本帖最后由 bee 于 2015-12-15 12:47 编辑 : q% F3 z. B& n
% |! r* g# d2 ?/ |6 p! @) h
可分别设定两个或其中一个齿轮“齿数”而自动改变的斜齿轮组
' [0 A5 Q+ L6 ^; O4 f3 G- W& @
1 U4 F2 P7 j7 s* L; B但画出来的样子跟“外挂”出来的差了3C左右,不知道是否能用!!
- D) I$ v8 `& W; R 有实体图ug/NX10.0格式,想要的会员可留言QQ号& B& r, M5 r7 K/ d) n
- Y2 G' J6 m+ Z' v
UG表达式:. U3 ` X! t4 U
[degrees]Alpha="Helical_Gear"::Alpha
4 a. b P- G9 h2 F5 s2 H% ^Beta=p107( w* R$ X" r6 X" M/ S- D
H=p111# _% L" y9 b8 {8 o i5 y( b# u7 T
[mm]Hole=if(df<20)(Hole_c)else(ceiling(ceiling(df/10)*10/3))
9 w- n7 l' ^- ~' t[mm]Hole_c=ceiling(ceiling(df)/2)+ V. @! K7 u. d2 T; {
[degrees]a=180/z" P2 S1 c8 W, W& z% m. }
[degrees]a1=-(a+2*bk)- X0 Q9 `1 j8 F0 K" R) @
[degrees]ak=Alpha
: q- g) |5 U' n& Fak1=arccos(db/da)
7 `) P% g, z0 i6 I* x8 c[degrees]ak2=deg(ak1)
- H* `4 @% G1 }/ j$ u! O, }[degrees]bk=deg(tan(ak)-Radians(ak)) p" a) f; _( [4 ~
bk1=tan(ak1)-ak1/ J$ C3 _/ L2 m7 ?/ I
[degrees]bk2=deg(bk1)
8 K* T" h' O1 D4 \4 t6 N5 Q1 j[mm]c=0.25+ v- r* u: R/ G3 E7 J
[mm]d=(m/cos(Beta))*z
! k \- d5 U2 l+ {& V) ~5 A+ v3 W[mm]da=d+2*ha*m3 D+ l2 z: n6 ^# P; c
[mm]db=d*cos(ak)- Y% c1 q6 a8 p; Q1 B! y$ P
[mm]df=d-2*m*(ha+c)
% P6 v3 }0 ~: z6 kft_2=-t*((tan(Beta)*H*360)/(d*pi()))/ E' U. q9 y h v% P0 p* n
[mm]ha=1
9 b# K& I9 A: F0 n O! |# c: U6 q; bm=1
: p; p8 y7 v$ @8 R( e2 tn=36 T" ?$ Q. F7 i6 A/ y& J7 V
nm="Helical_Gear"::nm
. M6 f/ l- H4 e4 J9 K5 cp7=2
: j5 t% r. ?# j/ [$ o[degrees]p8=a1
- i8 q2 h8 T4 Y; K( }- L1 M[mm]p9=10
; S* U4 s$ X9 X2 E5 f7 a[degrees]p10=-21.415833167365
0 p! w. q% I9 E[mm]ra=da/2
# g2 V s- ? J# H+ n[mm]rb=db/2
% m2 Z4 T! _0 O2 P: ?( dt=12 ~6 Q# V0 N2 H
u=ak2+bk27 Y4 Q, Q8 e% \' M& |% d
u1=Radians(u)
8 E1 a' Y' a% Q[mm]x1t=-(rb*sin(u*t)-rb*u1*t*cos(u*t))
) ]. B) |4 y+ d[mm]xt=rb*sin(u*t)-rb*u1*t*cos(u*t)
0 E' a/ p1 U0 Y[mm]yt=rb*cos(u*t)+rb*u1*t*sin(u*t)
9 P0 b% }! s9 B+ M% `, jz=z1& C- k% O$ |* I% _0 M+ b. h* I8 y
z1="Helical_Gear"::z1
1 ` w6 S( ~6 { Z[mm]zt=0- Z+ F w4 w4 z5 }
p11=2
2 [; W( b2 y! K5 K% Q[mm]p12=10
; P7 u) x7 t. Z) b; r1 M4 Y7 Y[mm]p13=10. O4 M7 |4 f- z. n
[degrees]p14=0
2 z0 e$ ^0 f, S1 K9 c[mm]p15=d5 F {3 A! V! l3 r
[mm]p16=df# w6 x+ \- n a. u$ L
[mm]p17=H
; R0 X5 I r" l" w" r6 I5 M3 {- e[mm]p18=H
, ^; G; {: D! _% e2 f J1 U5 A1 S1 J[mm]p18_x=0.00000000000
6 ] L0 E% l5 X6 U1 D0 T" J5 R8 a[mm]p19_y=0.00000000000
$ _& p1 K) I: ]% f" ^( W5 t; U[mm]p20_z=0.00000000000
. Q: N1 I7 ]* Y n6 A[mm]p36=da% ]) i# ? \ Y, T
[mm]p37=H' g1 T- z7 o; [% @6 p* w% I
p45=z
/ d7 x! C. O: \[degrees]p46=360/z3 c& f' A3 @* B4 d
[mm]p47=10; l- ~6 b$ I' I: X2 m: I& C& v
[degrees]p48=360
4 \: t# C' s: J% Z. L# cp49=1
5 F; V1 m) u/ m' y* d8 X. w[mm]p50=10
7 S, ^1 u/ E& k' U[mm]p51=0; ^$ f: `1 O5 t1 G. d3 E: ~
[degrees]p52=05 D7 @) [( k }" x3 z+ X
[mm]p56_x=0.00000000000
! v& a, j$ }$ K& c2 d, G$ t[mm]p57_y=0.00000000000
- D! S. F7 w6 c9 u6 P[mm]p58_z=0.00000000000
# ]5 ]# {1 y$ y1 l2 z2 H) ?/ F[mm]p94_x=0.00000000000
8 o: P' l5 @$ Z4 q5 R[mm]p95=Hole
) V/ P: ]! f w0 o3 H; D$ ][mm]p95_y=0.00000000000
0 o7 q/ |& u4 N2 q# b5 |# r# o[mm]p96=H
& k$ t& a; g( y[mm]p96_z=0.00000000000
4 b8 z2 `1 A6 O+ y, v[mm]p104=c: F% h! C4 g; K. @8 l! m( U
p107="Helical_Gear"::Beta
. Q6 O2 Z" O1 Lp111="Helical_Gear"::H/ i! z2 G% L2 w7 e
[mm]p112=ceiling(p113/3)( \0 ^2 z. G* q0 Q: ^3 R3 Y+ m
[mm]p113=ceiling(Hole/4)
4 i6 T1 j' O( ?2 c[mm]p114=0' w3 p. h' @$ D5 D1 E2 s
[mm]p115=H t6 A0 _# p) d( D6 `
% k! o7 {/ [3 g5 y |
