查看: 921|回复: 3
[疑难] 连续两次用UF_OBJ_cycle_objs_in_part出错
发表于 2015-5-7 19:41 | 显示全部楼层 |阅读模式
本帖最后由 西尔贝 于 2015-5-7 19:43 编辑   \' T: j1 u3 n0 T
5 I/ R& [" @2 w
为什么程序中红线句子连续用两次UF_OBJ_cycle_objs_in_part();后只能得到上面那个partName的partTAg而不能得到下面那个UF_OBJ_cycle_objs_in_part()的partName1的partTAg?????????,是不是不能两者用两次其中a.prt和a1.prt是两个长方体只是尺寸不一样7 i3 C+ q4 E4 f2 |, `. h  M9 y
#include "afx.h"
5 i5 f% V9 ~: }; Z/ w9 w& T" S" N#include <iostream>' A; o$ v8 N) W6 k, z$ ?! Y' S
#include <uf.h>0 F3 W7 i6 ?  n  |
#include "uf_part.h"! q% u% @" {, R$ X
#include <uf_attr.h>
, x# F7 e" o6 {2 E#include <uf_ui.h>' a; U# e7 ~' D9 z; b9 P1 \7 m9 O
#include <uf_obj.h>7 v! J& p& a+ i* c) G0 T
#include "uf_modl.h"! m) M; ^) z$ d  [  z
#include "uf_weight.h"7 S, G" I- \, R1 \: k. G" H, L
#include "uf_modl_types.h "
7 m& i0 ?( Y! k& s7 Q
: f& }1 W+ N+ f- M; ^- K' F6 Yusing namespace std;
( d! m$ a6 C4 ]2 _4 u- e$ J' u. U; S! l5 a4 C! t" m9 ?
#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
: z% M. M; r) r9 d& ^" v( Y+ [& A' m5 ^. L2 `, ?7 o! p% u
static int report( char *file, int line, char *call, int irc)
  \+ ], a+ t% S: T+ {{" R, |5 n6 I" }' V* l3 Z7 h
    if (irc)
  J+ w# l2 ]8 B. u8 @9 V% r    {5 e# |! G" f7 T+ R& A
        char    messg[133];
6 [6 L# U% ^# i2 C% M        printf("%s, line %d:  %s\n", file, line, call);
$ ^; n' r- e( Q7 P        (UF_get_fail_message(irc, messg)) ?9 }( ~& _1 }" }) U; z
            printf("    returned a %d\n", irc) :/ L  c1 A4 k" f3 J
                printf("    returned error %d:  %s\n", irc, messg);
$ C# J. J9 j6 @, s0 b! Z0 B4 v# ?! u    }
! I- ?0 s! `* ]7 L* _1 f& B    return(irc);& Z! C0 H2 c+ `' e2 A
}" c9 v. A/ Z; q
8 s/ g: L8 r# U! b, Xint main()* _0 R, ?+ P  v3 h
6 t0 O, x5 \* X& U; R; E, g        int                    nRetCode = 0;; r- @3 r8 F$ ~& ?6 S7 }. v
        int                    rcode;5 w; O# {' `/ V
    CString                partName = "e:\\a.prt";  //此处为创建block的全路径名    CString                partName = "e:\\a1.prt";  //此处为创建block的全路径名1 e% j: C0 Q, u+ ]$ P& ^9 R
        tag_t                  partTag = NULL_TAG;
; D4 q" ^" W. m, J' P. |; J        tag_t                  attrTag = NULL_TAG;2 n* a  a' l+ Z$ m6 L- c8 E0 |
        tag_t                  obj1 = NULL_TAG;0 ]3 y  W7 t3 @0 I: T
        tag_t                  obj2 = NULL_TAG;
1 M- X: `* D' `1 w3 m: m        UF_PART_load_status_t  error_status;
5 @* A0 a  V8 ^6 ~9 |6 a' Y* X
8 d) y+ X, a" ^+ M  _        // initialize ug and print and error on failure
' F. ?# |0 r6 I# W        rcode = UF_initialize();
( ]7 W' X! Y. F1 _6 v5 s: v! C5 H8 s  A% R+ r
        if ( rcode )
: _: ~0 {3 d% y) J$ \2 l        {" W% ^+ G8 k) Z% o5 b* c
                // TODO: change error code to suit your needs8 R; Q1 Z9 t4 |+ Z2 p) c' M
                cerr << _T("Fatal Error: UG initialization failed") << endl;
# T% m) G% y0 E" r/ a$ n/ R                nRetCode = 1;8 a9 G9 X3 E7 ]  u' T
- V' k2 I% [" u2 z" _+ e        else; |- i8 A9 o4 A' r% G. S% u, H
. [# l: Z6 {" s' V% e                // TODO: code your application's behavior here. ; w0 g2 Z2 v6 t- f% A' N
        //把部件载入内存
7 z5 ^4 h* n# F1 a2 Z' y$ y& g                UF_PART_open_quiet((char *)(LPCTSTR)  partName,
# I9 t  P- |( ~: I0 ]- ]. p                                             &partTag, 8 M. e" S; O) q' ~
                                             &error_status);  9 v) G! w; `# i5 E' ^5 R
                UF_PART_open_quiet((char *)(LPCTSTR)  partName1, ( \( X. Y; i, v9 V) B, r
                                             &partTag,
% M; [4 ~- h3 b7 u8 t: i; p' [                                             &error_status);
8 v3 f8 E2 W( J# h! s3 d# r
/ {  ]$ g5 z/ }# z7 ?
- p6 u/ _+ x! ^* t
' [4 A8 z, c. g+ Q( m    UF_terminate();: i3 Z% L+ h: J* N/ k5 U( Y
" l7 e- r0 \$ y+ T( r- q2 O) d
  l, F* \( ?* o( c7 `7 ]1 n/ |4 b8 `        return nRetCode;' ?1 n! `, y$ j% R1 y5 h& D. r9 w1 X) d
1 W( c& t, A# E; w2 b* s% o: X
4 C( ^: \/ T0 ~8 \% h  V
! M$ i* u7 K# z
发表于 2015-5-7 19:44 | 显示全部楼层
没看明白你问的
 楼主| 发表于 2015-5-7 20:02 | 显示全部楼层
victor_tech 发表于 2015-5-7 19:44
8 ]# ^- `) s, O# N  a8 N没看明白你问的
) G) d2 {' z6 H2 N# o% g就是,红线两个UF_OBJ_cycle_objs_in_part();只不过输入参数一个是partName一个是partName1,,,分别存在E盘下a和a1的两个文件,这两句话不就是获得他们的标识符吗,,程序运行完上面那个也就是文件a的部件表示符是正确的,线面那个获得a1的部件标识符是错的,,如果把这两句调一下顺序的话a1的部件标识符就对了,,部件a的部件表示符就不对了,,所以我想问问,是不是就是不能连续用UF_OBJ_cycle_objs_in_part()????
发表于 2015-5-7 20:10 | 显示全部楼层
第一 红色字体的是UF_PART_open_quiet
5 T, x  h% r  s我没有测试过,但是应该可以连续用两次的
GMT+8, 2025-6-28 05:31 , Processed in 0.114615 second(s), 20 queries .
