/ ?' d+ n! @# L5 G2 y$ Y! a9 m2 ~$ q
为什么程序中红线句子运行出错,,提示为Unkonw feature type,,,是哪错了吗?求大神知道啊# w' ]) P' U6 r: U. h4 w
#include <stdio.h>
' ^, t, _. B7 k; h3 ^' e( R#include "afx.h"
+ c# X3 `- `9 Y y- m#include <iostream>$ i7 k L) k/ {& @% q6 F* W
#include <uf.h>( q; H0 [: Y, ^: ~
#include "uf_part.h"+ |* ~2 {# \; G# z3 F% q) Q
#include <uf_attr.h>8 z0 [% K' f- e5 i7 t2 K
#include <uf_ui.h>7 `: `& Z5 M8 c7 ^5 r1 N" y9 h
#include <uf_obj.h>
0 H, [( r4 ^5 i- `#include "uf_modl.h"5 b& c5 L. k) \$ g% t5 E
#include "uf_weight.h"4 j" m9 P# O: y- Q w
#include "uf_modl_types.h "* K3 r5 ]; K& e: X) g# \
# Z" f/ f6 L( I9 Y* ]7 f* m
using namespace std;2 ?/ e- U/ |' |5 H; [# T5 F
3 M* J( k9 @ l1 e1 m0 K+ w#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
; _" r# C Y' n7 O2 ~7 Q1 S5 P+ F6 |4 u" U
static int report( char *file, int line, char *call, int irc)/ J% C E& m$ Y) W
{' P8 G0 ]" j' ]6 j& X w
if (irc)
) s2 z+ R0 N/ [ {
# b* W+ m* L( S! w+ C char messg[133];2 X7 \. g6 G! ^, y$ r8 Z7 ]1 U
printf("%s, line %d: %s\n", file, line, call);
3 d$ B) ]- Y* [9 w! c! ?& a* N& P# X/ X (UF_get_fail_message(irc, messg)) ?
5 W5 r! O( w: P printf(" returned a %d\n", irc) :
* j1 H7 i5 r+ ? printf(" returned error %d: %s\n", irc, messg);
w3 w; _/ Z8 m& z }
+ Q6 L% Z9 x4 `# M& l return(irc);' `* C5 i6 M* b
3 @% Z( r9 p5 ^3 o2 X$ m2 Q8 L8 ^3 _% l& b" Y
int main()+ s4 F% `; b7 G4 n0 M! v
k G& `6 [3 h& L" P int nRetCode = 0;
' G+ a5 ?4 `* G' r int rcode;$ S& _: u8 R: z* X" Q
CString partName = "e:\\a.prt"; //此处为创建block的全路径名
" h/ j8 ^1 X* r tag_t partTag = NULL_TAG;& V! _+ `) \ ]/ G( U0 y0 z
tag_t attrTag = NULL_TAG;
. f- W: |) v- @ tag_t obj1 = NULL_TAG;
. x" y% s2 a2 i% ]5 K% b tag_t obj2 = NULL_TAG;3 X3 d0 ?6 H6 [* X: W) O8 r0 A
UF_PART_load_status_t error_status;. _; f2 g0 ?3 ]* F2 d3 W
4 L* e$ n# v8 \7 A1 Q3 ^8 ?
// initialize ug and print and error on failure9 {& V5 ~# p) r1 f% w- g/ X
rcode = UF_initialize();/ Y: m: i. f, N* O. ^
- _& h# Y! \8 P if ( rcode )
$ i4 K+ S& P8 N. e2 ^0 A: T+ S {
' j4 g6 e& h, A/ j. y+ l // TODO: change error code to suit your needs7 i6 e6 h: R2 f( n/ K5 {
cerr << _T("Fatal Error: UG initialization failed") << endl;. ?$ L' a5 Q/ w5 w" F* O5 t O3 o/ b
nRetCode = 1;
" w5 @$ o- v* j$ V ] }, Q% R: l, ~2 G; n$ s( J. ?8 U
else
# Z& m( U* }2 F/ N8 R {. Y4 p# O. f* U+ S! K
// TODO: code your application's behavior here. 5 C1 _$ k1 O& r
//把部件载入内存
/ b& t* i; T/ A3 o UF_PART_open_quiet((char *)(LPCTSTR) partName, 8 G" g2 A0 n, J) J6 @( o: L
&partTag, ! a* k8 @; s/ v5 B* ?( H9 q1 _
&error_status); & h2 b: U- ^6 E8 ]9 p% s$ K& x
. E! S1 y8 y4 h: t- }8 ?+ K
//得到对象标识
4 U3 {6 ~( [# V+ v# d8 |5 a7 Q int number_of_exps=0;; w. z6 r5 ~5 v" {& `% }) t
int i;
4 _9 R# T) C v! M char *size[3];$ ]+ w& V, P) e# p/ h
UF_OBJ_cycle_objs_in_part( partTag, UF_feature_type, &obj1 ); * {* Q3 Z4 J c- z% [% ~& k' G
UF_CALL(UF_MODL_ask_block_parms(obj1,1,size));
" v6 {8 ]! |" j1 O for(i=0;i<3;i++)
1 `. y- O( e1 n; P7 p7 ^$ |5 F {. G& A) \8 t, V7 p8 C7 B1 V2 q+ ]
printf("%s\n",size);
& V4 e3 x4 F+ V" L+ d0 }: ?0 M }
, s: m5 z1 n2 D0 O1 ^* i$ c$ \' I3 T+ j7 R2 n1 W
" Y, X+ k9 a. N* }
UF_terminate();& R$ f& }9 J5 A; u5 G4 A
}/ ~7 g" ?4 p: i P h
% D, C5 D1 F4 V7 s3 r return nRetCode;$ h# |' O. {# C4 o/ H6 l# p
}% J9 b& d/ ?% ~3 S K2 L
, x0 p1 j8 u7 v7 l. ^6 v5 t ~& g$ {: I2 E0 T% k
