原帖地址:http://www.ugufun.com/?p=111 ug NXapi二次开发教程源代码_创建一个圆柱,并打孔倒角 以下为代码部分: #include <stdio.h> #include <uf.h> #include <uf_ui.h> #include <uf_disp.h> #include<uf_modl.h> #include<uf_layer.h> #include<uf_assem.h> #include<uf_obj.h> #include<uf_part.h> #include<iostream> #define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X))) static int report( char *file, int line, char *call, int irc) { if (irc) { char messg[133]; printf("%s, line %d: %s\n", file, line, call); (UF_get_fail_message(irc, messg)) ? printf(" returned a %d\n", irc) : printf(" returned error %d: %s\n", irc, messg); } return(irc); } static void do_UGopen_api(void) { UF_FEATURE_SIGN sign = UF_NULLSIGN; tag_t target = NULL_TAG; double origin [] = {0.0,0.0,0.0}; char* height = "100"; char* cyl_diam = "80"; double cyl_direction [] = {0.0,0.0,1.0}; tag_t cyl_feat_tag = NULL_TAG; UF_MODL_create_cylinder(sign,target,origin,height,cyl_diam,cyl_direction,&cyl_feat_tag); double value; tag_t target1; UF_MODL_create_exp_tag(height,&target1);//Creates a parameter expression, based upon the input string. UF_MODL_ask_exp_tag_value(target1,&value);//Asks the value of an expression tag. double location[3]={0.0,0.0,0.0} ; double direction [] = {0.0,0.0,1.0}; tag_t obj=null_tag; char *diam="30"; char *angle="0"; tag_t bottom,top; tag_t feature_obj_id ; uf_list_p_t face_list; UF_MODL_create_list(&face_list);//Retrieves an object from a linked list of objects UF_MODL_ask_feat_faces(cyl_feat_tag,&face_list); int count=0; UF_MODL_ask_list_count(face_list,&count);//Retrieves the count from a linked list of objects for(int i=0;i<count;i++) { UF_MODL_ask_list_item(face_list,i,&obj); int type; double point [3] ; double dir [3] ; double box [6] ; double radius; double rad_data; int norm_dir ; UF_MODL_ask_face_data(obj,&type,point,dir,box,&radius,&rad_data,&norm_dir);//Queries the data associated with a face if(type==22)//“22”代表有界平面 { if(fabs(point[2]-origin[2])<0.0005) { bottom=obj; } if(fabs(point[2]-value)<0.0001) { UF_MODL_ask_feat_location(obj,location); top=obj; } } } UF_MODL_create_simple_hole(location,direction,diam,height,angle,top,bottom,&feature_obj_id); UF_MODL_ask_feat_faces(feature_obj_id,&face_list); UF_MODL_ask_list_count(face_list,&count); for(int i=0;i<count;i++) { UF_MODL_ask_list_item(face_list,i,&obj);//Retrieves an object from a linked list of objects int typel; UF_MODL_ask_face_type(obj,&typel); //倒圆角 if(typel== UF_MODL_CYLINDRICAL_FACE ) { uf_list_p_t facesl; UF_MODL_create_list(&facesl); UF_MODL_ask_shared_edges(top,obj,&facesl); const char * radius="3"; int smooth_overflow=0; int cliff_overflow=0; int notch_overflow=0; double vrb_tool=3; tag_t feature_obj_idl; UF_MODL_create_blend(radius, facesl, smooth_overflow, cliff_overflow, notch_overflow, vrb_tool, &feature_obj_id ); } } } void ufusr(char *param, int *retcode, int param_len) { if (!UF_CALL(UF_initialize())) { do_ugopen_api(); UF_CALL(UF_terminate()); } } int ufusr_ask_unload(void) { return (UF_UNLOAD_IMMEDIATELY); }
- B) M4 M: y+ ^% _- X. B |
