[size=1em]机械图纸英语翻译
8 M0 }* v8 f+ d3 V3 \- U9 D& oALL WELDS CONTINUOUS UNLESS OTHERWISE STATED5 j3 E2 |" x: ^6 f7 Y# R3 I3 u: [
未注焊缝均为连续焊
* f3 C1 Z, T2 C0 h, {* o+ K5 L! |' N7 ^. Y1 P1 V2 k
% y+ {. U3 U1 r! `" f8 p9 r
; J! O" ]% @1 \! l! lALL WELDS 3mm FILLET UNLESS OTHERWISE STATED
, p, x) w [- [1 N- P4 D未注焊角高3mm.- d$ }; G* }* P
& m; m# J Q$ \8 x0 C! b
: ?/ A! Q" O$ T) @ALL UNSPECIFIED RADI - R3. ^ [$ M+ i" P. N& S' `
未注圆角R3+ ^. `" r J! d- Y
/ D. j4 Y6 e: m4 G# Q5 V- f* r5 c
( g0 X: V- X' K2 }7 TREMOVE ALL BURRS AND SHARP EDGES
- X# J! R+ I8 U6 n! N4 K& X棱角倒钝
8 h% j4 Z k- k# Z* c7 B
$ Q. G5 `0 c$ i) Z
. ~% d% Z$ m6 |+ G$ [" BCHANNEL 槽钢
8 r& {( m1 f" N Q& ^: M8 x: M, S( |1 y9 S. i0 G# t3 t. B
. y _3 x5 i' a {/ @
RSA 708 角钢 70X70X8* t* P4 P* m" ^2 X" b
m7 I. I0 b) t+ |8 L% e5 N$ Z/ T3 Q7 j( i% {
M30X1.5 pitch M30X1.5的锥螺纹; N: O9 N6 o3 h* w1 K
# a5 L( V V( u. A6 Z7 D) r* f- N( j; f P; G! T* h
Tackweld 点焊
+ U: [9 A5 u" t1 A$ L2 _* X0 r' Z5 i5 e
4 i, g' K* @4 l+ g
OD 1/4" outside dimension 1/4"的缩写 外径直1/4"8 j$ @) u8 c3 G' ~ K; N6 @/ Z& A
) k: D. h7 o6 s
3 }8 _( Z8 j' _$ A& o6 Y
75 CRS 尺寸为75 材质为冷轧钢板
+ D# l1 v/ w! b3 f' r1 ]5 M, o1 d( z7 B1 h3 z
0 M, A$ @% [ N) z. A4 a& W+ i
410 OPENING REF 410 开口参考尺寸4 ^! d% `* |3 m+ h
- L- v1 B; S6 N! U" P! c
) `" [6 D; s7 V2 K x; I40 REF 尺寸为40,参考值
' P p! }, ]: f* M: P) U, c+ h9 Q' F7 Y+ j" u/ [4 r6 x
5 p) y) {3 x, V% I( h* t
2.5" BSP 2.5” 圆锥管螺纹3 s9 B' Y4 p3 F# L7 j! S) `/ S
0 G; A @' b$ f: s/ J
O u" @& G0 w; `. K6 Z8 _2 ?
2.5" BSPT HEXAGON 2.5” 六角圆锥管螺纹(即对丝)4 d. X6 ^) R7 Q6 X6 d; C
5 \$ V- }7 n! g
( x& V$ q2 v; t30x2.5 FLAT BAR 30X2.5 扁钢 5 C( ^' L' f# o1 v B5 m* `
1 l* O, Y& m: u$ x; ]" O' R' G
c' k" W7 a+ p9 F- g- HTYP 2 POSNS 2处 ' J0 Y9 W+ x0 Z! Z8 K
. u* y% v4 D7 {) d9 N, @4 i# R% A0 J) B& a* ? ]/ v8 j
11 TOTAL COILS APROX.9 WORKING COILS APROX.RIGHT HAND WOUND ONLY,END COILS SQUARE TO TOUCH.
. s9 i4 I- J7 c/ j* g! _总圈数约11圈;工作圈数约9圈;右旋;弹簧的端部磨平以便于接触.(此为弹簧技术说明) + X( O1 F* J6 I2 g
, y* {+ U% z, |9 c! X& c# t
8 f, e1 o) ?0 H0 T2 v& l
FEMALE: 内扣(母扣)
! L3 P. N: h9 ]& o8 `
- X) U/ d4 x9 T9 ]: b) t8 L E6 T* }
MALE: 外扣(公扣)
! ^" G+ v# T0 V4 I3 o3 ~: L* U2 D0 v( F& }0 e1 u+ u+ N0 {/ K; p
S3 s. e- ?6 Y! n9 \7 V- `0 ?
偏心轴 eccentric shaft ) K/ p2 y( y7 x7 S( ?
4 \0 p( u! v. U N- u1 m
3 ~& p- f* M7 q0 r6 Q' u' B销轴 PIN + T9 I2 n- ^& _; N* T1 n, m
7 S" V, u$ x8 G2 M3 p5 G( o2 W4 u4 P# }
开口销 COTTER PIN & T- x9 t! w! p( B [
( Z8 t3 G A s! j& P$ t6 }0 ?' ]' e6 y* v5 B+ E% Y
螺杆 screw 7 W& \4 \% r* f& Q/ ^( z- l" \: n
) _: B: T- `5 u+ c5 E4 f4 f0 D, S9 K+ k, c6 c$ v) q M; \+ N. n3 }
紧定螺钉 SET SCREW
6 m. U I8 h: G9 R, A A. R: X: R* a1 B2 y
5 E2 I% p* N( V# d/ w
圆螺母 ROUND NUT ( |" a3 w+ q; m, i: u/ d0 c+ b$ e" k
7 x+ L& h: ~: M0 C- Z9 p
3 o6 `# M" y- Q$ E% ~. m内六角螺钉 SOCKET HEAD CAP SCREW
1 W1 a* @% L* g! f2 l! a. [/ N& N7 n" m% y+ C% ?* F
$ |/ j3 f( k/ R* u: w& O8 @; I六角螺钉 HEX HD SETSCREW
$ w5 X8 x$ |) y N" `
! G$ E8 j* t5 M% x, ^' |1 y5 J% N' k2 ?, K1 ^( V; W7 ?) U
六角螺栓 HEX HD BOLT 1 A* |% I" d; S+ e+ q$ g( U( g
* B3 [" o' m% _$ r3 L$ g, { L挡圈 closing ring
& r) r! L/ e2 f弹性挡圈 circlip
* i: O* k, b; G O Z+ L- X# f轴承隔套 distance sleeve of axletree z, c) J3 V2 _& }/ K# D" z: n# Y$ H: W
轴承 axletree . U- n) h. m% g/ E
深沟球轴承 DEEP GROOVE BALL BEARING
p& X" p9 |7 I H6 m! K无扣长 non-buckle longth
1 G) F$ n6 ^1 H' N8 Q( H& u弹簧 SPRING
, k% r6 e+ a. X# B吊环螺钉 LIFTING EYE BOLT
# ~( l+ r) Y8 e) y3 E; `$ B5 X# l+ p开槽盘头螺钉 SLOTTED PAN HEAD SCREW
9 U6 w2 [" h. r! C6 V圆锥滚子轴承 TAPERED ROLLER BEARING
" K- p( d$ V, ?, J4 T) D U) {/ F推力球轴承THRUST BALL BEARING
, f5 v7 Q6 O/ X7 k9 G3 n平键 FLAT KEY
1 @# w% U5 V: C0 v' o/ h弹簧垫圈 SINGLE COIL SPRING WASHER
: ?4 X. x$ O: p. Z& K) V4 v7 v9 e平垫圈 FLAT WASHER ! w9 I' [& u& V# c) l6 E2 ?9 B
螺母 FULL NYLOCK NUT
1 _* }2 N6 x9 B9 D# V7 P# r圆螺母 ROUND NUT
8 W' J2 ~9 M# [% Y( h _REMOVE ALL BURRS AND SHARP EDGES 所有尖角/棱角倒角并去毛刺 & w( P6 i% i( t4 S
40 REF 为测量的参考尺寸
, r: `# z6 x1 ?3 ]3 Y6 WOD 1/4’ outside dimension 1/4"的缩写 外径直1/4’------->应该为:外径值1/4"
4 I6 |" P A: b! i$ ^$ A75 CRS 尺75 材质为冷轧钢板 ------->应该为:尺寸75 材质为冷轧钢板 $ M: p" P# c$ t& w8 A) R3 u8 x% c
% `$ j+ ^3 _9 H4 [$ _& i, n; g! y: ?0 r0 U p
ACCESS Accessory 附件
% [# I$ o" X u O/ pADJ Adjustable,Adjust 调整
7 U- x8 X/ z: A# b$ c: HADPT Adapter 使适应
. |% ]( E7 I/ c$ eADV Advance 提前 ) Q# }+ b5 a; t( l7 n/ n
AL Aluminum 铝
& b* z3 u9 e; B/ lALLOW Allowance 允许 : K5 s, y8 Q7 {# E. m+ g
LT Alternate 改变( D" Q1 |* H) a0 |$ C! H9 M
- m! C4 r" _1 S4 _( R9 [/ S1 G {) n( ~, O9 G, O) s" Q G/ o
ALY Alloy 合金
J! h7 f) @/ \, h. X" eAMT Amout 数量 . u0 c f( }, z$ a5 Q9 ~
ANL Anneal 锻炼 1 m2 u, c- D" O
ANSL Amer Natl Stds Institute1 |+ n( A" y3 M7 B( k2 N3 I
APPROX Approximate 大约 ASME Amer Society of Mech Engrs 7 o$ D8 E4 b# {6 S* q' C4 \- ~1 G/ J* u
ASSEM Assemble 装配
4 s: n& T( |6 P8 \; R8 AASSY Assembly 装配
" z2 `- S. S& x$ \3 uAUTH Authorized 授权的" x8 @0 M$ q- z; s2 T3 a
AUTO Automatic 自动的
3 V, L4 q1 H& {9 C1 l* Z: h/ b: lAUX Auxiliary 辅助的 7 u% g4 j3 C4 [! L
AVG Average 平均 ! q# ]" W9 L% E8 z2 \: J
AWG American Wire Gauge / A F% V. E" b* L
BC Bolt Circle 螺栓圆周: `; `9 t. c3 T+ C# x4 c
BET Between 之间
+ @/ v Y5 }- A7 _, }# T' OBEV Bevel 斜角 4 r; a8 c: _* ^9 s
BHN Brinell Hardness Number 布氏硬度值
( X: x$ ], i" N- MBLK Blank ,Block 空白
' a. M0 n; n3 ], H# n4 zB/NM Bill of Material 材料费 . E+ x* o$ @3 j! b$ i2 |* W
BOT Bottom 底部 5 {: ]- R- E& |. U) o$ k
BP or B/P Blueprint 蓝图
5 L, O7 f- B+ J$ l" kBRG Bearing 轴承 . _% a8 {% r! T2 T
BRK Break 破裂3 `% U" z3 F- j% b' l( B$ o; G/ E
BRKT Bracket 支架
8 v* S' u' {; \* IBRO Broach 钻孔
e2 Y# `4 Z" U) }2 y; S" iBRS Brass 黄铜
, V& m K ^0 t' l1 \$ e7 vBRZ Bronze 青铜
! n' ~1 q5 }! I( a/ OB&S Brown&Shape 棕色&形状 ! g0 Q0 y, z" ~4 L3 W
BSC Basic 基本的. A+ e) p; i' y
8 G) b: S( m( D- _; l' }
& B0 ]" M3 m {2 ]/ I% \8 a* s
6 W/ e6 G+ I9 W! H
1 J E t6 Z5 mBUSH Bushing 套管
. P# j$ \, r1 a/ m9 \BWG Birmingham Wire GaUGe
- I/ E5 O8 I3 S' ZC TO C Center-to-Center 中心到中心
* ^5 F) Q' E6 T$ N) n% ^CAD Computer-Aided Drafting 电脑辅助设计
; A& ~2 z: V" ?% ~CAM Computer-Aided Mfg 7 `9 F( Y' w" l. V& }( X( O1 m: S
CAP Capacity 容量 " r: c* l) l, S/ d8 m
CAP SCR Cap Screw 螺帽# {, x. t( H( v: |0 [5 a- Z/ Z
CARB Carburize 使渗碳 2 }5 T) {4 [- I
CBORE Counterbore 扩孔/ U0 r; V' m) w
CCW Counter Clockwise 逆时针
O2 N ]# u j W# p% z& k; OCDRILL Counerdrill CDS Cold-Drawn Steel6 |3 ]* r6 O ~, ]
$ z7 I- _ Q. A; |& @
; U9 `0 @& R( H- d! i8 ]
* _8 v' v6 v4 l! j- c: i7 K0 w5 ~! l5 y* F- E
7 g9 l" Q4 v9 E) G[size=1em]看英文图纸的一些资料 & _3 T4 c+ Z1 O' z; i
# p! F; Z! L, Q/ G7 \3 s c. j5 I1 M5 ~
0 G* G* N9 S+ _
9 w8 b9 `1 @( W3 A) U
[size=1em]1标题栏 6 T8 `3 V5 E# `8 L7 H9 h0 D* \# {
/ _/ ]$ u' U7 d- k |& r% d% ]英文工程图纸的右下边是标题栏(相当于我们的标题栏和部分技术要求),其中有图纸名称(TILE)设计者(DRAWN)审查者(CHECKED)材料(MATERIAL)日期(DATE)比例(SCALE)热处理(HEAT TREATMENT)和其它一些要求,如:
: X" }9 o6 M: I& c) G& v$ g. E3 N7 E7 R
4 ^6 V) l/ U4 S# e3 m9 H- N1)TOLERANCES UNLESS OTHERWISE SPECIFIAL 未注公差 8 `+ a: f4 n5 S+ r. k
2)DIMS IN mm UNLESS STATED 如不做特殊要求以毫米为单位
0 R b; z9 g5 E& e2 f5 l4 d3)ANGULAR TOLERANCE±1° 角度公差±1°
* w6 R' D" l( R: p2 t4 I" o4)DIMS TOLERANCE±0.1 未注尺寸公差±0.1 % Y- ]# j% R! I6 d
5)SURFACE FINISH 3.2 UNLESS STATED 未注粗糙度3.2
. t# Y" g3 e& z. I, l* P7 @. q2常见尺寸的标注及要求
9 a# q+ m% T% [& |* M2 Y0 ^6 L/ ?4 l9 R! S
1 v; J+ `+ j1 i
* J* O# T/ \! X$ ~& y" D6 [
2.1孔(HOLE)如: , m _) i! H+ f$ u7 Z
(1)毛坯孔:3"DIA+1CORE 芯子 3"0+1;
y6 l( q G8 g. U$ G3 A) \(2)加工孔:1"DIA1";
_9 w1 z! m3 |3 V) P(3)锪孔:锪孔(注C'BORE=COUNTER BORE锪底面孔); 6 Q4 p- U0 h+ h! B- P! F
(4)铰孔:1"/4 DIA REAM铰孔1"/4; 2 |. {) L; K, T0 \2 U# y ?6 W0 h
(5)螺纹孔的标注一般要表示出螺纹的直径,每英寸牙数(螺矩)螺纹种类精度等级钻深攻深,方向等如: 例1.6 HOLES EQUI-SPACED ON 5"DIA (6孔均布在5"圆周上(EQUI-SPACED=EQUALLY SPACED均布) DRILL 1"DIA THRO' 钻1"通孔(THRO'=THROUGH通) C/SINK22×6DEEP 沉孔22×6, r7 `, I2 u& g0 F; i
2 F' N! ?# [* ?& s o$ ~
6 u: i% _3 Y( o* t7 l例2.TAP 7"/8-14 UNF-3B THRO'攻统一标准细牙螺纹,每英寸14牙,精度等级3B级
2 b r5 ~& Z0 C( P' a' \% ]2 i(注UNF=UNIFIED FINE THREAD美国标准细牙螺纹)
: E3 K" Q0 F2 C6 Y7 k- q1"DRILL 1"/4-20 UNC-3 THD7"/8 DEEP 4HOLES NOT BREAK THRO 钻1"孔,攻1"/4美国粗牙螺纹,每英寸20牙,攻深7"/8,4孔不准钻通(UNC=UCIFIED COARSE THREAD 美国标准粗牙螺纹) * J- E7 }( A- j3 p6 ~- t. h
. D/ _1 l: C. \9 r
/ p3 q3 K k+ H- \9 P1"-14NS-2THRO 攻美国固定特种螺纹M1",每英寸牙数14,精度等级为二级 (注NS=NATIONAL SPECIAL THREAD:美国固定特种标准)
/ i; y5 @$ r) [- K: f6 b: [* Q4 u/ R% \
* |5 q' \. S5 c
2.2倒角(CHAMFER) 6 N: T# [. o+ y+ f2 c+ ]% q% p
例1/8×45°BEV 倒角1/8×45°(注BEV=BEVEI,斜面)
& S' M: B Z# N( C( T4 [2 Q
+ \$ D+ S; R% A i; m2 _4 K% a1.5×45°CHAM 倒角1.5×45°(注CHAM=CHAMFER倒角)
0 R. L1 P# R/ v! m. X5 k
% t* J9 F$ m3 V" O5 V2.3方(SQUARE)
. n* p8 F2 {) ^1 ]% p# v例5"SQUARE5"×5"方& }! }! v( F( c
# ?( i2 ?4 W9 v7 p0 ?# `
/ \( ^) O, B* Y4 ?# k0 q2.4剖视(SECTION)( O# b! Y6 W8 |
例SECTION A-AA-A剖面5 M: S! K) ^2 h( H$ k c7 d
" ~, o- W' a- v) @3 w( s6 ]* P- g2.5圆角半径 3 R5 l0 P6 H# u; M' e
例1"RR1"
8 z( [+ f" Z2 S8 j' ORADIUS MUST BE SMOOTH AND BLEND INTO FACE
- r- X+ x" f3 y& E* `. n$ n# R圆弧必须光滑且与平面相切5 R; L8 L0 o" W! f( ~
% r& |5 R# D* j7 `; K
- b; u' f3 X& d. W6 v7 R' o$ b* y4 T
2.6加工余量
, G# I9 g' o N1 {- F例DOTTED LINES INDICATED MAX FINISH 1"/8,虚线表示最大加工余量1"/8
8 w3 N9 O5 I; U+ q! I5 V7 D+ x' ^) Q: |
+ [9 D- O: l# A
' H+ i) j: J; B9 e# n0 Y( |9 Z4 [2.7零件标记例
$ R3 m% @. }& B& l4 N5 a: YUSE 5"/16 RAISED HAIRLINE LET-TERS MARKING ON ONE SIDE OF BODY用突起高为5"/16的细实线字母在本体一侧打标记 & T. _# R6 K0 p& |
4 R1 t: L2 Y8 ~& D E% H3 I8 a
0 X# v6 }: i F2 P
1 M) l) r. |+ u! E* I3关于铸锻件的技术要求- s, b1 ?3 z' D% X7 i& R
3 A& N$ `/ l# l5 k2 P p! v) K
, i1 x4 Z+ m+ W1 L7 w例1.FORGING MUST BE ANNEALED TO BE BELOW 203 BRINELL HARDNESS 锻件必须退火处理,布氏硬度<203 ; S0 ^# a8 v& c1 ^0 L+ s: C. S" D
2 R9 p2 S. c: L' N6 F1 I! _) T- m' e+ P: m G. q% B
" v' q5 @! Z) q5 I
例2.NORMALIZE TO 163-207BHNMUST BE FREE OF SCALE & RUST锻件正火处理,布氏硬度163-207,锻件表面不得有氧化皮和锈蚀
" u: X/ g) S$ g+ M
. H8 e# c; \4 {, r% O5 h9 P* z" a7 T8 ~% G2 n+ U
例3.FORGING TO BE SHOT OR SAND BLASTED锻件需经喷丸或喷砂处理 ! m& [4 e1 f' {7 Y- R1 L
2 w- L( n6 B& k; `$ o. f4 |
. a3 r" w5 x6 _: F9 a例4.UNLESS OTHERWISE SPECIFIED DRAFT ANGLES 7°未注明锻造拔模斜度7°9 u" L% e' M; J ? N% c
- F2 }: i. K- Q. \4 L
% c$ a" X+ m" t0 d9 Q8 ^, p, d例5.CAST TO BE FREE OF EXCESSIVE FLASH 铸件不得有过多的毛边 / g7 E& {, z8 u7 G6 o! H9 j) U
, p, z! ?0 M6 J
' l1 w7 B7 l, ]4 H6 B
例6.DRAFT ANGLE 2° UNLESS OTHER-WISE SPECIFIED 未注明铸造拔模斜度2° # @& z2 x" ~. g8 |/ ?
( U6 y3 i* Z- L5 P2 f
* h. I9 K$ S: A7 D8 t% |总之,看英文机械工程图纸并不是高不可攀,只要坚持常看,熟记部分单词即可。
$ n+ y' y% _8 `" A3 W |
