查看: 1081|回复: 0
[疑难] 请教如何在待刀指令前添加 / 符号
发表于 2014-9-25 10:40 | 显示全部楼层 |阅读模式
如下图所示效果,在待刀前面增加斜杠符号  P5 ]1 V+ B! L0 ?; }5 r
: V9 J5 C" f# I- o QQ截图20140925103301.jpg
5 R6 {; y8 g9 ]0 i* y1 M
" {! T; v: z$ Y  K; c" q9 U# J! i4 c5 Q" a
3 T- y4 z4 A2 \3 }/ x因没有PUI文件,只能在TCL文件里面改,我关了 MOM_do_template tool_change_2这行就没有待刀指令输出了,但就是不知道怎么添加 “/”符号,有哪位知道怎么改的请告知。如下红色字体所示/ h" l" I5 b2 {
- [/ Q( }0 G, _, w/ Q% T0 d& t% g#=============================================================
/ \) z# O+ o6 I- Qproc PB_auto_first_tool_change { } {0 }6 z7 m2 t: ^; i$ \+ h( }
#=============================================================& V  R7 P5 J- z. }4 Y& M3 C5 [
   global mom_date6 @& U& f1 g, c
   global mom_tool_name
- J8 X% H. D( b: K7 h   global mom_part_name2 v  n1 J8 t# {2 W3 p
   global mom_output_file_basename
* q  C& K4 X; T, }; Y' D   global mom_tool_diameter mom_tool_corner1_radius
. i/ k: ^- b/ Z& M& L- l8 f   PB_CMD_tool_change_force_addresses
- A- g0 F4 \0 p, Q3 _4 a  f   MOM_output_literal "%"
8 {2 `4 R0 A) U" d: ~* `   MOM_output_literal "$mom_output_file_basename"# o& H9 Q3 V5 S& c; t* ]
#  MOM_output_literal "O$mom_output_file_basename  ($mom_part_name)"
: s. S) x7 ]( n2 r( I# Q#  MOM_output_literal "($mom_date)"   8 H0 ]/ s" R. \7 B+ R
#  MOM_set_seq_on
, T5 @0 {" F" s& O; X7 N$ W( Y& g   MOM_output_literal "($mom_tool_name)"
$ R+ V( K1 G6 B2 _/ a! D#   MOM_set_seq_off+ g8 v5 Q* {# j- x7 f
#  MOM_output_literal "(D[format "%3.2f" $mom_tool_diameter] R[format "%3.2f" $mom_tool_corner1_radius])"
+ a+ ~* w; F" \4 a0 }( r7 a#  MOM_output_literal "G91 G28 Z0.0"
, e1 J, R! u0 b2 q" z# MOM_output_literal "G28 X0.0 Y0.0"- s2 Y' Q. K: C3 ?; a# |
   MOM_force Once T M
+ {& H# X( L0 {: V, T* A! @   MOM_do_template tool_change_1
; X" _7 A6 G7 M   MOM_do_template tool_change_2    + C- D  M! f; Y' I5 y% H
   MOM_force Once G_mode G$ }' c, X: b& B  e
   MOM_do_template auto_tool_change_1
) c5 m7 q2 o3 L! u% w6 P$ [# MOM_do_template from5 Z. l8 p. O$ {; K' e
# MOM_do_template auto_tool_change_2
7 t& p5 y8 ]3 ?; X) m   MOM_do_template auto_tool_change_3
( m$ ^- z! g4 L( i# e* U$ {   MOM_force Once S M_spindle
1 J2 @) H$ c: ]( S" e0 {7 `# ^   MOM_do_template spindle_rpm
, D! ~- T) L: M7 k: ~- G9 T/ X) c   PB_CMD_excel4
* Z6 E+ G1 j: p& _" E7 @, g' @9 D. k0 K; F- s3 ?
}* M' v5 d2 P+ F6 k. |- O7 j
6 h; k* S) `! w, @! y+ \#=============================================================  b' c& q/ t  x- O
proc PB_auto_tool_change { } {
* r, b) }- E% A#=============================================================
! N& Y5 H1 Q! x   MOM_do_template coolant_off" t' f1 u; g' ]' x
   MOM_output_literal "M05"9 U) q) C9 J& V$ `+ T# X  ~+ k
   MOM_output_literal "G91 G28 Z0.0"# x+ E% Y3 ^- _( s0 f+ e
#  MOM_output_literal "G91 G28 Y0.0"- C& `$ R& Q& D# U0 n4 ?  l
   MOM_output_literal "M1"0 l8 m0 a9 J' `, P
4 d) O/ }0 u4 N$ c" L1 f   global mom_tool_diameter mom_tool_corner1_radius6 q+ q& Q8 ~' y& y& m. C  c
1 O/ B6 e/ |6 H( s, e+ s5 g#   MOM_set_seq_on' J+ f# ?' X" O. L# @
+ `5 O2 n9 \0 t9 j2 X8 a  w#   MOM_set_seq_off) e+ w  @" Q  g( ~$ w$ u. N6 i! i# W
#  MOM_output_literal "(D[format "%3.2f" $mom_tool_diameter] R[format "%3.2f" $mom_tool_corner1_radius])"& j, B$ [* m4 B2 [$ S; U  B/ @: r
' q+ ~/ r' K$ M0 y#  MOM_output_literal "G28 X0.0 Y0.0"- n- w, t% d, i0 S  j& E) u
   MOM_force Once T M
, D* \( v0 L! K   MOM_do_template tool_change_1
1 r* E) A4 u5 B$ g0 ~8 |   MOM_do_template tool_change_22 T6 }6 L2 X9 V; S
- C6 o" W# [% ~3 B: ^5 W   MOM_do_template auto_tool_change_1
5 ~, a( Y9 T- F( T! b0 d, B$ O #MOM_do_template from
  v/ w$ G- p+ w+ f! i #MOM_do_template auto_tool_change_25 Y+ J/ V+ t9 ~* n+ p' ]
   MOM_force Once S M_spindle+ f. O1 M# Z/ K2 A
  O# _! G( p* j- t& r/ `   MOM_do_template auto_tool_change_39 a. s4 x' V4 {: g5 R' N5 Q
   PB_CMD_excel2
9 I$ T7 I0 j) _. E   PB_CMD_excel4" J% }0 R2 e& T4 I* J
/ M+ o5 F& y# `1 `* G. K- [7 j% J3 M0 F3 F7 x1 ?7 r) Q) R
GMT+8, 2025-5-1 08:23 , Processed in 0.056816 second(s), 23 queries .
