楼主: ugii
青华模具UG10.0视频教程—女式高跟鞋(菜鸟、青春鸟必学)
发表于 2023-3-8 07:11 | 显示全部楼层
Is it safe to use a vibrator while pregnant?
风雨火 发表于 2015-12-31 10:05; V3 C: T* B2 p
很好的资料
1 k' A' Y  \) p4 P1 d0 V3 p
Pregnancy can result in a rocketing sex drive due to hormonal changes, despite the limited ability to have sex. However, is it safe to use a vibrator during pregnancy? The answer is a definite yes, with some conditions.
$ }4 {/ _" _4 f$ x
5 P. m% }+ d/ O5 p$ n; z+ cAs long as sex is safe for you during pregnancy, using a vibrator should also be fine. However, it is important to be careful when using a vibrator as it can feel firmer and less pliant than a natural penis. Avoid deep penetration if the vibrator is particularly hard or long.
! @8 x; k  z9 M( O. ^& Y1 F5 w
0 x5 M  A" e' N. U; z! R/ I! yHygiene is also crucial. Clean the vibrator appropriately both before and after use to minimize any risk of infection. Check out our 7 sex toy cleaning and care tips to ensure your sex toys are always clean and safe to use.
4 ~1 N7 b1 \: D+ ] 8 d- o* E$ @8 I' A% O: v
However, if your doctor has advised you not to have sex, you have a vaginal infection, have been told you could go into labor early, your waters have broken, or you have experienced abnormal vaginal bleeding, it is best to consult with your midwife or doctor before using a vibrator.
( @2 c+ Y0 Y7 o- Q: Q/ I9 f  ?' z8 [ ! n- L1 G) l: }5 {7 j# n
In conclusion, using a vibrator during pregnancy is safe as long as certain precautions are taken. Stay safe and have fun!
GMT+8, 2025-10-13 13:55 , Processed in 0.073614 second(s), 20 queries .
