查看: 1067|回复: 3
有高手帮忙改下后处理文件
发表于 2014-3-31 12:49 | 显示全部楼层 |阅读模式
PowerMill的后处理文件修改后让刀具在NC中的描述为  例如CUTTER:T0D6.35R3.175S0.H127.)这样的格式.哪位高手能帮下忙啊.非常感谢  D: K6 G$ ?9 ]8 ^- H& U8 b) \
后处理文件如下/ w7 T, |% @% Q
machine fanuc
( G" f) T3 ]8 D; {- w6 U7 X; F& p) l1 E#  Option for with Fanuc18t control.5 h; H* `! ~$ S, z* K, I7 V  S
#  Modified by Delcam HK on 14 May 2002.
. @$ m: y% t$ z5 D4 `3 V8 _
: }+ y& E/ y: e   define word TN7 y) M& Q2 W1 C& x( }4 W
    address letter = "( T - ") g+ x5 t. |: `$ t7 l
    address width  = 6
! |; l! V1 I6 H* K: a$ `" @    field width    = 2
( B5 }9 I! ?4 u: i# e   end define, g  @2 j+ f& x: n$ k' ]( N
   define word TL" e. o4 _9 q" R, L7 o7 W
    address letter = "   L - "
) Q/ @7 q0 _' z, u5 [7 Z    address width  = 7
! M; z( l# o7 Q& _; V    field width    = 2% Y+ `8 B/ e% s: t" g8 ]8 d
   end define1 O2 q8 g& J; E$ P
   define word TD) d4 u4 m: N: q8 S7 X% ^
    address letter = "   DIA. = "& @2 z) n1 H1 B( T0 U
    address width  = 10
8 ?# x# t0 g: [) d5 w) y5 }; R' ~" H* X    field width    = 6
2 X; _  {* H5 I3 d    scale factor   = 2. W2 [0 |' N0 C! O8 R2 H- C
   end define+ E; w: ?9 Z6 B1 v: {2 X8 F1 V0 H. I
   define format (TD)
# m: C( _2 j$ Y' ~9 p    metric formats' g: i+ p/ g) |& D
    decimal point = true4 U9 K  R1 j$ }; M
    decimal places = 2
# w" O1 W' _: q8 Q5 G    leading zeros  = false
8 f# c# F7 G& ?/ h/ T: @8 c9 Q    trailing zeros = true0 V. I8 Y% s( j! Y6 j* L( a
    imperial formats = metric formats
' e/ t. Y6 x) T2 }& c   end define
$ C; z: v+ L1 O3 j& {! e   define word TD2  O1 D, ?9 T  X
    address letter = "( DIA. = "
7 ?, ?+ Q; D5 ~; L9 K    address width  = 9
% L/ R. J% `; v    field width    = 6
+ ]1 d5 m) {7 {( S# V. z2 a    scale factor   = 2
, e% ?5 K; y1 ~8 [9 M1 D# W   end define
9 c# w2 y8 Z3 A  v   define format (TD2)# [1 a+ [$ n: p4 E" d. z4 J; N/ I. o4 o
    metric formats
+ p; u: m8 R. t2 ]    decimal point = true
: J9 K3 i; V* p1 y& z, N; z    decimal places = 2
+ v$ Y3 ]% }3 i; X    leading zeros  = false' `. P6 S! _! D& V% _) \7 N5 M
    trailing zeros = true! `( W/ N4 |; R/ C2 e6 [/ E7 S
. y1 w7 T* j2 g   end define# s' U+ o8 w7 {- ?6 i, N7 ~8 s
   define word TipR" M' t+ U* P% q/ Q3 j
    address letter = "   R = "
* u  {5 r8 O1 d8 n    address width  = 7: D, ?8 b1 g; U2 t. K
    field width    = 6
' N  P2 \8 h+ t) x& a# p( d    scale factor   = 1: g+ U: o' u1 v7 ^! ^9 A5 V4 i' r
   end define
. ~  y' p9 f& \- t1 B7 P7 F6 n1 A   define format (TipR)
2 j) r! u7 l; D+ X$ Y    metric formats2 E+ a4 k$ B$ \0 j7 y! ]
  x7 ~$ U; `2 g" v- V3 X- Q' D    decimal places = 2
6 |" P/ u! Q% k' ^3 k+ C5 y    leading zeros  = false* Y2 j- x$ Y; p4 ?- T
    trailing zeros = true2 h1 i' h  x, W: E- I* p2 e
5 k* o6 H1 X( Y3 {, i   end define- S7 u* q! {  H8 x6 ?7 }4 ]
   define word TPN
! S3 e+ B: @0 x5 U2 s( E- @    address letter = "   "3 l2 _; q2 S$ K2 ~2 S7 v1 G$ W" |8 }
    address width  = 3+ F0 R# D. F0 W4 b; `+ u# ^: e# s+ r
    field width    = 15; @6 |3 ^, i  _7 e% M, z
   end define
6 a+ e! R9 c& b* Z7 _) S- b. I#$ I+ o2 q$ r( v' ?
   define format ( / G6 S T L P D E H O )( Q6 D" ?# j$ y) U( n
    address width              =   1
* G0 Z( X6 ?8 j  B* ]) k& P    field width                =   27 I5 x6 C3 J$ `% b
    exponent width             =   0
6 O0 m" e% |  O# s& S    scale factor               =   1" Z6 T+ Q+ o% ]9 K# ~) z5 I& I
    scale divisor              =   1) T3 D- M. R& H) q/ C: M  C" m
    tape position              =   0
; ^/ D8 G* u" p5 g3 y9 c    print position             =   1
7 }$ X' u4 v# M9 K- d8 z    sign                       = none
' {' \3 [3 N3 A, b    not permanent! o" o) n2 L! {8 k0 m- x! N6 k
    not modal
5 B3 B6 p1 R* |5 E' y* W2 Z   metric formats; `3 v7 ?7 y. |7 p6 j) F
    leading zeros              = false+ P- f0 i% ^7 t6 e
    trailing zeros             = true+ T$ Q" v1 G5 d4 @
    decimal point              = false
) e6 ?+ M6 Q! j) g$ M, l    decimal places             =   0- k( Y& U  U' E0 ^
   imperial formats7 _5 g$ Y$ \) i% A: `
2 Y8 M- E- x3 b# x9 ~& ?    trailing zeros             = true
0 o; ~2 l$ s) E0 Q' ?    decimal point              = false
- C  v9 P8 F& D' c( |3 r8 o* j5 C7 q    decimal places             =   0
" k+ Z6 E+ Y; s   end define
( A' a0 v9 W0 |' c0 C6 k" j4 k
, x. E& v0 @" K2 o   define format ( M1 M2 )- Z* W7 Z4 @# S, v; Q2 t
    address width              =   1
3 e! \7 }: d& z    field width                =   2
8 c; _5 X2 s0 ~; M/ }    exponent width             =   06 F3 @! G6 L- @9 G7 @6 ~  k
    scale factor               =   1+ R# t) h$ ^& X- E2 a/ q8 u
    scale divisor              =   1
  \/ x2 r" n! C2 T1 T0 e    tape position              =   0
' {1 L' U- ?2 d1 X; D6 O    print position             =   1
+ ~' |+ {. G, U0 Z" D    sign                       = none
4 [" h$ g! U+ V& @0 F    not permanent
5 R' n" P$ b2 F5 g& y" E& N    not modal  J  K5 x- D) }
   metric formats7 i% `' f# v# A) i8 s
    leading zeros              = true3 j3 A9 M) T' \/ C. F- t9 m
    trailing zeros             = true0 j, W8 U5 C, A- K  i
- P( i! d% m7 x! o# N! N    decimal places             =   06 {0 R" t3 k- k! X* \2 y
   imperial formats) J2 U' V/ R* `- ^$ S
    leading zeros              = true3 f+ o% d" \" f- F
    trailing zeros             = true- X: m0 u; ]2 e* k
    decimal point              = false4 t0 D/ t( I0 w+ A; g
    decimal places             =   0
% w) n6 P- z/ o1 ~7 n. g. [1 g' \   end define
6 g! R' j3 V. Z! i+ F   define format ( N )
1 c8 c0 T* J4 M7 c$ i* S    address width              =   1- I0 U% l/ v6 T# v* |8 W
    field width                =   4  M& T& @+ u1 T
    exponent width             =   0! C4 a0 w. u5 L1 d2 p9 o$ [* N
    scale factor               =   1& r6 H6 j# f$ `! x
    scale divisor              =   1
' f" M; K! L& |- `9 Q7 ^) j1 m    tape position              =   0  w! g) H7 t; R: d% K% X
    print position             =   1/ i; X+ L6 @9 u& K
    sign                       = none
4 ]! e7 l! G: _/ G: I+ b    not permanent# N% Y: t4 z7 T7 E. Q% }  y, T
    not modal! W. P4 k) ?% L
   metric formats, l% i$ N5 _6 c% a3 [
    leading zeros              = false1 [  d, e& t( W3 i7 r" J' q) a3 r
' y  A( p9 M* R, ?( P' b    decimal point              = false) Y- a2 Y4 s+ B& q! B
    decimal places             =   0
3 q; r7 P7 \( ], \  z$ F' s7 N   imperial formats& v+ Z* |3 n% A- [5 D8 h. W
( M' w2 Z% [: i1 R    trailing zeros             = true
+ |6 v% f' b2 a$ `( U- A1 m4 D# K) Y# `    decimal point              = false
) r, v  R5 D4 N  p/ {    decimal places             =   0
1 C: z% ^7 h* S; L/ f: b   end define
& H1 B- ]: z4 B5 n5 R
+ m7 Z+ S: j, P( J5 S   define format ( G1 G2 G3 G4 G5 G7 )
) [- ]6 D  I. P) Y5 A1 q    address width              =   14 j7 R' q, P' Q8 J# Z( W
    field width                =   28 L; E- r+ q4 _9 U, Y: X
    exponent width             =   0& e' h$ ]$ V4 z+ i2 w( }" v/ x7 j
    scale factor               =   1
$ b+ V, V. L( h/ ^    scale divisor              =   1
* }0 N5 Y! k9 U( W3 W    tape position              =   0
. \! S' h, t( G8 N/ }    print position             =   1% y: X8 ~+ |7 r! I* B2 l* K. C/ y
    sign                       = none0 l  G2 B- {  b. U4 y4 u+ Y
    not permanent
& r. W0 o  e. B; j% |    modal
. p+ O$ Y5 F# `: M* _   metric formats
& y/ q& [/ H% f$ ~4 Q#    leading zeros              = false  V( Z, i0 w& d% F
; a; H# ^; B! n7 M    trailing zeros             = true& ?- t3 [: x% ]' i" m( i: q
    decimal point              = false6 M9 E% ]8 M) o
    decimal places             =   0
5 h' F) Q; w0 t1 H" l6 B' l   imperial formats4 a, _+ R5 e' d8 _3 w$ r. j7 q
    leading zeros              = false5 n# G! h1 Q) r: r6 p
    trailing zeros             = true9 w, D# Q1 t# }$ ]$ t0 h
    decimal point              = false  j2 M4 W6 P2 S+ e+ }, p
    decimal places             =   0' p* s9 Z" F- ^' W) ]) O, ~
   end define5 t/ G* ]( F" |' I; T0 U
4 i+ i) U- Q: m/ r% c
   define format ( X Y Z R B C )
/ @# y" c( r# `: G) Q3 p; P% q    address width              =   1
/ x9 n. z7 @/ c2 S5 Z; c& N. I- m    field width                =   8
3 A) ~4 Q" g, q6 h    exponent width             =   0
6 C; n( W/ y8 M: V    scale factor               =   1; U5 Z7 @, J$ R; }5 Q( [0 T
    scale divisor              =   1
  |7 v, L+ G$ I' ]+ N    tape position              =   0
, Q( c6 j% {/ p. c2 q    print position             =   11 Q' b  [4 f+ F# e1 q: H. v6 a
    sign                       = if negative
( V- L* p0 |! ^- x    not permanent
) y9 V* i; }+ U" B+ w7 k5 G9 i' t    modal
4 S8 z5 ^  f- p) |* ^3 y   metric formats
% J% ^  i) \. G; g    leading zeros              = false
, w4 L) W" F2 p! ]2 Z4 g* X    trailing zeros             = false
& P" C: S. {- b5 f, R4 P# O* k    decimal point              = true
. K+ L( c! W8 X6 I) Q6 f    decimal places             =   3, N; W6 }! \! T1 F" w% c
   imperial formats# Q; @' e( w; F$ i) o" m; m" A
" {& i" C+ r  c2 l0 Q0 _    trailing zeros             = false* \& ~+ v  m+ j- l9 h9 ~* n) j6 u
    decimal point              = true+ f& y7 }6 h7 M! e% X9 [/ _
    decimal places             =   4
5 z$ d# ?- O' M6 q, V% |& f   end define
. y4 `! X1 a4 \8 ^" @7 p4 E! b8 d ) l6 J4 e1 r8 i& j* O6 R! M
   define format ( I J K )  X1 {* J  E6 H: l
    address width              =   1
5 M( n9 [, ?! x# T1 e' D3 k    field width                =   8
/ Q  S% P1 }$ N& k    exponent width             =   0
& T3 B7 M6 y; w; I" v    scale factor               =  -1  N1 d( ]! o0 ?, H% {, I) K
    scale divisor              =   10 Q1 m; @2 }+ p, g( x+ J" P, [$ z
    tape position              =   0
& _% f6 ]6 z- b, |5 Q2 q4 _) Z6 u    print position             =   1, m* V& g- ~* p$ E& ~0 M
    sign                       = if negative. }5 c( m/ ~! U$ o' s
    not permanent: W( I: e% O2 l$ @- P6 ?
    not modal4 F4 u( W- H6 s7 u8 n# y, X
   metric formats3 G/ s" S' H* n8 `' ?
    leading zeros              = false$ |& g- N3 I  A$ D* k
    trailing zeros             = false% y9 R' W; O  |8 J3 s1 K# n% h7 ^
% |# c+ s, g& A9 a! w; M    decimal places             =   3
, H% b0 W' s# I6 L" R& O   imperial formats% T: q8 C! n7 j
/ k8 ]8 }+ `4 J. v6 ]4 v- j0 r    trailing zeros             = false
1 L& f, R, x/ @2 |  J2 p    decimal point              = true
. v& n8 k! T6 K* B, y& H3 _    decimal places             =   4
+ \( R. E% ~( F' l$ b! w   end define7 X; U3 X1 M0 l, M
0 r4 _/ {' ~1 F( P4 ~
   define format ( R2 Z2 Q1 )" {- e( s) S( E
    address width              =   14 {4 t* w  T+ V7 x' K3 j$ h
    field width                =   8
/ L: M5 x, r  u* U    exponent width             =   0
/ F& ?6 F- U3 {% T8 x0 B    scale factor               =   11 s5 s; c6 F. G9 y
    scale divisor              =   1
: l5 M. r1 c% Z6 I$ l! R# s    tape position              =   0' f4 y- n, J! ^# }
    print position             =   1
9 U* @' v$ `- A3 G) W  d' F* r    sign                       = if negative, _6 R1 Y1 I9 x, p  o, K( N4 d0 |
    not permanent
, [  N3 m6 o; P" g6 A  x    not modal+ `( f, Y8 l& z; C. y8 g3 Y
   metric formats3 p. e( V3 h# M9 w6 B  f
# G! Y) a5 f; U! I    trailing zeros             = false& T6 W* K4 \! U% ?4 S
* [+ y# A6 {' @1 @3 W6 v    decimal places             =   3# M7 j2 f- D+ @
   imperial formats
, }6 d8 s* y8 \7 h    leading zeros              = false: F: e. @2 `. H4 p: V
; L" g; B. c7 P. Y1 C$ o5 {    decimal point              = true
' Y) D- O. Y: g) [' t8 t, m    decimal places             =   4
1 D  g5 i& T! e# c- P; j' E* u   end define
8 {- u# }' M0 h% i( P  l4 L
: A9 Y" h2 u- p$ m   define format ( Q A U V W )
3 {' }7 g  N2 y5 [4 z# q    address width              =   1% B& V- \2 }: \
    field width                =   20 k' q" `4 s8 c/ Y
    exponent width             =   00 E* d; ?; a8 C& {5 M
    scale factor               =   1
% a3 E: U: g  U2 ^3 l, C    scale divisor              =   1
  K  i& t( z: [4 o    tape position              =   0
5 M* p9 A1 P) E9 X! S% G    print position             =   11 s0 G9 X  ]: Q3 u7 R4 J
    sign                       = if negative
& W! p0 U+ p6 q2 m9 \3 M    not permanent
" C% _7 c5 P' l# w2 k+ N' o. n7 {    not modal
" c$ U6 ~/ K  K6 j4 s+ ], }   metric formats
6 @" M# J- ?3 y8 W: p. l+ ?    leading zeros              = false
" Q7 D: t) X" M3 X; d5 I. j    trailing zeros             = true
' c) O, I0 P7 F. s    decimal point              = false
! n' d* L' K* m/ }    decimal places             =   0/ o8 r0 R" w$ ~  C1 d8 q
   imperial formats
% c6 q, a6 _$ J6 T/ Z1 u    leading zeros              = false) p& Z9 H3 D& t4 R+ I1 B6 ?. ~; c5 D
    trailing zeros             = true1 ]% _" N1 t% {# z
    decimal point              = false/ _3 C# n+ b. C* i/ W/ ?$ Q
    decimal places             =   0+ a: A9 V" C+ D
   end define' `8 A: `& I) Q! C7 \
. Y1 |- m3 F- L' Z* L1 O
   define format ( F )$ Y  s5 f0 w& J& d
    address width              =   1% P' g, v' ^- z/ v
    field width                =   2! R4 ?4 ~. t) l' O4 L7 c  m5 T0 E9 z
    exponent width             =   02 _/ D% i- _; X9 R  k5 O( I+ c
    scale factor               =   14 K( [5 B1 J9 A# G  J9 }
    scale divisor              =   1
: X1 ]9 B3 z# _, |; @* a    tape position              =   00 S, l* i- n& O4 ~9 I: a$ _
    print position             =   1
& H& z8 r  H. P9 P    sign                       = if negative5 ]& K, I5 V% P
    not permanent
! E* W4 n: T/ X/ ]    modal
( H* a: D7 `- }) X; V) H   metric formats& x' }! [2 S( L% D" p
    leading zeros              = false, a  a1 G# z, N& X
    trailing zeros             = true# C4 C! Y. {6 i
    decimal point              = false5 G- H5 L& @" [
    decimal places             =   0: T; o6 i8 T: N1 {$ o
   imperial formats
% \3 a7 [4 W/ R' @+ m- D    leading zeros              = false
& m) C5 {! d% v8 D" p5 j    trailing zeros             = true
' D8 u" X% s0 M9 G+ [9 A+ O* t    decimal point              = false& f' W9 b5 b. A
    decimal places             =   0
* Q# W3 c. a. v6 }7 L   end define
2 v; w. O. P% a
; @5 Y% H+ j8 ]* T0 E! \% w   define format ( MS EM OP )( x4 g0 p. A4 @
    address width              =   1* F( i% _/ y9 X
    field width                =   0$ D* x5 q) g8 L7 @
    exponent width             =   04 P3 {( V1 c9 H& @3 e
    scale factor               =   1
( T: K' F9 F) @& ?4 [+ |    scale divisor              =   1& Z" U' p3 H4 z$ I; y1 o
    tape position              =   09 o2 t: p* L0 \
    print position             =   1
* j3 P0 g  d( C6 L2 h/ z    sign                       = none6 n2 }/ C; N/ l- q; }9 F
    not permanent
( A  A( t4 K/ q, b- a1 g. V2 v    not modal
" P3 t1 ]" V( b   metric formats% ^. M5 V5 i% X8 e7 J( Q* _
0 ?, z+ l( i7 u* S1 D2 u: z    trailing zeros             = true- p% ]3 f8 A# F; W/ w. L- n+ @
$ m! ]/ X; J) C. p! H    decimal places             =   0
% Y1 u0 K  ~  M; J; V   imperial formats
; G! N% q& y4 u0 l) u    leading zeros              = false
" [% F5 q) `3 R/ [3 b    trailing zeros             = true; N* J( K5 M  u& S1 t# Z
    decimal point              = false% r" S) K; N, ?% m
    decimal places             =   0
; Y, n5 j; M1 G. o" U. Y   end define# w  F3 @5 Y4 O. M  s3 M' r
! N# w2 y9 a. ?/ C. w  J9 b   define format ( ID )
+ m: K- t6 v2 l- M2 d; b2 I    address width              =   1! L6 W5 K0 b, W5 I: ?
    field width                =   4; X; s) ]. }) h) `6 g9 `
    exponent width             =   0
- E; Q3 C& z5 o1 w    scale factor               =   1
1 \0 U+ v" K2 V5 V: a    scale divisor              =   1! u" c4 M- `3 e* V3 z! o- @  z6 d
    tape position              =   0" d$ i( i5 o  m' }
    print position             =   1: \0 f2 ~* h6 t
    sign                       = none
  s  @% l. }5 x    not permanent
$ J5 d, d) \- u  l2 _; k    not modal
! X2 s  ?7 ?& x9 d* u   metric formats
8 V$ u" ~' y, w- Z    leading zeros              = true
2 G/ u- [: W- s. m: ?    trailing zeros             = true
" b8 H0 v. z* v/ A    decimal point              = false0 l0 r" Y" S: V
    decimal places             =   0
2 _+ v6 x0 ^1 V- j2 E, \   imperial formats/ I+ g$ z/ A+ f4 l( f* `1 l
! W) w/ r/ j: e1 F. `/ P    trailing zeros             = true
+ Y; u4 b8 ]+ V. s9 Y- `    decimal point              = false8 |* W% Q/ `  [' g# _/ K9 R
    decimal places             =   0; P1 x) g+ L( a3 ^, Z6 v
   end define$ W% d" i7 |5 k2 m/ o& |9 |( S* B
! l% ]1 W- Q& c4 [8 a) a- V   define format ( null )+ Y) ]* p5 m4 G  c4 d" |, O2 i
    address width              =   0( R# j( H; Q5 i0 l
    field width                =   0
5 ?" b8 z  e/ ]& J4 R- G, x/ e, [9 [    exponent width             =   0
0 U3 M7 z. L; d. [; V# a/ {6 g    scale factor               =   1
4 w# d7 `1 F% u- _2 B8 P    scale divisor              =   1
* O) m& }# X; R    tape position              =   0
* [/ w, l; U5 v0 P2 _0 ]7 _9 M6 H( t    print position             =   1
: K0 i% M( }; ^: @# C- o0 k( N- {    sign                       = none
! h4 u% b* O! n( K0 @/ q    not permanent
: I, ^, ?: Y; L    not modal4 T% y) H- s7 @( I2 J' j2 J
   metric formats
, Y0 f, V; |2 v( ~, `: Y7 O    leading zeros              = false$ A  I! }/ H% ]3 ^% O
* E. O# e2 c! t0 L; \2 c    decimal point              = false
1 j9 c9 u/ i( c$ S" i    decimal places             =   08 N( m, P7 E! V1 K, F
   imperial formats: X/ |. s  v  C; d' x; b) c; {
    leading zeros              = false) y5 g& D$ g& P
    trailing zeros             = true( p0 E6 u3 r6 l( Z
* `8 E+ J- [: n: o5 ~4 L    decimal places             =   07 K+ V" G; `# k9 U
   end define
$ O9 H. V( g: I
9 W$ t/ L( V5 \- n# linked words1 Z9 r9 l7 T8 v6 `- s6 K4 g
   define format ( MS ), H8 W) Y0 }! d: B+ G
     link to EM
' P5 h1 [! s' [% |9 y   end define% Q: f+ k1 r+ }- K+ W7 G+ v  M
2 P5 S; A& y2 Q/ M
0 s5 C; e# F% z8 ?# N    word order = (    OP   N    G1   G2   G3   G4   G5   )3 N" ~+ m7 \8 s# }& G
    word order = ( +  G6   G7   X    Y    Z    B    C    )
% H) ^! ?; {# P! E, X2 v: r    word order = ( +  I    J    K    R    D    S    T    )2 ?* @6 X, w* k6 K$ i* A
    word order = ( +  H    M1   M2   MS   msg  EM   Q    )4 E, M: k& K) R( g  ]1 I; e
    word order = ( +  Q1   Z2   R2   ID   F    )
# ^. D$ {5 b# n; F% V3 E9 l#
  _2 _2 Z( _. N: M2 k    word order = ( +  TN  TL  TD  TPN  TD2  TipR  )" a" c) t( J, Q6 U3 U/ U- @" o+ S
' W. b: f! l9 V# ^  K' _  define keys' b( Y  M' p" V" T
    blocknumber                       not used9 G% R$ S* Y- A4 R" T$ ?/ [
    preparatory function              = G1$ n  x  f/ u* @1 ~
    aux function                      = M11 c7 p$ j) I8 X9 w3 l- T' a
    x feedrate                        not used
" A8 r, i! D+ [" m5 H: c6 I' t. f    y feedrate                        not used- Y! z1 I$ u  Y$ b; K, y% p' d
    z feedrate                        not used
  Q  M7 u. Q. R" w    circle angle                      not used8 H! _* z) ~9 F9 |5 r
    x coordinate                      = X
- w  T( K* c: o' W* x1 Q2 E    y coordinate                      = Y
9 b3 P  Q( w" t( b" b    z coordinate                      = Z
: T9 U: y6 ?: Z  L. P. P    key i                             = I
' ^9 g) W- ?2 A5 |) c    key j                             = J; ?7 g4 o! E2 S' C) y
    key k                             = K
$ M: R% h3 D2 V    feedrate                          = F
7 B8 g8 W' ^4 [7 R: Z6 F7 V    feedrate per revolution           = F6 k  P* T) j8 N# s; L; Q4 {
    spindle                           = S! n! D5 J+ R4 }1 N3 s
    tool number                       = T
1 ]" w& h- \& l7 K    cycle dwell                       not used8 p+ f' X  A5 z6 ]1 v
    dwell                             = X
7 j( |9 `( y/ u: M2 W$ I    tool length                       = H8 T  L/ e) c5 C: W. F" o  i" C
    tool radius                       = D
8 s1 L0 O4 ^, ~0 s    drill peck depth                  = Q12 F, A$ y* @$ M. d% Z  t' X
    drill hole depth                  = Z2  B1 `& l* x: L. r- }, P
    clearplane                        = R2
; @* t. U! B- `, q$ v5 Y; w( V$ K    message start                     = MS
. ?" P& G. o: ?    message end                       = EM2 _8 h% I# p* R0 I  T
    opskip                            = OP* ~* u& T, C9 [2 O, ^, b+ y8 t
    radius                            = R
/ G! Q1 G2 ?+ Q  L    program id                        = ID
& E2 f# |( f5 j  e% N5 i    azimuth axis                      = B
) C( S' U' M& J8 [$ e; _6 n    elevation axis                    = C& K. Z9 y+ e7 n
    3rd rotation axis                 = null, A2 z2 H' k9 q7 w* m
    leader                            not used) W) Y/ r0 `  J
    x vector                          not used
0 [7 G4 }3 J, P7 F    y vector                          not used
) f# a1 c; \, I0 E( `    z vector                          not used
1 d; m5 \% j5 r# r$ u  end define
5 t$ a8 [( ^/ D3 g
$ N1 o7 T- |& F" Q4 d* n  define codes
+ x# y6 |+ C6 g! C7 I6 X    rapid                             =  G1    0
/ F- v+ G' Q9 A( V    linear                            =  G1    1
, G8 |& \6 O! Y- w' L/ [    circle cw                         =  G1    2
( }  w; h5 {. `5 b    circle ccw                        =  G1    3( e$ \, l8 I, |) y
    dwell                             =  G6    4
6 S) D, ^( L0 |    xy plane                          =  G3   17) \# O, \8 w0 t  M7 d/ |( f$ D
    zy plane                          =  G3   199 ]! X& `* k* T0 q9 p4 f+ E0 ~8 B
    xz plane                          =  G3   18( N: e# P) C% z. }
    compensation off                  =  G2   40
; O4 _3 h/ `, Z6 ~    compensation on left              =  G2   41& L! V' c- h% t& A$ _; B
    compensation on right             =  G2   42
* ]6 J5 F) D- K) e    imperial data                     =  G4   20
7 V& F: K& S/ h/ U7 k! Z# ~    metric data                       =  G4   21* ^( c3 E7 K" J8 e6 |
    absolute data                     =  G5   90( U4 t8 Y" ^) Z9 s- M; z
    incremental data                  =  G5   91
) O4 Q" B2 D% K/ [    from                              =  G3   54
( f$ y7 I0 x; }$ ^5 w0 c: X    feedrate per minute               not used) ^7 O+ d: k- \; m
    feedrate per revolution           not used
. p  P& a) l" l1 C3 i4 r0 y    spindle rpm                       not used0 y: i+ R+ g& S' E5 c+ j
    constant surface speed            not used
  d; ]6 k) t3 k4 q: `, K& A, j* Z0 W    drill                             =  G4   81" _! l9 O0 K8 W* [
    break chip                        =  G4   82
' P$ G  B$ V: T/ L' z' W    deep drill                        =  G4   83
0 k/ Y" y0 K: r9 I    tap                               =  G4   84
; O, ^, b9 s  S5 }  h: K! u    bore 1                            =  G4   85/ E; H8 ]$ `! ?# g2 T7 J
    bore 2                            =  G4   86
, Z. d+ ]2 D8 \( z7 x1 j% i    bore 3                            =  G4   87; I$ p  l6 }; E% {3 J$ ]
    bore 4                            =  G4   88
0 }6 T+ d9 o1 ]; x    bore 5                            =  G4   89) W+ g+ b8 K5 z) p8 z1 L" \
    end of drill                      =  G4   80
, v' V6 P* Y7 }, `) R    macro start                       not used4 J# B4 g7 V5 v9 a! Y+ J+ T  b1 c
    macro end                         not used8 v/ N3 H/ i+ ?( G  K, x
    macro call                        not used) x9 G, O) z# u+ s$ V. u' p
    cycle retract                     =  G6   994 ]$ J$ S/ V. M8 d- n: u
    tool length offset                =  G6   43; D# v$ S# y% ^0 n3 @7 Q  |
    spline                            not used
6 z& d7 s. ?: v: U    stop                              =  M1    0; h, n: V9 v4 }( N
    opt stop                          =  M1    13 m0 l$ e' R5 P0 y7 h% M1 l3 i. `
    spindle on cw                     =  M1    3
% I3 R! w, l0 R3 D    spindle on cc                     =  M1    4* f7 F5 }' y! h5 C' b
    spindle off                       =  M1    54 o' w- T2 U1 {4 V
    spin coolant on cw                =  M1   136 [+ w) {$ \/ ~1 r" j0 f! y$ }/ v% g
    spin coolant on ccw               =  M1   14' {: a( a# [* e6 t3 i6 N9 ?. T; z
    spin coolant off                  =  M1    5" o0 z3 e! J: @1 Z6 o
    change tool                       not used1 n9 B: K$ p5 s7 M
    coolant on mist                   =  M1    7
4 w" W  D6 ^8 T: ?2 T5 E7 c    coolant on                        =  M1    8
4 o6 B3 `- \0 \3 N6 M    coolant on flood                  =  M1    8
- q4 D7 B- H) e  S4 i! V    coolant off                       =  M1    9! {8 j, y+ N& C( m* D1 Z
    clamp on                          not used
; y( Z- U5 E4 f$ P3 s    clamp off                         not used0 e6 a4 U( Z. r0 T1 E% ?' c
    end of tape                       =  M1    2
1 Q2 }, J" M4 N, g7 |    end of prog                       =  M1   30
2 H6 r: p3 N$ m" K! E# Q. P; G1 B    gear range 1                      not used" B' b. {* f9 Y  a. t% L1 S# r
    gear range 2                      not used
% u8 Q. S! w$ `8 `6 T    gear range 3                      not used
+ V% l! {$ k( A( i    constant contour speed            not used) E1 C! o1 j6 c3 d
    constant contour speed 2          not used0 B- p+ A+ a. H7 ~5 W# O
    word drill                        not used( d" c) Q: p% b( H5 U  a/ Q- ^( a
    word break chip                   not used
4 d# ^) ?, C1 \    word deep                         not used
  T5 ?/ n7 N4 C7 c2 a    word tap                          not used4 R/ e: Q  k( P% f0 k
    word bore 1                       not used/ I9 @, G: J/ \- I/ F: S) [1 N
    word bore 2                       not used+ n% M/ {& p  {1 ^" @: A
    word bore 3                       not used$ a/ z6 p. K( E8 X; j
    word bore 4                       not used! [" ]" D- \3 e" O7 p
    word bore 5                       not used$ S! `1 [" ], |
  end define
. e2 m/ S6 |& ?4 T& p & V+ p6 m' j3 Q) ^2 d; k
  print header               = "Delcam Postprocessor"
0 z& m/ {; {; `5 d+ `- s  machine name               = "Fanuc6m          version 1.2"$ [$ ]: ]+ d; l/ Y, E7 ]
  point                      = "."
. c% Z6 T, {5 t" O8 Q/ _  zero                       = "0"
) M/ E4 i/ W6 F  ~5 P# P* X  tape headers               =     12 N+ i* a2 @% Q: Y$ |" F/ d
  integer   6                =     2
: h* F; E( o, U& A& Q& L  integer   7                =     1
; W! P3 z* k6 t- Q  integer  10                =     2: E% e, J) t/ r* }  g9 f
  integer  11                =     1) a! k# K% E% J0 e: l" }$ q
#  p0 T. u" e! E0 {- Q
  integer  12                =     1
; t) d# N) W& C% |#  integer  12                =     08 i( \/ f  ~1 {3 r
#  integer  13                =     0% c( C! \# u" m
#$ n! N! t0 q5 ?) Q* s
  tool reset coordinates     =     21 ^2 r8 }2 a# A4 |$ Q$ X" Z
  cycle output               =     1
$ U6 {' \2 o& T( {8 h  integer  20                =     1
- Y  t. i" F1 ~  block start                =     1
) b2 e3 R! l& R# H* Z  block increment            =     1
, d. ^; H9 e: [# F7 g* v8 ?. Z/ h  split move                 =     0
6 K# f4 a2 m; r& ]  integer  26                =     1
- h7 f, Y( v# ]' c  program id start           =     1  _9 X  ]3 {2 t+ |$ R
  integer  34                =     3
; I+ A3 {& I1 v  integer  35                =     1! E; V6 Z+ `6 O2 x; ]
  integer  36                =     1& ?8 ?6 }7 f4 o' }; f4 F6 k
  integer  37                =     2
7 C$ {+ I2 ?9 k  R' {  rapid feed code            =     01 _: Y, O/ O* I. O9 p6 Z
  maximum block number       =     0
1 E8 j5 E1 [/ c6 {$ ~( \# H1 ]! i- F  maximum tape blocks        =     02 V7 d) {* D5 W; [3 n
  minimum tape blocks        =     0* H( ?7 R* e1 S3 s9 x$ h$ f
  segment type               =     00 J- O0 q& a( Q% R+ O& }$ Y
  counter start              =     0" o9 J$ @5 P! f3 J" }
  counter increment          =     0% s* _) C& S. v9 i2 D3 x
  tape split retract distance  =  -9996 n' u% A( o3 Y, @$ v3 k
  multiaxis coordinate transform  = true$ _" e$ b, J1 u' ~) i% a* M. j
  message output             = false
& D0 z7 n* H: e  b  p! s1 p: z#* [0 ~& {2 X- [* j: j8 r
#  block order                = false  w. g9 C5 w! g+ a0 _9 y
  block order                = true$ S$ U0 U# ?1 J
#8 x  c3 X& B" h! I4 X& F
  tlo output                 = true/ S) X! _" N8 @  M
  tape split on tool change  = false
- |' C  ^( \% d4 @0 p9 W( V  full circle                = true& J! n$ ?6 z$ ]* d$ A
  incremental centre         = true
( P; W% ?4 ?5 z1 p$ M. u  go home output             = false
# m( M: C' r9 {+ v8 {) s7 ]5 t  use partid                 = true3 N- j. ]% ?1 }( ]8 s" j2 n
  use progid                 = true9 N' Q$ T9 y4 t9 A7 ^4 n& R
  spindle x motion           = false: `- P: h3 T! g- j+ T( e% B
  spindle y motion           = false
8 v- L. s! \% i( x' h/ L0 l  spindle z motion           = true# c, S3 P, N- W( H4 m0 L4 z
  spindle w motion           = false$ {* Z: p- R" e9 B0 c0 A
  spindle azimuth rotation   = false7 ^) u* V' Z  d
  spindle elevation rotation  = false' W# U( h9 w3 p
  linearise multiaxis moves  = true
; O3 o: ^$ X2 {  F1 {  use hole top in cycles     = false# Q( D( d+ _8 o/ D+ c" i, L1 n
  knot vector type           = none4 u" z- _# M8 X1 C; L) G
  units                      = input
; b" s' @, l* n9 D  i. \3 h- `* W  coordinates                = absolute
7 c% `* [' _4 Q2 G  Z  azimuth axis units         = none& y- @8 j& _# N' G% r6 a$ {( O! r
  azimuth axis direction     = none6 Y" s* Q) h/ \
  elevation axis units       = none
' {' c3 b- p% V' X: f; e' G  elevation axis direction   = none7 d! G: a2 n% u' u
  spline type                = none- D; ?! E' y6 W- m* s. P3 v# p0 ?
  maximum feedrate           =  9999.0000
2 ]" N' _& ?9 P) U# `' \" u  minimum feedrate           =     1.0000  X" _; a2 _1 s
  rapid feedrate             =  9999.0000
$ {5 ]9 `3 c% y+ L" A# D  maximum tape length        =     0.0000% d" b/ g, i! B2 Z# K: _: E
  maximum segment            =     0.0000, Y' T8 |- P7 l$ P
  diameter                   =     1.0000
$ T) h, H" u/ ~. z+ b2 L% r6 L  withdrawal amount          =    50.0000" |6 K; G) h; v  D& D; q
9 S; |& [- O" X  D/ q5 r# t  azimuth axis parameters    = (      0      0      0      0      0      0 )
! c" d5 K* ^$ p* |8 G  azimuth centre             = (      0      0      0 )
0 p- r( Z* [/ M6 M% j& |4 d, \  elevation axis parameters  = (      0      0      0      0      0      0 )# F+ @) |# A4 o# _) C1 ^
  elevation centre           = (      0      0      0 )4 H' t& z& S1 z
  pcs origin                 = (      0      0      0      0      0      0 )
4 N) V. t$ q/ r. z  linear axis limits         = ( -99999 999999 -99999 999999 -99999 999999 )
- R$ F( z1 K3 r. q, D! x  rotary axis limits         = ( -99999 999999 -99999 999999    999      1 )1 M- B0 {# q, F4 L% S
  move safe angles           = (      0      0      0      0 )
8 k) J* A1 `6 D7 U ) h+ H. y1 Q7 Y6 }" r
  define block tape start" L2 W* X0 B& L4 A
    "%"4 R* w/ y. I5 r9 a% Z  i. J
( N& b) z" @# e: ~( h8 t2 ?1 ?1 o! ~    TN ToolNumber ; TL ToolLength[ToolNum] ; TD ToolRadius[ToolNum] ; TPN ToolPathName ; " )"
0 T, i- I  V' S! u  W    TD2 ToolRadius[ToolNum] ; TipR TipRadius[ToolNum] ; " )"
. N: c# y; ^. E9 P' U#2 y- G1 B; _% B- N; X" a2 O5 t
    G3  17 ; G6 ToolComp ; G2 49 ; G4  80
1 o0 s5 G! c% R6 G  end define
. G( `. t  I9 ]" ?5 m   p0 ^' i8 c! i" }9 {; {
  define block tape end! W; d6 d2 a- R1 e8 `) Y
#   M1  9  ]0 U4 S& \9 ?, \. B. t
    M1  5
) @* g$ Q  `% U    G5  91    ; G6  28    ; Z   0     ; Z =C
& j' |2 J0 K1 a0 A: q- B#   G5  90    ; G2 0 ; G3 54 ; X   0 ; Y   0     ; X =C ; Y =C
4 Y: F) R$ \; o4 m    M1  30
6 Z5 Y6 C) R6 Z7 k    "%"
2 `& w5 C- v# E5 X5 h: S  end define( v- W3 K# }4 A; d$ B+ G) x
- x' b% I; R5 d1 ^
  define block go home preamble
1 W9 ^  @! L* `! U) J6 D) L7 x  end define
/ I0 D0 ^+ \+ T+ Z* X  L5 @, ^- H 8 `0 y$ ]5 Z/ B; s
  define block tool change first5 f0 I: r4 r+ J% U
* U0 m( S7 n$ [    G5  90    ; G3  54
. h; H5 ~2 F% q* [- W& ]8 y& G    S ToolSpeed ; M1 3     / p) H+ @: s0 l& w& c- C5 c
    / a$ Q0 z! s0 J, l# n! g; y
  end define0 F8 N- b; p) V9 q7 x: f
2 n5 L4 A. [6 a7 @3 M  define block tool change+ w9 u8 P4 V8 U4 g- V! M
  end define
  d5 u- |* R1 `5 p4 _( P! r 5 S% ?% p1 }% |2 A: h3 w: a
  define block tool change clear
9 q# f, L; ?: {" w9 p6 Q# z  end define
! D! u0 k& D3 M1 M3 R$ e 5 x6 b" K2 f/ R( e+ @
  define block go home z move
/ ^  z4 {! v/ M$ X1 m( o; g" `  end define
6 q$ q0 x3 P2 e* I+ A
  U% J# ^- w# U. \: L  define block go home xy move
' R7 o& [2 G# Q* W5 D% [; ?  end define, p4 n# J( Q7 h9 {/ i, V8 K5 ?
- w3 t; u. P6 {8 q& ^0 z! K: _- S
  define block move from
; V3 G1 P  R5 R8 j1 C7 I) J  end define' F  @" N1 S# z. W+ e
" B  t' G6 |; H+ F+ i1 l
  define block move circle( y0 v2 ?  I+ G+ n- l
    G1  ; G2  ; G3  ; X   ; Y   ; Z   ; I   ; J   ; K   ; F   ; D
: V& @+ a: H* G  t7 a  end define
& i( A' d7 P/ a . z# D4 E  U& e  w+ V3 N: T
  define block move linear
% C6 `6 {& k- u$ s3 W6 |0 z2 e! E  end define1 o0 N1 r7 W0 N3 i) f
% f1 G. |4 H4 \$ C+ s+ H  define block move rapid7 l4 k: n0 p7 V# X; t' J5 Q' ^4 i
    G1  ; X   ; Y   ; Z     ;  F & W1 p1 a2 Z6 O/ v+ X; _  }
  # G1 0 ; Z FromZ   ;   G1 =C     & X4 O0 s8 b- H# \: e
  end define9 J3 j. j2 m4 q9 s3 f0 n
6 z  o4 S8 I0 z# p6 L5 L2 f3 i
  define block move cycle
. s. ~( t- e9 k+ K    G4  ; G6  ; X   ; Y   ; Z2  ; R2  ; Q   ; Q1  ; F   ; M2
- |2 N1 u' y+ J( F6 F3 _# _  end define
% v3 p( V! q# F9 R0 t % G3 I: \% P1 K/ p1 s+ D, |
  define block move tap, v8 e" E8 J# z5 x2 j7 B
    G6  ; G4  ; X   ; Y   ; Z2  ; R2  ; F   ; M1  ; M2; y" P- F/ f% }1 J& i
  end define6 N& Q# ]- P" W8 N+ i
2 v, V; F) j. v
  define block tape segment5 ]+ v/ ]& F9 t$ Q7 m# ?- K7 ?" l
  end define+ U4 ]0 {, b2 r# Y
1 B0 W/ ^0 x/ v7 h' R1 h8 O3 V: W  define block tape split start
) m; t1 P8 d* C1 f, _1 [) P8 m    "%". h/ s( x+ Q( Z0 f( _9 s& N% n& _
  end define& V6 A9 {8 D% q: B  B" D2 }. y
0 u% y  u4 I  y* i  define block tape split end
0 W' Q6 l+ Q5 U9 j#    M1  9) V  u. z: R3 Y8 ]# _
    M1  5
: Y  s% Z: C+ y3 D2 e1 |    G4  80    ; G1  28    ; G6  91    ; Z   0     ; Z =C) q, C* x4 l5 a! }3 z6 x
    G4  80    ; G6  28    ; Y   0     ; Y =C
- `" h5 j6 c, p: J! S8 Y* z6 t3 E/ H    M1  30
: Y* p6 \# R% O, @/ ]% P% w    "%"5 M. G! Z4 p- F
  end define
) {* _: }" m' y! X& `, K 6 w6 N8 b6 `+ ?" p, @4 s9 q( A* |+ Y1 D! }
  define block cycle start
  x/ F* G: A5 z) u    S   ; M11 X+ i0 g9 z9 [$ [
    G3  ; G5  ; M2
  B9 M' E" @, m3 `. {    F =C      ; G4 =C     ; Z2  ; R2  ; Q   ; Q1  ; G6  ;. Q# E; Z5 r4 j; V1 G8 `
  end define; l% l( U7 B; i8 e; @$ ^
: p3 P; ^2 W2 G- c2 {
  define block cycle end
' I/ R/ w0 q. W: n' e
& q# _+ j* a( ?. z    G4  80( ]; L6 h9 d- H  o. l4 r
  end define' {3 j& ?8 ~" J/ D: w- A0 n) F
3 f  X. ?& [. `/ \" p! ]5 S  define block tape split move" k# ?) _- L! a
  end define
$ \6 W; O" _4 b0 T" X9 {* W
8 p" k" W( B. }+ D7 n" Q  define block move spline
, Y9 x9 M# c1 d' _  end define
* a8 T0 L* ]% Q+ ~5 l
$ T) |# r/ ]" q9 p  uend' c7 x8 J1 `8 I( p5 {! F8 u. N/ ]" E! T  q
& K- U3 s" F& B# o
发表于 2014-4-2 10:32 | 显示全部楼层
, R0 I: m0 K; Q) P" P( p, T5 a, m
" a6 C) o" E) r! [/ K这个没法修改。。。我特意去请教了一位老师傅   说那CUTTER数据PM没给出   只能手动在程式里面添加  也可以在后处理时,写进去 产生后处理时写到注释里               后处理是做不出来的# X, p% v, z2 R
& e) R3 q6 v, y  R7 N
 楼主| 发表于 2014-4-3 09:09 | 显示全部楼层
◆◇黑白无常、 发表于 2014-4-2 10:32% q8 x0 L4 W5 Z5 ]! |
这个没法修改。。。我特意去请教了一位老师傅   说那CUTTER数据PM没给出   只能手动在程式里面添加  也可以 ...
/ G: W5 H# S0 v
这样啊,那就没有办法了,谢了
2 Y' Y8 }# M3 S1 W
 楼主| 发表于 2014-4-3 09:20 | 显示全部楼层
fjf83 发表于 2014-4-3 09:091 j& D$ U6 u' [0 a6 z
这样啊,那就没有办法了,谢了
( u2 n# f2 D" x6 s% d& o
那为什么我公司的就可以啊,关于刀具的定义后处理是这样的
GMT+8, 2025-7-22 16:26 , Processed in 0.175985 second(s), 24 queries .
