! t5 F3 z' v, h- N dowel pin 定位梢 draft 拔模锥度 draw bead 张力调整杆 drive bearing 传动轴承 ejection pad 顶出衬垫 ejector 脱模器 ejector guide pin 顶出导梢 ejector leader busher 顶出导梢衬套 ejector pad 顶出垫 ejector pin 顶出梢 ejector plate 顶出板 ejector rod 顶出杆 ejector sleeve 顶出衬套 ejector valve 顶出阀 eye bolt 环首螺栓 filling core 椿入蕊 film gate 薄膜形浇口 finger pin 指形梢 finish machined plate 角形模板 finish machined round plate 圆形模板 fixed bolster plate 固定侧模板 flanged pin 带凸缘销 flash gate 毛边形浇口 flask 上箱 floating punch 浮动冲头 gate 浇口 gate land 浇口面 gib 凹形拉紧楔 goose neck 鹅颈管 guide bushing 引导衬套 guide pin 导梢 guide post 引导柱 guide plate 导板 guide rail 导轨 head punch 顶头冲孔 headless punch 直柄冲头 heavily tapered solid 整体模蕊盒 hose nippler 管接头 impact damper 缓冲器 injection ram 压射柱塞 inlay busher 嵌入衬套 inner plunger 内柱塞 inner punch 内冲头 insert 嵌件 insert pin 嵌件梢 king pin 转向梢 king pin bush 主梢 一、入水:gate 进入位: gate location 水口形式:gate type 大水口:edge gate 细水口: pin-point gate 水口大小:gate size 转水口: switching runner/gate 唧嘴口径: sprue diameter 二、流道: runner 热流道: hot runner,hot manifold 热嘴冷流道: hot sprue/cold runner 唧嘴直流: direct sprue gate 圆形流道:round(full/half runner 流道电脑分析:mold flow analysis 流道平衡:runner balance 热嘴: hot sprue 热流道板:hot manifold 发热管:cartridge heater 探针: thermocouples 插座: connector socket 密封/封料: seal 三、运水:water line 喉管:tube 塑胶管:plastic tube 快速接头:jiffy quick connector plug/socker 四、模具零件: mold components 三板模:3-plate mold 二板模:2-plate mold 边钉/导边:leader pin/guide pin 边司/导套:bushing/guide bushing 中托司:shoulder guide bushing 中托边L:guide pin 顶针板:ejector retainner plate 托板: support plate 螺丝: screw 管钉:dowel pin 开模槽:ply bar scot 内模管位:core/cavity inter-lock 顶针: ejector pin 司筒:ejector sleeve 司筒针:ejector pin 推板:stripper plate 缩呵:movable core,return core core puller 扣机(尼龙拉勾):nylon latch lock 斜顶:lifter 模胚(架): mold base 上内模:cavity insert 下内模:core insert 行位(滑块): slide 镶件:insert 压座/斜鸡:wedge 耐磨板/油板:wedge wear plate 压条:plate 撑头: support pillar 唧嘴: sprue bushing 挡板:stop plate 定位圈:locating ring 锁扣:latch 扣鸡:parting lock set 推杆:push bar 栓打螺丝:S.H.S.B 顶板:eracuretun 活动臂:lever arm 分流锥:spure sperader 水口司:bush 垃圾钉:stop pin 隔片:buffle 弹弓柱:spring rod 弹弓:die spring 中托司:ejector guide bush 中托边:ejector guide pin 镶针:pin 销子:dowel pin 波子弹弓:ball catch 喉塞: pipe plug 锁模块:lock plate 斜顶:angle from pin 斜顶杆:angle ejector rod 尼龙拉勾:parting locks 活动臂:lever arm 复位键、提前回杆:early return bar 气阀:valves 斜导边:angle pin 术语:terms 承压平面平衡:parting surface support balance 模排气:parting line venting 回针碰料位:return pin and cavity interference 模总高超出啤机规格:mold base shut hight 顶针碰运水:water line interferes withejector pin 料位出上/下模:part from cavith (core) side 模胚原身出料位:cavity direct cut on A-plate,core direct cut on B-plate. 不准用镶件: Do not use (core/cavity) insert 用铍铜做镶件: use beryllium copper insert 初步(正式)模图设计:preliinary (final) mold design 反呵:reverse core 弹弓压缩量:spring compressed length 稳定性好:good stability,stable 强度不够:insufficient rigidity 均匀冷却:even cooling 扣模:sticking 热膨胀:thero expansion 公差:tolorance 铜公(电极):copper electrode dowel pin 定位梢 draft 拔模锥度 draw bead 张力调整杆 drive bearing 传动轴承 ejection pad 顶出衬垫 ejector 脱模器 ejector guide pin 顶出导梢 ejector leader busher 顶出导梢衬套 ejector pad 顶出垫 ejector pin 顶出梢 ejector plate 顶出板 ejector rod 顶出杆 ejector sleeve 顶出衬套 ejector valve 顶出阀 eye bolt 环首螺栓 filling core 椿入蕊 film gate 薄膜形浇口 finger pin 指形梢 finish machined plate 角形模板 finish machined round plate 圆形模板 fixed bolster plate 固定侧模板 flanged pin 带凸缘销 flash gate 毛边形浇口 flask 上箱 floating punch 浮动冲头 gate 浇口 gate land 浇口面 gib 凹形拉紧楔 goose neck 鹅颈管 guide bushing 引导衬套 guide pin 导梢 guide post 引导柱 guide plate 导板 guide rail 导轨 head punch 顶头冲孔 headless punch 直柄冲头 heavily tapered solid 整体模蕊盒 hose nippler 管接头 impact damper 缓冲器 injection ram 压射柱塞 inlay busher 嵌入衬套 inner plunger 内柱塞 inner punch 内冲头 insert 嵌件 insert pin 嵌件梢 king pin 转向梢 king pin bush 主梢
4 H( B, M$ k5 h4 [difference quantity差异量 cause analysis原因分析 raw materials原料 materials物料 finished product成品 semi-finished product半成品 packing materials包材 good product/accepted goods/ accepted parts/good parts良品 defective product/non-good parts不良品 disposed goods处理品 warehouse/hub仓库 on way location在途仓 oversea location海外仓 spare parts physical inventory list备品盘点清单 spare molds location模具备品仓 skid/pallet栈板 tox machine自铆机 wire EDM线割 EDM放电机 coil stock卷料 sheet stock片料 tolerance工差 score=groove压线 cam block滑块 pilot导正筒 trim剪外边 pierce剪内边 drag form压锻差 pocket for the punch head挂钩槽 slug hole废料孔 feature die公母模 expansion dwg展开图 radius半径 shim(wedge)楔子 torch-flame cut火焰切割 set screw止付螺丝 form block折刀 stop pin定位销 round pierce punch=die button圆冲子 shape punch=die insert异形子 stock locater block定位块 under cut=scrap chopper清角 active plate活动板 baffle plate挡块 cover plate盖板 male die公模 female die母模 groove punch压线冲子 air-cushion eject-rod气垫顶杆 spring-box eject-plate弹簧箱顶板 bushing block衬套 insert 入块 club car高尔夫球车 capability能力 parameter参数 factor系数 phosphate皮膜化成 viscosity涂料粘度 alkalidipping脱脂 main manifold主集流脉 bezel斜视规 blanking穿落模 dejecting顶固模 demagnetization去磁;消磁 high-speed transmission高速传递 heat dissipation热传 rack上料 degrease脱脂 rinse水洗 alkaline etch龄咬 desmut剥黑膜 D.I. rinse纯水次 Chromate铬酸处理 Anodize阳性处理 seal封孔 revision版次 part number/P/N料号 good products良品 scraped products报放心品 defective products不良品 finished products成品 disposed products处理品 barcode条形码 flow chart流程窗体 assembly组装 stamping冲压 molding成型 spare parts=buffer备品
$ D/ u* [1 d. {% x
" u' S. @" f) t, Hcoordinate坐标
dismantle the die折模 auxiliary fuction辅助功能 poly-line多义线 heater band 加热片 thermocouple热电偶 sand blasting喷沙 grit 砂砾 derusting machine除锈机 degate打浇口 dryer烘干机 induction感应 induction light感应光 response=reaction=interaction感应 ram连杆 edge finder巡边器 concave 凹 convex凸 short射料不足 nick缺口 speck瑕疪 shine亮班 splay 银纹 gas mark焦痕 delamination起鳞 cold slug冷块 blush 导色 gouge沟槽;凿槽 satin texture段面咬花 witness line证示线 patent专利 grit沙砾 granule=peuet=grain细粒 grit maker抽粒机 cushion缓冲 magnalium镁铝合金 magnesium镁金 metal plate钣金 lathe车 mill锉 plane刨 grind磨 drill钻 boring镗 blinster气泡 fillet镶;嵌边 through-hole form通孔形式 voller pin formality滚针形式 cam driver铡楔 shank摸柄 crank shaft曲柄轴 augular offset角度偏差 velocity速度 production tempo生产进度现状 torque扭矩 spline=the multiple keys花键 quenching淬火 tempering回火 annealing退火 carbonization碳化 alloy合金 tungsten high speed steel钨高速的 moly high speed steel钼高速的 organic solvent有机溶剂 bracket小磁导 liaison联络单 volatile挥发性 resistance电阻 ion离子 titrator滴定仪 beacon警示灯 coolant冷却液 crusher破碎机 模具工程类 plain die简易模 pierce die冲孔模 forming die成型模 progressive die连续模 gang dies复合模 shearing die剪边模 riveting die铆合模 pierce冲孔 forming成型(抽凸,冲凸) draw hole抽孔 bending折弯 trim切边 emboss凸点 dome凸圆 ! ^* R9 g" z& m0 Z
; D; b S4 M/ _% [+ @# w7 ~
semi-shearing半剪 stamp mark冲记号 deburr or coin压毛边 punch riveting冲压铆合 side stretch侧冲压平 reel stretch卷圆压平 groove压线 blanking下料 stamp letter冲字(料号) shearing剪断 tick-mark nearside正面压印 tick-mark farside反面压印 冲压名称类 extension dwg展开图 procedure dwg工程图 die structure dwg模具结构图 material材质 material thickness料片厚度 factor系数 upward向上 downward向下 press specification冲床规格 die height range适用模高 die height闭模高度 burr毛边 gap间隙 weight重量 total wt.总重量 punch wt.上模重量 五金零件类 inner guiding post内导柱 inner hexagon screw内六角螺钉 dowel pin固定销 coil spring弹簧 lifter pin顶料销 eq-height sleeves=spool等高套筒 pin销 lifter guide pin浮升导料销 guide pin导正销 wire spring圆线弹簧 outer guiding post外导柱 stop screw止付螺丝 located pin定位销 outer bush外导套 模板类 top plate上托板(顶板) top block上垫脚 punch set上模座 punch pad上垫板 punch holder上夹板 stripper pad脱料背板 up stripper上脱料板 male die公模(凸模) feature die公母模 female die母模(凹模) upper plate上模板 lower plate下模板 die pad下垫板 die holder下夹板 die set下模座 bottom block下垫脚 bottom plate下托板(底板) stripping plate内外打(脱料板) outer stripper外脱料板 inner stripper内脱料板 lower stripper下脱料板 零件类 punch冲头 insert入块(嵌入件) deburring punch压毛边冲子 groove punch压线冲子 stamped punch字模冲子 round punch圆冲子 special shape punch异形冲子 bending block折刀 roller滚轴 baffle plate挡块 located block定位块 supporting block for location 定位支承块 air cushion plate气垫板 air-cushion eject-rod气垫顶杆 trimming punch切边冲子 stiffening rib punch = stinger 加强筋冲子 ribbon punch压筋冲子 reel-stretch punch卷圆压平冲子 guide plate定位板 sliding block滑块 2 S3 o. o; a; X# \( S
; p$ |9 S8 I' K" D! ?7 g F4 J& T/ a2 o' n0 J/ ^% K
; k9 Y \0 ~0 F, b7 P5 q
101个热处理常用英文词汇
7 @7 M0 j6 B x" ~- W V( B! l$ u/ C$ a% I* K4 N' d
1. indication 缺陷 2. test specimen 试样 3. bar 棒材 4. stock 原料 5. billet 方钢,钢方坯 6. bloom 钢坯,钢锭 7. section 型材 8. steel ingot 钢锭 9. blank 坯料,半成品 10. cast steel 铸钢 11. nodular cast iron 球墨铸铁 12. ductile cast iron 球墨铸铁 13. bronze 青铜 14. brass 黄铜 15. copper 合金 16. stainless steel不锈钢 17. decarburization 脱碳 18. scale 氧化皮 19. anneal 退火 20. process anneal 进行退火 21. quenching 淬火 22. normalizing 正火 23. Charpy impact text 夏比冲击试验 24. fatigue 疲劳 25. tensile testing 拉伸试验 26. solution 固溶处理 27. aging 时效处理 28. Vickers hardness维氏硬度 29. Rockwell hardness 洛氏硬度 30. Brinell hardness 布氏硬度 31. hardness tester硬度计 32. descale 除污,除氧化皮等 33. ferrite 铁素体 34. austenite 奥氏体 35. martensite马氏体 36. cementite 渗碳体 37. iron carbide 渗碳体 38. solid solution 固溶体 39. sorbite 索氏体 40. bainite 贝氏体 41. pearlite 珠光体 42. nodular fine pearlite/ troostite屈氏体 43. black oxide coating 发黑 44. grain 晶粒 45. chromium 铬 46. cadmium 镉 47. tungsten 钨 48. molybdenum 钼 49. manganese 锰 50. vanadium 钒 / h* c9 v5 m# t; ?+ ]' v0 f3 E
51. molybdenum 钼 52. silicon 硅 53. sulfer/sulphur 硫 54. phosphor/ phosphorus 磷 55. nitrided 氮化的 56. case hardening 表面硬化,表面淬硬 57. air cooling 空冷 58. furnace cooling 炉冷 59. oil cooling 油冷 60. electrocladding /plating 电镀 61. brittleness 脆性 62. strength 强度 63. rigidity 刚性,刚度 64. creep 蠕变 65. deflection 挠度 66. elongation 延伸率 67. yield strength 屈服强度 68. elastoplasticity 弹塑性 69. metallographic structure 金相组织 70. metallographic test 金相试验 71. carbon content 含碳量 72. induction hardening 感应淬火 73. impedance matching 感应淬火 74. hardening and tempering 调质 75. crack 裂纹 76. shrinkage 缩孔,疏松 77. forging 锻(件) 78. casting 铸(件) 79. rolling 轧(件) 80. drawing 拉(件) 81. shot blasting 喷丸(处理) 82. grit blasting 喷钢砂(处理) 83. sand blasting 喷砂(处理) 84. carburizing 渗碳 85. nitriding 渗氮 86. ageing/aging 时效 87. grain size 晶粒度 88. pore 气孔 89. sonim 夹砂 90. cinder inclusion 夹渣 91. lattice晶格 92. abrasion/abrasive/rub/wear/wearing resistance (property) 耐磨性 93. spectrum analysis光谱分析 94. heat/thermal treatment 热处理 95. inclusion 夹杂物 96. segregation 偏析 97. picking 酸洗,酸浸 98. residual stress 残余应力 99. remaining stress 残余应力 100. relaxation of residual stress 消除残余应力 101. stress relief 应力释放
' \ J7 x! j; \9 H( i" c4 e4 ]' b! p! |
9 a6 @) u- o9 |4 s' k& T
$ d+ B' x, R2 V5 C
, N( Y/ b" n) @3 M
机械类常用英语:冲压模具-零件类 + b; F5 _6 Z! L6 K0 G6 S
punch冲头 insert入块(嵌入件) deburring punch压毛边冲子 groove punch压线冲子 stamped punch字模冲子 round punch圆冲子 special shape punch异形冲子 bending block折刀 roller滚轴 baffle plate挡块 located block定位块 supporting block for location 定位支承块 air cushion plate气垫板 air-cushion eject-rod气垫顶杆 trimming punch切边冲子 stiffening rib punch = stinger 加强筋冲子 ribbon punch压筋冲子 reel-stretch punch卷圆压平冲子 guide plate定位板 sliding block滑块 sliding dowel block滑块固定块 active plate活动板 lower sliding plate下滑块板 upper holder block上压块 upper mid plate上中间板 spring box弹簧箱 spring-box eject-rod弹簧箱顶杆 spring-box eject-plate弹簧箱顶板 bushing bolck衬套 cover plate盖板 guide pad导料块 landed plunger mold 有肩柱塞式模具 burnishing die 挤光模 landed positive mold 有肩全压式模具 button die 镶入式圆形凹模 loading shoe mold 料套式模具 center-gated mold 中心浇口式模具 loose detail mold 活零件模具 chill mold 冷硬用铸模 loose mold 活动式模具 clod hobbing 冷挤压制模 louvering die 百叶窗冲切模 composite dies 复合模具 manifold die 分歧管模具 counter punch 反凸模 modular mold 组合式模具 double stack mold 双层模具 multi-cavity mold 多模穴模具 electroformed mold 电铸成形模 multi-gate mold 复式浇口模具 expander die 扩径模 offswt bending die 双折冷弯模具 extrusion die 挤出模 palletizing die 叠层模 family mold 反套制品模具 plaster mold 石膏模 blank through dies 漏件式落料模 porous mold 通气性模具 duplicated cavity plate 复板模 positive mold 全压式模具 fantail die 扇尾形模具 pressure die 压紧模 fishtail die 鱼尾形模具 profile die 轮廓模 flash mold 溢料式模具 progressive die 顺序模 gypsum mold 石膏铸模 protable mold 手提式模具 hot-runner mold 热流道模具 prototype mold 雏形试验模具 ingot mold 钢锭模 punching die 落料模 lancing die 切口模 aising(embossing) 压花起伏成形 re-entrant mold 倒角式模具 sectional die 拼合模 runless injection mold 无流道冷料模具 sectional die 对合模具 segment mold 组合模 semi-positive mold 半全压式模具 shaper 定型模套 single cavity mold 单腔模具 solid forging die 整体锻模 split forging die 拼合锻模 split mold 双并式模具 sprueless mold 无注道残料模具 squeezing die 挤压模 stretch form die 拉伸成形模 sweeping mold 平刮铸模 swing die 振动模具 three plates mold 三片式模具 trimming die 切边模 unit mold 单元式模具 universal mold 通用模具 unscrewing mold 退扣式模具 yoke type die 轭型模 塑料成形模具 mould for plastics 热塑性塑料模 mould for thermoplastics 热固性塑料模 mould for thermosets 压缩模 compression mould 压注模、传递模 transfer mould 注射模 injection mould 热塑性塑料注射模 injection mould for thermoplastics 热固性塑料注射模 injection mould for thermoses 成形零件 定模 stationary mould fixed half 动模 movable mould moving half 定模座板 fixed clamp plate, top clamping plate. top plate 动模座板 moving clamp plate. bottom clamping plate. bottom plate 上模座板 upper clamping plate 下模座板 lower clamping plate 凹模固定板 cavity-retainer plate 型芯固定板 core-retainer plate 凸模固定板 punch-retainer plate 模套 chase. bolster. frame 支承板 backing plate. supprr plate 垫块 spacer parallel 支架 ejector housing. mould base leg & B c% @8 q0 J) L" k. ?5 k& _
* ?0 J1 R, }& c5 K模具工程常用词汇英汉对照 # F% X5 Z- \: D" q8 Q9 K
! }9 D" e! x6 @( udie 模具 figure file, chart file图档 cutting die, blanking die冲裁模 progressive die, follow (-on)die 连续模 compound die复合模 punched hole冲孔 panel board镶块 to cutedges=side cut=side scrap切边 to bending折弯 to pull, to stretch拉伸 Line streching, line pulling线拉伸 engraving, to engrave刻印 upsiding down edges翻边 to stake铆合 designing, to design设计 design modification设计变化 die block模块 folded block折弯块 sliding block滑块 location pin定位销 lifting pin顶料销 die plate, front board模板 padding block垫块 stepping bar垫条 upper die base上模座 lower die base下模座 upper supporting blank上承板 upper padding plate blank上垫板 spare dies模具备品 spring 弹簧 bolt螺栓 document folder文件夹 file folder资料夹 to put file in order整理资料 spare tools location手工备品仓 first count初盘人 first check初盘复棹人 second count 复盘人 second check复盘复核人 equipment设备 waste materials废料 work in progress product在制品 casing = containerazation装箱 quantity of physical invetory second count 复盘点数量 quantity of customs count 会计师盘,点数量 the first page第一联 filed by accounting department for reference会计部存查 end-user/using unit(department)使用单位 summary of year-end physical inventory bills 年终盘点截止单据汇总表 bill name单据名称 This sheet and physical inventory list will be sent to accounting department together (Those of NHK will be sent to financial department) 本表请与盘点清册一起送会计部-(NHK厂区送财会部) Application status records of year-end physical inventory List and physical inventory card 年终盘点卡与清册使用-状况明细表 blank and waste sheet NO. 空白与作废单号 plate电镀 mold成型 material for engineering mold testing工程试模材料 not included in physical inventory不列入盘点 sample样品 incoming material to be inspected进货待验 description品名 steel/rolled steel钢材 material statistics sheet 物料统计明细表 meeting minutes会议记录 meeting type 会别 distribution department分发单位 location地点 chairman主席 present members出席人员 subject主题 conclusion结论 decision items决议事项 responsible department负责单位 pre-fixed finishing date预定完成日 approved by / checked by / prepared by核准/审核/承办 PCE assembly production schedule sheet PCE组装厂生产排配表 model机锺 work order工令 revision版次 remark备注 production control confirmation生产确认 checked by初审 approved by核准 department部门 stock age analysis sheet 库存货龄分析表 on-hand inventory现有库存 available material良品可使用 obsolete material良品已呆滞 to be inspected or reworked 待验或重工 total合计 cause description原因说明 part number/ P/N 料号 type形态 item/group/class类别 quality品质 prepared by制表 notes说明 year-end physical inventory difference analysis sheet 年终盘点差异分析表 physical inventory盘点数量 physical count quantity帐面数量 difference quantity差异量 cause analysis原因分析 raw materials原料 materials物料 finished product成品 semi-finished product半成品 packing materials包材 good product/accepted goods/ accepted parts/good parts良品 defective product/non-good parts不良品 disposed goods处理品 warehouse/hub仓库 on way location在途仓 oversea location海外仓 spare parts physical inventory list备品盘点清单 spare molds location模具备品仓 skid/pallet栈板 tox machine自铆机 wire EDM线割 EDM放电机 coil stock卷料 sheet stock片料 tolerance工差 score=groove压线 cam block滑块 pilot导正筒 trim剪外边 pierce剪内边 drag form压锻差 pocket for the punch head挂钩槽 slug hole废料孔 feature die公母模 expansion dwg展开图 radius半径 shim(wedge)楔子 torch-flame cut火焰切割 set screw止付螺丝 form block折刀 stop pin定位销 round pierce punch=die button圆冲子 shape punch=die insert异形子 stock locater block定位块 under cut=scrap chopper清角 active plate活动板 baffle plate挡块 cover plate盖板 male die公模 female die母模 groove punch压线冲子 air-cushion eject-rod气垫顶杆 spring-box eject-plate弹簧箱顶板 bushing block衬套 insert 入块 club car高尔夫球车 capability能力 parameter参数 factor系数 phosphate皮膜化成 viscosity涂料粘度 alkalidipping脱脂 main manifold主集流脉 bezel斜视规 blanking穿落模 dejecting顶固模# h- h) P6 L# m; B6 w' l4 M ^
demagnetization去磁;消磁 : @( J' l4 y! x
