查看: 2059|回复: 6
[疑难] 用C#语言编写一个调用装配图各零件装配关系的程序
发表于 2014-9-25 10:31 | 显示全部楼层 |阅读模式
悬赏200G币已解决
小弟急需做一个用C#语言对ug二次开发的程序,目标是从UG数据库调出装配图各个零件的装配关系,求各位大侠帮着编个程序,谢谢了9 `4 s0 X  s4 [0 j' N
最佳答案
查看完整内容
public class AssmTree (){ private static Session theSession; private static UI theUI; private static UFSession theUfSession; private static ListingWindow listwindow; private static Form AssmTreeForm; private static TreeView PartTree; public AssmTree() { theSession = Session.GetSession(); theUI ...
本帖最后由 danyfer 于 2014-10-17 21:26 编辑 , }+ \' A6 K2 V% Q& U
% N5 Q9 a2 a" q7 P+ W
public class  AssmTree (){              private static Session theSession;- P# ?/ f3 e% R0 N/ \
. N0 a! s. G% {) L* d        private static UFSession theUfSession;
! b3 u2 p! a1 w        private static ListingWindow listwindow;9 H+ w0 ?  U9 h* P( g) W4 g! N
: s8 N+ E: L$ q6 D: w" P        private static Form AssmTreeForm;/ r) z, }7 c7 B8 t- W: O
        private static TreeView PartTree;7 i4 ?2 O" j. i
( x: i' R0 g2 e! ~% I5 @
) W  i: ~0 F9 D. e7 w# j  [$ ]        public AssmTree(), U$ N, Q3 y7 @( E- O8 ^
        {8 K4 P2 T( Q' O7 x; x
            theSession = Session.GetSession();7 A% O% y4 i. J. P/ g' D7 G
            theUI = UI.GetUI();% X' w! T8 F- d
            theUfSession = UFSession.GetUFSession();
% e/ k* p- P0 Q) X. h" N            listwindow = theSession.ListingWindow;
1 t" y: t3 t. R. ^% C* ]            listwindow.Open();           % q+ A4 @! t3 S2 _" {
+ G0 v, E* M7 _0 n  e4 i/ C
            AssmTreeForm = new Form();, m& S5 H+ [4 ?; C9 d$ e( ~- w/ ?
* b, n* w  J- a
            PartTree = new TreeView();
. k& o1 {1 _; @            PartTree.Parent = AssmTreeForm;: q4 c2 d& r/ H8 I' O- O7 y
            PartTree.Dock = DockStyle.Fill;
% Q* p9 V( h1 G7 T9 @        }8 S* a2 m* y/ @& D3 z! S3 G
public void GetAssmPartTree()
6 |  }9 U1 R; O8 E+ N        {
2 o' }& |( u7 T9 C9 A4 i            NXOpen.Assemblies.Component rootComponent = theSession.Parts.Work.ComponentAssembly.RootComponent;
6 F% A, {7 l6 B5 D9 v
9 d* z& N- b# i7 b& A            TreeNode parentNode = new TreeNode() ;5 q1 V2 K! S/ X% \
            parentNode.Name = rootComponent.JournalIdentifier;
$ G* R' u# b- Y( ?  \1 {+ T            parentNode.Text = rootComponent.DisplayName;* M6 O( M% ~) O) c) F/ E( Y8 l' H
            - g! J# f2 B6 W7 o
            PartTree.Nodes.Add(parentNode);
; G9 n/ v+ P& o- b            getSubComponent(rootComponent, parentNode);% w4 [% h( p' K1 G. ]7 P3 q6 i
3 }2 ?5 v' |4 X4 V( E' }
            AssmTreeForm.ShowDialog();
6 ?; {9 r. o( N' y, ?        }* h5 K" T5 ?- _: R
" S1 E  z- Y. X% h
        private static void getSubComponent(NXOpen.Assemblies.Component ParentComponent, TreeNode parentNode); b9 v, f% z. S3 K9 h( R3 Q; \
! Q% p- c* A( W; t+ ?# o            NXOpen.Assemblies.Component[] sub_component = ParentComponent.GetChildren();
  Q/ ^) I% C6 g( t; ?            foreach (NXOpen.Assemblies.Component comp in sub_component)+ U  ?4 H* z3 Z+ h* E( F9 k
            {6 c4 m5 ~1 G. T
                TreeNode subNode = new TreeNode();( y* k8 Y! j$ F# C
                subNode.Name = comp.JournalIdentifier;
3 G! b6 m1 y) k$ w                subNode.Text = comp.DisplayName;
: ^# U6 h. {! k+ |                parentNode.Nodes.Add(subNode);
" r9 `8 o2 q1 w                if (comp.GetChildren().Length > 0)$ s0 v& t9 y% A2 {& t  m/ @1 d; ]
  ?6 i1 T6 ^+ M0 R& E: M( R                    getSubComponent(comp, subNode);
5 F: M; z! R/ N+ v  i! z4 H                }/ }( r+ a4 s0 c4 _5 y/ ]
            }4 K) Q: Y( o- T) K( q5 o1 _
            ParentComponent.Blank();9 ?  O8 d2 L8 I: ~
            int sub_num = sub_component.Length;% X" `. z# a/ a3 ~4 Y3 h0 ?! U6 Q
. g( X- Z6 s# T1 S}
( @% k- S* ]; d! z. O3 J7 A# u" E
回复
发表于 2014-9-26 06:05 来自手机 | 显示全部楼层
支持一下…………
回复
 楼主| 发表于 2014-9-26 09:24 | 显示全部楼层
danyfer 发表于 2014-9-26 06:05! L( G" ?% L2 ?- l3 H3 w' t  C
支持一下…………
5 T% P$ F# }( V" C) c0 K$ T9 ]谢谢,能帮着编一个这样的程序吗?7 w* _4 n: O! S" z
回复
 楼主| 发表于 2014-10-3 19:42 | 显示全部楼层
danyfer 发表于 2014-9-29 13:18
+ p- U5 H" c! Nprivate static Session theSession;/ O% w* c" Y, k5 X6 O- X1 C
        private static UI theUI;4 K/ {' ^( h0 D
        private static UFSessi ...
% l9 X5 n, G1 g7 \5 g. p. {太感谢了,我试试% `9 N1 T: m. ?# x# L' e
5 y( a6 |' `3 O2 [# O: _
回复
发表于 2014-10-23 21:49 | 显示全部楼层
楼主的话真如“大音希声扫阴翳”,犹如“拨开云雾见青天”,使我等网民看到了希望,看到了未来!
回复
发表于 2018-5-9 15:34 | 显示全部楼层
5555555555556666
回复
GMT+8, 2025-9-15 12:54 , Processed in 0.054784 second(s), 20 queries .
