// TODO: 在此添加控件通知处理程序代码
9 d" ]+ a3 m3 a6 O int num_views;
. g) R/ Z7 V; [. T" U, u" B char message[MAX_LINE_SIZE + 1];
+ ~+ V5 }% K$ z1 Y7 j/* 定义图纸变量*/ ' e8 W' D8 S1 C0 H4 d6 h0 {, i
char drawing_name[MAX_ENTITY_NAME_SIZE] = "my_drawing"; 3 }' i! ?/ H* Y6 G
UF_DRAW_info_t drawing_info;
" Q9 x+ H% v! p$ h [. R1 x tag_t drawing_tag = NULL_TAG; % }. h8 Y% \" p8 q. Q9 {6 t! L+ b
tag_t view_tag = NULL_TAG;
5 o+ c3 H3 t9 M$ u7 X4 l/* 定义前视图变量 */
+ y2 b. c! c- q$ A tag_t front_view_tag = NULL_TAG; 1 k5 T3 [# }) `6 l, b
char *front_view_name = "FRONT"; # H( o1 Z3 ^: t5 t! W- \- x
double front_reference_point[2] = {210.0, 400.0};
5 X0 ]2 y! ^; r/ U7 u: X" ?8 T/* 定义轴测视图变量*/
8 y0 m/ v) H/ R1 K tag_t tri_view_tag = NULL_TAG; 6 }* K- I" `1 J4 Y+ L1 w1 P {, r0 N
char *tri_view_name = "TFR-TRI"; - T" S J1 f6 R" ]; t6 m& C- s; x. K
double tri_reference_point[2] = {630.0, 120.0};
3 C2 r3 o7 f# x& J ' s! ^ V5 s- `/ T1 e7 t/ s) ^- ?
/* 定义俯视图变量*/ 5 F. s* F' G6 c% s j
UF_DRAW_proj_dir_t bottom_projection_direction = UF_DRAW_project_below; ( l% r) X4 E, N3 R- a
double bottom_reference_point[2] = {210.0, 120.0};
+ H( ` H0 W0 R; z2 M, F+ L" Q tag_t bottom_view_tag = NULL_TAG; 0 s/ @- N" |9 b! C$ i
/* 定义左视图变量*/
+ M8 A3 { N6 k7 X! m( n8 P UF_DRAW_proj_dir_t left_projection_direction = UF_DRAW_project_left; % \5 b) \: N+ x6 p7 O4 L. N6 K4 g5 X/ K
double left_reference_point[2] = {630.0, 400.0};
. W) m3 V0 |5 D8 i tag_t left_view_tag = NULL_TAG;
& f- A" a0 ?1 x! `/* 创建并打开图纸*/ : p$ T, N" g9 H5 D# J
drawing_info.drawing_scale = 1.0;
z- r1 n6 r" @+ w }/ Z drawing_info.projection_angle = UF_DRAW_THIRD_ANGLE_PROJECTION; 9 N+ `4 \- W2 \/ z
drawing_info.size.metric_size_code = UF_DRAW_A1; $ I1 M* m, x6 O3 D7 U
drawing_info.size_state = UF_DRAW_METRIC_SIZE; 0 ?, X4 C% p+ q% x7 P+ w
drawing_info.units = UF_PART_METRIC;
, T2 a3 `# K, [ UF_DRAW_create_drawing( drawing_name, &drawing_info,&drawing_tag);
' p b: l1 N$ ? UF_DRAW_open_drawing( drawing_tag ); ; v% u- W- l# B8 C
/* 设置视图参数*/
/ }7 w+ Z" O- [8 I1 q: c, J3 Y UF_DRAW_view_info_t view_info;
! ?9 c1 ]. p# d UF_DRAW_initialize_view_info( &view_info );
/ A2 [* k! a* ]8 Y# o view_info.view_status = UF_DRAW_ACTIVE_VIEW;
7 z; l) w8 n7 m view_info.anchor_point = NULL_TAG;
/ Q, |- A' H9 S- C: T* t view_info.view_scale = 1.0;
6 O1 ~& s5 W% v- n7 m2 K view_info.use_ref_pt = TRUE;
1 V& z+ A$ j: I( }3 b view_info.inherit_boundary = TRUE;
( E: Y/ N) ^4 I' U3 z7 J! R/* 创建前视图*/
1 t2 U+ v0 o" U UF_OBJ_cycle_by_name( front_view_name, &view_tag );
: y: y7 W, X ^if( view_tag != NULL_TAG )
) N4 h- z& f6 V( F& [5 R{
+ H$ d( ?$ K( G7 u6 p1 b2 x4 R UF_DRAW_import_view( drawing_tag, view_tag, front_reference_point,&view_info, &front_view_tag ); # A4 d$ b+ o, X* v& V5 K9 [
UF_DRAW_define_view_auto_rect( front_view_tag ); * y$ W- p [$ F x E
- b( v' f6 m: i% u$ T+ }7 Vview_tag = NULL_TAG;
7 w) Y5 S! |1 M' ^/* 创建轴测视图 */ ; b7 q, c6 ^8 \* [: J
UF_OBJ_cycle_by_name( tri_view_name, &view_tag );
2 n% {: m4 l1 `" Qif( view_tag != NULL_TAG ) " ~# \3 }4 i+ p+ m
{ , r" Q( f# E* k, X! O, {+ |' A, y
UF_DRAW_import_view( drawing_tag, view_tag,tri_reference_point, &view_info, &tri_view_tag );
4 O+ J1 Z$ I1 |" S UF_DRAW_define_view_auto_rect( tri_view_tag ); % v0 O5 B/ K; s- M$ w$ r- S: R. d
} - [+ d: D+ X1 w' X' H2 W, Q
/* 创建俯视图*/ % l* w- ^; p( i* Q7 i* |
if( front_view_tag != NULL_TAG )
$ r" F9 E' S) v7 w1 a3 c& Q$ H { 3 ~) G. d1 A2 J7 S. C
UF_DRAW_add_orthographic_view( drawing_tag, front_view_tag,bottom_projection_direction, bottom_reference_point, &bottom_view_tag );
) \4 K7 ?1 l3 q& L0 Q UF_DRAW_define_view_auto_rect( bottom_view_tag );
' d- i7 z6 c E( p& A3 q2 n# ?8 G }
( q6 ~! E$ ~% u1 l( k" C: A" }/* 创建左视图*/ ; C1 Q% N& P( ^' `, f4 k- E7 a
$ ?% C3 d" X% A1 D- j6 o+ k if( front_view_tag != NULL_TAG )
8 k+ V. ?- h, F2 k( ~ { 2 [- q. _% a2 `, j& X
UF_DRAW_add_orthographic_view( drawing_tag, front_view_tag,left_projection_direction, left_reference_point, &left_view_tag );
+ p" a" o; G m+ z0 [ UF_DRAW_define_view_auto_rect( left_view_tag ); 3 Z k6 F/ v3 j, n
} ; y6 ?! s8 P4 n. o6 } {, m
/*查询当前图纸的视图个数*/ , f. v6 k+ \6 p$ K7 }# p/ C, {
UF_DRAW_ask_num_views( NULL_TAG, &num_views ); : N4 @* I7 Y3 \4 K; C
UF_UI_open_listing_window();
. W1 r" K; b9 z. Usprintf(message,"当前图纸共有:%d个视图。", num_views );
3 ~$ F; p1 P+ a: V9 nUF_UI_write_listing_window( message ); |
