This command is provided to overwrite the system RAPID_SET7 T2 v( s% P F8 @
# (defined in ugpost_base.tcl) in order to correct the problem) C( _) y6 `! a6 x; j
# with workplane change that doesn't account for +/- directions" m, M% f8 i! E* A W& p0 y' Y
# along X or Y principal axis. It also fixes the problem that5 C2 \% u' J# t" l/ b. w
# the First Move was never identified correctly to force( G# I* q6 U; @% m0 |' Y5 J
# the output of the 1st point.
( j7 I7 b/ e7 D6 P- y5 u2 O8 G0 p, l( C3 L( b: r% {+ z
