3 P" O( e6 m" T+ }+ c; o" N% j9 `
求大神们指点。小第用的是ug6。0这是三精雕机后处理。- F/ H9 l( {# q% c
9 O4 l1 |& P% s9 [ i
8 L6 H. N! F! U7 t; q- r7 S5 `& ?0 ]- k
. d# w/ i! ?+ h1 M5 U. U9 k* m( FILE_NAME: D:\\h12.nc )
& r! X1 d) V; X2 @( DATE: Thu May 08 19:05:33 2014 )$ M/ I; q* J3 `& t4 Z0 {6 F8 @
( ToolName=D3 DESCRIPTION=Milling Tool-5 Parameters)
5 m+ [+ i" S2 G' }+ q) r6 j, i0 p0 h3 n( D=3.00 R1=0.00 F=50.00 )0 N- I5 N$ L8 W0 K& `
N1 G40 G17 G49 G80 G54 g& V0 C6 h6 T+ K7 Z+ X
( REST_MILLING)) T- u. t0 C* [# D& l- t
N2 G0 G90 X-45.172 Y-44.506 S4000 M035 _& T, @# e# j! q: _$ v! x* c
N3 G43 Z10. H01' V: n; P' G2 _4 P9 n8 U
N4 Z.409
" {0 u, ^3 {# dN5 G1 Z-.591 F4250. M08
6 ^! l/ R5 }. {! l! EN6 Y-43.006
! ?: G- Q. P v; e0 ^; }, f% WN7 X-47.37
+ @8 E) K) Y j& c& z3 \4 oN8 G2 X-47.561 Y-42.994 I0.0 J1.5。。。。
: E7 [! R- _, \0 P# j。。后面。。% e- W; l" V) g4 b
N12065 X51.993
0 D. ^* Q2 I2 cN12066 G2 X52.04 Y-40.287 I-5.025 J-.6887 q3 l. j9 T5 k/ q4 G& z0 }0 q- d
N12067 X51.939 Y-41.293 I-5.072 J0.06 S: u7 R0 d! k6 W9 h p
N12068 G1 X52.0388 J: A/ r ?9 f( l( ~" Q
N12069 Z-3.138
. d7 b9 S( e( _' [4 @8 ZN12070 G0 Z10.
0 t) P( c/ b5 u" x3 `+ iN12071 G91 G28 Z0.0
3 S- T0 a6 n8 t/ x7 K" lN12072 M05% D3 M* R \& M8 j h, D
N12073 M09. A* @0 i7 ~+ v* K u5 v7 M
N12074 M30
' ~" z0 ?7 ]' h9 g1 z1 j* R5 P(MACHINING_TIME: 89.01 MIN)7 c: J( ^. s n8 j$ U8 U9 _- _% F/ O
%1 a* n3 J" }) K3 [3 C
红色的M08是放油在开关油。参数里面怎么设置不放油 Y M9 B! ~3 D0 S& K7 O1 ?
! M5 I& {: m9 l& S/ U
N12071 G91 G28 Z0.0这是抬刀。参数里面怎么设置走完刀抬刀到固定点而不回几床0点
$ i8 }7 W) W' y+ ^" u! k
2 ?5 j, S; H+ G6 d9 F( ] |
