英文字面的意思是这样的!
( ^0 R: R, z( T4 r% h6 b" c4 @/ U$ S6 W
If the pre-loaded tool option is used within NX CAM, this is the pocket number where the tool is located.
0 b; I9 D1 c' y# s+ ]' k0 M" I: J& ~5 p2 e) |& C' W/ Y, s2 ^" d- N* n
* g: C! e4 u2 Y# e2 g9 Q
中文解释6 ~8 O7 }" Q1 E k
( e& Z( i( X$ ?+ E6 A! U1 {
调试模式开启时,生成一个附加文件 <unique_name>_debug.out,其中包含生成的所有事件的日志和这些事件设置的所有 mom T6 C4 y& k2 j% m! q* \
变量。下例是该文件的一部分,显示了为刀具头事件设置的变量。. B7 M+ ]2 [4 n- x' |5 f: _
Event 8: MOM_TOOL_HDR
# A; c0 ^) v; f; A: {+ s/ OVar: mom_event_error =
. \, w, d) V7 X, H( w$ B" s3 P/ tVar: mom_attr_TOOL_MARKTOOL = 11111
* G. J& i. ^4 y8 BVar: mom_libref = ugti0202_019/ {2 H) I5 ^1 e1 q* E! d
Var: mom_member_count = 1
$ N f1 v( c; T6 [( e/ r0 [/ xVar: mom_template_type = Library; ] E' }- {9 o" D s, m- K
Var: mom_template_subtype = Insert Cutter 2"( ?/ o7 F* ?' [, U
Var: mom_pocket_id =4 q) X+ R+ ~2 ?" J* l$ X* s
Var: mom_driven_flag = 09 v7 E, g, W" Q) b t* T \: S3 v
Var: mom_rotatable_flag = 0; m6 I/ j. v; R" K y& O
Var: mom_tool_query = z {& R* V1 T9 i# ~4 M5 l
Var: mom_tool_holding_system = 3304 @& _0 B% e4 ^; V; ]8 Y8 K
Var: mom_preloaded_flag = 0
2 t( [ _* E: y$ S- t: }2 f' KVar: mom_mounting_angle = 0.00000000000000000
5 U, k& M) h% H- [5 \4 v3 Z- X0 A( YVar: mom_partfile_name = ugti0202_019.prt- x5 B; @ K0 k8 d b
Var: mom_tool_material_description = Carbide, Uncoated (Indexable) |
