查看: 3513|回复: 11
[疑难] 想后处理出来D的出现取决G41 G42 其他位置不要
发表于 2014-10-28 10:09 | 显示全部楼层 |阅读模式
这是我,D修改为非模态出的程序- q8 u  p! `* n1 r- g. Z& A
! E% l/ W) p8 P& i! M/ `  _/ tO1234(1)
- @. ?% x7 C2 ]* B# q. X" C/ B; ?(Creation Date: Tue Oct 28 03:15:13 2014)
: d, g! h* n' o- Q8 @2 E6 q(Machine Time = 2.71 MIN)
8 X1 }8 F- u9 \4 W8 ](X-max: 0.000)  (X-min: -200.000)" ?0 R. E( c5 W( i
(Y-max: 76.258)  (Y-min: -140.000)3 n2 y) f0 B+ N( S/ O
(Z-max: 13.662)  (Z-min: -10.000)2 [% Q1 Z+ `" ?$ r6 ]" x" u
G40 G90$ ^1 b/ ]) ]& C
G54
% `5 l7 n1 [( D4 w" h, o. ZT01 M06$ i( v0 d4 G. Y; [8 J
(Tool=20P DIA=20.00 R=0.00 T=1 H=1 D=1 L=75.00 FL=50.00)9 Z% O6 `$ V6 e! M0 b2 }' a3 J
/G05.1 Q1: i/ h6 \8 Y' H4 s
G19 G00 Y-125.076 Z-9.132 S1000 M03  S" F+ ^& B! g! r! z' X6 [+ K0 Q0 p# _* P
G43 X-200. H01/ A* X  {  o' a/ b% k  M+ j+ R
X-3.  V8 C2 ?# U# @8 p7 S3 K
N0001 (side stock=0.0000)# J. s: L4 b- F
(floor stock=0.0000)! V2 D. @' `: l
G01 X0.0 F250. M08
4 }7 n& r/ }5 r  LG41 G19 Y-130. Z-10. D01' ]6 @4 m9 X" \" R% u
G02 Y-140. Z0.0 J0.0 K10.7 m$ n' O# N1 o5 ~1 r$ O! i
J40. K0.0( l- c, X& R( w: x* p+ U; l4 d) A( `
Y-139.688 Z4.987 J40. K0.05 [  N) ~; c+ n; a
Y-128.519 Z13.662 J9.922 K-1.247. z) f( U0 e" G1 E' Y& V
G40 G01 Y-123.742 Z12.187 D01(这里的D1去掉): W3 O. ^4 C; D6 ?
X-3. D01 (这里的D1去掉)3 w6 |) n1 _  `! ~
G00 X-200.+ V; n8 _7 U+ i& m; I
Y74.924 Z-9.1326 l+ l5 ]9 c1 i; V! p, X; p& B
X-3.2 N3 m& K# g: L: t% C9 r( O
G01 X0.0 D01 (这里的D1去掉)8 ?  p" w( c) U1 k
G41 Y70. Z-10. D018 W# J; L! n6 ?/ ^: H" E
G02 Y60. Z0.0 J0.0 K10.4 t9 O/ J! y! B, Y# K; {: E0 n
J40. K0.0  q8 ^- i$ `8 K5 J6 r& D" }% s. |
Y60.312 Z4.987 J40. K0.0; w' c$ a6 o) u7 @9 p% B
Y71.481 Z13.662 J9.922 K-1.247
8 I9 J' b# _" G/ }G40 G01 Y76.258 Z12.187 D01(这里的D1去掉)- z2 J3 W% D* `, T
X-3. D01 (这里的D1去掉)
5 a1 r: I, P+ M! [% Q- g/ AG00 X-200., f9 N5 u8 e* C3 z( L% e8 ~
/G05.1 Q04 s; j( l8 e8 q7 N0 F( L- Y& _
M30# c5 ?9 W; \# ^3 z; n, i7 q
%: g! j5 ^" y6 i8 w
我未修改之前的7 b( c8 m2 J* w- K  p
%+ p( }: N& s8 K: ?
O1234(2)
1 i) X! c( {, f. ]$ S(Creation Date: Tue Oct 28 03:18:39 2014)
" a9 @; T8 h  Q" }$ R( w5 i(Machine Time = 2.71 MIN)
+ F! p) }0 b3 r7 Z' }(X-max: 0.000)  (X-min: -200.000)
6 v' S" Q# P8 m8 M(Y-max: 76.258)  (Y-min: -140.000)
/ k4 M; K) @+ U$ n(Z-max: 13.662)  (Z-min: -10.000)# Y" K' h/ l6 F( t) \" @
G40 G90) q" f! \6 |/ |4 D& U; X) F" M8 k% {5 v
G542 F+ ^3 f* V5 _1 e# c
T01 M06
' ?3 F3 O' H4 R/ `5 R% q(Tool=20P DIA=20.00 R=0.00 T=1 H=1 D=1 L=75.00 FL=50.00). J- B/ e9 k! i" g; K5 }
/G05.1 Q12 A- S% F  y: H
G19 G00 Y-125.076 Z-9.132 S1000 M03; k6 Z/ _0 L/ E0 p# k% b/ J
G43 X-200. H01
7 u. B; H  X+ L6 V7 |$ kX-3.
! I4 ]" |6 p  d, d8 WN0001 (side stock=0.0000)9 m( h. q3 g* u1 c) u
(floor stock=0.0000)! b0 w# C: W' V( e: f  d
G01 X0.0 F250. M08
: V6 ?+ m  v6 h9 M" CG41 G19 Y-130. Z-10. D01
: i8 w; I$ ~# @G02 Y-140. Z0.0 J0.0 K10.2 i2 W8 x7 g6 p1 u# C$ f% c
J40. K0.06 A. L3 L' t3 W
' C$ ?' n9 ]$ H: X- s. G9 YY-128.519 Z13.662 J9.922 K-1.247
, G5 A- J* N) T- v' J. AG40 G01 Y-123.742 Z12.187
6 L: L9 P; ^8 w+ r- FX-3.; P$ B* K: u6 H0 b! q/ k+ e. C4 [
G00 X-200." N. h5 ]: U0 D6 Z! \$ g, h9 Z
Y74.924 Z-9.132
4 y7 Q( }: s1 Y1 ~X-3.
& K* G0 n" k: O* u( M8 `% t+ ~G01 X0.0
, W' c$ F# Q1 H' `# Y0 hG41 Y70. Z-10. (想要的效果在这加D1)# d# H5 P: H5 I. `5 m
0 U$ \6 b/ o% ]' R5 kJ40. K0.0( I+ q4 [( U/ U0 j) Y
1 o4 U: Z( M) ]$ T2 z' l6 g) Q8 z) @Y71.481 Z13.662 J9.922 K-1.247
- y7 c9 }" z1 b. |. uG40 G01 Y76.258 Z12.187) V4 ?" Z/ Y6 f# g9 q$ U: d; c' L
X-3.
3 H% b8 @, ^5 f4 L; N2 `G00 X-200.* z' Z: n8 ^+ U) e1 Q. S
/G05.1 Q03 V9 {3 f1 `9 @" Q3 X0 g8 X
M30- W1 |/ ]/ _6 `( T$ l  f3 s+ b
6 g& V8 U+ L  N% {2 H
 楼主| 发表于 2014-10-28 10:33 | 显示全部楼层
有人看没人顶 不 沉了吗?自己顶一下
 楼主| 发表于 2014-10-28 10:37 | 显示全部楼层
高手在哪里,
发表于 2014-10-28 12:21 | 显示全部楼层
那能改模态 ,数控机子 ,只要出一次D,会一直在起作用的,只是不好看,去写个块
 楼主| 发表于 2014-10-28 13:24 | 显示全部楼层
模态是可以用,就头次调用带D 其他都不带,当下次调用的时候直接在寄存器里读取,我这让他添加是为了方便从中间段启动时防止出错
 楼主| 发表于 2014-10-28 13:26 | 显示全部楼层
看样子 解决不了了 就模态吧出一个
发表于 2014-10-29 20:00 | 显示全部楼层
翻翻老帖!
: G) i7 O1 e* d. Q+ @4 P9 ]+ W或試試:"MOM_force once D"
 楼主| 发表于 2014-11-1 08:11 | 显示全部楼层
Yeager 发表于 2014-10-29 20:009 S$ F; f$ V  B
翻翻老帖!
3 o5 S+ G' Z+ T3 W+ m+ o或試試:"MOM_force once D"
0 m$ a# ?7 [% S谢谢,按照你的方法解决了,我是新人老帖找起来有点费力
7 x9 r) t$ F$ M%
" L4 x/ U3 C/ a: ?O1234(12)
  m. l' z  A! a* v(Creation Date: Sat Nov 01 08:00:14 2014)- P$ H/ {, C2 q4 R1 z
(Machine Time = 1.33 MIN)9 u0 f7 m4 F0 ?, E: ]0 K
(X-max: 10.576)  (X-min: -10.000)
/ O* a1 k$ E2 ^& E2 i& D(Y-max: 10.000)  (Y-min: -10.000)5 w, U# Y( `5 i1 l) }1 Y/ i; e
(Z-max: 223.756)  (Z-min: 30.000)
" Q: k/ C9 v. w. [7 CG40 G90
) f" Z# i  G9 mG539 [- }& z; j' F6 j/ _, D; D
T01 M06
" I  o0 X3 q% V. y/G05.1Q1! e  z: N1 H. o5 r
(Tool=10P DIA=10.00 R=0.00 T=1 H=1 D=1 L=75.00 FL=50.00)
+ S2 Z1 _- \. L0 j( n9 i" iG18 G00 X-9.566 Z42.462 S0 M03+ Q6 U$ V  E9 `, s3 y+ d
G43 Y-10. H01
# G6 ?5 d7 x/ TY7.
7 d- }$ Y! z* F6 O2 K. j+ [N0001 (side stock=0.0000)- `. z" G& t9 A4 C
(floor stock=0.0000)/ D) \7 U" q: h' ?' @# |8 x3 D
G01 Y10. F250. M08
% [% y; u0 L4 s# v, eG41 G18 X-10. Z40. D01
2 ^4 _5 S5 Y4 L( G7 PG02 X0.0 Z30. I10. K0.0
1 ^; W7 b2 r+ ~: T9 l0 [' c9 vI0.0 K15.
4 J0 A2 C8 C8 {, o) W: YX1.994 Z30.133 I0.0 K15.
! }( @7 j* r& c$ X  D* G. LX10.576 Z41.374 I-1.329 K9.911$ i0 b6 y' _# n; r" Q7 a
G40 G01 X9.818 Z43.756
7 F) d' B4 k6 U% c* d+ _Y7.
" p! \* u9 o& M3 p$ y2 G1 `( LG00 Y-10.
5 O3 D! X% d* Q% C8 C4 [- iX-9.566 Z222.462
4 d; V' J1 P8 B' CY7.  u3 ?! L3 s# _/ q: Q
G01 Y10.- ]% c* M5 f- s8 m
G41 X-10. Z220. D01
# |$ {8 M/ w6 ~& I2 `G02 X0.0 Z210. I10. K0.0
: G1 s) f* o. E  D4 m2 u2 II0.0 K15.! a( V  ^4 E+ [* Z4 l' t* ?& N
X1.994 Z210.133 I0.0 K15.
" r8 E8 @. ~( i8 L9 M( l- w: RX10.576 Z221.374 I-1.329 K9.911
3 y9 e5 `7 `$ p% _G40 G01 X9.818 Z223.756
2 D. |6 E2 r# f2 B7 G* IY7.
: K% ?: D9 c- O7 a3 lG00 Y-10.3 A" `) B: n' t2 U( [9 ]
/G05.1Q0
) g$ W1 M5 i& IM30: i7 H* t( x- i
9 @2 i8 F9 D4 M2 l5 W* N
发表于 2016-8-4 17:56 | 显示全部楼层
这个我可以解决,QQ280387710
发表于 2016-11-10 12:44 | 显示全部楼层
Yeager 发表于 2014-10-29 20:00* N1 A. O# q: h) O; r3 ]$ t
翻翻老帖!
* f$ s4 h! [8 [5 c; k: x& x5 G或試試:"MOM_force once D"
3 _' ~7 e' m. D' w% F你好  老帖在哪里 我没找到,   请教详细修改教程( g& F- M; f/ u/ H* T4 }: O7 b
GMT+8, 2025-2-19 06:45 , Processed in 0.084932 second(s), 22 queries .
