查看: 1865|回复: 1
多轴加工中,Coutour Profile驱动时,Follow Wall 选项在哪里呀?
发表于 2008-11-13 11:51 | 显示全部楼层 |阅读模式
多轴加工中,Coutour Profile驱动时,Follow Wall 选项在哪里呀?% n. J0 h4 t4 p0 A  w
! g& a- ~9 A3 g7 }6 E在文档说明中有这么一句“The Contour Profile Drive Method requires a floor definition as well as wall geometry. If your part doesn't have floor geometry, use either the Follow Wall Bottom or Auxiliary Floor options to position the cutter. ”,但我找不到“Follow Wall ”,请教大家
发表于 2012-5-11 20:40 | 显示全部楼层
就是底面或者辅助底面啊
GMT+8, 2025-8-19 04:21 , Processed in 0.052508 second(s), 23 queries .
