查看: 1287|回复: 1
仪表盘振动焊接报告书 [兼容模式]
发表于 2014-7-18 10:23 | 显示全部楼层 |阅读模式
仪表盘振动焊接报告书 [兼容模式]
5 {5 r2 W! B3 q% c. y
Major Check points for linear vibration welding.
: h# d. y  C2 U* E1. Material & Part Manufacturing Process (材料及生产流程) 1. Material & Part Manufacturing Process (材料及生产流程)5 x% m4 w  k! E8 P" v+ X6 `- _
2. Part Size (产品尺寸)9 `4 h7 Y/ N1 [9 Y0 F0 r
3. Weld Interface Design, Weld Area, & Clamp Force
( y9 v* B0 W2 r$ B4 R(焊接筋设计焊接面积压力) (焊接筋设计, 焊接面积, 压力)( l/ h: t! n) b; w1 Z2 X
How to design an energy direct for the instrument panel How to design an energy direct for the instrument panel6 R  ]8 _1 ^4 _$ o- l  V; V+ S- v
仪表台常用的焊接筋结构
+ A9 n: p0 ^; k4 @' f4.Part Sensor/Locator against Part’s Warpage/Shrinkage5 ]% V3 a9 b0 |4 r7 {, f
(产品感应装置及发生产品变形或收缩时固定焊接件的方法及装置)
9 H& [6 Z# t! A' L" u: R5. Fixture Traveling Interface : CAM Sliding/Tilting Device 5. Fixture Traveling Interface : CAM Sliding/Tilting Device
$ d7 e# K1 W; f(治具移动装置: 凸轮/ 下治具板滑动装置)
1 u$ U( ^& s$ ^+ @$ K  u+ {6. Others
' w' }/ t5 Z' G* n9 }2 k: |(其它) (其它)4 H) a3 z8 F; f7 V
7.振动焊接机设备治具有关资料及产品照片7 _( y& f, R; y" U  \0 E
• General Material & Part Manufacturing Process
/ j$ p+ w7 @# n) W# n" T• (仪表盘使用的材料及 相应的焊接工艺)
* }; o% y9 E9 u/ O2 V• Materials for IP : PP, PE, PU Spray, / k: J& C, V1 i& e6 @; F( S
TPO (Thermoplastic Olefin), , T: I7 u6 `7 e$ l- W0 Q
PVCPSMPVCABSTPUPSM PVC PSM, PVC‐ABS, TPU PSM1 d: f3 u8 Q" C. _8 W5 y; i
(* PSM : Powder Slush Molding )! }# y. f# B2 B( ]& p
• Forming(Skin) :  PU, TPO, PVC‐*  : Ultrasonic welding, Heat Staking.
6 Q6 w6 i7 C: {8 Q! wVibrationWelding Vibration Welding: z/ v2 E" J7 m' h
• Injection Molding : PP, PE : Hot plate welding, Vibration Welding.
8 o2 L5 x) d9 D+ m+ s• Vibration Welding:  1) PP + PP
: h& N0 d' c# [! _, W; Z• 2) PP‐TD2 + PP‐EPDM‐TD2 (‐MD)5 t( ~( k1 Z! V
• 3)PC‐ABS+PC‐ABS 3) PCABS + PCABS
) a+ j3 Y+ e3 j2 K• Part Size
+ q9 p: A  p, q4 G, i• : Depend on customer’s design p g
( W7 a) H4 o8 p, i. ^; A4 l3. Weld Interface Design, Weld Area, & Clamp Force
# T/ c/ J6 X& Q( s7 j( 焊接筋的设计, 焊接面积及压力)4 }1 L* ]- x% B! }& K
• Thickness of Part(产品壁厚) • Thickness of Part(产品壁厚)
! [' U0 ~/ k5 D% w/ a* C  a1) IP : 4.0T (为防止产品表面受损)
: C! ]7 f/ I/ g1 z. T9 d8 _2) Duct : 2.5T+ ~7 \/ a. ^9 w8 K' u
• Weld Area(焊接面积) Weld Area (焊接面积)
4 P% U* I  E" V, ?1) Max weld area (最大焊接面积): 830e : 490cm
! F# @% M  k0 _" f3 v, q+ n: P8 N) b2  / 930e : 650cm6 W# X- `  ]. y2 w9 o( D' |6 T: j
+ {) U1 C. q5 u' r) u• Clamping Force (焊接压力)6 w/ F3 _( W! m. A! P
1)Consideringclampingforce per unit weld area(cm! f" Z$ J5 ^% _  H7 C3 D4 q& {- ^
2' w, I) l: A! _" i" A& @- ]9 B
)(根据单位面积所受压力,设定焊接压力) )gpgp ()(根据单位面积所受压力,设定焊接压力)
$ f& W  A$ d0 g( X) G9 I2 w• Weld Interface Design (焊接筋的设计)% x3 t$ h. E8 Q
1) Welding Interface Overlap : Welding area of upper & lower product should perfectly match7 \" C5 P/ v% y5 \! a
each other before welding. (上下产品上的焊接筋在焊接之前100% 能够互相紧密接触
3 b6 k% M2 z; ]  u# B  F+ W
, e" q: X# d' G QQ截图20140718101406.jpg $ c# ]2 J# L* k2 W/ v/ D
  L; `7 A6 g/ @# P7 H  R QQ截图20140718101418.jpg
; W" F; f0 h( X" `- `
/ K) B8 L" [+ V" s0 E* o0 A1 g8 O QQ截图20140718101424.jpg
7 B  T  x( h" H! H0 P3 q1 [1 D, m- _7 x
% i" u# r5 J" A6 _  q) ]+ e! E6 {6 F5 l9 L9 j7 ~( ^8 l
QQ截图20140718101436.jpg 4 p, s3 o; Z( {4 F( |2 d  G
+ n0 w5 f/ k2 ]6 i
1 产品位置的调整:在xy轴上50mm(每个支局模块:+/ 15mm范围内可调整) 1. 产品位置的调整: 在xy轴上5.0mm. (每个支局模块: +/-1.5mm 范围内可调整.)
% X* F& U- g" ?5 \( n2. 侧面夹紧装置(气缸驱动)$ h$ f3 h. _1 a" ^& ^5 R9 r
- To cope with dimension tolerance (可缓解因产品尺寸变化导致的焊接位置不良现象)
; C4 b7 f, q( S& J& h3 ]# V$ [# n-To secure hold a part not to be out of its position (防止产品脱落) To secure hold a part not to be out of its position (防止产品脱落)
, `+ i: C& z" E0 `) o  P3. Center Part Locator : To provide center position (reference positon) (产品放置基准装置)7 B9 W0 ^* v7 d* B# N# b
4. PHOTO TYPE Part Sensor (光电产品感应器
1 c" h9 N& A* I4 Y# G4 t
4 W5 F. V7 _; H1 l) w5. Fixture Traveling Interface : CAM Sliding/Tilting Device: B* z3 K9 d3 g/ N/ O% F& {: g
; I6 r9 {9 L8 K5 L8 m& _•标准的振动焊接机下治具是只做上下动作的;但因有的仪表台形状较有特殊性,5 I9 k" V! b/ W7 W
需要振动焊接治具不但要做上下移动还要做前后移动,此时需要在设备上加凸轮,; t2 {' W- D1 o" M$ g
让治具沿着轨迹上升。 在以下情况需要加凸轮装置。$ @) b- z  q2 u% e
' A9 q( j( F/ q: ~% U# k QQ截图20140718101656.jpg 5 u' P. f1 ~$ n
% t* ]4 v, o  Z+ I QQ截图20140718101704.jpg & I: {4 z- u5 S! X0 u# V8 a
  k; m# T2 }1 Y2 O2 M) W5 i* D: I•不同国家因交通规范的不同,同一个车型方向盘有的是在左侧、有的是在中央、有的是在右侧,5 B8 E$ \# {& L) d6 c0 Q# q$ a" k
可制作这三种公用的焊接工装,可降低成本,而且缩短换模时间,提高生产效率。
! J! C, ]% z- P/ w8 t% P  C7 F
: W5 `1 h" |, g: n  g QQ截图20140718101710.jpg
0 l! N2 Y9 c; U( M, A% l5 N# D; j1 |6 D& B2 u/ P
/ U7 \3 A4 c" T7 Y* w' x2 I' R0 a, s( D8 n. o0 u3 F
4 `. M3 ]7 L7 g大荣公司振动焊接机特点
! C8 s; z. N# z* Y0 R• 1. 频率自动谐振) y3 M3 G# v! y3 w  i7 r5 F6 _" R$ ~
• 2. 可通过人机界面设定焊接条件,及进行机械动作
! A" N3 f' t8 Y0 V' T, m) y• 3. 有深度、时间两种焊接模式
! W% z- Y3 K3 [, v7 p. O• 4. 使用最先进的伺服崩控制液压系统,保证加压力的稳定准确性
3 r& a& J0 S- M' F4 k9 _$ h  }可储存 种焊接条件 • 4. 可储存80种焊接条件5 ^* C3 I, R$ D: w5 v
• 5. 采用单项连线法的电磁线圈(比三相连线法效率提高了30%)$ W4 v" M% v  p1 M' q" X! e
• 6. 可外部通信、可打印焊接数据7 `& e+ p6 j+ J
7可判定焊接质量 • 7. 可判定焊接质量! L5 e' k' b3 A9 z# ?( h0 L6 a
• 8. 多阶段熔接( J$ C9 N3 a- @5 Y, \
• 9. 具有系统保护功能
, v: e0 X2 @. H, F% Y6 }9 e) g2 i
* o/ v; y' {4 x+ L7 R$ y: J2 x+ f8 H) k+ g5 l" P$ o. h2 d
" s5 w1 _3 P8 F( t) g
, z3 P0 f  q2 n' R5 x  L8 Z" n9 Q' D* z$ ~0 g
 楼主| 发表于 2014-7-18 10:28 | 显示全部楼层
QQ截图20140718102446.jpg QQ截图20140718102514.jpg QQ截图20140718102530.jpg QQ截图20140718102507.jpg QQ截图20140718102432.jpg QQ截图20140718102453.jpg QQ截图20140718102440.jpg QQ截图20140718102519.jpg QQ截图20140718102500.jpg QQ截图20140718102525.jpg
GMT+8, 2025-9-13 21:25 , Processed in 0.056541 second(s), 27 queries .
