! S3 R7 R- J
if           (resp          ==           UF_UI_OBJECT_SELECTED           ||           resp           == UF_UI_OBJECT_SELECTED_BY_NAME)
UF_CALL(UF_DISP_set_highlight(object, 0));
return object;
else return NULL_TAG;
- w$ j' W/ U" L, D+ s
& u% w3 B& d' ~4 d
- z/ ?! e' I3 ~6 M8 U2 j; c* r, A+ h- ]7 Y
static uf_list_p_t make_a_list(int count, tag_t *item_array)
2 J- T" ]% b/ R5 z' [& {
5 V' P3 V9 ~5 i' F' W, y) q+ O
int
( G. O+ y& S% N( z
) v, h1 D+ K  v6 ^
/ U$ b7 v: ?; W3 R0 ^
ii;
2 ]9 S! B' n3 T3 |- N+ S4 @4 W
+ O7 ?5 s! ^) j) s3 \: T) x
uf_list_p_t list;
; ]5 s0 ~3 f" E7 V$ L) z4 p" I
3 I& o% d9 @% d( H
UF_CALL(UF_MODL_create_list(&list));
# V6 A! ~- @' W* L% W6 y' V8 j" t
for (ii = 0; ii < count; ii++) UF_CALL(UF_MODL_put_list_item(list, item_array[ii]));
+ N' U9 c( O: o* |) ]2 ]7 ~5 W% ?# B6 {/ a8 d
return (list);
3 t% I& X' ^& T- U( k
+ n3 r1 m" O; |* m# P9 H9 x( K
static tag_t ask_part_occ_of_prom_occ(tag_t prom_object)
tag_t
owning_part,
part_occ = prom_object, proto;
) B/ `' {$ }/ E
2 U% s" s8 l2 M7 e0 F
proto = UF_ASSEM_ask_prototype_of_occ(prom_object); UF_CALL(UF_OBJ_ask_owning_part(proto, &owning_part));
while (!UF_CALL(UF_ASSEM_ask_parent_component(part_occ, &part_occ))
&& (UF_ASSEM_ask_prototype_of_occ(part_occ) != owning_part));
# H! L  ]2 o8 L! j( `+ r" r; k
7 T- w6 U% s8 ]: l( I0 g4 _  [! S5 m
return part_occ;
/ b" v0 t) W, l3 H6 l5 l
5 a5 n" Q) a( x1 J! C. q
static tag_t create_dumb_body_copy(tag_t body)
2 u: J. Q+ X6 E8 J. J# n
: |# }; s1 }  L) V8 [% d
tag_t
, C; y5 r! k( ^+ W3 k7 W: T! F) m7 d/ A; C
" a' d; Y; s* \2 h9 V& n, ?8 m
feat,
; e+ ?; n4 o, |/ Q/ N2 {' x
' e, X8 J: _% e( [! i3 w8 k
part_occ, proto, xform,
dumb_body;
uf_list_p_t list;
7 {' C  N, _' g* T6 l: s2 x
1 d+ j( I8 F9 M! g
if (UF_ASSEM_is_occurrence(body))
proto = UF_ASSEM_ask_prototype_of_occ(body);
( m0 T; ~" l* ]$ p7 _
) L4 k6 t2 P. A& J
else
2 F# t5 D! A/ b
- M. J9 c0 R; u/ V6 C% E9 Q. T
9 K; \8 c6 A8 f) u- t
proto = body;
$ g& T7 o5 d$ v
1 K7 @. b& g  T+ E6 u+ W( e# @
if (UF_OBJ_is_object_a_promotion(proto))
part_occ = ask_part_occ_of_prom_occ(body);
9 S: s$ @& q: b$ r
- V9 G  k0 v1 x  s5 a% e- N
else
; K" J7 t  K+ O1 b4 b/ d  x' m' c1 F7 d! b+ ?# \5 P
* u3 B7 @. {' v* B5 V4 A+ l
part_occ = UF_ASSEM_ask_part_occurrence(body);
: @% k  b$ r- h  C: P) _' X: I, Q" L/ K8 ~! ~5 o* ^
0 |  p* b$ g) R( A- Y
& q1 W; _- r( }. j/ s
if (part_occ == NULL_TAG)
UF_CALL(UF_WAVE_create_linked_body(proto,NULL_TAG,body,FALSE,&feat));
" C. W( O" K8 ?
4 B  z9 O* f# b( o; h
else
+ r5 G: b0 U8 s9 Z" I8 z- ^
0 f/ Q$ L3 f% F  }3 O, \
- _% x6 r% ^9 |- N5 ]
2 l& T4 y% ?9 u; s2 o0 }
3 c$ k( V+ L+ U  Z% Y& H! b8 n+ `6 x, Z8 n& D' q9 k! C9 `6 Q
- Y* P" Q' m7 A- e# Q" e
UF_CALL(UF_SO_create_xform_assy_ctxt(body, part_occ, NULL_TAG, &xform)); UF_CALL(UF_WAVE_create_linked_body(proto, xform, body, FALSE, &feat));
* O9 q, x8 Y  f$ q4 c/ j' k6 ^0 [- M5 Z7 t- A
' F1 B0 G, {5 R7 S' n" \
/ g0 g6 f% r$ t, V. s5 m( B
UF_CALL(UF_MODL_ask_feat_body(feat, &dumb_body));
  _* ~4 E1 M, K) g5 h: _
! H+ \$ \" @0 x, V" H6 z! m8 E& g. L
if (dumb_body != NULL_TAG)
list = make_a_list(1, &dumb_body); UF_CALL(UF_MODL_delete_object_parms(list)); UF_CALL(UF_MODL_delete_list(&list));
+ c6 _4 h0 ^' E$ y
+ O6 |& g* b/ g. X) f: F
return dumb_body;
& w) Q* x6 @+ e: g8 q% v3 c" Q7 [( g( K4 U
static void do_it(void)
) T/ I9 ~7 G' z( _6 v( f6 J
" U( M6 v9 z* a# x
int
, _) H# I/ E5 H+ t
9 |( B* h% R0 ]1 A# z
3 F$ o1 ^) S( U, Z  H7 C
flag, n_results;
% c0 p" n( R* J# _) ]
; g5 n# ^! p' L% H) p
tag_t
body1, body2,
*results;
uf_list_p_t list;
! r4 \  z0 ^$ x4 E; h
while (((body1 = select_a_solid("Select Body 1")) != NULL_TAG) && ((body2 = select_a_solid("Select Body 2")) != NULL_TAG))
UF_CALL(UF_MODL_check_interference(body1, 1, &body2, &flag));
if (flag == 1)
body1 = create_dumb_body_copy(body1);
5 h. n7 T9 X; a& m4 n
( U9 q3 }' k: I8 e8 x
body2 = create_dumb_body_copy(body2); UF_CALL(UF_MODL_intersect_bodies(body1, body2, &n_results,
&results));
if (n_results > 0)
list = make_a_list(n_results, results); UF_CALL(UF_MODL_delete_object_parms(list)); UF_CALL(UF_MODL_delete_list(&list)); UF_free(results);
6 H, O4 N* |" g( f! S- v
5 \  O  O8 v" E9 c3 X
/*ARGSUSED*/
void ufusr(char *param, int *retcode, int paramLen)
if (UF_CALL(UF_initialize())) return;
do_it(); UF_terminate();
) V7 j4 L) |2 B) I& h) x5 k
8 o$ v. y5 m5 Z& [3 \
int ufusr_ask_unload(void)
return (UF_UNLOAD_IMMEDIATELY);
1 Z  e  M6 f* `
7 a0 x/ B; T) j( N" S7 {& U) s
GMT+8, 2025-3-10 10:55 , Processed in 0.110416 second(s), 20 queries .
